Anyone out there that would not buy a Highlander again?
On a drive to Portland from Seattle Friday I got 22.7MPG averaging 67 MPH, trying to maintain 72MPH.
Some folks have complained that the RX' (HL?)engine revs too high at speed, 3000 RPM at 72MPH, but I don't personally see what difference that really makes. The Chrysler T&C 3.8L V6 revs 2250 at 72 and only gets about 20MPG.
number of problems. 2 of them I have seen here. The first is the
vibration behind the pass air bag. They replaced a clip which didn't
seem to help at all. Did anyone ever find a working fix for this?
Also, I have a wind noise that occurs when I am driving between 40
and 60 MPH and when there is a cross wind. At first they couldn't
reproduce it till I showed them the speed range. It can get loud.
They have removed the moonroof wind deflector, the roof rack, and the
hood wind deflector. It happens with windows up/down, moonroof
open/closed and they are trying to find a fix from their database. I
gave them the TSB posted here about the door seals but, they say it
doesn't apply to mine. It is a 2002 that I bought in mid June 02 and
it was shipped fresh from Japan. Does anyone have any suggestions?
Thank you, Bill
is now gone. It turned out it was the hood wind deflector after all.
They are refunding me for it. The Toyota deflector that was
installed with the vehicle seems to alter the air flow and caused the
noise. I'm glad it's over as it was getting to be too loud. I do
still get overall wind noise ( not whistling )but, that seems to be
inherent to this model.
2) The vibration behind the airbag that everyone seems to get is due
to a cable that bounces against the back of the air bag housing ( I
think that is what they said ). They now have a TSB for it and a kit
to fix it. I didn't get the paperwork yet so I don't have the number.
3) I still have something strange with the auto climate control. It
was 46 degrees out and the engine was warmed up. When I set to Auto
for heating, at a setting of 65 degrees, the fan speed goes to max.
As soon as I go one degree to 66, it drops to the lowest fan speed.
It doesn't go to 2 bars on the speed till I set to 71 degrees and
then 3 bars at 80+. They are going to test some others at the
dealership and figure out what is going on. Anyone else have this
problem?
4) I too have the low speed whistle from the right rear and gave them
the fix posted here. They are going to check on it.
Overall, I have benn very happy with the level of service and the
people at the dealership. It is Competition Toyota in Middle Island,
NY. I had no problem getting a lowner car and they stayed courteous
and friendly despite my constant calling for updates.
I would appreciate any comments on the climate control.
Thanks, Bill
They're also there to provide you with the most rapid cool-down, or warm-up modes. At any normal setting the system moderates the heating or cooling levels, not so hot as to "discomfort", etc.
"Could hear squealing noise from R.R. that sounds like dry rubber seal noise (sounded like fire truck siren in distance) - Removed rear calipers and rotors. ran vehicle on lift, noise appeared to come from inboard side of both wheel bearing/knuckle assemblies. R&R necessary parts to remove axles from hubs. Checked inboard seals, felt dry and sticky. Lubricated both seals with wheel bearing grease. Reinstall all and test - noise gone."
We are happy to report that all is well again and our HL does not sound like a 10 year old Ford any more !!!
Good luck all.
It occurs when the vehicle is parked, locked or unlocked. Never while it's running. Sometimes, I'll lock it, start to walk away, and hear it going down. Sometimes I'll come out from work and the window is down. Or in my garage. Sometimes it will be parked for hours before it occurs. It has nothing to do with the keyless remote. It has nothing to do with the cell phone.
Any suggestions?
But then a strange thing happened. A month or so ago I turned off the motor and pulled the key and, low-and-behold, the cabin light came on. This has happened again a couple of times since. I can't find a reference in the manual as to whether this should or shouldn't be happening, so my question is this: Is the light supposed to come on and mine only works once in every 400 attempts? Or is this not a feature and my wishing for it hard enough finally made it happen anyway? (in which case I'm going to start focussing on that Powerball jackpot).
Craig
Normally (in a 2002 model, anyway), when you unlock the driver's door with the key, the window will start to go down after a few seconds if you continue to hold the key in the unlock position.
