Subaru Impreza WRX Wagon
12930323435115
    Some JDM Imprezas have moonroofs in the SoJ web site, so hopefully we'll get that option too.
    -juice
    1) don't know, sorry
    2) noone has complained yet, so it must be okay
    3) you may have to remove the windshield washer coolant reservoir, maybe part of the intake, for easy access to the plugs, but it's not hard
    4) you can use Prestone in the Subie, but not the VW. I would not mix them.
    5) 1000 miles, keep it under 4000rpm if possible, avoid flooring it or stabbing the brakes, basically drive smooth but vary rpms
    -juice
  • narenjinarenji Member Posts: 161
    Thanks for the rec of the Toyo tires. I'm checking prices around the area to see what stores can offer. I'd prefer to get both tires and wheels at the same place if possible, but if not, I'd get the wheels from Revolution Motorsports or maybe even America's Tire Co. (they can special order Subzeros), and if they don't have the best price on the tire I want, I could get them elsewhere, but surely they'd want me to buy there, so maybe they'll work with me on tire price...
    I'm also going to stick with either 215-45-17 or 215-50-17 because that seems to be the suggested size by Subaru and since I have a wagon, I think the smaller size would be better if I get different suspension in the future to avoid rubbing.
  • cinosweivecinosweive Member Posts: 166
    1) $400 seems a bit high for a turbo gauge. Mine was a port installed mounted on the steering column. I think I paid about $100 for it.
    2) Dunno.
    3) I read here some months ago that the spark plugs were neigh impossible to access. The post indicated you have to do it by feel, and there isn't much clearance. I haven't even looked. When I owned by old Rabbit, I did all my own maintenance because it was either that or have a second car on standby all of the time. Now that vehicles are virtually maintenance free I tend to take them to the dealer. Besides, they have all the high-tech diagnostic goodies that I couldn't possibly afford.
    4) Dunno.
    5)The manual says to keep it below 4000 for the first 1000. I believe in a slow breakin. I go reeel easy for the first 1000 - not just below 4000, but I take my time getting there as well. Above 1000 miles I gradually increase my agressiveness. Call me dorky, but I believe a car isn't truly broken in for 5000 mi or so. Even after breakin - just because the Tach goes to 7000, doesn't mean you can make a habit of it and expect a long trouble free vehicle life. Just MHO, FWIW.
    When I first bought the car, I thought it had a pretty notchy shifter. That has all gone away with breakin, and it is now one of the smoothest shifters I have ever owned.
    Enjoy your Roo.
  • gotwrxgotwrx Member Posts: 52
    Congrats.
    Think you did all right on the price. I paid more but I was in a hurry and didn't try super hard.
    Wouldn't sweat the plugs. You don't have to change em until 60K/60mths. By the time you either
    a) sold the car
    b) figured it out
    c) saved up enough to have the dealer do it
    I doubt rain through the scoop is an issue. Got to be quite a bit of water all at once to take out enough heat to cause problems. You probably get more coming up from the road anyway. I just wouldn't spray a hose in there especially when the engine is hot.
  • barresa62barresa62 Member Posts: 1,379
    You made it! Congrats on the WRX purchase too...a wagon, no less!
    I can answer you about the turbo boost gauge. I just bought one from www.subaruparts.com (the Tacoma, WA Subaru dealer) for about $195 as I remember. It's also available on www.subaruWRXparts.com for a bit less. I've looked at the install instructions and it doesn't see to difficult. I've found that visiting the your local i-club chapter in your area at www.i-club.com finds you folks that are willing to help with an install that you may not feel comfortable doing by yourself. Hope this helps and enjoy the WRX! :-)
    Stephen
  • stupendousmanstupendousman Member Posts: 36
    Hey Congrats Nixomose, I'll just comment on if you got a good price, and your taste...
    I believe you've picked the perfect car. Black WRX wagon and got it at the perfect price...
    ...not that I'm biased or anything since I have a black wrx wagon manual for which a paid 22,500.00. So personally, I think you did alright. Enjoy!
    Ken
  • bluesubiebluesubie Member Posts: 3,497
    Congrats nixomooe!
