Subaru Impreza WRX Wagon
1105106108110111115
  • oneduckstwooneduckstwo Member Posts: 34
    thanks for the comments regarding the intakes, i think i'm just as well w/o it! as for the tires, i gave up reading the user comments about the yokohamas on tirerack.com as either people loved them or hated them (often w/the same car!) but are there any other suggestions? the sz50s apparently aren't avail. anymore...
    someone also just told me that i need to get the tires balanced again after a patch? they just patched it and threw it back on...is that a problem?
  • locke2clocke2c Member Posts: 5,038
    if it's holding air it won't be a problem for normal commuting. I wouldn't do a track day or autocross with a patched tire, but otherwise have had no problems with them in the past.
    are you asking for suggestions in the OE 205/55-16 size?
    ~c
    I realize I haven't been clear...
    To recap: I had a flat/puncture which I was able to have patched. But I have been planning on getting new tires somewhat shortly as they were not in the best shape when we bought the car 10000 miles ago. I checked out a bunch of tires on tirerack.com and the Yokohama's seemed like an ok choice but some people REALLY don't like them. I'm just wondering if there's any other somewhat affordable options for the OE size. Thanks.
    Actually my favorite summer tires are Faulken Azenis :) They are a bit hard for folks who don't like a stiff ride however they handle great.
    -mike
  • jwilson1jwilson1 Member Posts: 956
    ...and my favorites are the Toyo Proxes T1/Ss, tho I haven't had my WRX long enough to check out if they are in OE size for our wagons. If they are, I won't even think twice having had the Toyos on 3 other cars.
    Edit: I should add that they are summer-only tires.
    JW
  • kevin111kevin111 Member Posts: 991
    Have had them for about 6000 miles. Great tire! I upsized to 17s. Handles great, have a better ride than the 16" tires I had (Micheline Pilot Sport A&S) and while a little noisier than OEM, not too noisy.
    I will probably buy another set of these again when the time comes.
    The T1/S are great tires, but I think are a little more expensive.
  • barriostkdbarriostkd Member Posts: 71
    Another great tire is the Toyo Proxes4 (all-seasons). You might want to look into it as well. This is what I have on my WRX and I've been happy w/ these so far.
    JB
  • wrxwagwrxwag Member Posts: 6
    I spent a few weeks away driving my brother's BMW M Roadster. When I got back in my 2002 sportwagon I was surprised to feel the clutch engage so far off the floor. I have about 10K on a warranty clutch. The free play is about an inch or so. Does the WRX clutch require periodic adjustment?
  • snarkssnarks Member Posts: 207
    Its all relative to your feel, cars differ one from the other and engage at different points.
    You can adjust the pedal, I'd only be concerned if the clutch was slipping.
    -juice
    "I spent a few weeks away driving my brother's BMW M Roadster. When I got back in my 2002 sportwagon I was surprised to feel the clutch engage so far off the floor"
    - There is your problem right there! You are comparing a BMW clutch with a Subaru clutch. Two different animals!
    BMW's clutches have had a reputation of being very finicky. There is a small amount of travel where the clutch will initiate and catch, though the actual travel to start the clutch to catch is pretty long in Bimmers. This has commonly been reffered to as the "on/off switch" feel.
    Subaru's clutches are not nearly as finnicky and usually have a fairly long range for the clutch to catch. As a result, you do not have to press the pedal that far down for the clutch to catch. This is actually ideal, especially for quick shifting.
    actually I find the M series clutches to be anything but finicky-- they have a very predictable engagement zone and a nice firm pedal feel. I detest the "Honda" style pedal that goes to the floor with maybe 6-10 lbs of force.
    they do tend to engage very low, usually 1.5" to 2" from the floor. once you're used to it there's nothing weird about it.
    now, tell us what you thought about the torque delivery, throttle response, and total HP (felt) compared to your WRX. :)
    ~c
  • km24km24 Member Posts: 36
    Hi
    Which ac is better the 2004 WRX or the 2005 WRX climate control? People have complained that the 2004 system was not strong enough to cool the cabin in warmer climates.
    Khyle
    they are the same as far as I know. I have never read anything to indicate otherwise.
    if the car is all black, of course you'll have cooling problems in Arizona, Texas, Florida, etc. that's not a Subaru problem by any means!