Maybe whatever piece of magic silicon that causes that to happen is getting/giving false information.
Hope you find the problem.
The dealer SM looked at it twice and could not find the problem but we are printing this and hopefully he will look at all the rubber parts that could touch the axile.
At least we are not alone in this thing.
DEO
back to dealer who says nope, not us. that's an alarm company thing (they had third party install). off to alarm company they say nope, not us, that's a dealer thing.
and I of course am in the middle.
suggestions??
thanks.a
ront
It is a pretty freaky experience the first time it happens to you though, isn't it. Feels like the car is about to shake apart.
I HAVE DRIVEN SEVERAL 2002 HL W/6CYL. ENGINE AND I CAN DEFINITLY FEEL THE ENGINE RUNNING WHILE SITTING AT A LIGHT IN DRIVE WITH THE FOOT ON THE BRAKE, BUT THE ONE I OWN IS WITHOUT A DOUBT THE VERY WORST. sINCE BRAND NEW, IT HAS BEEN BACK TO THE DEALER FOR THIS SEVERAL TIMES, BUT THE DEALER SAYS ITS OK.
I CAN'T ACCEPT A $30k PLUS VEHICLE WHICH IS SO CRUDE, BUT UNLESS I WANT TO TRY AND LEMON LAW THE VEHICLE, THERE IS NO SOLUTION EVEN THOUGH TOYOTA MUST KNOW THEY ALL VIBRATE TO SOME DEGREE. ANYONE HAVE ANY THOUGHTS ON THIS PROBLEM. I SUSPECT A BAD MOTOR MOUNT(S). ANY TSB ON THIS??
If this is the case, and it's not hard to start all the time (like after it's warmed up), then possibly something in the cold-start portion of your fuel system, like a cold-start valve/injector.
Or, maybe something further downstream that feeds info to the control module, like a coolant temp sensor.
Cars were so much simpler in the old days...
Also, thumping sounds on bigger cracks/potholes; feels like the suspension's weak. Any suggestions would be highly appreciated.
I don't know how it was reset the first time but since then I've just been disconnecting the battery for a short period to turn off the light.
thanks.
ront
From what you're describing, I would say that almost definately you're describing the ABS engaging. Hope this helps.
Could it be possible that this is water (rain, carwash) that became trapped in the windshield trim, or cowl area, and is now ice pieces rattling around?
I realize I'm reaching here - but in the two posts, "cold" seems like the common denominator.
Turn the engine off.
Engage the parking brake.
Turn the engine on.
The DRL will not turn on again until you release the parking brake. Just remember to do so before getting under way.
Hope this helps.
I noticed there is a click sound from the
front and outside of the car when I just start the
car or make sharp turn or reverse.
The sound goes away when I drive faster than
40mph.
I know there are some posts regarding to the click
sound when the first time accelation.
But I also have the sound when making turns. The
dealer checked it about 2 hours and couldn't find out the reason. Anyone who have the same experience can help me out here? Many Thanks!
I can apply just a slight amount of pressure while driving and the rattles will stop. I'm thinking that maybe removing the trim and lining the back with a material much like is used to solve the glove box rattle. I just need to find a way to pop the trim off without damaging it. Anyone tried this??
Also, my co-worker has a HL and she has a rattle that we traced to the trim around the shifter housing. So, it seems like the trim pieces are a good place to start when attempting to find squeaks and rattles.
Anyone with a similar problem and a solution????
Door gaskets replaced under warranty. Corrected wind howl in head/cross winds.
1. The air bag warning lights goes on in the cold morning. It's happened twice so far and we don't know why. Both happened in the very cold morning and the Air bag warning light went on and flashed every 20 seconds but it went away when my wife started car again after work. Does anyone have this problem?
2. Fuel Injector "clicking" noise?
After a few months we owned the car, I noticed the "clicking" noise from the engine when the car is parked with the engine running. Brought the car back to the dealer and they told me that it's normal. They stated that all the Toyota engines with the same Fuel Injector System make this "clicking" noise. Does any of you hear this noise? Is it something minor and I shouldn't be worry about?
Thanks a million for your input!!!