    A little water won't hurt the intercooler.
    In fact, the higher h.p. (and as of right now, only overseas) WRX STi's come with a water spray that sprays directly onto the intercooler. Some folks have added aftermarket sprayers.
    Further to what Stephen said, check out your local i-club chapter. Since you're in White Plains, it would be the Tri-State Area. I'm in NJ and have been to all kinds of meets. Dinner, backroad drives, drag races, off-roading, etc. A lot of fun and a good group of folks.
    -Dennis
  • nixomosenixomose Member Posts: 95
    Thanks for the info. My friend who pointed me here said you were a lively bunch. Guess he was right. Sadly, my drive-beyond-my-capacity days are over (I'm a very old 30 year old) I don't see myself racing or off roading, I just wanted something fast that handles well. My other car is a VW GTI VR6. It does the fast part okay, but it handles worse than my grampa's caddy. So I wanted something to drive while I fix the suspension on the GTI this summer. (what I wouldn't give for a brand new 92 gti, oh well, vw's been really dropping the ball lately.)
    Good deal, Ken. I must say the black helps it a lot, and I haven't seen ANY black wagons other than mine, since I've started keeping an eye open.
    I'll shut up about the intercooler, thanks for the advice. I noticed in the ad book, there was a stock option to replace the clock with a factory 3-gague set (boost, oil pressure and something else) I figured that would be the easiest and most factory-able way to go.
    I looked under the car for the first time yesterday. I notice the exhaust pipe going under the rear axle (I think, it was a quick glance) was the lowest thing on the car. Anybody destroy this yet? I'm paranoid, I worry about stupid stuff.
    cinosweive: I'm with you on the break in stuff. I have a friend who refuses to buy a new car because of the depreciation loss in the first 5 minutes. But the first 1000-5000 miles are the most important, and *I* am going to be the one doing it, not some leaser who doesn't care.
    Definitely look into the I-club. They have regular dinner meets in Northern NJ and some of us aren't spring chickens :) If you want to see some Rexs come out to Giant's Stadium on Sunday. We have an auto-x there! Good fun.
    -mike
    The i-club meets have folks barely old enough to drive, and on up into their 40's and 50's.
    -Dennis
  • artgeckoartgecko Member Posts: 78
    Did you ever get the clear side markers from the eBay guy I recommended? I hadn't seen any more from you or Austin. Sorry if there was a problem for you, as mine went through quickly using paypal, coming in four days.
    What reminded me, was that my Silvervision lamps came today, so I guess I need to finally try to perform open lamp surgery. They threw in a free pair of 5W BlueVision bulbs, too, but I don't know if they are the same size as any of ours. Seems like the'y'd look goofy. Maybe I'll stick them in Deb's A6, since she has those blue HIDs in there already.
    Anyway, hope it worked out alright, because mine is about 2.71 HP more powerful with the clear sidemarkers.
    Steve
    Well, that wasn't too bad. I took the amber lens gel out of my headlamps and put in the SilverVision bulbs. The bulbs do have a little orange tinge to them, but it is not noticable from any distance.
    I used the blow dryer to take the first one apart, and then to put it back together. Didn't seem to really seat too well, so I put it in the oven as recommended. I should have done this to take it apart. I did the entire second lamp in the oven. It pushed together much easier and seemed to seal tighter with the whole lamp heated up.
    One warning for anyone doing this. Don't do the stupid thing I did. I didn't notice until I took the second lamp out of the oven, but somehow I must have bumped both lenses against the top burner. Grrrr! Now I have a couple of scuffed marks on the clear lenses. Not too bad, and it will probably come out with some plastic polish. Stupid mistake, and I did it twice.
    I ended up using the BlueVision bulbs in my headlamp as running lamps. One had burned out already somewhere along the line. Maybe I damaged it when removing or installing. Whatever happened, I replaced both. You don't see the blue at all. They are just noticably whiter than the OEM running lamp bulbs.
    So now I have all white lamps on the front and sides of my black wagon. Looks really nice without any other colors. It is wet (raining off and on here) and dirty now, but I'll post a photo after I get it cleaned up.
    Steve
    Can't wait to see some pics.