    ~c
  • bkaiser1bkaiser1 Member Posts: 464
    The 05 climate control adopted the full automatic controls, but I'd imagine the actual compressor and AC hardware is the same as the previous years.
    My 04 WRX cools pretty well in 100+ degree heat, at least as well as my other cars have in the same conditions. Given the amount of complaints generated by Subaru's full auto climate controls, I'd probably opt for the old manual controls were I given the choice.
    Brian
    Hi
    Is it possible to convert the normal wrx headlight on a wrx 2004 or 2005 to a wrx sti hid headlight system. Also how much do you think it would cost. I am looking for better night vision.
    Khyle
  • hypovhypov Member Posts: 3,068
    Yes, buy the STi unit and plop it in + the necessary wirings.
    ...how much do you think it would cost.
    My guesstimate, ~$2k
    Pick up the Hella Micro DE Xenon for ~$700 instead.
    -Dave
  • 02wrxwagon02wrxwagon Member Posts: 1
    Have an 02 WRX wagon, has been perfect. Was wondering if anyone has over 80k miles and what to expect in possible repairs, ie timing belt, transmission (auto), etc.
  • saintvipersaintviper Member Posts: 177
    I'm at 89,000 miles on my 02. No repairs so far.
    I believe the recommended change interval on the timing belt is around 100,000 miles. I know that I'm going to have to change it once during my ownership, and I know I'm not going to keep the car for more than 190,000 miles, so I'll probably have it done soon when I take it in for some long overdue maintenance. So far the only maintenance I've done is oil changes and air filter changes.
    The climate control is a controversial topic, but apparently they waited and got the improved one from the 2005 Forester.
    The one used in the 2003-2004 Forester was nicknamed HAL for its obtuse operation.
    -juice
  • bluesubiebluesubie Member Posts: 3,497
    I would gladly take a manual climate control in my Forester over the ACC.
    The big difference between it and the one in the WRX is location, location, location. In the Forester, it's to the right of the steering column. In the WRX/STi, it's in the center of the HVAC console.
    I never had a problem with cooling in my '03 WRX or the '04 FXT.
    -Dennis
    You are probably the only person reading the WRX Sportwagon comments here interested in my thoughts on the M Roadster clutch. I don't think I mentioned that this Roadster has an aluminum clutch(don't know the details and didn't ask), supercharger, trick exhaust and a few other things. It's supposed to be cranking out 340 hp. I'm pretty sure they are all there. I found it to be the easiest shifting car I've ever driven. The clutch feel was outstanding and the early engagement helped to make better shifts. It was a bit on the stiff side, though, and occasionally I felt what may have been friction from the pedal bushings or linkage.
         It's best not to compare torque or acceleration. The cars are night and day. The BMW six has excellent torque at all rpms. The word that comes to mind when describing the acceleration is "violent". This Roadster is the most dangerous car I've driven. Ridiculous power + car that doesn't like the smallest of bumps = instant trouble in the wrong hands. I'll never forget this car but it's not one I would choose to own... too scary. I like traction too much.
         Yes, my WRX felt like another car after two weeks with the BMW. I'm trying to forget about the torque, clutch, shifter, acceleration, killer exhaust note and heavy duty hardware construction. I still love my WRX but man, I sure could use some more low end torque.
    nah, others read your comments and were interested but they probably haven't driven an M3 or M-roadster. :)
    ~Colin
    Hi
    What is the best service center in norther nj for cost and knowledge, town motor, liberty subaru,lynne's subaru, ramsey subaru, bill kolb jr subaru , etc
    Khyle
    Town Motors, but I responded to your post in the Subaru Crew: Best Service Facilities thread.
    -Dennis
    M-Roadster, in stock form is not that fast. I routinely rolled them at the track with my SVX.
    -mike
  • nixomosenixomose Member Posts: 95
    I have an 02 wagon with 25K miles on it and I've had to replace the drivers mirror, the right rear shock (and now the car doesn't sit straight) the front brakes and rotors, and now I notice that the right rear brake caliper seems to be frozen open because the disc is all rusty. But I expect that's not what you were asking about. :-) Good luck with yours you apparently have some of mine.
    somebody just mentioned A/C and it reminded me.
