Visitor Agreement.
The other advantage is that the LSD works under all conditions at all speeds. The approach of using brakes to transfer torque is generally limited to speeds around 30mph and lower (to avoid rotor warp and really premature wear of brakes, in addition to instablity of braking at higher speeds on slippery surfaces) therefore you have no torque transfer on slippery ramps or other circumstances where slippery conditions might exist at higher speeds.
But to be totally fair the above statement probably also means an LSD would not incur enough wear in 100,000 miles so as to result in a failure.
But given that the method of implementing the new "virtual" type of LSD, rear and center, is also integral to ABS/VSC/TC/AWD/EBD/BA (is there more...??) the need for an actual LSD seems more than just redundant, more like in a total waste.
yes, actually, more to come.....
Trailing, "drag", braking.
The brake fluid pressure application/release valving already integral to these systems would allow the rear brakes, ONLY the rear brakes, to be applied first/initially, with "LIGHT" braking. Anything beyond a certain brake pedal pressure point/level would bring in the front brakes also. A second method might be to only use rear braking until ABS activation is "triggered" for the rear brakes indicating that the driver is asking more of the rear brakes than they alone can supply or roadbed conditions are limiting the level of braking the rear can supply.
On a slippery wintertime roadbed, or even with a fresh rain on an oily roadbed, this would not just result in the desireable effect of stabilizing the direction of the vehicle, it would also result in the dedication of the ENTIRE front tire roadbed adhesion coefficient to lateral, directional control/correction, forces, much like the way drag brakes are often used on a tractor/trailer rig.
Many vehicles already make use of the above method for directional stabilization/correctional aid, rear braking only, when VSC detects plowing/understearing.
Delayed ABS activation.
Unless VSC senses/detects that directional control is being threatened via severe braking there is no reason for ABS activation on the front wheels.
But given that the method of implementing the new "virtual" type of LSD, rear and center, is also integral to ABS/VSC/TC/AWD/EBD/BA (is there more...??) the need for an actual LSD seems more than just redundant, more like in a total waste."
I'm from the NorthEast so I think there are enough wet, icy, snowy conditions to fully benefit from a mech LSD. Unless you've driven both types of vehicles I think its hard to evaluate however I've driven enough vehicles with both open and mech LSD (both rear and ctr) to know I would always and I repeat always... take the vehicle with the mech LSD over the brake induced torque transfer vehicle with an open differential.
But don't take my word for it. Just do some research and you'll find that nearly every single performance vehicle on the road uses a mechanical LSD and that includes vehicles that benefit from its instant torque transfer response that are generally traveling far in excess of 30 mphs. And every single off-road or full time 4wd vehicle on the market includes a mech LSD or locking differential in the rear and center .....other than Toyota.
So don't take my word for it...just look at what the rest of the marketplace is doing. They're not installing LSDs because the customer demands it since most customer's don't even know what it is. They're installing it because it provides better traction under all conditions, is more reliable and causes less wear and tear on brakes and rotors than a brake driven torque transfer system. It simply distributes torque better than any computer/brake drive system since its based on simple physics vs complex computer algorithyms. Which explains why Toyota has migrated to center LSDs on their drivetrains with higher power. Now they just need to fully match the competition by adding a rear mech LSD to those higher end vehicles that deserve it.
BTW can you name a high end performance sedan or a serious AWD or 4wd vehicle that doesn't have a mech LSD in the rear (other than Toyota)? I know I can't but maybe you can help identify another manifacturer that views LSDs the same as the views above.
Going back a few years we lived up in the woods (Seattle eastside) at the end of a two mile dirt and gravel road (mostly dirt [MUD!!] for the last mile or so) with several fairly steep inclines. That is when I began my second experience with LSDs. We purchased a 1985 Jeep Cherokee LTD to be sure we could get in and out of that road in all conditions. It took chains on all four wheels several times but we always made it through. I later traded up to a '92 Jeep Cherokee LTD with the same RWD/AWD/4WD/rear LSD capabilities as the '85.
In 2000 the '92 was retired to the ranch in MT (still "going" strong even today) in favor of a '00 AWD RX300. The '00 RX was shortly traded in for an '01 AWD RX300 that had HID, GPS/nav, VSC, Trac etc. Like the '00 the center diff'l of the '01 has a VC, viscous coupling, to "stiffen" the otherwise open center diff'l when disparate F/R wheelspin/slip develops.
Oh, whereas the '00 RX had a mechanical rear LSD the '01 RX uses TC to implement a virtual rear LSD. As a matter of fact the center VC turns out to be dead weight since TC also implements a center virtual LSD. The VC was dropped from the RX series beginning with the 04 model year.
And...
My '01 911/996 C4, which I drove home in 4" of snow just the other night, has a TC (PSM) implemented virtual rear LSD of which I am very pleased. Currently there seems to be a lot of 911/996 owners who have added a mechanical LSD without realizing they need to find a way to disable the virtual one otherwise the mechanical one is just dead weight.
And I would be VERY surprised if the ML320 or BMW X3/5 has anything but a
virtual LSD.
"Name a high end performance sedan or a serious AWD or 4WD vehicle that doesn't..."
Frankly I don't know of any high end performance sedan that I can say for sure either way...except for Lexus using the virtual one but that's just another Toyota. But I serious doubt that it matters to those buyers one way or another, or if they even "know".
IMMHO there is NO SUCH thing as a "serious" SUV with AWD and not 4WD or 4X4 mode also. No self-respecting "serious" SUV would stoop to that level. But I will grant you that if it has a 4WD or 4X4 mode then it is marketed, at least partially so, to the off-road crowd and therefore it very likely has a mechanical rear LSD.
Be advised that I am in no way denigrating mechanical LSDs, just that they have their place and that is NOT in a general public market vehicle.
Hmmm...
I wonder if the PSM equipped Porsche Cayenne has a mechanical LSD.....I think probably not.
Now, there is ONE SERIOUS 4WD SUV...!!
But useless, overall, as teats on a bull.
"In 2000 the '92 was retired to the ranch in MT (still "going" strong even today) in favor of a '00 AWD RX300. The '00 RX was shortly traded in for an '01 AWD RX300 that had HID, GPS/nav, VSC, Trac etc. Like the '00 the center diff'l of the '01 has a VC, viscous coupling, to "stiffen" the otherwise open center diff'l when disparate F/R wheelspin/slip develops.
Oh, whereas the '00 RX had a mechanical rear LSD the '01 RX uses TC to implement a virtual rear LSD. As a matter of fact the center VC turns out to be dead weight since TC also implements a center virtual LSD. The VC was dropped from the RX series beginning with the 04 model year."
The 2008 Lexus RX AWD has a center LSD (VC) and an open rear differential. (Its a Toyota and I don't believe Toyota uses a rear LSD in any of their vehicles including trucks, which I believe is a competitive mistake.)
"My '01 911/996 C4, which I drove home in 4" of snow just the other night, has a TC (PSM) implemented virtual rear LSD of which I am very pleased. Currently there seems to be a lot of 911/996 owners who have added a mechanical LSD without realizing they need to find a way to disable the virtual one otherwise the mechanical one is just dead weight."
All versions of the 2008 Porsche 911 (Turbo, Carrera, GT3, Cabriolet) have a mech rear LSD. Various models can be upgraded to include an auto-locking rear diff.
"And I would be VERY surprised if the ML320 or BMW X3/5 has anything but a
virtual LSD."
"IMMHO there is NO SUCH thing as a "serious" SUV with AWD and not 4WD or 4X4 mode also. No self-respecting "serious" SUV would stoop to that level. But I will grant you that if it has a 4WD or 4X4 mode then it is marketed, at least partially so, to the off-road crowd and therefore it very likely has a mechanical rear LSD."
By "serious" AWD I simply meant with sophisticated awd designs meant to manage all available power to avoid slippage. Toyota's approach is to generally reduce the power through engine management to compensate for slippage (in addition to transferring some power by brake management).