    The clear sides came yesterday. I also picked up my OEM rear mudflaps from a fellow i-clubber who does great paint work. He painted them platinum silver for me. I'll try putting them and the clear sides on tomorrow and post pics, weather withstanding.
    I noticed that the Silvervision bulbs don't fit well in the headlight connections as the nubs are not aligned to fit light hole connection. I got mine to go in w/o shaving down any nubs. The lights work fine. I did manage to get some goo residue on one of my headlamp lenses. As far as the clear sides, I need to get some amber bulbs for behind because I'm pretty sure the bulbs now are white behind the amber lenses. I thought about putting silvervisions in but I don't want to wait on another order or pay $23. I don't want to risk any "officials" attention with white bulbs "on" behind the clear lenses. :-) Maybe I'm being paranoid?
    The other items I'm waiting on are:
    STi painted grille
    Front and rear strut tower bars
    STi hood scoop
    Pocketlogger for my Palm Pilot
    Brake caliper paint from Folia Tec
    (see why I don't want to wait for more Silvervisions, LOL)
    Stephen
    the May issue of Road & Track?
    In it is a comparison test of four small wagons, all automatics: Saturn LW300, VW Jetta GLX, Volvo V40, and the Subaru WRX. While the WRX did win the comparison, R&T did not like the WRX's automatic one bit. The WRX's engine charactoristics and the 4-speed automatic were not a good mix, in their opinion. The car was 1.1 seconds slower 0-60 than the 5-speed they tested earlier, and the shift points and turbo lag were not a good match. They said as long as you had your foot to the floor, it was fine, but how often do you drive a car that way?
    Their advice: get the WRX—but with the 5-speed...
    Bob
    AH is going be in here postin' a rebuttal in no time soon! (Just teasin' ya AH). Bob...you bad boy!! :-)
    Stephen
    Any complaints, take it up with R&T, not me.
    Bob
    They won't work in the side marker lamps, anyway. The sidemarkers are the same as the front running lamps. Little with no base, if I remember right from when I had mine out. I'd heard VW has little bulbs that are clear but burn amber for the clear side markers on the Jetta and Passat. I've been driving around for a few weeks with the clear sides with clear bulbs. Haven't put my front license plate on either, but I carry it with me. "I'm waiting to get to a Subaru dealer and find out what they use for a bracket, officer, as you can see there isn't anyplace to mount the plate unless I drive screws right into the bumper!" I've been practicing.
    My SilverVision bulbs fit with just a little filing. I aligned the one nub with the slot, and filed the other down until it was a very tight fit in the non-slotted area. Worked fine. I probably could have forced it in without filing, but I didn't want to risk pulling out only the bulb and not the base whenever they need replaced. Thanks again for the tip on getting the Silvervisions!
    Glad the guy from eBay worked out for you. Sounded at first like you were having trouble with him, so I was feeling bad about recommending him.
    Next for me? Hmmm..trying to give D Stock auto-X a go, so I can't do much. I even put the intake resonator back in. No more Phisshhh- whoosh sound. Most things have been cosmetic to stay stock.
    Removed DRL module
    Removed intake resonator
    Removed Impreza from liftgate
    Removed steel box under armrest
    Added STi shifter trim
    Added MOMO Race Airleather shift knob
    Added clear side markers
    Replaced intake resonator
    Replaced one blown RE92 tire
    Removed amber gel in headlamps
    Replaced turn bulbs with SilverVision bulbs
    Relpaced running lamp bulbs with free BlueVision bulbs
    I think that's it.
    I've pretty much got the monochrome sleeper look I want for now without changing wheels and tires. Not sure what I'll do next. I am sure that you guys will bring up something sooner or later to grab my attention!
    Now if only someone would have a go at me. Where did all those potato blasting Civics go I saw while deciding to ge my WRX!
    Steve
  • hunter001hunter001 Member Posts: 851
    If you go back and read Post #1463 (before rehashing things already covered), you would have found the following (a related post is covered in Post # 1441):
    I briefly scanned through that article.
