-June 2024 Special Lease Deals-
If you're stuck for coins then replace the brake pads, depress/apply the piston back and forth into the caliper several times, and wait and see if it sticks again.
But be sure to thoroughly clean and lubricate the caliper guides/slides/pins also.
If you have used a Bluetooth phone and have the NAV, would you please let me know if you too have people complaining about the connection or if it is working fine for you.
I need some ammo if I'm gonna insist that mine is defective and needs repair.
Thanks in advance.
Tires, another story. The OE tires suck!!! Even the tire guy at Sams wouldn't sell me a set he had in stock. Ordered a set of Michelin's (don't remember which ones), they have ~15K on them and look almost new. I rotate them twice a year (only drive ~8K/yr now that I'm retired.
I bought a Hyundai Azera 2008 w/25K miles just a month ago and wish I had bought another Highlander, but, didn't want 2 of them in the family just for the sake of not having 2 in the family
I love my Highlander and cannot convience my wife to give it back and her drive the Azera.
FWIW....
When it starts, use your fingers to lightly press on the plastic piece(s) on the rear of the steering wheel at the bottom. That is, on the bottom of the wheel, when the noise is happening, lightly pull the bottom of the wheel backing toward you.
Learning what made the noise was the hard part.
I plan on some little dabs of clear silicone at the edge of the wheel and the backing plate, maybe 4, and stuffiing some foam rubber between that backing plate and the steering column while the silicone cures.
Unless someone suggests a better idea.
Phil
Like the springs in the remote are too weak, they are set off by keys in your pocket
who is the next (old) Toyota? Honda? Ford?
The problem is not so much the brightness of teh bulbs as the density of the dark window tint. If you back up using the exterior mirrors, visibility is fine. Trying to do it through the rear window is not.
You cannot fault Toyota's R&D. They are, by a considerable margin, the world's largest R&D investor spending USD7.6bn last year.
Cheers
Graham
I usually use my side view mirrors because I'm old, stiff, and cannot twist arouond enough to look out of my back glass....... ain't that a pisser?!
So what are parking lights? At one time many cities had laws that if you parked on the street you had to turn on your "parking lights". I see many driving around in fog and just before sunset with parking lights on thinking that they are for driving in dim light.
I agree with the others who complain that backing at night in unlit areas is a pain because of the tinted rear windows. If someone knows of a brighter bulb that won't overwhelm the wiring, please post the information.
I agree that it is a minor flaw.
My independent mechanic told us the rears are not working at all. Full service (pad and rotor replacement) was done less than two years ago at this dealership (April 2008) and we paid ~$600 for it. I just came back from there and Toyota's service rep said the brakes are working fine (then why are the rotors all rusted out?) but he slipped by saying that the rotors look original until I told him to check service history and then after looking at the vehicle in the back, he confirmed that these are the parts they did indeed install two years ago and everything is perfect now. WTH??? I told him we're going to check part numbers and production dates, so he'd better watch out but he calmly stuck to his guns... Is there a way for anyone to tell if these rotors are from 2001 or 2008? Please help!
But.
Drive just a few miles using the brakes fairly often and the pads should quickly polish the rust away within the scrub area.
With most vehicles you might drive with the rear brakes fully non functional for days or even weeks and not notice. Normally the front brakes contribute 70-80% of the braking effort. That's the primary reason rear brake pads and rotors seem substandard in comparison to the fronts.
And you know this to be factual information..??
How..??
Twenty years ago I would have agreed, but not today.
"...crud everywhere.."
The only working part of your brake rotors is the pad braking "scrub" surface, the rest can be covered with dirt, mud, rust, and it would have no adverse effect. At least once a year I remove my wheels and throughly wash/clean the wheel itself, especially inside the rim, but to my knowledge I have never seen a brake rotor so "cruded" up that it needed my attention.
The most frustrating flaw in my Highlander, and apparently many others, is the lack of a lock washer or at least thread locking compound on the heat control knob. I read again and again that people's heat controls stopped working . . . all because the nut came loose. It went on for many years . . . that is unnecessary and stupid.
Also, I think the dim backup light is enough of a flaw to get annoyed about. The reality is that my windows are tinted and that it rains sometime, cutting down the visibility. Brighter backup lights would make my Highlander better. I will check them before buying my next Toyota and see if the dealer can come up with a fix in order to sell me a car.
Then there are Toyota dealers. Toyota should be able to keep them from ripping customers off with their bogus "required repairs" of brakes and the unnecessary service items like flushes and cleaning.
I would be driving a Highlander Hybrid now if Toyota hadn't refused to sell me the base model at the advertised price and hadn't used the hybrid system to improve acceleration instead of fuel economy.
Guess I am writing this in the hope that somebody at Toyota reads it and will do a little better with the things we notice and complain about. The things I have mentioned wouldn't cost anything significant . . . so why weren't they fixed?
Someone should have noticed the bad backup lights, or the door wind noise, or the remote control that has such soft button springs that the keys in your pants pocket sets off the lock or unlock actions.
Or the adjustable steering wheel that does not move very much
the real question is, who is the next Toyota? Honda? Ford?
You just answered your own question. These issues aren't fixed because Toyota is good enough to get you back and buy another Toyota. Yes, I agree, they aren't perfect. No manufacturer is.
FWIW, I had the same problem on my Camry after only 3 years. Never bothered to fix it but my wife is going to insist that it be fixed, regardless of cost.
That was it. I had changed the battery last month and hadn't used the sunroof until a couple weeks ago when we got to Florida. It took 3 tries but the normalization process worked as described once we did it right.
Thank You
It rides like it was new and has nothing else going on with it. It's quieter and smoother than the Hyundai Azera Limited I just bought 1 month ago.
WON'T be buying another one that is for sure!!
I have the same thing in my 2005 Camry but the 2004 Highlander is ok. I wasn't aware of any complaints on this issue.
