Chevy 1500HD Reviews
So what does everyone think of their 1500HDs?
After test driving the Ford 150 & 250 Supercrew and jumping in a Chevy HD for a hour drive, there
was a considerable difference.
1)Fords are higher, but only because of suspension blocks.
2)Fords look great on the outside, but interior
is bland.
3)Chevy I believe could of spiced the exterior up some but the interior is more refined.
and the LT pkg is more/less like the SUVs.
4)Noise levels are much lower on the Chevy, including Road & Motor noise.
5)Chevy 1500HD 4x4 Payload = 2847.
Ford Supercrew 150 = 1670.
6)Chevy 1500HD 4x4 GVWR = 8600.
Ford Supercrew 150 = 7700.
I was debating between the 2500HD 4x4 LS Crew and/or the 1500HD 4x4 LT Crew. It was a long drawn out process and I finally ended up with the 1500HD 4x4 LT Crew Cab.
Options: SummitWhite, Tan Leather interior, 6.0l, 4.10Ratio, Electronic Climate Control, Polished aluminum Wheels, Locking Rear Differential, Rear Window Defogger, Complete Trailering Pkg. Wheel Flares, Deep Tinted Glass.
Then I'll be putting on a Topper and having the lower 1/4 half painted light tan to match the interior.
Anyone know of nice looking running boards and mud flaps for this truck?
I'll be posting to this forum in the near future as I have more driving / towing reviews on this truck.
is bland.
check out http://www.picturetrail.com/ryanbab
for pics of them on my truck
Ryan
• The new 1500HD is really nothing more than a short-bed crew cab using the Chevy 2500 specs, which has an 8600 GVW. This is the first time I believe that a so-called "1/2" ton" pickup has ever used a 8600 lb. gvw. I know Chevy has offered a 1/2 ton Suburban with a diesel with a 8600 gvw, but I believe in the past 8600 has always been a heavy-duty 3/4 ton pickup model. So, I guess now we can expect to see other 8600 gvw 1/2 ton pickups in the future.
• I mentioned in my post title that this is a "marketing" issue. Chevy thinks most customers will be personal use buyers, as opposed to commercial buyers. Most personal use folks who think of "personal use," think of the "1500" series, not the "2500" series.
• And to further confuse the issue, Chevy will be marketing a "2500 series" Avalanche, in addition to the 1500 Avalanche in the fall. The 2500 Avalanche and the 1500HD Crew cab both have a 2500 GVW. Don't you think that the 1500/2500 Avalanche is going to compete with the new 1500HD Crew Cab? I do. I guess Chevy is betting that folks who are turned off by the "over-the-top" styling of the Avalanche will opt for the more conservative looking 1500HD Crew Cab. Confused? I know I am.
Bob
Bob
That should have read:
The 2500 Avalanche and the 1500HD Crew cab both have a 8600 GVW.
Bob
except 1 alternator and an air conditioned.
I am going to purchase a new truck. I need to find out what type of silage these trucks are getting on the highway(new 1500 4wd crew cab).
But...252,000 miles on the '95? I'd say that one deserves to be retired and put out to stud, a good one!
A lot of driving, you are doing! Towing lots? Auto or manual on the '95?
Campo57
<< I am looking into purchasing a 1500HD. I have been waiting many years for a true 4-door 1500 series truck with a regular size bed >>
In my earlier post I suggested that Chevy labeled this vehicle a "!500" rather than a "2500" model for marketing purposes, even though it rides on the 2500 series 8600 lb. gvw chassis.
Your above comment proves my point. If this vehicle had been labeled a "2500" instead of a "1500," I suspect you probably would not have considered it.
Ahhh, the power of savvy marketing...
Bob
Bob
Yes you are correct on the step in height, also for the same reason.
Best of luck with your truck.
-Eric
1500HD 4x4 LT CrewCab
First issue - Tranny was replaced @ 450mi
It was intermitted in going into reverse.
Since then it's did it 3 times, If it happens
a 4th time she going back to the dealer.
Otherwise I love this truck!
Photos:
http://community.webshots.com/album/13776922cTltRRmmmG
Pros:
*Tons of power to tow our 23ft Boat (Cuddy)
*Very Quiet interior. little wind and road noise..
*Lot's of Looks from the Ford folks!
*There is not as many on the road as ford (mainly because they are so new) it's nice having a truck not everyone and their brother has...
*Plenty of leg room in the back seat
*VERY solid construction, Frame / chassis.
*Drives great! Seats, fit you like a glove.
Cons:
*Gas Mi - avg 14.0
*I have the 4.10 rear-end
*Tranny was replaced @ 450mi
*MONTHLY PAYMENTS... :-(
*It sits about 1/2" lower on driver's side??? (not a big deal though)
*Firestone Tires - They look great and they look much better than the basic tires, before the upgrade.
*Wish it sat up like the 2500HD, (but I saved $$$$.$$) and really did not need that extra
beefed up 2500HD.
Ask me, would I buy one again???
O ya...!