    Basically, they were referring to the WRX upshifting too quickly etc., but anybody with a rudimentary knowledge of "Adaptive automatics" know that the tranny can be re-trained to hold the gear till redline in every gear. So they basically got a "Green" WRX, whose tranny had not adapted to holding the gear (for acceleration) and was basically programmed from the factory for upshifting too quickly (for fuel efficiency).
    Another thing that stood out, is that they test Manual-Sedans with the lightweight 17" optional BBS wheels with light and sticky summer-only RE011 tires, while they test the Auto-Wagon with the heavier, sloppier 16" wheels with the pathetic all-season RE92 tires.
    In addition to the above, the 17" wheels with the RE011 tires have an overall diameter that is 1/2 an inch less than the RE92-equipped 16" rims, with a resultant "effective gear ratio reduction" which will enable it to accelerate like a mofo, even excluding the lightweight nature of the rims/wheels. This would affect every statistic, including acceleration, braking and also handling. So I was kind of pissed off at those folks, even though they positioned the WRX at #1.
    Everything being equal (tires/wheels etc), and with a well-adapted Automatic-transmission, the Auto-WRX should be slower than the manual by around 1/2 a second to 60mph (which is plenty fast enough), even though 0-60 and such things are not the reason for owning a WRX.
    But having an Automatic-WRX equipped with an Adaptive-automatic-trans, in an un-adapted state, and equipping it with RE92 all-seasons on a heavier sloppier, narrower wheel with tires/wheels having an unfairly high diameter affecting gear ratios (when compared to the other combo), is not a fair-and-balanced test. Publishing such comparison figures (without stating the different conditions of the other test)would make their opinions irrelevant to say the least.
    Later...AH
    Try a full second AH but if a 1/2 second makes you happy who am I to steel your thunder. :-)
    Stephen
    I just don't get this adaptive transmission thing. You spend a week training it to do 0 to 60 in 6 seconds then on the following week you have to drive in commute traffic so you spend another week training it to drive in commute traffic. Then on the weekend when you want to go 0 to 60 in 6 seconds but it thinks you want to 25 to 0 mph every 30 seconds.
    I coulds see having preset programs or even two or three adaptive programs that work in different ranges that you manually switch between but I can't see how an all the time adaptive can be a good thing if it takes a week to learn. What am I missing?
    Adaptive takes a few 100 to 700 miles to really take effect. It is an overall thing. I do notice it on the XT6 and my dad's legacy. It isn't an instantaneous thing, but over time you notice it. If you are an aggressive driver your driving in bumper to bumper is often not too different than on the open road. Same for a non-agressive driver.
    -mike
  • tricycletricycle Member Posts: 4
    Reaching back to a now long-ago discussion -- did anyone ever verify that the wagon wheel track specs on the UK subaru website, which are given as substantially narrower than the US specs (once all the exciting mm-to-inches conversions are performed)are correct? Or are the stated differences in fact an error, or some artifact of measuring with the larger (stock) UK wheels? I actually called Subaru America with this question, but they were, shall we say, information-challenged on this point ("call England" was their basic response, "we only know about the US cars..."). Just curious about this, mostly because Car magazine (a UK automotive press offering which I rather like)was especially harsh on the wagon (vs. sedan). If the wagon's wheel tracks were in fact narrower than the US, that may have accentuated perceived differences in the handling of the wagon.
    For what it's worth: I've driven the auto (wagon) twice at a dealer, and the experiences were night and day. The first time, you could have 2 cups of coffee and read the paper while waiting for the engine to slowly grasp it was needed for something back in the world...it was just dreadful, and seemed a total waste of the turbo. But the second time, the car that had clearly been broken in a bit. I noticed almost no turbo lag, and exceptionally smooth shifting (at the not too terribly fast speeds I travelled during the test drive).
    Personally, I'm still going to get the MT, mostly because with this engine, I'd rather have instant control all the time. But the AT in the second car I drove was surprisingly effective. If that one experience is indicative of the true capabilities of the adaptive AT (and other posts suggest it is) then I would have no qualms about recommending the AT to anyone who really needs or wants to say good-bye to two-foot driving -- it will still feel like a WRX.
