Scruff Mark on Car
My wife backed out of the garage and bumped into my car. Both vehicles have a scuff mark (fuzzy white area) that regular wax will not take off. No dents are present. Does anyone know what I can use to clean off these marks.
However, if there really is no scratching, and it is just a little rub mark on the paint, the paint thinner might just do the trick without any polishing. Be sure to use paint thinner though, and not laquer thinner. A little paint thinner on a rag will do no harm at all to your paint. Say by-by to any wax though. And this might make the finish look slightly different when you are through. Just re-wax.
If the scuff mark is truly on the surface, and not deep into a paint, a clearcoat polishing compound may well do the trick. I have found that the liquid Formula 7 clearcoat polishing compound works very well for removing surface scuffs, and foreign paint matter. It may take three to five applications of applying, waiting to try, and then polishing, before all evidence is removed. Patience is a virtue. Just follow the product directions. Wash and try the affected area, first. Use a mildly damp rag to apply the compound in same general direction of the scuff. Don't be afraid to apply some pressue when rubbing. Wait for it to dry to a haze, and then polish the residue, off (falls off generally like a powder). You will most likely need more than one application. For a stubborn spot, you may try applying the compound crosswise to the scuff.
If that does not work, then using one of the clay-based products that professional auto detailers use will produce a high probability of success. Clay seems to have some interesting properties for removing surface blemishes without harming the finish underneath. There is one product out there called "Clay Away". I have not used it myself, but heard it peforms just about as well as anything a detailer will use.