    Obviously you know only what you're used to, but does anybody else notice that in the summer when it's real hot and humid, when the compressor shuts off (not recirculating) you get blasted with warm wet air until the compressor goes on again.
    I find the A/C does a nice job but when it shuts off (Which I expect it to do) it gets no benifet from the existing pressure in the system. apparently. I dunno. I found the difference striking from any other car I've ever driven in heat.
    a M-roadster is waaaaaaay faster than a SVX. your skill/daring relative to the other driver is something totally different.
    ~c
    Of course Mike is talking about autocross as well. When you don't go over 40mph, the strengths of the M Roadster may not make themselves as apparent as they do in the real world.
    Strengths like windows that roll down...
    "now I notice that the right rear brake caliper seems to be frozen open because the disc is all rusty"
    - Interesting, because I have seen rust on the left front and rear disks, and just assumed this was surface rust. The car seems to break fine though.
    BTW, have also seen rust on the disks of either an '04 or '05 Lexus ES330.
    What are you talking about?
    My SVX was actually never auto-xed, however I did take it to Limerock and Jefferson Circuit Road Race courses SEVERAL times and Rolled SEVERAL MCoupes at each event since we used to do a lot of track days with BMWCCA.
    As for windows rolling down, not sure what you are talking about but all 4 of my windows roll down w/o an issue.
    -mike
    Hi
    Has anyone driven both the Wrx wagon and the aero Saab 92-x ? does the 92-x have more body roll? I test drove an Audi a4 and you can't feel the awd like in the Subaru. in the Subaru I felt the road when I took a turn I could feel the grip. With the Audi I new that it was gripping the road but the ride was softer the feel of the grip was muted.
    Khyle
    It may be hard to quanify that feeling, but I think you should definitely buy the one that "feels" right to you.
    I think the Saab has a little more insulation, but I'm not sure if the springs are any softer or not. Should be pretty similar.
    -juice
    So I finally got around to doing a little more playing with the brakes on my wrx.
    The thing about their being rust on the disc surface is bad. If you drive the car at all and apply the brakes, the pads will scrape off the rust. You should never have rust on your discs after driving anywhere. Mine's been like this for weeks now.
    So I thought I'd test it out before I brought it in. Lifted the rear two wheels up and turn one wheel, the other spins in the opposite direction. As expected, fine. Apply the emergency brake cable. Now it gets interesting. The wheels still move. They only move the amount of play in the tranny, but they move. If the rear brakes were applied by the hand brake, they shouldn't move at all, as on all other cars I've ever owned. So I look under the car, and what don't I see? Brake cables going to the rear calipers.
    Well silly silly me. So now I'm guessing that the emergency brake is wired to the transmission, which is an interesting and neat idea. (I oft complained how e-brake on the rear wheels would be a bad idea on an awd car, and in fact I guess I was right because they don't do it. I just never looked before.)
    So can anybody with some non-empiracle knowledge verify that for me?
    Now my problem is finding somebody with a foot to step on the brake while I try and turn it because I don't see any other way of finding out if the caliper is actually working. (the downside of living alone) Ideas?
    Okay, So I couldn't post this yesterday, I borrowed somebodys foot. Having them step on the brake I can no longer turn the wheel, so it seems the caliper is working. It looks like there's still brake pad left, but I'll have to take the wheel off to get a better look.
    Why am I having so much grief from the brakes on this car. I am NOT hard on them.
  • dcm61dcm61 Member Posts: 1,567
    The emergency brake is actually a drum brake within each rear rotor. There is a cable going through the backing plate of each rear brake.
    DaveM
    Yeah and it's indy from the discs and calipers.
    You can get the rotors coated if you hate the rust, but it is normal.
    Go to a junk yard, check out cars that have been sitting for months - every single rotor will be covered with rust.
    -juice
    hello all. i typically do fairly routine maintainance on my 02 wagon but noticed in the manual that perhaps you might want to have a dealer change the spark plugs. it seems reasonable to me as i don't think i even know where they might be on this engine so i'm wondering approx. what the dealer would charge for this? i picked up the car w/31000 mi. and i think the 30k scheduled maint. was skipped as the air filter was filthy. i've since put on 10k more miles...
    thanks.