    I must be a passive agressive driver then:) Since I don't like to drive agressively in traffic but I do on the open road. Probably 'cause I'm getting old.
    Still sounds like the transmission would be better with a switch. Of course our Camry has a switch; the mysterious ECT button. Does absolutely nothing as far as I can tell. Well it does switch on a light on the speedo that say ECT and it is an enless source of amusement. We use it whenever we want to pass with the driver giving instructions to the co-driver to engage the ECT; great fun. So maybe the switch idea is a non starter.
    my calculations showed that the UK wagon and sedan were relatively the same as the US wagon and sedan with the UK wagon being may be 5mm narrower (about a 1/4 inch). This might be because the UK wagon has 17 inch wheels though that does seem odd. I didn't try to convert the full track measurement.
    Where is track actually measured? Is it center to center, inside tire wall, outside tire wall or something else?
    If the cars have substantially differ track measurements from the US spec it might be because its measured differntly.
    Regardless of what has been posted here and elsewhere, R&T doesn't think the WRX and the current automatic are a good combo. They did like the LPT Volvo V40 and its 5-speed automatic, however.
    Even so, it still won the overall comparison test.
    Bob
    If you go back and read my previous post, the gist of it states that the R&T folks drove the Auto-WRX with an un-adapted transmission. Any person knows that an "adaptive" transmission in an un-adapted state, might appear to be "confused" or "hunting for gears" or "upshifting too quickly" or "downshifting too late", all of which are typical "gas mileage increasing" combinations programmed right out of the factory.
    When re-trained to the aggressive mode of driving, the shift patterns dramatically changes to "holds the gears in the power band", "downshifts when needed" etc. There is no rocket science in it. The car would intuitively do the gear-shifts perfectly !!
    All R&T did is to test an Auto-Wagon with an un-adapted Auto-Transmission and make comments on how the Auto-Trans in the un-adapted state performed. This does not reflect how the Auto-trans would perform with a few hundred miles of aggressive driving.
    I blame only Subaru for this blunder, since they presented a "Green" car (with an adaptive trans in an un-adapted state) to R&T, while Volkswagen (smart guys!) presented a car that had been well-adapted to the aggressive driving mode. If you go back and read their comments on the Volkswagen in the same comparison test, it states that "the adaptive transmission downshifted when needed and upshifted appropriately" or something along those lines. Do you think it was some magic or something ?? Superior VW engineering ?? Inferior Subaru engineering ?? NO !! The VW folks gave a good workout to the transmission to teach it the aggressive driving mode (possibly over several hundreds of miles) before handing the car with the well-adapted transmission over to the R&T folks. No rocket science there !!!
    Later...AH
    I'm not arguing or disagreeing with what you're saying. I think what troubles me about *any* adaptive transmission is if you have two drivers (in your family), one an aggressive driver, and the other a normal driver; the car will adapt to the driving style of whoever drove the vehicle last. That may, or may not(?), be very frustrating to whomever the next driver may be. This could be especially true when you consider the WRX engine's power characteristics...
    BTW, how long does it normally take an adaptive transmission to re-learn its shift points? A few miles? Several hundred miles?
    Let's hope Subaru will offer the SportShift feature on the '03 WRX automatic, as they are doing on the '03 Legacy GT, and as is found on Japanese-spec WRX automatics.
    Bob
  • locke2clocke2c Member Posts: 5,038
    Adaptive or no, the lag is going to be there and the low stall speed (used for launching from a stop) is going to be a severe hinderance.
    this statement was hilarious--
    quote: even though 0-60 and such things are not the reason for owning a WRX.
    Oh really? What's the point of owning a WRX if you don't mind me asking? Racing people 0-60 should not be any adult's point of owning a car, but some like it. 0-60 however is often a decent overall measure of the power and (straightline) performance of the car... and if no one cared about that, we'd all be driving Metros.
    -Colin
    Its raining, but I took some photos anyway. Here are two of my black WRX wagon with all white lamps on the front. It is my Black & White Rex in stealth mode.
    Steve
  • taos2taos2 Member Posts: 31
    What's the best source for purchasing a duplicate
    set of the stock 16" wheels?
