Subaru Impreza WRX Wagon
Thankx to all for the feedback -- and info ....
and I agree with you Colin ... if money were no object (and it is for all of us I'm guessing) I think I'd head toward Volk or Advan this time. The Sube boards should help from here with some more economical choices.
Best, JW
~Colin
-juice
the Evo uses this same lug pattern, and consequently '05 STis and Evos now use similar if not identical wheel fitments.
~c
Don
<My memory says>
It's at the door panel, forward of the manual latch to open the door.
</My memory says>
-Dave
is cleanning the throttle body total BS to pay for the dealership owners yacht??
I believe the WRX is at 60,000 (or more?), because of the platinum spark plugs. I also checked my MySubaru site and it also listed 30,000. I have often found errors on the MySubaru site. I think they have difficulty because the Impreza comes with two different engines, and then there's the whole issue with dealer recommended vs. manuf. recommended.
I believe the base non-turbo 2.5L might get them changed at 30,000. Either way, I had my 30,000 done a few months ago and they did not change the plugs.
Take care,
Paul
Judging my MySubaru's site, I need new spark plugs, brake fluid, fuel filter, coolant, air filter, and engine oil/filter (along with a whole host of other checks). One dealer with the lowest price doesn't include brake fluid or fuel filter changes in that price, so it goes to $450 with those added. Another charges $440 for the 30k service, but doesn't do the spark plugs until 60k. Ugh...what a hassle just finding a place to get this done!
Serge
If you go to mysubaru, at least when I sign in, it brings up my dealers "recommended" maintenance schedule which does change at 30K. So does the edmunds site.
I am sticking to what is in my manual.I vaguely recall seeing somewehere that on the turbo its like the DOHC 2.5, PITA to get to the plugs so they put platinum ones on in the factory good till 60K.
Andmoon - Any worries about your car passing smogging with the reflash? Just curious. Also, what differences are there in performance and gas mileage?
Obviously if you can talk people into changing plugs early, there's more money in it for the dealer. Just as good, too, to have people think it's important to change oil every 3000. At 75000 miles (on my wife's Forester) they told me I should follow up on the 60k tuneup with new air filter, fuel filter, tire rotation (done in October!), oil change, spark plugs (again? must be a high profit item) and consider brake pad replacement. I had them do the oil change and told them I'd keep an eye on the rest.
JW
-mike
Recently took the WRX SW to be serviced at 24K and told the service writer about some noises with drivetrain--sounds like crunching or creaking, especially when cold--that seem to emanate from under the floor on the driver's side. And, also that it's been a real struggle lately, again especially when cold, to get it into first gear without double clutching. I am aware of some discussion of these issues here. Any insights for me, the service people seemed to think it was totally temperature related, claimed to have called Subaru USA, and additionally claimed to not have found ANY TSB's dealing with this. Can someone direct me to threads, similar experience, or/and solutions. I love the car, it is the best blend of sports car and functionality I have owned.
Thanks in advance.
j0elboy
In the previous one (Dec.) the only difference in my car I could detect was the gas mileage which dropped about 5 mpg. This time, no drop in mpg and no noticeable running difference. The only other variables I can identify on my own that correspond with past CEL's is a significant drop in temp (we had a week of 0 to -25) requiring more warm up and more reluctant early running while cold. The car is touchier when the weather gets more extreme.
On this CEL, I've filled two tanks of gas, opened & tightened the gas cap as many as 10 times, and made sure that I drove as gently as possible during warm up periods. I'll attempt to make an appointment with the dealer, but I'm tired of paying a fee for diagnosis for a problem that I think should have been cleared up at at least the 2nd time in to the dealer. This will be at least the 4th attempt to fix this. And, now my warranty has expired (by 3,000)so I'm on my own it seems (unless someone cares to see it as a pre-existing, ongoing problem which I doubt).
Okay, I've vented some frustration. If suggestions are also out there, pass them along.
Thomas in Mpls
-juice
I replaced them with winter blades which cover the structure of the wiper, but they still freeze solid and stop tracking. These blades also catch more wind at freeway speed and get lifted off the glass?
Any ideas?
The PIAA's sold through TireRack gets pretty good reviews.
