Oldsmobile Intrigue Accessories & Modifications
in Oldsmobile
I had my windows tinted (:
Just thought I'd get things going here.
Didn't have the Bose and didn't like the stock unit, especially the word Oldsmobile written on it. Not that the sound was bad, it just wasn't impressive. So, I replaced it with a Pioneer DEHP4100 for about $218 installed if I remember correctly. Incredible, even with the stock speakers. Detachable face, tiny remote control, DFS alarm, etc. The audio functions are great with indepth, multi-level tuning to set the sound exactly as you like. No longer have control from the steering wheel but I like the tiny remote better anyway. Very functional in the right hand while driving and controls a bunch of functions. Don't need an amp or different speakers.
Future mods/upgrades: Struts will be in the trash as soon as I get the nerve and motivation to do it, plus, I'd like to do the tires at the same time and I've only got 12K on this car. I wish I could see the bare bones of my drive train, chassis, and suspension system to get a better idea of exactly how different struts would eliminate the harsh ride. So far, the way I see it is this. Buick Regal and Intrigue weigh the same and use identical springs. Regal ride is comfortable, mine is harsh. The only thing I can think of is the difference being in the struts. However, I've been told not to look for ride improvement in the struts, only dampening ability? I want my suspension to absorb the road, not just dampen the trauma after the fact. So... I guess I'm waiting for a little more assurance that a strut replacement will make a difference at least commensurate to the cost.
Also interested in Cat-Back and Strut Tower Braces. Maybe a K&N down the road.
The part number is 33-2063-1. However, I did a search under 2001, Oldsmobile, Aurora to figure it out. But to make sure that it will fit the Intrigue, use another filter maker as a reference. In other words, see if the part number for, say AC Delco, is the same for both the Aurora and Intrigue. If so, you've got a fit. Don't bother searching under Intrigue for the years 1999 thru 2001. You'll come up blank.
Here's the link to do the search: http://www.knfilters.com/appinq.htm .
My 3.8 feels much smoother across the board, but particularly so when in 2nd gear and mashing the gas. Very smooth and linear-- V-8-like. For me, it was a good move.
But the 3.8 has been around a while. If I get another Intrigue (2002 model), I'll put one on. K&N has a good reputation and (speaking only from my personal experience) the performance improvements I've noticed are worth the risk. Plus I look at it from a financial perspective: I'll never have to replace an air filter again
9 inch K&N cone (would recommend 7")Made cold air box out of thin corrurgated plastic and covered it with aluminum heat tape. Whole thing cost $45. Sounds very nice and noticible HP on butt-dyno. A 7" cone (and plenty big)at jegs is only $31.
Check out the Pioneer 4100DEH. Without changing your speakers, the sound is crisp and clean. Of course, upgrading the speakers would be even better. If you do, you'd probably need an amp... the receiver is only 45Watts. But after listening to systems with more power, I've seen that wattage isn't what makes the sound.
Why did I pick it? Truthfully, because oscarz did and I was in the market for one. I picked it up at Circuit City for about $239 (on-sale). Features include:
-3 band eq
-source level adjustment (SLA)
-15 FM station presets
-display name of CD playing
-BSM (Best Station Memory)
-detachable face
-remote control
-alarm built in
-reads CD-R and CD-RW disks
There are so many ways to adjust the sound to perfectly fit your taste that I would have to open the manual to explain. The highs are crisp, the lows deep and NO distortion when cranked up to unnecessary levels.
I don't have the steering wheel controls but it is generally agreed (and assumed) that they will still work since good installers will use a wire harness and thus keep your settings. But remember, it comes with a remote control :-)
I don't own an Intrigue, but I thought I would point this out. Actually, I considered an Intrigue because of the cost, but the Aurora's interior, coupled with that incredible sounding V8 was too strong to resist. My only suggestion would be that the GLS not include the spoiler and chrome wheels. I think the Intrigue looks much cleaner without them. It's a very attractive car.
I hope no one sees this as offensive. My intent is not to belittle the Intrigue. I really think it is a great car. I just thought the Aurora was the Intrigue of the next level.
Prod# Code Service#
22133031 FKN 22133030 Highest Rate
22133030 FKJ 22133030
22133029 FJT 22133030
22133028 FJS 22133028
22133027 FJR 22133028 Lowest Rate
Rear Springs
Prod# Code Service#
10258880 TDJ 10258880 Highest Rate
10258879 TDH 10258879
10276574 TFY 10276574
10276573 TFW 10276573 Lowest Rate
Here is a discussion on the subject
I haven't posted anything in a few months, but I thought I would try to revive this discussion with listing out my mods.
I own a Red (I don't know the official color name, but it was no longer used after 99.) 99 GL 3.5.
You won't believe the amount of searching I've been doing (online) to find mods for the Intrigue. So far, I've only found an SLP front stabilizer bar, a drop-in replacement K&N filter, a Tornado Air unit, and the SLP cat-back exhaust (which was mentioned early in the main discussion).