    I think (but double-check) that the plugs last 60k miles, so you should be OK.
    It's kind of hard to reach, so if you're not familiar let a shop do it.
    -juice
    The WRX has Platnum sparkplugs. They are changed every 60K miles (the maintenance booklet in the glove compartment will state this).
    - When I brought my car in for the 30K mile maintenance at the dealer, I noticed that there were no charges for spark plugs or service of the spark plugs. When I asked, the dealer stated that the WRX is every 60K miles, while the RS is every 30K miles.
    I would change them far more often for optimal performance, idle quality and fuel economy.
    I'd do half those intervals on both types, so copper every 15k-20k and platinum (or iridium) every 30k.
    ~Colin
    Hi
    I would like to know what are the best headlights for night vision? The sti come with hid lights but I don't think that they are xenons. I am looking for a good set of xenon lights for performance and durability for a 2005-05 wrx. Also how good are the sti hid lights?
    Khyle
    yes they are xenons. all HIDs are xenon gas illuminated with a high voltage arc ballast. they are very good. my Evo has HIDs and I would find it hard to buy another new car without them.
    it would be quite expensive to retrofit the lights onto a 04+ standard WRX but you can purchase HID driving lights for considerably less-- be sure to aim them properly, though.
    ~c
    hypov has a set, maybe he'll chime in.
    -juice
    This is what I got
    Hella DE Xenon
    Never seem to get myself to remember to get pics of how much light they put out on the street, but here it is on the car.
    The light it puts out is whitish with a dash of yellow hue. Too white or bluish don't do too well for me in the rain, the yellow of the halogen does better.
    Visibility, from eyeball gauge, ~300ft and range of light cast IIRC from Hellas' chart is 300m
    -Dave
    think you covered it all except price! hehe
    btw that's a pretty narrow mount on those. why didn't you mount them at the edges of the grill or lower, say to the far sides of where your plate is?
    ~c
  • searcher1searcher1 Member Posts: 6
    I installed aftermarket HID bulbs on my Honda a few years ago, thinking it was just a matter of plugging the new bulbs into the existing wiring.
    Live and learn. I had a great improvement in night vision for a few days, but soon fried my headlight wiring. The wires were cooked by the added power, the female end of the plug/bulb connection burned and melted, and both bulbs blew.
    Not long afterward, by coincidence (or not), my ignition failed and I had to have the black box replaced. Very pricey. I suspect the misadventure with the HID bulbs damaged the ignition chip.
    Make sure your alternator and wiring can handle the load from the HIDs. Check the rating of the relevant fuses and completely replace the lighting relay with heavy duty wiring and connections. Also check the ground strap connection for corrosion. This is often a weak link in the electrical system.
    Better yet, get an experienced electrical/ignition specialist to test the electrical system and do the install. Your regular dealer/wrench turner may not know enough to do the job right. As I discovered, the consequences of a bad install - or a stupid DIY job - can be serious.
    um no. you did not have HID 'bulbs'. they may have been cleverly marketed, but at most you had higher than standard watter bulbs in your regular headlamps.
    this sounds like a PIAA 100w superwhite experience in fact. :)
    HIDs do not have a reflector like a tradition headlamp and they utilize a 40,000 volt ballast. without the ballast, you definitely do not have an HID. aftermarket HID light kits will come with a ballast and instructions to properly wire them in-- it can be done safely. I should know, I have a 1,000 watt stereo and no problems. (btw-- my stock alternator can drive the HIDs, air conditioning and the stereo with no voltage sag. wow.)
    ~Colin
    Doh... knew I forgot something.
    The unit cost about $700 shipped.
    Ya, the mount is pretty narrow. It's somewhat behind the grill with a section of the grill cutted out for the lens to protrude. There isn't much play in room to go wider unless I had had a STi grill then. Anyway, narrow as it is it still lights up four lanes wide.
    I had thought about mounting the lights lower, but was just toooooo plain lazy to remove the bumper to drill the holes to it and then the bumper frame to get a secure mount... but the grill cutting and fitting might have been the more time consuming route :p
    -Dave
    four lanes wide? is that a fog lamp or driving light?
    ~c