Audi, Subaru, GM and others take the approach of more agressively transferring torque through the use of mech LSDs to find a non-slipping tire with a less agressive engine management to reduce power. I prefer to manage the power as a driver and want the vehicle to figure out which wheel can best utilize that available power. Toyota assumes the driver doesn't know what's best and decides for them through more agressive engine management.
"Be advised that I am in no way denigrating mechanical LSDs, just that they have their place and that is NOT in a general public market vehicle. "
"I wonder if the PSM equipped Porsche Cayenne has a mechanical LSD.....I think probably not.
Now, there is ONE SERIOUS 4WD SUV...!!"
I'm not sure I would consider the Cayenne a serious suv however it is certainly a serious performance vehicle. The 08 Cayenne has a center LSD and a rear mechanical auto-locking differential.
Here's a few vehicles and what their designers thought were the best designs for traction and power distribution:
2008 MB ML & GL uses open diff. designs plus the ABS brakes to transfer torque. They can be upgraded with locking rear differentials. If you want the AMG versions, both models will be upgraded with limited slip rear differentials.
2008 BMW X5 comes with a ctr LSD and an open rear diff. You can upgrade to a rear LSD for $625 and all M versions of any BMW come standard with a rear LSD.
2008 Subaru Forester, Outback, Tribeca, Impreza all have mech rear LSDs and a ctr LSD (VC).
2008 Audi Quattro's R8, S8, A4, A6 have mech rear LSDs.
All of GM's Full size suvs either have a rear mech LSD or offer it as an option including the new Tahoe Hybrid which comes std with a rear mech LSD.
I think I've shared that there are many on-road vehicles with mech LSDs and in fact most of the higher end vehicles either come with mech rear LSDs std or offer them as options.
NOT...!!!!!
When the RX330 first came out all of the maketing materials, printed and inline, indicated it had, like the previous RX300, a VC, Viscous Coupling, across the center open diff'l.
It did not and I have an email from Lexus corporate agreeing with me and apologizing for the miss information.
Now all of the maketing materials for the RX350 indicates it uses the VC.
It does NOT...!
I have opened email discussions with Lexus about this falsification on three separate occassions. Each time I am asked to convert the discussion to verbal via telephone and each time I have ended up being told that I will recieve a retrun call with a definite answer with 48 hours. No such return call has ever been made.
The NCF, New Car Features, at techinfo.toyota.com, for the first model year of the RX350 indicates a return to the MF2AV transfer as was used in the RX300. But all of the other documentation, repair manual, etc, for that same initial model year and all following years indicate that the MF2A transfer is used. A search for the term MF2AV for any RX350 model year yields no results whereas a search for MF2A
in those years yeilds dozens.
In addition I recently tried to buy a new VC "canister", from an online source I often use for Lexus parts. I gave a valid VIN number for a 2008 AWD RX350 but got no response. On the same day I ordered parts, same online source, for my 1992 Lexus LS400 and got a response within 24 hours.
I don't have a clue as to why Lexus might or maybe would be falsifying, continuing to falsify, marketing information about the AWD RX series in this way.
Look at it this way, even if you are driving a 4X4 what would any experienced or knowledgeable driver do if all four wheels began spinning on ice or packed snow due to the lack of enough traction to move up an incline.
You'd STOP what you're doing, scratch your head and say "what can I do to add more traction?"
But how do we begin to get the general public to understand that, absent it being FORCED on them via engine dethrottling..??
Yes, spinning your wheels will often help to get you up and moving initially, but what I seem to be noticeing is far too many drivers simply "burning rubber" with little or no hope of moving up even the smallest of slippery roadbed inclines.
So, what I see coming, soon, is that all vehicles will have a dethrotting "feature" to prevent such actions by unknowledgeable and/or inexperienced drivers.
I often see circumstances wherein NOTHING will get a vehicle moving forward, not even a 4X4 drive system, other than when equipped tire studs or tire chains. And in that case, studs or chains, RWD will often easily suffice.
I am totally opposed to tire studs as a result of the damage they do to our highways when they have no use anyway, so I always carry a set of tire chains, two during the winter months.
http://autos.yahoo.com/lexus_rx_350_awd-features/?p=brak
http://consumerguideauto.howstuffworks.com/2008-lexus-rx-5.htm
http://www.autobeat.com/index.cfm?page=4&INVENTORY_ID=2074143
http://www.carsoup.com/new/detail.asp?year=2008&seriesid=2008600903&styleid=2008- 600903&vehicletypeid=1&makeid=24&modelid=20086009&mode=make&cont=1&redirtype=InB- ound&delta=1
http://www.conceptcarz.com/vehicle/z14609/Lexus_RX_350.aspx
I kinda doubt that all these publications got it wrong when they published that the 2008 RX has a viscous limited slip center differential. However if that's not enough evidence for you here's the formal press release from Toyota announcing the all-new center LSD in the 08 RX that was published to the entire media. http://pressroom.toyota.com/Releases/View?id=TYT2007082898955
Lastly its rather hard to refute the clear evidence from the Lexus website that highlights the viscous center LSD as an important "Performance" feature of the 2008 RX. I kinda doubt the lawyers would let the marketing team publicly market a prominent feature that is not a part of the vehicle. http://www.lexus.com/models/RX/features/performance.html
BTW, based on March 08 sales it looks like the sales of the RX and the GX are struggling abit http://pressroom.toyota.com/Releases/View?id=TYT2008040198482
I think before making the claim that Toyota is falsifying their marketing of the 08 RX you might consider publishing a single thread of evidence from a reputable source or photos of an 08 ctr LSD that shows it to be an open design. My money is with the lawyers that would prevent Toyota from falsely publishing a major feature in press releases and their website (for any lengthy period of time) before taking it down quickly or sending out a correction.
There is little need for referencing publications other than Lexus themselves as it seems quite clear to me that Lexus would be the base source of such information.
Now go back and read the very first paragraph under the bold title:
"Full-Time All Wheel Drive with Vehicle Stability Control."
But first, let me tell you that lots of Porsche 911/996 owners have gone out and installed mechanical rear LSDs onlyto discover them to be totally non-functional usless a way can be found to disable the factory supplied "virtaul" LSD using traction control firmware.
VCs, couplings or clutches, are not instant acting. The VC in my '01 AWD RX300 takes tens of seconds to stiffen enogh with sustained wheelspin/slip before it will convey even 20% of the engine torque to the rear driveline. But the reality of the matter is that even the VC in my RX300 is completely non-function for real world aspects.
The TC, Traction Control, system in my '01 will instantly apply braking to any wheel or wheels that slip due to engine torque and just as quickly dethrottle the engine. Apparently teh RX330 and RX350 will do the same thing. The only real difference being my TC dethrottles the engine via EFI control, fuel starvation, whereas the others have DBW, e-throttles.
But read the paragraph that I referenced and see if you can make any sense of the wording. For me, the described operation of Trac makes the viability of having a functional VC non-functional.
Of course mistakes do happen, however even if the website was mistaken at first the lawyers would have required a correction immediately. Since the Lexus website clearly states that the new RX has a ctr LSD and it has been on the website since launch (nearly 6 months), I think most reasonable people would agree that the new RX includes a viscous ctr LSD in the absence of physical proof or a reputable source that suggests otherwise..
I see no conflict between the software advantages of "selective braking" and LSDs in a drivetrain. In fact, its really the best of both worlds. By incorporating the LSDs you get real time torque transfer at the moment its needed without any speed limitations, wearing of brake pads, potential warping of rotors or overly agressive engine power reductions.
The physics of an LSD manage the torque transfer seemlessly across the various corners. By having an LSD in the center and the rear, it enables the software developers to dial back the VSC and TC to levels that would only be activated if the LSDs were overwhelmed by speed, traction, torque transfer, driver error or some combination. This would make the VSC and TC the safety features they were originally intended to be instead of a cheap man's version of a mech. LSD.