    SKIREX
  • bkaiser1bkaiser1 Member Posts: 464
    Ebay has tons of WRX wheels...some w/ RE92's, some w/o...most of the prices I've seen on there are fantastic (under $500 for wheels/tires). Yeah, it's Ebay, so you just have to trust the seller, but I've bought a few things on Ebay (laptop computer, bike parts, etc) with no problems. Aside from the high cost of shipping wheels, Ebay's the way to go for OEM wheels.
    Try posting in the i-Club private sales, too. I see them on occasion for sale, but people get a lot of responses when they post in the wanted section, too. I saw a set of wheels with stock RE92 tires on there the other day in NY for $450 shipped. It is about $80 to ship across country, according to the UPS site (2 boxes 20" X 20" X 20" at 70# each), so these were $380 before shipping!
    I've also seen a for sale set of wheels/tires split up among buyers; one getting the wheels and the other the tires.
    Oh, and if you just want some replacement RE92 tires for any reason, Tire Rack has new take-offs for $71 each. I just got one this week to replace my blown out tire.
    HTH
    Steve
    Lights look great! I think this is easily the biggest and least expensive thing you can do to make the headlights a lot more attactive and take the focus off the bug-eye look.
    It looks like I won't be able to do my clear sides and mudflaps until tomorrow because of windy/rainy weather here today. Oh well, I still have to go buy the amber bulbs so....
    I'll post pics when I finally get done. Heck, with the weather the way it's been I might have the STi grill and hoodscoop by then! :-)
    Stephen
    Especially on Black.
    Like the "bug eyes" myself. Think the front end styling is a bit retro 60s british sports car but I may be seeing things.
    Tim
    Only really bugeyed car from then was the fifties AH Bugeye (or Frogeye) Sprite.
    Totally OT, but here's my contemporary era '58 MGA. See how it compliments my WRX? No windows, heater stinks, and no top. One for warm dry days, one for anything else that Mother Nature can throw my way. One for fun backroad spirited romps, the other for haulin' stuff...especially haulin' [non-permissible content removed]!
    Steve
    (sorry for the OT bandwidth)
    I love any pics (OT or not) of classic cars! :-)
    BTW, managed to get the painted rear mudflaps on in between dry spells. I might be able to get the clear sides on tomorrow.
    Tues, my dealer (Carter Subaru in Seattle) is launching a website for MRT products and the owner Brett Middelton will be there. There will be an openhouse for we i-clubbers. I kind of want to get the clear sides on by then.
    Stephen
    looks bug eyed to me :)
    Tim
    The adaptive feature is more of an averaging over a few hundred miles/thousand miles depending on how much past data is stored in the ECU.
    For example, if there are 2 drivers with 2 Auto-WRXs, one an aggressive driver and another a "grandma-like" driver, then after a couple of thousand miles, if the grandma were to drive the other driver's car, typical comments would be - Hey, this car is very fast. A lot faster and smoother than mine. There must be something wrong with my car. Now if the grandma continues to drive the fast car, gradually (over a few hundred miles depending on how much data is stored in the ECU), the shift points get re-averaged to the "slower-mode" and the car would start feeling sluggish.
    Now, if the aggressive fellow tries out the other car, the comments would go the other way This car is definitely sluggish. Maybe you should take it back to the dealer and get it corrected. If he continues to drive the slower car, the shift-points get re-averaged to the faster mode.
    This would be obviously visible in a new WRX equipped with the Automatic, available at a dealer, where the default mapping from the factory is geared towards fuel efficiency (slow downshifts, too early up-shifts).
    So, it would be a disservice to such a transmission, to performance test it in the "fuel efficiency" kind of shift mapping and make comments on how "sluggish it feels" or "it downshifts too late" or "up-shifts too quickly".
    Now, when any magazine borrows a car from an auto-maker, obviously they intend to test its raw performance and so Subaru should have had the foresight to re-map the shiftpoints to the performance mode before handing over the car to the folks from the press, which obviously they did not do, unlike folks from Volkswagen and Volvo, who were smart enough to do so.
    Later...AH
    all this adaptive stuff...
    IMO, it would make more sense to have a "power/economy" switch and/or "tip-tronic" capabilities for the transmission.
