Visitor Agreement.
Should I get the TB changed? If so, how soon? What else should get changed with it? More importantly, rougly how much is this going to cost? Please keep in mind, that I'm lucky I know where the dip sticks for the oil and transmission are. Thanks in advance!!
That's a 60K belt that probably is due for a change.
When we had the belt changed, they also replaced the oil seals up there, and something else (I forget what, though). I forget exactly how much it cost, but everything was under $300.00. This was about 5 years ago, though.
One good thing about the Chrysler 2.2, though, is that it's a non-interference engine. This means that if the belt breaks, you're still stranded, but it won't do any damage to the engine. On some cars, when the belt breaks, the pistons will smash the valves and do other fun things, which can result in the need for a new engine!
I wouldn't push more than a few thousand miles beyond a manufacturer's suggested replacement date. Sure, the automaker probably has some slack built into his figures, but given the consequences and how infrequently you have to have it done, I don't much see any sense in procrastinating.
1. Camshaft Seals
2. Crankshaft Seals
3. Water pump.
4. Idler Arm
5. Tensioner arm
Most of the labor involved in these repairs involves removing, replacing and adjusting the timing belt. Here's my story with 2 cars.
1991 Mazda Replaced timing belt at 90,000. Cam and crankshaft seals leak at 115,000. As soon as I can save enough money, I will have all of the repairs listed above done.
Dodge, replaced timing belt at 135,000. 145,000 water pump died. Idler Arm died at 150,000. Ate timing belt. 160,000 crank case seals leaked (a fair amount) replaced belt as well, 165,000 another tensioner arm had to be replaced.
I think in this case being agressive actually saves money in the long run. But what to I know, my humble opinion is based only on pocketbook experience.
What I do is go to a dealer for my type of car and ask about who they would recommend as an outside mechanic. They usually recommend frineds who have left recently. Twice I have gotten mechanics who are experienced on my car. They know whether the cam and crankshaft seals will last for the duration of the timing belt.
But it's a preventative issue. In my experience if you have a 60,000 mile belt that you put on at say 90,000, you will likely have a leak before 150,000, your next scheduled timing belt change.
My Mazda Estimate for my cam and crankshaft seals is a $236.00 job. Of that it is $35.00 for the seals, and $25.00 for labor. The rest is for the timing belt. Water pump labor is only $35.00 IF the timing belt is already off. That's why I'm saving up to do the whole shebang.