The very best high performance vehicles and the best AWD systems layer the mechanical approach with the computer approach to maximize torque from the engine being distributed to the tires that can best use them. If the power is more than can be distributed than the safety features of VSC and TC step in to protect the driver.
That's why you are probably correct that the guy's adding LSDs to vehicles like 911s that had open diffs with VSC and TC may be wasting their time unless they disable the VSC or modify the programming to acommodate the LSD. That's why its best to have the LSD from the factory if the vehicle has VSC and TC.
That is my personal preference and the best vehicles in the world take that approach to torque management. Toyota attempts to jump straight from "torque management" to "driver management" by skipping the physics of an LSD (as well as the cost advantage) and instead use software to manage the driver.
Toyota did make some progress in their thinking by inserting ctr LSDs back into their drivetrain lineups for many of their models in 2008. Now they just need to catch up to the best manfuacturers of 4wd and AWD vehicles by adding rear mech LSDs, at least for their premium products.
"no conflict.."
I really can't speak, directly, for an RX model but my own. On a packed snow or icy parking lot my RX's Trac system will quickly abort even the slightest level of wheelspin/slip due to engine torque. The brakes are almost instantly applied and the engine is dethrottled via fuel starvation. MY '01 does not have DBW so at first I didn't know how the dethrottling was accomlished but the shop/repair manuals for my '01 indicate it is via fuel starvation.
Viscous clutches and couplings do not react anywhere near instantly to desparate rotational rates at the two inputs. That's actually their greatest advantage in this particular application. There is very little VC functionality to interfere with the need for the front wheels to be free to rotate independently of the rear when turning. The onset of VC "stiffening" depends on the formulation of the viscous fluid, basically how fast its volume (tries too) expand due to the heat of "stirring".
If these is no ability for sustaining an extended period of disparate rotation of the two inputs to the VC then the VC will never become functional.
This, the above, is the basis for my firm belief about why the VC was dropped for the entire RX series with the introduction of RX330 model and is also not used on the AWD versions of the Highlander and the Sienna, although otherwise those AWD drive trains are an exacting duplication of the RX.
But, I remain quite willing to be proved wrong.
But the evidence available to me so far indicates, weights heavily, on the side that Lexus is intentionally misleading the buying public.
As to "why", my only answer would be for you to study the Japanese culture.
My experience with viscous ctr LSDs is far different from yours. My recent experience is with GM's viscous ctr LSD and Toyota's Torsen ctr LSD. The response time of the viscous LSD in the GM Denali AWD is literally measured in fractions of a second as stated in their literature. You can actually feel the difference in a vehicle with a dedicated power distribution compared to a vehicle without a dedicated ctr LSD. For example, when accelerating through an off-on ramp you can actually feel the Denali "pulling" itself in addition to "pushing" itself through the curve.
By having a ctr mech LSD the manufacturer can dedicate a certain % of power to the front wheels without having to worry abound binding in sharp turns. That's why the Tundra's 4wd system is parttime and the Sequoia's is full-time (Tundra has no ctr diff and the Sequoia has a ctr torsen LSD). A 4wd system or AWD system that does not have a ctr LSD cannot distribute torque with minimum power requirements which is a significant disadvantage for 4 wheel drivetrains with open ctr differentials.
You will not enjoy this satisfying feeling in a 4wd vehicle that does not have a mechanical LSD. This same feeling can be felt with the Sequoia when 4wd is engaged since its power has a dedicated distribution of around 40Fr/60Rr in 4wd with the ctr diff unlocked.
This same design philosphy equally applies to a rear mech LSD where transferring torque from one side to the other is the priority unlike a ctr diff which is addressing torque transfer from front to rear.
The new 08 RX330 with a viscous ctr LSD has this advantage of "guaranteed" power to both ends of the vehicle when in 4wd. This article describes the RX's new viscous ctr LSD as delivering a balanced 50/50 power distribution until slippage occurs.
But no, my stated position is that I DO NOT believe ANY RX350 has a VC involved with the operation of the center open diff'l, including the 2008 model. And for that matter not even the new 2009 model.
Viscous clutch and coupling fluids can be formulated in an infinite number of ways. Some manufacturers even include a small amount of gas, a "gas" bubble, within the hermetically sealed fluid container, so as to delay the onset of the coupling coeffficient as the temperature of the fluid rises due to the "stirring" of the fluid by the clutch plates.
Suppose, for whatever reason, I drive my VC equipped '01 AWD RX300 in a very tight circle, as fast as is reasonable, continously for say, three revolutions. At what level might the coupling coefficient of the VC fluid rise to in that instance?
Frankly, I do not, cannot, believe that any Full-Time AWD system can be constructed using a center diff'l VC technique and have coupling coefficient responses on the order of anything less than multiples of seconds. And frankly, what is, where is the NEED..??
Think of the hazard that might result from driveline "binding" due to a quick and tight VC coupling coefficient as I enter a tight turn, even an accelerating tight turn, on a slightly slippery surface.
That's nice...
I have flown Cessna 337s, that's the in line thrust push-me-pull-ya Cessna that has a rear engine and prop and a front engine and prop. Not only could I not ever get a "feel" for which engine might be pushing or pulling but the airplane had a serious flaw in the early days because pilots could not readily tell, sense, that the rear engine was not even turning. Later models had a torque sensor at the rear and a light on the instrument panel to indicate to the pilot that the rear engine was not operational.
But I admit readily that I might be unique in that I could not sense, as you seemingly can, if the vehicle, or airplane, is being pushed or pulled, regardless of attitude, turning, climbing, whatever.
But even more interestingly, it turns out that the GMC Denali, like the 2008 AWD RX300, has a full-time AWD system which consists of a simple open center differential and a TC, Traction Control system that is used to implement a "virtual" center LSD.
So maybe you don't have the "seat-of-the-pants" sensor feel of pushing and pulling of the Denali that you thought you had/have, maybe it was your imagination, and a bit of wishful thinking, all along.
I think that is unwise! You would normally be decelerating on an off ramp. An on ramp is the place to accelerate. :P
The OP referred to an "off-on ramp" so he has himself covered so we should probably take care to quote people accurately.
But seriously, I'm not sure there would be any detectable or discernable difference between a push and a pull. I'm just wondering whether a curve or change in elevation on the ramp may be misinterpreted as a push-pull effect.
SUVs and Smart Shopper
I believe this to be a "seat of the pants" difference that anyone would notice coming from a rwd vehicle to an awd vehicle that has a dedicated minimum power distribution from front to rear. The only way to have such a dedicated power distribution is to have some type of mech ctr LSD that can be setup to share power continuously between the front and rear drive wheels. The Sequoia uses a Torsen ctr LSD and the GMC Denali uses viscous ctr LSD.
The Sequoia has a minimum power distribution of 30Fr/70Rr when operated in 4wd Hi with the Torsen ctr LSD unlocked. There is no question of a difference in handling in a curve when operating the Sequoia in 4wd (AWD) vs 2wd. Others might describe the feeling differently but the best way for me to describe it is to refer to the sense of the vehicle "pulling" itself as well as "pushing" through the curve. Perhaps professional drives use more accurate terms but even the most novice of drivers would notice the handling difference when a Sequoia is operated in 4WD Hi (AWD) vs 2wd.
For those that have never driven an awd vehicle, you really don't know what you're missing. Check it out by test driving a real awd. IMO if a vehicle is marketed as awd but doesn't have a dedicated minimum power to both ends of the vehicle, it doesn't really have awd. Since the only way to have awd with dedicated power to both ends is to have a mech ctr LSD, all vehicles with an open ctr differential (regardless of their use of brakes to transfer torque) are lesser in their handling and traction abilities.
