GMC Yukon
I have noticed that my '97 GMC Yukon has a very bouncy ride at road speed if the surface is the least bit wavy. Other than that, it is a great road vehicle. Anybody have knowledge as to the best brand/model shock absorber to cure this?
They have just become available at my local parts store, Murray's
Good Luck
My 95 truck is really acting up last few days, if anyone has a solution before it gets worse & I take it in to the dealer let me know.
Its a "Starting problem" The truck starts fine in the morning or after its been sitting a long while ( or right after you shut it off... & turn it on again) , But after driving it, if you shut it off... and come back after 20 minutes or so it just won't start. All I get is cranking...(I left work once and couldn't start to get back)(on another occasion I did get a start out of it on a 6th or 7th try once, it was like the 7th try when I turned the key it didn't even struggle and started right up at the touch of the key). Also once, I did try pressing the pedal all the way down "as maybe it was flooded" but no luck.
Notes: I did a tuneup about a few months ago, its got ~68K mi. Its' a 5.7L V-8 with a TBI Rochester carb. I did a top end cleaning today to see if it will help. I also checked for loose fittings as I pressure cleaned the engine compartment a while ago.
Help with Ideas & Thanks in advance folks:
DREJ,(with his fingers crossed as he starts the truck)
warranty) And Mr. dealer couldn't find it
the first time . But he did say it needed
$800 worth of brakes. LOL !!!!!!!!!Not under
warranty either............Geo
Tracy Goodrich
tracycgoodrich@cs.com
Oil pressure sending unit
Crankshaft Position sensor
Ignition module
No oil pressure will shut the pump off to protect the engine from severe damage.
Crank sensor tells the computer when to fire the injectors, if no signal from that, and the computer will not fire the injectors.
Ignition module failure would not fire the plugs, but fuel will still be sent to the cylinders. It would act like no fuel.
You also could have gotten a bad fuel pump, or the mechanic may have re-installed the old fuel strainer on the bottom of the pump. If that strainer is clogged up the pump will suck it up against the intake port stopping the gas, and shutting your truck off.
How many miles are on the truck? Is the problem while you are driving or after you drive and stop, then get back in to go, like if you stopped to fill up or the like? Who are you taking the truck to? Is it still under warranty?
Richard
RichardQuillen@msn.com
Thanks for Support.
