Changing transmission fluid and filter
                    Just left Jiffy Lube, where they offer a service called T-Tech.  Supposedly, they replace close to
100% of the transmission fluid but do not replace the filter. They claim, replacing the filter is not required for most vehicles. Has anyone had any experience with this service? If so, were you satisfied? Were they feeding me a bunch of Bull, when they said it's not necessary to change the transmission filter?
The guys at Jiffy Lube are supposed to sell you these services, so unless your car is "due" for this fluid change, there is no reason to do it. Just putting a little oil on a piece of tissue paper (they love to do that---did they do that for you?) to show you is meaningless.
Look in your manual
Somehow when I hear the words: Jiffy Lube and Transmission I shudder and break into a cold sweat. Scary!
I use Amsoil but always thought the Mobil was a true synthetic?
Al
For a true flush, a flushing agent has to be put into the transmsission. On an older transmission that has never had its fluid changed, a flush to remove the build up of varnish and gum is a good idea. 30k miles is the refill schedule, under severe use (which almost everyone falls into as far as the transmission goes).
Any synthetic ATF, of the proper type, is better than conventional ATF. I use Mobil 1, which is Dexron III compatible. For longest life, have a transmission fluid cooler installed.
The "Quickie Lube" places get blamed on a lot of mishaps due to screwups and poorly trained personnel.
In reality, given the large number of cars they work on, they probably do a fairly good job.
Still, the overselling of services and mistakes that happen once in awhile tend to paint them all with the same broad brush.
Jim
Automatic transmissions are basically "controlled bleeding" with hydraulics, so the viscosity and type of fluid is important...it's more than just a lubricant, the oil is a form of "transmission" itself.
I have a trans cooler on my older Benz, and it still has the original transmision after 200K miles.
Domestics [with exception of GM] generally fail before this time and 200,000 mile life is an exception except in LS400 which was way over designed but they are trying to build a reputation as a better than MB and cheaper than MB car to buy and own long term.
Even Lexus has had complaints by dealers that the transmission last too long and they are losing money in their repair facilities.
Unfortunately even Lexus techs must be paid or they will find a brand with lots of failures where they can make a living.
A fine balancing act you can't make a car to good or you won't sell new ones!
That oil transmited heatand kept the transmission oil from forming acid and varnishes. There is now a substitute called Lubegard (www.lubegard.com)developed in conjunction with the government after 20 years of research. It is made from vegitable oils It is very slippery, and temperature reductions are impressive. It also reduces acid, This is RECOMMENDED by auto manufacturers, and more important does not have any FTC claims against it. See the site above, but I have also seen other auto manufacturer's recommendations.
On a Ford Transmission, I would change the fluid every year at a transmission specialist shop, and add the lubegard. You will notice significant changes, or rather a reduction of problems.
http://www.atra-gears.com/
Never heard of it being used in transmissions.
And yes, they stopped using it some time ago. The replacement comes from tumbleweeds or some such desert 'weed' that they found also has superior lubricating capibilities.
The 'sperm oil' was also extensively used in machine shops to lube parts being milled.
But is there something that will help auto-trans in terms of additives???
Like I said I'm using Mobil 1 syn because I don't know of anything better. Auto trans deserve the best lub they can get.