I do not believe this is true. Its not just a matter of slippage to change the torque distribution but load as well. Going through a turn will "unload" the weight on a particular corner of a vehicle and change the available traction on thate unsprung wheel vs the loaded wheel ina curve. That is one of the reason the better cars have a LSD to start with.
"But no, my stated position is that I DO NOT believe ANY RX350 has a VC involved with the operation of the center open diff'l, including the 2008 model. And for that matter not even the new 2009 model. "
There's really not much that can be said when someone has blinders on and refuses to believe the hard evidence from the actually manufacturer claiming that the 08 RX350 has a viscous ctr LSD. I suppose I should use my garden hose to fill my car's gas take because I believe it should run on water even though the manufacturer says to use gas. Can't help you with your refusal to believe the manufacturer's posted information in publications and their own website and press releases.
"Frankly, I do not, cannot, believe that any Full-Time AWD system can be constructed using a center diff'l VC technique and have coupling coefficient responses on the order of anything less than multiples of seconds. And frankly, what is, where is the NEED..??"
Once again, given your inability to believe any reputable resources that might suggest your view is incorrect, its not worth trying to prove that a viscous LSD transfers torque nearly instantly (which it does).
"Think of the hazard that might result from driveline "binding" due to a quick and tight VC coupling coefficient as I enter a tight turn, even an accelerating tight turn, on a slightly slippery surface."
That's why its called an LSD. Both Torsen and a viscous LSD do not "lock" and therefore cannot bind since they do not transfer all available torque from one side to the other. That's why they are able to operate in dry conditions where a PT 4wd system cannot.
So maybe you don't have the "seat-of-the-pants" sensor feel of pushing and pulling of the Denali that you thought you had/have, maybe it was your imagination, and a bit of wishful thinking, all along. "
The only flying by the "seat of the pants" appears to be in the claims you make. You really don't appear to like facts.... do you?
The 08 Lexus RX350 clearly has a viscous center LSD as described in technical detail in the many sources I shared earlier including the Lexus website and formal launch press releases. But hey...you seem to want to be a disbeliever in the facts.
Here's another fact for you to disbelieve. The 2001 GMC Denali XL has an AWD drivetrain that uses a viscous center LSD that has a minimum power distribution of 38Fr/62Rr and can transfer power upto a 50/50 distribution as needed. The Denali XL also has a mechanical auto-locking rear differential to ensure maximum torque is distributed across the rear wheels to the tire with the greatest traction. http://www.edmunds.com/used/2001/gmc/yukonxl/100001202/standard.htm
IMO, for on-road use, this is the absolutely best available drivetrain design for maximizing traction at all 4 corners of a vehicle. The new Sequoia gets a close second place and would have been even better had Toyota elected to include a locking or mech LSD for the rear to go with the center Torsen LSD.
GMC denali AWD viscous
Indicated the Denali's, Envoy, SUV, PU, had a VC type center LSD, dealers, automotive publications, ALL.
Then I dropped "viscous" from the search and discovered that there is NO official GMC site that even mentions the word viscous with regards to the Denalis' AWD system. Instead some of them, GMC itself especially, go into great detail in describing how the traction control system is used to allocate, apportion, engine torque in accordance with traction at individual corners.
Professional drivers....
About two years ago now I had the opportunity to drive my '01 911/996 C4 on the track at SIR, now known as PIR, Pacific International Raceway. The C4 uses a VC mounted in series with the driveline to the front wheel to allocate up to 45% of the engine torque to the front with a sustained period, even discontinuous, of wheelspin/slip.
Instead of driving myself I opted to be a passenger while the "track master", Don Kitch, drove my 911. During the initial two loops around the track at what I considered sub-standard speeds, not pushing it, I begin to think Don was being overly considered of my "nerves". Then I noticed, a couple of times, a slight look of confusion on Don's face. After the second loop I pointed out that my 911 was AWD and believe me, the following loops around the course had a completely different "tenor"(??)
When we finally parked the 911 you could smell the brakes still "cooking" from at least 100 yards away. I subsequently had the opportunity to drive my C4 on the track at Daytona. But with no previous experience one way or another with AWD all I can tell you is that the drive was a complete and total THRILL and if the front wheels were ever really "pulling" me through the turns I couldn't tell.
Don's C.V. can be found at teamseattle.com
hdfatboy:
But the bottom line is that your apparent lack of understanding of my use of "seat-of-the-pants" sensor, and a few other matters, indicates quite strongly that we are holding this dissertation on two different, ENTIRELY different, levels, so I leave it to you alone to continue this particular RX350/Denali AWD discussion.
Go for it...!!
It has not been that many years ago that the general public began to wise up to the fact that the only advantages of FWD were on the side of the manufacturers, costs. As a result while some manufacturers decided to abandon the FWD venue entirely, Cadillac, many others stuck a compromise and found an easy and inexpensive way to re label these patently unsafe FWD vehicles as FWD.
So far the public, in general, seems to be none the wiser.
Not speaking directly about Audi, but many of these, say the Lexus RX series, along with their brotheren (sisters??), the Highlander and Sienna, are AWD in name only, only for purposes of marketing to a general public that has not yet fully "wised up" to the industry's deceptive marketing practices.
If you want, and/or need, a fully functional, TRUE, AWD vehicle, a truly SAFE AWD vehicle, then look for one that "boosts" of rear torque biasing in normal operating mode. For many years I was perfectly satisfied to accomplish my need for adverse traction, "AWD" with the part-time models, 4WD/4X4 Jeeps. But since there is no real detriment today to having a full-time AWD system, a TRUE and SAFE AWD system, I opted to move on.
I agree with you that most AWD vehicles (although defintely not all) are using awd as a marketing tool versus an engineering advantage. Most lower end unibody awd vehicles are conversions from fwd and have an open ctr diff. In my opinion these vehicles are not really awd. I would classify these vehicles as fwd vehicle with a TC system that transfers some torque to the rear wheels but only after the front wheels slip.
I disagree that most awd vehicles are derived from fwd vehicles. The better vehicles are actually rwd vehicles with awd added. This is true for Porsche and many other higher end vehicles
Real AWD (IMO) is a vehicle with a torque bias to the rear and a minimum % of torque to the front wheels at all times with an lsd in between. The only way these vehicles can have power to all 4 wheels all the time is to have a mech ctr lsd. Vehicles that generally meet this standard are Subaru, Audi and GM vehicles labeled as AWD, although there may be other specific models by other manufacturers.
Many of the newer awd vehicles have used the credibility of these awd manufacturers to call their vehicles awd while really only offering fwd (or rwd) with limited or no power going to the other end unless there's slippage. The result is a less then capable (but less expensive to make) awd vehicle than one that has a mech LSD in the ctr and the rear.
I think it was you in fact that shared an excellent video which demonstrates the real world outcome difference between awd vehicles with a mech LSD vs an open ctr diff that tries to distribute torque through engine management and wheel braking. An open system that only distrubutes torque through brakemanagement is clearly not as effective as a system that combines these electronic approaches with mech lsds in the drivetrain.
http://youtube.com/watch?v=t09ExAUgtyE&feature=related
It's been a really long time since I've driven a rwd vehicle. I do remember that 4wd and rwd do feel different so we would only differ in the words we would use to describe it.
IMMHO the problem arises mostly with front torque biased AWD systems, or even AWD systems that are really only FWD with maybe a modicum of rear drive torque ability.
Think about it, do you really want a high level of engine drive torque on those front wheels when they are already "loaded up" with lateral forces..?? Accelerating into a turn with the surface adhesion questionable..?? Or even a low level of engine torque, leading OR lagging(engine compression braking) on a slippery roadbed...?
NOT...!!
Basically that's why TC is so very quick acting on modern day FWD vehicles. It can grow quickly dangerous with torque driven wheelspin/slip on a FWD or F/AWD due to the fact that with the onset of wheelspin/slip also comes the fact that the driver has now also lost all directional control of the vehicle.