That's a great feature on transitional surfaces.
Bob
<< <B>Interesting marketing on Chevy's part by rsholland Jun 24, 2001 (07:23 am)
I picked up a flyer at my local Chevy dealer on the 1500HD, and they compare it to the Ford F-150 Super Crew. I find this rather interesting for the following reasons:
• And to further confuse the issue, Chevy will be marketing a "2500 series" Avalanche, in addition to the 1500 Avalanche in the fall. The 2500 Avalanche and the 1500HD Crew cab both have a 8600 GVW. Don't you think that the 1500/2500 Avalanche is going to compete with the new 1500HD Crew Cab? I do. I guess Chevy is betting that folks who are turned off by the "over-the-top" styling of the Avalanche will opt for the more conservative looking 1500HD Crew Cab. Confused? I know I am. >>
As I mentioned in my previous post, I'm convinced this was a marketing decision, nothing else. They (marketing) apparently think if they stuck a "2500" badge on it instead of a "1500HD," that they would lose consumer (as opposed to commerical) sales, because it would be perceived as a 3/4 ton, and not a 1/2 ton.
I do agree—it's dumb, and confusing. Your post accurately reflects that.
Bob
How do you know the 5.3 would be adequete? The truck is on the 2500LD platform which means it is heavier duty than a 1500. The 1500HD is all marketing
Bob
I just recently ordered a '02 Silverado 1500HD Crew Cab LT which should come to the dealer sometime in late Sept. or early Oct. I am really excited about getting it but I wonder if I screwed up on something? I ordered the 4.10 ratio rear axle and I wondered what the difference would be in fuel mileage if I would have ordered the 3.73 rear axle instead? I think we're only talking about 1-2 mpg. difference. The engine is the 6.0L V8 Vortec. If anyone out there can enlighten me I would appreciate it!
Joe
I've got the GMC 1500HD w/ 3:73's and I consistantly get 14.5/15 mpg in town and easily get 16.5/17 on the Hwy.
As for the problems. I hope they are all fixed otherwise a Toyota could be in my future, I'll just have to wait till a 4-door Tundra is available though.
I have a 1999 Z71 and am thinking about putting on some larger tires. The stock wheels will handle 285 75 16 with no problem, I have even seen 305 70 16 tires on stock wheels, but think that is pushing it a little. If I spring for new wheels will they fit on the 1500HD? I am thinking on upgrading to a crew cab and the 1500HD will be on my short list.
1) Does anyone have any reliable information or know where I might find information on adjusting the front torsion bars to level out the truck?
2) Does anyone know what's involved in moving to a larger tire? Will I need to change any of the computer equipment, etc?
David
Measure both sides of the truck. Jack the front of the truck up. Crank the bolts (i suggest 3-5 turns). Jack the truck down measure make sure both sides are equal. drive it for a day or two then get the front aligned. Also make sure you leave some thread on the bolts do not tighten them all the way. Both sides may have unequal thread left. I know the pass side on mine has about 5 threads left and the drivers side has 3.
For larger tires if you go to 285's to reporgram your speedo you will need to buy a programmer (dealer cant fix). They can only correct up to 265's. Your speedo will be off when you go to a larger tire. Also your abs might be off. Other than that it should be ok.
I have done both (jack torsion bars and i have 285's on my Z71)
If you need any more info let me know
Ryanb0928@yahoo.com
They come with the rear end raised slightly for good reason.
How much of a difference does the one inch diameter make to the ABS? Do I really need to have the calibration done if I go to the larger tire?
Using my spreadsheet to figure 245/75R16 vs 265/75R16 looks to be just over an inch in diameter and just under 4 percent odometer reading.
Width (mm) / 25.4 gives width in inches.
Width (inches) x AR (aspect ratio or 75) gives section height.
Section Height x2 plus rim gives tire diameter.
Tire diameter x 22/7 (pi) gives circumference
5280*12 gives inches in a mile.
(5280*12) divided by circumference gives revolutions per mile.
Dividing the revs per mile of the 245 tire by the revs per mile of the 265 tire gives me the approximate 4 percent odometer difference.
I can live with 4 miles per hundred short.
But, can the ABS be confused if all wheels are the same size? Do we have an air speed indicator or a GeoSat reference that I don't know about?
Then the front end isn't really higher. No free lunch.
I gained 1" in the front the headlights arent affecting any other drivers i havent been flashed yet
Why does an alignment need to be performed after this procedure? Is this something that may or may not need to be done? The truck has just over 5,000 miles on it and I really don't want to upset the factory settings as they seem to be right on.
Also, does anyone know of any problems going to the 265-75/16 tires on the factory rims? They appear to be wide enough to handle this size tire.
You will want to get the front aligned because cranking the torsion bars will throw the front end off a little. I know my left side was off the most.
The difference in the front and back i dont know offhand i have the numbers somewhere. It was like a 2.5" difference and now it is like 1.25-1.5". Good enough in my book
Hope this helped
Ryan
Jim
-- Don