As for the speculation in this discussion of the K&N drop-in, I've managed to find the part that fits. It toook a small bit of work to find it. I went to ACdelco.com and did a "Vehicle List" search for AC part # A1096C (Intrigue 3.5 air filter). It listed all the vehicles and years that also use that part #. Simply do a K&N search for the replacement filter for any of the other vehicles, and you'll have better luck than searching for an Intrigue. I ended up doing a K&N search for the Olds Aurora '97 and the filter fits fine. It's K&N part # 33-2086. Not 33-2063 as previously thought(I list my method so any naysayers can do it themselves for that visual proof).
As for the Tornado Air unit, I actually noticed an improvement, despite some lack of faith from other posters. I've noticed almost a 2 mph improvement of top speed in first gear. I tested this on a flat street with the shifter in first.
In fact, I installed the K&N after the Tornado and, expecting the combo to knock my socks off, I did not see any real improvement at all with the same test. And I know that K&N's power comes on in the high RPMs.
The SLP cat-back is the crowning achievement so far in my mod-quest. I don't remember the first person to post the existence of the exhaust on the forum (and am too lazy to search for it), but I thank you whole-heartedly for showing me the light. I haven't had a real chance to put this baby to the test with WOT, but I have felt the difference. I first noticed the drop in low-end torque, but soon after, noticed the pick-up in the mid to high RPMs. As a bonus, the engine seems to want to get to the redline quicker than stock. I've also noticed that the acceleration curve is a lot more linear in the low RPMs, but starts to curve upward steeply at around 3200. However, it does lack that noticeable punch.
Oh, and when searching on slponline.com, the exhaust system is listed for the Intrigue with the 3800 V6 and the Buick Regal. Don't let that put you off, the system fits the 3.5 perfectly. The system purrs at idle, from outside, and is noticeable, but not intrusive,inside the cabin. The exhaust note is almost imperceptibly louder from stock and is barely noticeable at speed, other than being lower. However, the more you open the throttle, the more apparent the gruffness of the note.
I haven't dyno-tested the car, but my guess is that, with all mods included, I'm pushing about 230 peak horses and about 237-240 peak lb/ft of torque and with a bit more room under most of the curve.
Upcoming mods will be a custom-fit cold-air intake (no one makes one for the 3.5), 18" wheels, and hopefully an OSV-like custom ground effects. Those Razzi GEs are crappy. This is all when I can afford it, of course. Oh, and I'll put on the front anti-roll bar that I have.
Well, there goes my list. I've probably precluded myself from having any more to say, but I've got it all off my chest.
Traded it on a 02 GL---the 02 is a mess, tires were all changed at my expense.,File was started at Olds the day after the purchase..
Olds made a suspension change to soft mushy calibration, requested new springs and struts or a buyout..
Is it a PC 168?
Thanks in advance,
Javier
http://www.cardomain.com/id/javidogg
Can anyone suggest a place to get such a thing?
Do Google search for "Oldsmobile accessories".
Dirk
Thanks, Mark
Lots of problems with it along the way (still uses at least 2 quarts oil between changes), but what really bothers me is that the performance & pick-up is not great anymore.
Engine has a bit of a knock now/takes forever for it to "take off" when I floor it/shifting is not smooth at all/etc.
That was the only reason I could even tolerate all the problems. This car was/is really fun to drive!
Is it just too old to perform the way it used to? I am thinking the transmission may be ready to "go"...and am trying the Lucas treatment to see if that will smooth it out (not slipping yet, just jumping into gears now).
Should the spark plugs be replaced (recommended I heard at 100K)?
Should I be using high octane gas now(never have)?
Anything else I could do to pep it up?
Thanks for any suggestions.
WWW.ROCKAUTO.COM (COPY AND PAST TO YOUR WEB BROWSER)
i BOUGHT THE TURN SIGNAL BULB HOLDER AND AFTER GREASING THEM UP WITH DIE ELECTRIC GREASE HAVE HAD NO PROBLEMS!! PLUS NOT EVERYONE CARRIES THESE. ONLY DEALER AND VERY FEW CARRY ONLINE. CHECK THEM OUT BEFORE YOU BUY YOUR NEXT PART FOR YOUR TRIGUE!!!!
My next projects will be a powertech dual round tip muffler that i found at http://dynamicautodesign.com/product_info.php?manufacturers_id=7&products_id=406- &osCsid=1ac662e9865f03a76ab690be14746513
i also found a cold air intake for the 3.8 engine at andysautosport (offers manyyyy other autoparts for any car)
and my last project will probably be tinting windows and redoing the interior
please reply to me at jammyburks1@hotmail.com via email
Also does anyone know the approximate length from side of trunk lid to spoiler holes ?? :confuse:
I went to pull-a-part,and and got a spoiler from another Olds Intrigue,and I didn't write down the measurements. :mad:
I dont currently have a spoiler on the trunk lid and am adding one..I dont want to just guesstimate the measurements.
And really dont want to drive back to pull-a-part to measure the holes considering its 25 mins away...
If anyone can help,I'd appreciate it.