Toyota and Lexus have just recently announced a new TC feature for their R/AWD vehicles that points this out. The Toyota and Lexus R/AWD, rear torque biased AWD, vehicles now come with a TC "sub-mode". When the driver switches into the new sub-mode of TC an extended period of wheelspin/slip with virtual LSD functionality still fully active, will be allowed without engine dethrottling. The only detriment to this new feature, technique, might be brake rotor overheating and subsequent warping. The upper limit of this new operational mode might be the shutoff of the ABS' fractional HP pumpmotor due to the potential for it to overheat and fail if allowed, required to operate continuously for more than a minute or so.
I haven't yet seen any indication that this new TC sub-mode will be made available on any Toyota or Lexus FWD or F/AWD vehicle. It's likely that the resulting liability would simply be too great.
Oh, my 1994 AWD Ford Aerostar has normal operational torque distribution of 30/70 F/R and then switches to 50/50 with detection of disparate F/R driveline rotational rates. I'm pretty sure this is accomplished by having slightly different F/R drive ratios in the 30/70 mode, the rear driveline is lower "geared".
A good analogy is to think about how the open diff'l of a RWD vehicle would work, operate, with one tire's circumference being smaller than it's opposite. Which tire would bring the most "rubber to the road"..??
Fair enough...I'm not sure what the right words are for describing the difference between how an awd vehicle with "forced" torque distribution (35/65 for example) feels in a curve vs how a rwd vehicle feels but its definitely noticeable and gives the driver a greater sense of confidence in the vehicle's handling.
I described it as a sense of "pulling" + "pushing" through the curve, but I'm sure there are better terms. In any case, its a desirable feeling of control that is greater in a "real " awd vehicle vs a rwd or open ctr diff 4wd vehicle. For those that haven't experienced it, its worth the test drive in a Subaru, Quattro or GM AWD to feel the difference. You won't want to go back to a non-awd vehicle after experiencing it.
In fact, I think given my driving experience in the AWD Denali, I probably would not have settled for the Sequoia if it had not been designed with a Torsen LSD for operation when in 4wd hi.
I absolutely agree. I just don't think its a replacement for a mech LSD and its a definite advantage to have it in addition to a mech LSD. Order of on-road benefit to the driver from lowest to highest for maximum traction with mid to high engine power:
fwd
rwd
rwd + rear e-lsd (open rear diff)
rwd + rear mech lsd
awd front bias + e-lsd (open ctr and rear diff)
awd rear bias + e-lsd (open ctr and rear diff)
awd forced minimum torque 35/65 + mech ctr lsd (open rear diff) + e-lsd
awd forced minimum torque 35/65 + mech ctr lsd + mech lsd or locking rear diff. +e-lsd
The Sequoia's H4F mode, High Speed/ 4WD / "Free" (Diff'l NOT locked), can be used Full-time, regardless of road conditions, and the center LSD function (AWD functionality) is accomplished via TC, Traction Control braking.
The center diff'l used in H4F mode is a standard, simple, open type wherein engine torque distribution, absent other means/methods, will ALWAYS be 50/50 as long as the loading of both front and rear drivelines are roughly equal.
The TC firmware is specifically designed to take into account the relative slight front/rear driveline rotational difference due to turning and accordingly will not activate braking for torque apportioning, even with an extremely tight turning radius (probably uses the VSC's stearing wheel rotational position sensor as input for this control.).
In H4L and L4L modes the center diff'l is locked and therefore these modes should NEVER be used for a prolonged period on a predominantly high traction surface.
08 Sequoia Launch Press Release quote "On four-wheel-drive models, a two-speed transfer case that contains a lockable Torsen limited-slip differential is used to transmit power to both the front and rear wheels." http://pressroom.toyota.com/Releases/View?id=TYT2007110908452
08 LC Launch Press Release quote "The Land Cruiser is the first Toyota vehicle to use a newly-developed JF2A transfer case to provide full-time four-wheel drive. This lightweight, compact, chain-driven unit offers a standard 1:1 high ratio for highway travel and a low-range 2.618:1 ratio for traversing challenging driving surfaces. The transfer case employs a Torsen limited-slip locking center differential. The locking function is actuated by a push-button switch. High and low ranges are selected with a rotary dial, located next to the HVAC and audio control panels. Indicator lights in the right-hand combination meter on the Land Cruiser's dash panel indicate when low range and/or center lock is selected." My note: the LC was first because it was launched 1 month before the LX and 2 months before the Sequoia. http://pressroom.toyota.com/Releases/View?id=TYT2007091764006
08 LX570 Toyota Launch Press Release Quote "A TORSEN® limited-slip locking center differential distributes the power 40:60 front-to-rear, directing more power to the wheels with the best grip should slippage occur." http://pressroom.toyota.com/Releases/View?id=TYT2007121777191
My guess is that the Toyota technical site you are checking is just out-of-date by 6-9 months. Check the ctr diffs for the LC and LX. If the site is wrong about the RX, Sequoia, LC & LX I think you would have to agree that its not a reliable source of technical data on very recently launched products with substantial engineering changes such as those on the RX, Sequoia, LC & LX (at least when considering drivetrain changes).
I will agree with that!
I have a subscription, and it clearly states the RX300 came out in 99 with a VC in the center differential. It was redesigned in 04, and the VC was taken out of the center diff., it was an open bevel gear design with a 50/50 split and TRAC to take care of slip. The RX350 was redesigned for 07 and the VC is now back in the center diff. It handles front to back and TRAC handles side to side. The Highlander has followed that pattern until it's redesign for 08, the VC is not back, it uses the same transfer unit as it did in 04 with an open center diff. I am puzzled as to why, because the V6 engine is the same, and the transmission is also the same. I believe the VC makes it a better AWD vehicle, by always keeping power to both axles, whereas the open center with just TRAC, can brake both wheels on one axle, hurting forward motion especially on inclines.
As for the Sequoia, Wwest is reading the details from 2001 when it came out. In 2005 it got the same transfer case as the 2003 - current V6 4Runner which has a torsen center diff. 40/60 split normal, Up to 53/47 on rear wheel slip, and 29/71 on front wheel slip.
Now as for your comment on the Denali being the best, and the Sequoia being second I have to disagree. A torsen diff is proactive, and a VC is reactive as far detecting wheel slip. Which means the torsen is better. The Sequoia has ATRAC, and the Denali has an automatic locking rear diff., and TRAC. The locking rear diff only works until 20 mph, and then it is all up to TRAC. The Denali has NO locking center diff, and no low range. The Sequoia has both, along with one of the best Traction Control systems, in line with Land Rover and Mercedes, the Denali couldn't keep up with the Sequoia's 4WD abilities ever. You keep knocking Toyota and their AWD and 4WD systems, are you forgetting the Land Cruiser? I think Toyota knows a little bit about AWD and 4WD.
Last, as for the Subaru comparison, the Highlander has a Bevel gear center diff, which unlike a planetary center, can only split power 50/50, so when the front wheels started to spin TRAC should have braked them and power would have went to the rear. They definitely shut off TRAC when doing that test. Now when on the rollers, the open center sent all power to the front and TRAC was off and couldn't step in. TRAC just doesn't allow all that wheel spin.
4wd
So the information I "quoted", found, at techinfo.toyota.com is for the 2008 Sequoia.
2toyotas,
Go back to the site and search the entire document set for MF2AV for the 2007, '08, and '09 RX350. Then search for MF2A and look at all the hits you get for all years of the RX350.
For the 2007 introduction year of the RX350 there is documentation indicating that the VC has been re-adopted, changed from the MF2A in the RX330 to the MF2AV, VC "transfer" model for the RX350. When detailed pictorials of both transfers. The pictorial for the MF2AV is an exact replication of the transfer in the original RX300.
And it isn't just the above. If you read Lexus description of the TC functionality it clearly flys in the face of also having a VC.
