Oldsmobile Intrigue: Problems & Solutions
I didn't even know there was a TSB until I had to take the car back yesterday (the SES light came back on after two days). The shop manager at the dealership then let it slip that water in the pump was a known problem. He then checked to be sure the new hose/shield combination had been installed.
They reset the light and sent me on my way - only for the light to come back on 24 hours later....
I'm ticked. I guess this is another example of why GM is facing serious troubles - with massive recalls and their debt being now classified as "junk" status.
How do you know when to take it to a shop to take a look at it?
Major water collected on the floor board, passenger side after running the air conditioner for a couple of hours the last few days (I vacuumed up about an inch with my shop vac) I couldn't believe there was so much water! I traced it to condensation dripping from the blower moter under the dash on the passenger side. However, there is nothing there to catch or channel the water away (except for the covering that goes over everything under there) so the water simply drips down and collects on the floorboard.
Has anyone experienced this? Does anyone know of a method to either stop the drips, or deal with them? I was hoping to find maybe a manufacturer or after-market fix with a pan and hose to collect and drain off the condensation.
Any ideas anyone??
As far as oil burning goes (cob), that clean out procedure is fairly common on the Caddys with the Northstar. Apparently you are not driving it hard enough. They require occasional full throttle wind outs to 6500 to keep the rings from sticking.
Margo
bornwild, The outside temp sensor is mounted on a plastic panel behind the radiator. It cost me around $8.00 at the dealers. Takes about 5min to replace and you don't even need any tools. Just unsnap the old one from its mounting hole, unplug it, plug the new one in, and remount it in the hole. It's black and so is the panel so you'll need enough light to see (daytime's best). Buy the sensor first so you'll know what you're looking for. You can get the part # on gm direct parts. Mine was doing the same thing and it fixed the problem. Good luck.
What do you think, any suggestions ?
DAVGRAY
Diagnostic Aids
Inspect for the following conditions:
* Inspect the heated oxygen sensor wiring. The sensor pigtail may be routed incorrectly and contacting the exhaust system.
* Verify that the PCM to engine block grounds are clean, tight, and in the proper locations.
* Test the fuel pressure. The system goes lean if the pressure is too low. The PCM may compensate for some decrease. However, if fuel pressure is too low, a DTC P0171 may be set. Refer to Fuel System Pressure Test. See: Component Tests\Fuel System Pressure Test
* Test the fuel injectors. Refer to Fuel In] Coil Test - ECT Between 10-35 Degrees C or Fuel Inj Coil Test - ECT Outside 10-35 Degrees C. See: Component Tests\Fuel Injector Coil Test\ECT Between 10-35 Degrees C (50-95 Degrees F) See: Component Tests\Fuel Injector Coil Test\ECT Outside 10-35 Degrees C (50-95 Degrees F)
* Inspect for any vacuum leaks. Inspect for the following conditions:
* Any disconnected or damaged vacuum hoses.
* An incorrectly installed or malfunctioning crankcase ventilation valve.
* Any vacuum leaks at the Throttle body, the EGR valve, and the intake manifold mounting surfaces.
* Inspect for exhaust leaks. An exhaust leak may cause outside air to be pulled into the exhaust gas stream past the HO2S, causing the system to appear lean. Inspect for exhaust leaks that may cause a false lean condition to be indicated.
* Disconnect the MAF sensor and note if the lean condition is corrected. If the lean condition is corrected by disconnecting the sensor, replace the MAF sensor.
* Test for fuel contamination. Water, even in small amounts, may be delivered to the fuel injectors. The water may cause a lean exhaust to be indicated. Excessive alcohol in the fuel may also cause this condition. Refer to Alcohol/Contaminants-in-Fuel Diagnosis. See: Fuel Delivery and Air Induction\Fuel\Testing and Inspection
* Inspect for a faulty connection at the PCM. Inspect the harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals and faulty terminal to wire connections.
* Inspect the wiring harness for damage. If the harness appears to be OK, observe the HO2S 1 display on the scan tool while moving connectors and wiring harnesses related to the engine harness. A change in the display indicates the location of the malfunction.
I like the car but it has started to shut down after about 2 mins, even when parked,
starts straight away again and will only repeat when switched off for a while.
Im going to time it and see if it is always the same.
Will check fuel and oxy sensor in exhaust first before delving deeper
Where can I get a workshop manual and an owners manual?
What are the gaps for the spark plugs?
Thanks for a great forum, Im still sifting through all the messages, good advice and interesting to see what goes out on this model and why
It's a shame, because it can cruise at 100MPH at just 3500RPM. It could reach 140 or 150MPH easily.
John
Why go and spend 2,600 before you get the DTC diagnoised?
Good Luck.
how much did the dealer charge you for the socket?
If anyone is having trouble with the turn signals, check the inside of the socket. Mine was burned at the bottom of the socket and didn't allow the bulb to have full contact with the wires. The socket is very easy to change.
This is a great forum for Intrigue owners.
Sounds like you flushed the radiator/engine block yourself? You might want to have the dealer do a power flush because the Intrigue has an aluminum engine and that means transfer of aluminum by the hot water inside the block (creates scales) which interferes with heat dissipation. If you look closely at old coolant (five years old stuff) you will see some aluminum color. I had a power flush at 5 years and plan on doing it again in 2010.
With my 99 GL 3.5L, I have essentially the same symptoms you describe. Plus, ours sometimes dies when accelerating from a stop, also.
I'm afraid I don't have an answer yet, but I certainly will share it if/when I do. For what it's worth, I previously have replaced the sensors that one might suspect, but this time around there are no diagnostic codes set. I have replaced the fuel filter, and it made no difference.
Regarding manuals, I just found this one by Chilton:
http://www.themotorbookstore.com/regal1.html
However, I vaguely remember reading something awhile back about it not covering much on the Intrigue -- especially the 3.5L. Don't really know, though. Probably more useful (although much pricier) is the real deal from Helm: www.helminc.com
A couple years ago I had an online subscription to AllDataDIY, but I found it to be of limited value and let it lapse.
Good luck!
DW
Th good thing with the Intrigue is that the high voltage to each spark plug will burn off all that blow-by.
Hope I've helped Linda