-Dennis
-juice
The charge for the install was $50, which was well worth it to me since I hadn't found the motivation to tackle that project in the past year! I have to say, as insignificant as it sounds, the crooked steering wheel has bothered me since day one and I'm glad it seems to be history.
Brian
Are the new bushings urethane or rubber? Or are they just shaped differently?
-juice
B
-juice
No problems with cobbs reflash. It has been a while but I think I got 1 or 2 mpg better after the reflash.
My dealer installed aftermarket steering rack bushings for free (I bought the bushings) after a oem steering rack bushing followed by a new oem steering rack didn't fix the ramdon crooked steering wheel issue I had since day 1. I am now at over 26K and have had no issues with the aftermarket bushings.
Wagon runs great at 26K. Only issues are 1) rattle in the drivers side a pillar that the dealer has tried to fix many times. 2) squeeks in the cargo area during winter months. 3) I have to lower and raise my windows to stop wind noise after opening a door...just started this winter so I am not sure if it is temp. related...however it didn't do it last winter.
Compared to other OEM stereos I've had, the WRX system just sounds underpowered and a little muddy at higher volumes...and the lack of XM or Sirius truely sucks. If you are really on a budget, you can probably find the Subaru Sub online for pretty cheap and install it yourself...all the wiring is already there, just plug it in. But if you've got a few hundred to spend on quality stuff, I'd go aftermarket instead.
Just my .02....
Brian
Apparently they come with keyless entry only. To me, it looks like they are all wired up for the plugin "security" module, but I just want to confirm. Obviously can buy it much cheaper online after the fact than from the dealer.
Anyone else have this?
Don
1. The subaru bike rack is not so great and overpriced?
2. Yakima/Thule racks come in 6 million configurations and alot of people post about cutting (!) their rails to clear the gate?
So I'm not sure what to get. The easiest (cheapest) solution seems to be a trunk/hatchback rack if this is possible. I'm not really interested in a hitch rack as I don't even have the hitch or any interest in getting one. Any help would be appreciated. Thanks. Oh, we have 2 mountain bikes (G.Fisher Marlin + Spec. Rockhopper.)
One advantage to using the Road Warrior basket as the mounting point (rather than the round bars) is that it elevates the bikes enough to eliminate clearance problems with the rear hatch. With some setups, the rear spoiler can hit the bike trays (or bike tires) when it is opened. The Road Warrior mounts directly to the Subaru flat bars in a matter of minutes, and the whole thing can be removed from the car (and remounted) in less than a minute.
There are dozens of different ways of mounting bikes to your wagon, each with their own strengths and weaknesses...and virtually none of them are very cheap. Plan on spending at least $300 to $500 to get everything you need.
The cheapest solution, the hatch/trunk rack, is my least favorite because they don't hold the bikes nearly as securely as other racks, and they have a tendency to wreck your paint. But at least they are cheap...
Brian
-juice
I like the idea of the trailer mount because it carries the bikes securely and out of the air/bug stream. I also like that these types of racks can be added and removed in just a few minutes. An additional advantage is that you never have to worry about pulling into your garage with bikes on the roof.
Drawbacks with this type of rack are that they only carry bikes. A roof rack can carry skis, canoes, whatever. The other drawback is that you may not be able to open the trunk with them mounted.
The trailer mounts have attachments for skis.
The stuff off my Miata was muddy like that. I went synthetic. I'm at 53k miles now, so at 60k I'll change it again. Hope it looks better than last time!
-juice
The Si is still fwd right? 200hp, but probably 140ft/lbs of torque? And Civics have gotten fat over the years. Might be close.
I will say a couple days ago an old man in a newer blue WRX wagon with blacked out rims and giant exhaust gave me quite a run late at night exiting the 210 in Pasadena. The guy looked like Sherlock Holmes or something, and just disappeared...all I saw were taillights. I wonder if he posts here...
Any thoughts as to scheduled maintainance if I'm doing oil changes myself? I'm on 45k and the last time I went to the dealer they told me it wasn't necessary. Picked it up w/30k and it hasn't been there since...
-juice
Khyle
If not then, then sometime between then and late summer you will see something for sure.
Bob