Now I have no idea why GMC would mislead their dealers with regard to the center diff'l of the Denalis, or by default allow them to mislead the public, But it has become pretty clear to me that the direct GMC statements on the matter indicate that the denali series has a simple open center diff'l and uses TC for both LSD and AWD functionality.
Then there is Lexus. In their case it is clear that Lexus itself is involved in misleading the public, Intentionally or accidentally, who knows at this point. Or maybe they're just being liberal with terms. If they stated that TC was being used to provide the functionality of a VC, quicker responding functionality, that would be much more acceptable in my mind.
If the RX series were rear torque biased I would totally agree.
In 2000 the FWD version of the RX300 had Trac, Traction Control, but the AWD version did not. In 2001 the AWD RX300 become equipped with both traction control and VSC. As I have stated before, the RX series is quite heavily front torque biased, ~95/5 F/R and as high as 75/25 F/R once the VC is given time to "stiffen". I don't really have any idea how the biasing is accomplished. I first verified the front biasing for myself, to my own satisfaction, using shade tree mechanic techniques. But so many posters expressed doubt that I had my testing verified on a 4 wheel dyno. The figures above come from that test.
The fact that the AWD RX series is so heavily front torque biased forced Lexus, for safety reasons, to adopt Trac in the same way, for the same reasons, as existed on the FWD RX's.
With such severe front torque biasing initial wheelspin/slip due to drive torque will normally develop at the front wheels FIRST. As we all already know, if wheelspin/slip at the front "stearing" wheels cannot be quickly abated, alleviated, loss of directional control quickly becomes a distinct threat. Since the VC is reactive, only responds AFTER a sustained period of F/R driveline rotation differences, VC CANNOT be depended on to provide this functionality.
So, in effect, the AWD RX is really mostly FWD. So just as they did with the actual FWD for SAFETY reasons, Lexus is forced to adopt Trac for AWD and rear LSD fucntionality, engine dethrottling included.
Side note: Keep in mind that the above is NOT a problem with R/AWD since it is the rear wheels that will normally develop spin/slip initially and that does not represent a direct threat to directional control. So the use of a VC to implement a center LSD is perfectly acceptable for R/AWD vehicles.
So, as of 2001 Toyota/Lexus had themselves a real connubdrum, what was the VC to be used for, of what purpose did it now serve.
NONE....!!
Toyota, in fact, had no problem, no equal problem anyway. Neither the AWD Highlander nor the AWD Sienna had ever been advertised as having a VC. So those vehicles had a virtual duplicate of the RX's F/AWD system, but no VC, EVER.
As the introduction of the RX330 approached, with the engineers having REMOVED the now uselss and otherwise non-functional VC, I can almost visualize the (heads down) non-argument amongst Lexus's japanese upper management personel.
So, when the RX330 came to market without the VC, the marketing literature said otherwise. Now, big surprise, here we are again.
Let me clarify. I'm not knocking Toyota's 4wd drivetrain. In fact I just bought a new Sequoia with the new drivetrain as one of the features that made it attractive. That does not mean I view the Sequoia Drivetrain as the best on the market for primary on-road conditions and light duty off-roading. I do feel the Denali has a superior drietrain when operating on-road in 4wd (which of course is the only operating mode for the Denali.) The Sequoia has the significant advantage in that it has more flexibilitywith various other modes for different conditions.
I also agree with you that a mechanical clutch type differential is superior to a viscous LSD. I think the GM engineers also agree with you because as I stated earlier, the Denali transitioned to a clutch type ctr differential in 2004 (I believe). The Denali had the viscous Ctr LSD from 2001 until they changed over. They've had a mechanical rear LSD or locking diff all along. They also now have much of the same stability software used by most SUV manufacturers to use the ABS brakes in reverse to make suvs more stable (GM's is called Stabilitrak). Alot of this stablility software was added as a result of the gov. applying rollover ratings to suvs.
Since the COG of these vehicles wasn't likely to be lowered much (although ground clearances are definitely lower than they were a decade ago with the Sequoia being one of the highest in the industry at 10"), many manufacturers looked to the software engineers to see if the braking system and engine management computer could be used to keep drivers out of rollover situations..... ie VSC, e-LSD, Stabilitrak and a half dozen other aphabet soup names for this software.
Does it help traction...yes to a point ...but then instead of improving torque transfer, it moves into "nanny" mode to keep the driver out of a bad situation. My only point is that by placing mech LSDs into the drivetrain (in addition to the software which almost all suvs manufacturers are now using), a vehicle can be designed to have better traction before the "nanny controls" take over.
Open diffs are likely to have the nanny controls take over sooner which can be a PIA to the driver. I believe that's one of the reasons that Toyota included a Torsen ctr diff to the Sequoia, LC & LX. With the 401 ft lbs torque in the new 5.7 combined with open diffs, you'd have had a recipe for the nanny controls kicking in nearly everytime the driver hit the throttle hard.
My only knock on Toyota is that with all the available power of the 5.7, they could have put more of it on the road with a mech LSD in the rear than giving it up to the "nanny controls". Which explains why the Sequoia has its best 0-60 times when all the controls are turned off and the vehicle is operated in 4wd hi mode. My guess is that if the Sequoia had a mech rear LSD its fastest 0-60 time would have been in 2wd with all the controls turned off.
I'm not saying that 0-60 time is the best measure of performance for an suv but simply to demostrate the advanatges of mech LSDs with electronics versus open diffs with engine management and brake application to control wheel slippage.
I have no facts to backup the following guess on why the RX would have the viscous ctr LSD and the Highlander wouldn't...for what its worth.
The RX is made in the US. The manufacturing costs are measured in $s. The Highlander is made in Japan. The manufacturing costs are measured in Yen. Toyota is probably losing their shirt on the vehicles made in Japan and sold in the US due to the $ - Yen exchange rate. Keeping costs as low as possible on the Highlander given the current economic cycle is key to profitability.
The RX OTOH has more room to work with and a higher end image to maintain. Maintaining or improving the RX drivetrain is "cost effective" because its made in the US.
Just one opinion on why the RX might have a better drivetrain than the Highlander.
The 08 RX AWD is not fwd biased...at least not as Toyota describes it or promotes it. In fact Toyota describes the Torque distrbution in the 08 RX AWD as split 50/50 until wheel slippage occurs
"The all-wheel drive RX 350 uses a viscous limited-slip center differential to enhance drivability in all types of driving conditions. The full-time AWD system works with TRAC to evenly distribute power to both axles with a constant 50/50 front-to-rear power split. If slippage occurs, the viscous coupling differential directs torque to the wheels with the most traction."
BTW here's the Toyota official Product features sheet for the 08 RX 350. You'll note it states " Center Differential (AWD)....Viscous coupling type limited slip differential"
http://pressroom.toyota.com/presstxt/2008lexuskit/2008RX350_sf.pdf
I thought you all might find this quote from the "Lexus Technology round-up" of interest. You'll note that it specifically references the torque transfer advantages of a mech LSD over "speed-sensing" e-LSDs (I interpret that to be electronic or "virtual" LSDs). This is exactly what I have been saying all along...that mech LSDs are superior in torque transfer over any type of software approach, as evidenced by their statement below about the LS600h Torsen ctr differential.
"All-Wheel-Drive Passenger Cars
The 2008 GS 350 and IS 250 models offer all-wheel-drive as an option. A planetary-gear center differential and a wet-type multi-disc clutch control power distribution. The system normally sends 70 percent of the power to the rear wheels to provide the traditional performance advantages of a rear-drive vehicle, but it will vary the torque split ratio from 30:70 to 50:50 in response to driving conditions and driver input. The system's electronic control strategy takes inputs from steering and throttle angle, combined with vehicle signals from wheel speed and yaw rate sensors.