    Bob
    IIRC, it's built in. It changes depending how quickly you depress the accelerator.
    -Dennis
    On the AT equipped subies it know how hard you hit the gas: IE: If you punch it, the shift points are raised up, if you are gently on the gas the shift points are kept lower.
    On older subies like my XT6 and the SVX (I think older legacies also) there is a "power" light on the dash that lets you know when the higher shift points have been indicated by the computer. Basically it's like having a "power" button on the shifter, but instead of you manually hitting this button to move the shift points, the rate at which you depress the accelerator dictates when the "power mode" engages. I'll try to snap a shot of my dashboard tonight on the XT6 to show you the "power" light that is now absent (but the feature is still there) on current subies.
    -mike
  • hypovhypov Member Posts: 3,068
    Dennis-
    the 4EAT comes with the "Power Mode" you'd described. A quick depress of the accelerator and it down shifts. There's a learning curve for both the driver and 4EAT to happen though. I had been trying for the longest time, nothing; until after some 'Sunday Backroad Drives'. Now, it's easy to engage the 'Power Mode'. Guess you have to adapt the 4EAT to a little 'umph' kind of driving for it to work.
    -Dave
  • twrxtwrx Member Posts: 647
    Hehe, just disconnect the battery each time before you switch drivers so the ECU forgets! (or get the ulitmate adaptive transmission: the 5 speed.) Actually with out getting the AT/MT debate started again: I'm a MT driver and the WRX has a very nice MT. I can't say that about the MT on the '98 Forester I had. Clutch was marginal and altough shifting action was OK, my previous Hondas were far better. The clutch now is very smooth and the short throw shifter is great. If you like driving a 5 then this one is well worth it (or you can wait for the 6 MT on the WRX-STI.
    TWRX
    artgecko: wow, is that a B&W photo? ;-)
    The auto needs another ratio. And shiftronic. Both. With 5 closer ratios the revs would not drop as much in between shifts.
    Any how, the bottom line is it still won! ;-)
    -juice
  • kenskens Member Posts: 5,869
    Would the adaptive AT being "green" have any effect on 0-60 times? If you mash the gas, wouldn't the TCU go into some closed-loop program independent of what it's learned?
    Ken
  • WarpDriveWarpDrive Member Posts: 506
    The automatic will kick down to the lowest gear possible if you mash it. That's regardless of what it has learned.
    Yes, the AT being "green" was the factor due to which they gave the lowest points among all cars in their comparison, for the transmission of the Subaru WRX (among the other transmissions), which basically affected the final points standings and their negative comments on the transmission throughout the review.
    0-60 and other acceleration/braking figures was probably independent of it and was mainly due to the lousy, heavy and large diametered 16" wheels equipped with the All-season RE92 tires. With the optional Max-performance wheels/Summer-tires (with which they did earlier tests), it would have provided a lot more raw grip (for handling + acceleration), in addition to lower gear ratios for blistering acceleration along with its lighter tires/wheels.
    Note 1: larger diameter wheels/tires = bad for acceleration. Stock 16" with RE92 = 25.1" while the Optional 17" BBS with RE011 = 24.6". Gear ratios become lower, with lower tire/wheel diameter and makes a significant dent on the accelerative response of the car, in every gear. It is almost like getting lower (numerically higher) gear ratios, on the sly. Very significant impact on acceleration.
    Note 2: heavier wheel/tire combo = bad for acceleration and braking.
    RE92 with stock 16" = 38.5 lbs
    Optional RE011 with 17" BBS = 35lbs
    This additional poundage is rotational mass and has a much greater effect on acceleration than the 3.5lbs/tire-wheel leads us to believe. It is NOT the same as 3.5 x 4 = 14 additional pounds inside the car.
    Later...AH
    But if you count in the BBS wheels and tires, it puts the car at close to $3500+ more expensive. Have to compare apples to apples, stock to stock, etc. etc.
    -mike
    I think they equipped the Saturn with the optional high-performance tire/wheel combo.
    But you are right in that, with the BBS alloys, the price would have shot up quite a bit.
    Later...AH