Power in the all-new LS 600h L flagship model is distributed by a newly developed full-time AWD system that delivers secure handling and traction in various driving and road conditions. A Torsen® planetary gear-type limited-slip differential (LSD) distributes torque 40:60 under most straight-line driving situations. The compact new Torsen® differential is 30 percent smaller and 11 lb lighter than previous Torsen® systems.
Unlike speed-sensing LSDs used in some AWD vehicles, the TORSEN unit in the LS 600h L L is a full-time torque sensing, torque biasing system. Torque and differentiation are continuously managed between the front and rear wheels and biased instantaneously according to varying road conditions. As a result, power is automatically shifted to the wheel or wheels with the most traction even before wheel slip can"
http://pressroom.toyota.com/Releases/View?id=TYT2007082869358
Anyone buying a FWD or F/AWD vehicle, especially an SUV, very likely isn't wise enough, hasn't bothered to do enough research to fully understand just what capabilities, poor safety factors, are being purchased.
So why shouldn't the manufacturers take advantage of this customer "class", haven't they been doing exactly that for YEARS..??
Buyer Beware...!!
Why would any manufacturer put a Torsen, Torque Sensing Differential, in what is basically a FWD vehicle to begin with??
No, these customers are much better served via the use of TC for implementing AWD and rear LSD functionality. Absent the quick dethrottling of FWD and F/AWD modern day vehicles our insurance rates would likely be extraordinary.
Oh, is there any such thing as a rear locking diff'l for this market segment. Drag racing or maybe other racing venues of maybe even serious off-road, but road going.
NOT...!!!
And anyone who believes the RX330 or RX350 F/AWD drive systems differ in any way other than firmware with those in teh Highlander and Sienna should go to the dealer's parts department and buy a spare VC "canister" immediately as I understand they are scarce as hen's teeth.
Otherwise when yours fail Lexus will be scouring the earth trying to find a replacement.
2.Traction Control Operation
The traction control system controls the engine torque, the hydraulic pressure of the driving wheel cylinders, slipping of the wheels which may occur at start or acceleration of the vehicle, to ensure an optimal driving power and vehicle stability corresponding to the road conditions.
Anyone knowing, understanding, the operation of a viscous clutch or coupling would immediately see the conflict in the above operation of the RX350's Traction Control system were it to have a VC as described. Were the RX350 to actually have a VC mounted "across" the otherwise fully open center diff'l (as was the VC in the RX300) it could NEVER be functional given the apparently INSTANT intervention of TC (as SAFE operation of any FWD or F/awd REQUIRES) at any initial detection of wheelspin/slip due to engine torque.
Now, when I purchased the 2000 AWD RX300, and then subsequently the 2001 AWD RX300 in order to get HID & VSC. Actually having read the 2001's shop/repair manual prior to purchase I was fairly certain TC was to be used to implement AWD and rear LSD, and quite possibly front LSD.
At the time the Lexus sales persons seemed to be well aware that these RX300s were heavily front biased, and often touted same thinking it was an asset, a good sales point.
With regards to the validity, trustworthiness, and truthfulness, of the documentation found at techinfo.toyota.com.
I have the COMPLETE hardcopy versions of the shop/repair manuals for the '00 RX300, the '01 RX300, the 90, 91, & 92 LS400, the 2003 Prius, the RX400h, and the 05 RX330. These are the exact same manuals you will find at any Toyota or Lexus dealer for reference use of the shop technicians/mechanics.
To my knowledge and experience the documentation at techinfo,toyota.com is exacting in replication of the actual hardcopy manuals. So, who, which do I trust to me the more truthful, Toyota/Lexus Press Releases or these documents.
THE DOCUMENTS.
4WD SYSTEM
DESCRIPTION
* The 4WD model of the '04 RX330 has adopted a full-time system that constantly distributes torque at a ratio of 50:50 to the front and rear axles.
* This system, which has adopted front and center differentials with bevel gears, employs TRAC control in order to ensure the proper drive when a wheel slips, with the use of an LSD (Limited Slip Differential) mechanism in the center differential. Thus, a lightweight system that offers high levels of driving stability and drivability. has been realized.
I think the above is where the Lexus dealer sales persons got the idea that the RX330 had 50/50 F/R torque distribution vs 70/30 F/R for the RX300 series. In thoroughly reviewing all of the pertinent documentation for the center & front diff'l and the "transfer" across the RX300 product series vs the RX300 there is NO different other than the VC is not used in the RX330 transfer.
And I certainly do not disagree that a simple open diff'l, as seems to be used throughout the years, all RX F/AWD models, will ALWAYS distribute torque equally to the two output drives just as long as both represent roughly the same level of torque loading, Large or small.
I have no idea how the 95/5 F/R rear biasing ratio is accomplished other than the possibility of differing final drive ratios for the front axle vs the rear as is done on teh Honda/Acura SH-AWD system. On the SH-AWD system the rear driveline is overdriven (13%?/) (analogy: rear in 3rd gear vs 2nd in front). Until the rear left and right clutches are engaged the rear is just free-wheeling, with them engaged at a moderate level the SH-AWD system most definitely goes into rear torque biasing.
If the RX's rear driveline is overdriven vs teh front then the front will receive the majority of the engine torque absent VC stiffening ('99-'00), or ('01-XX) if TC activates to prevent front wheelspin/slip.
Oh, it appears that in order to prevent a severe level of torque stear with only left or right TC activation due to front wheelspin/slip BOTH front brakes are activated.
No input is needed/required if you believe the torque biasing is 50/50, we already understand the reasons for your position, understanding.
And what would you say are the "reasons for my position"? Seems like you are really struggling with Toyota, not me. I don't have a position. To be honest, I really don't care whether a Highlander or RX, does or doesn't have a viscous ctr LSD. I have no interest in either of these vehicles from a personal perspective.
I'm simply sharing the readily accessible information that Toyota makes available to the public. The readers can decide for themselves based on the sources I shared as to whether Toyota's formal press releases and product information brochures are more or less accurate than the source of the information you're basing your view on.... that's not available to the public (without a fee).
For my money, I would go with the publicly available information from Toyota because I am very confident that these documents (particularly press releases) go through an extensive copy control process and legal review to avoid lawsuits. I also think that the tech files are likely to be somewhat behind the launch of a new product as all these vehicles are.
If you're frustrated, and it sounds like you are, its not with me. It must be with Toyota. You seem to keep referring back to documents that concern 7 & 8 year old Toyota vehicles. All of my posts have been about 2008 Toyota and Lexus vehicles.
Based on the information from Toyota's own publicly accessible website here's the facts as I read them. These facts apply to 2008 vehicles and 2008 only (although they may also be true for previous model years as well).
08 RX AWD has a mechanical viscous center LSD combined with TRAC that delivers 50/50 fr/rr torque distribution that moves torque from this starting point to wheels with greater traction as needed.
08 Sequoia, Land Cruiser and LX570 have a mechanical Torsen LSD differential that maintains a minimum of 40fr/60rr torque distribution until slippage occurs at which point power can be moved from the rear wheels to the front "instantaneously" (Toyota's words, not mine). Each of these vehicles also has a mechanically open rear differential.
Toyota engineers view a mechanical Torsen LSD as superior to a "speed sensing" LSD (ie. e-LSD using electronic engine and brake management to simulate a mechanical LSD).
These are simply statements of fact from Toyota's own publicly available and highly promoted documents (since much of the same information is in the promotional brochures for these vehicles). To the extent you disagree with these facts you're not disagreeing with me.... but with Toyota.
I'm not aware of any manufacturer that has applied a Torsen mech LSD to an AWD drivetrain for a vehicle that would otherwise have been a FWD vehicle. What manufacturer and vehicle are you talking about?
"Oh, is there any such thing as a rear locking diff'l for this market segment. Drag racing or maybe other racing venues of maybe even serious off-road, but road going."
What "segment" are you talking about? SUVs in general? Many of the GM full-size suvs have locking rear differentials standard (including the new Hybrid Tahoe) or offer them as an optional upgrade. If you're talking about smaller suvs, then the Porsche Cayenne is worth noting since it has a auto-locking rear differential.
If you're referring to lower and mid-level SUVs (both size and cost) I'm not aware of any suvs that would have a locking rear differential since they aren't likely to have the power and torque to need or benefit from such a differential.
That is the SOLE and ONLY reference made to either viscous or MF2AV throughout the ENTIRE documentation set for the 2007, 2008, and 2009 model years of the RX350.
On the other hand, when I searched for MF2A in the RX350 files for all of these model years, '07, '08, and '09, I had "hits" throughout the documentation sets indicating the continued use of the RX330's MF2A transfer, non-VC transfer system.
And if you were Lexus, which group would you wish(***1) to "fool", the mechanics and technicians who are called upon to work on these vehicles on a daily basis, and more importantly understand, completely, the operational aspects of same.
Or customers, apparently like yourself, that unquestioningly, or even not knowing or even being interested otherwise, follow the marketing "line".
***1: Over-stepping on my part, at least I like to think so. Just as quite clearly happened during the marketing rollout of the RX330, someone, somehow, mistakenly conveyed the idea that the RX330 had a VC. That was subsequently corrected for the marketing material for the subsequent years of the RX330's market availability.
Methinks that somehow that same mistake was repeated for the marketing introduction of the RX350 and Japanese "culture" being what it is, no one is willing to step up and take on the responsibility for either admitting the mistake, nor correcting same. Everyone is in "heads down" mode.
The way the material reads, and marketing being what it is(***2), it even seems like there is a possibility that Lexus at one time during the design phase of the RX350 intended to put the VC into the RX350. But undoubtedly some bright young engineer later pointed out that all that would do is add weight and cost to the product since the way TC operated the VC would never be functional.
***2: Product marketing materials must be made available for distribution months before the products reach the dealer showrooms. Clearly, even just days prior to actual production began for the RX350, the initial decision to incorporate the Mf2AV in teh design could have been revised to the MF2A. Since both the Highlander and Sienna continue to use the MF2A inventoried parts availability would not have been an insurmountable issue.
"And if you were Lexus, which group would you wish(***1) to "fool", the mechanics and technicians who are called upon to work on these vehicles on a daily basis, and more importantly understand, completely, the operational aspects of same. "
I doubt that the website you're accessing is the only reference used by Lexus and Toyota mechanics for making repairs. IMO the site you're accessing is just another nice money making venture for Toyota to tap into a market of overly enthusiastic Toyota fans willing to pay $10/day to access a technical site that they probably only update a couple times a year at best. Do they even give you a "revision date" on the website your paying Toyota to access?
"Or customers, apparently like yourself, that unquestioningly, or even not knowing or even being interested otherwise, follow the marketing "line". "
My bet is that the information provided to the public is significantly more accurate then the website you're paying to access. Mechanics can't sue for false technical information. OTOH Consumers and State Attorney Generals are ALWAYS looking for a new deep pocket to go after. Whether its for personal wealth gain or media headlines, attorneys would chase a purposeful false advertising by a large corporation like Toyota like wolves chasing a lone sheep. A false claim on a high $ purchase like a vehicle would have either been addressed by an external attorney for a headline/$ or an internal attorney for a correction.
You aren't by chance one of those "conspiracy theory" guys that think the US landing on the moon was all a hoax by the gov. ...are you? Sounds to me like an attempt to justify all the money you've spent accessing the Toyota technical site (aka Toyota's little "moneymaker"...I think they probably refer to it internally as their "100% profit margin" product with next to no upkeep or capital cost:))
You aren't by chance...
No, but I am quite quite thoroughly convinced that just as Harrison Ford says, he could do a STELLAR job as US President vs the IDIOT we now have.
But I really do have to go now...
This discussion has now become totally useless, even bordering on the nonsensical.
You might want to have a more thorough looksee at the 2008 Sequoia "Vehicle Inquiry Report" you posted at Carspace.
It quite clearly states that your Sequoia has:
A-TRAC
Auto Lmtd Slip Diff,...
Yes, "Auto Lmtd Slip Diff" does leave the door open to the possibility of that being a Torsen diff'l. But certainly that wording is not explicit enough to refute the information I have access to indicating that in H4F mode it is a simple open diff'l using A-TRAC for torque distribution. And if you are in of the firm belief that a simple open diff'l results in 50/50 F/R rear torque distribution how do you get that your Sequoia is 40/60..??
Obviously in H4L or L4L there will be no "split" as the front and rear drivelines are mechanically "hard" coupled.
Since you seemingly put more faith in marketing materials than actual facts here's one that supports your description of the '08 Sequoia 4WD but then goes on to say that the '08 also includes A-TRAC.
http://www.jdpower.com/autos/articles/2008-Toyota-Sequoia-Preview
Toyota's own definition of A-TRAC, ACTIVE-TRAC:
http://www.toyota.com/help/glossary.html#a
The Traction Control documentation, A-TRAC, etc, at techinfo.toyota. com quite clearly indicates that in 2WD mode it is the front wheels that are being driven.
I have always assumed the Sequoia to be RWD in 2WD mode.
But.
Why not FWD..? (I guess)
What on earth on you talking about? I've never made a post in the "Vehicle Inquiry Report".
"It quite clearly states that your Sequoia has:
A-TRAC"
When did I ever say the Sequoia didn't have A-TRAC? It definitely has A-TRAC. As does the LC and LX570. A-TRAC is entirely compatibale and in fact functions better with a Torsen than with an open differential. A-TRAC is nothing more than the Toyota traction control software designed for 4wd vehicles. I'm familiar with the function as it's on my new Sequoia.
You seem to be somewhat confused on the difference between the purpose of Traction and stability control software in the 08 4wd SUVs (A-TRAC & VSC) and the purpose of a mechanical LSD such as a viscous unit or a Torsen unit. The software is entirely complimentary to a drivetrain with a mechanical LSD. Have you not read any of the earlier posts? Subaru, GM, Audi, Porsche all use mechanical LSD combined with stability and traction control software.
Toyota also includes mechanical ctr differentials on their 08 4wd 4Runner, 08 RX AWD, 08 4wd Sequoia, 08 4wd Land Cruiser, 08 LX570, 08 LS600h. Why would you think A-Trac couldn't be used with a mechanical LSD? Many manufacturers have combined the 2 technologies (Braking/engine management software + mech LSDs) for nearly a decade.
But.
Why not FWD..? (I guess)"
You're kidding ....right? I would definitely cease using the techinfo source as a reputable source if it shows the 2wd mode of a 4wd Sequoia operating as FWD.
For the record, the 08 Sequoia is undeniably a RWD vehicle when operating in 2wd mode (identical to the LC and LX). Even you couldn't possibly think the Sequoia is a fwd vehicle. Just look at the driveshaft in a 2wd model for crying out loud and the available tow rating.
If it were me, I would ask for my money back for accessing techinfo.toyota. You're definitely getting ripped off based on the very innacurate information you're posting.
Maybe just because I'm NOT an IDIOT...??
Certainly not on the scale of Shrub.
With a Torsen center diff'l, say 30/70 F/R what additional capabilities would be added by including A-Trac....??
And think back...
It was with the introduction of the RX330 in 2004 equipped with "A-Trac" that the realization came, finally, that the VC was now useless, just added weight and was therefore a needless expense.
And the last documenation I can find that indicates the 4runner, the LX470, and the Sequoia have, had, a Torsen center diff'l, just happens to be the 2003 model year.
Why continue to purchase Torsen Diff'ls from Zetel, or even pay them a license fee, once you come to the realization that A-Trac will do the job at an acceptable level for the public at large...?
And are you STILL of the mind that the GMC Denali series has a center mechainical LSD? You haven't had much to say on that front lately.
