How about those pickup crash test results???????
                    look at
http://www.hwysafety.org/news_releases/2001/pr060401.htm
for some insurance institute photos of trucks crashing. Look like Ford must have never tested their truck. If they did, they ignored the results - either way an ethics problem. Toyota did it right.
They are lower for the Toyota, even tho you might thing the crumbling ford would absorb the impact.
I think other body types (of a pickup truck) would have different results (4 full size doors) because they have pillars in the middle of the cab...
I would have to assume that I'm going to be involved in a crash with a large vehicle if I'm considering safety in my purchase. Obviously, a larger heavier vehicle will do better in a crash with a smaller one-that's just common sense.
You could make the comparison that the GMC Behemoth did very well in a crash test with a motorcycle but how safe does that really make you feel?
This type of test does not predict which vehicle would "win" in an off-set collision between two different vehicles. It is a much better test of a vehicles structural integrity than the governments head-on tests, and should replace or supplement that test conducted by the gov. Leaving this test to the insurance institute allows long delays before a particular vehicle is tested. In this case, F150 has been enjoying a 4-Star rating from the government for years and may be(probably is) the least safe vehicle in frontal crashes.
So the trucks we drive.. where is the 'passengers' cocoon?
Back to the test.. was there anything in there that was closely related to the cocoon thing?!
BWAHAHAHAHAHAAA
I congratulate Toyota on a good test result for the Tundra. The Tacoma is still horrible.... And the Tundra is still a poorer performer than the F150 or the Silverado in the Govt DOT crash tests.
Hopefully, the tests will encourge all designers to improve crashworthiness.
Also, remember that 4doors with center pilliars almost always outperform their brethern.
So for max safety, buy real crew cabs, real full sized SUV's and full sized 4 doors.
http://www.hwysafety.org/vehicle_ratings/ce/html/summary_smpickup.htm
As Brian O'Neil said: "The government’s test does not really test the structural design of the vehicle because the whole front end takes the load. In this (offset) test, only part of the front end’s taking the load and then you see structural failure.”
Transcript of the Dateline segment with video clips of the tests: http://www.msnbc.com/news/580811.asp
Drew
Drew
Oh, you saw it on TV.....
BWAHAHAHAHAHAA
What's the matter guys??? Don't like FACTS or PICTURES?????
Absolutely... I wish my Rado was number 1 in the crash test and kudos to Toyota for having the safest one. Im sure in the coming years that Ford and GM will do better with these crash tests.
Anyway... still LOVE my Rado..
My 2 cents anyways.
Jim
All the things supposed to make a truck safer, like non-intrusions into the safety cage, structural integrity of the safety cage went wrong on the Silverado, BUT THE DRIVER came out good, better than Tundra driver who had lower leg injuries. So what counts? The photos, or the measured forces? Just ask the dummies. Lowest recorded forces on the Silverado dummy. Silverado driver ain't no dummy! LOL!
Anyway to answer a question about weights, here are the listed weights from the insurance institute tests:
Tundra 4363
F150 4475
Silverado 4709
Ram 4930
Silverado: INJURY MEASURES: GOOD Measures taken from the head, chest, and both legs indicate low risk of injury. Head acceleration from the shoulder belt housing contact was low.
Tundra: INJURY MEASURES: RIGHT LEG/FOOT MARGINAL Measures taken from the head and chest indicate low risk of injury. However, forces on the right tibia indicate the possibility of lower leg injury.
By the way, I didn't *watch* any crashes. Just read the report. It's right there, from the experts.
Tom
I'll go back to the Sedan Board now.
Here's some real world data for you:
http://www.hwysafety.org/vehicle_ratings/ictl/ictl.htm
Just select 'Pickup' under category
You can make numbers say anything you want. Would you want the F150 to hit your family sedan or the Tundra? The F150 obviously would transmit less crash force on the other vehicle because of its weaker structure.
I have seen head-on crashes that were not offset. Rear end collisions can be on center using both frame rails just like the govs test.
I think the best compromise might be the Silverado. This truck had the best personal protection in the offset and did well on the gov test too.
http://www.nhtsa.dot.gov/ncap/cars/2001Pkup.html
as far as firestones being a big problem to ford is concerned, well that's a big joke too. seems it's been proven that the geometry on the explorer's front end sucks and is even further proved to be bad by ford's sudden redesign of it. you also don't take a tire that's design to be inflated to a specified air pressure and then tell customers to only inflate to a lower pressure, all to enhance the ride.
Discussing the merits of the crash tests without looking at the specifics is getting only part of the picture.
http://www.hwysafety.org/vehicle_ratings/ce/html/grey_lgpickup.htm
You will clearly see that the reason why the IIHS rated the Tundra "good" is because its intrusion and injury measures are very significantly less than the other vehicles in the majority of the categories. For example, despite the Tundra and Silverado both scoring "good" in the head/neck category, the Silverado had more than 5 times greater neck bending forces (13 Nm vs. 66 Nm). :
I hope this helps to shed more light on the specifics of the tests.
-it has? who proved that? how come the explorers with good year tires didn't have a problem?
And how about head restraint ratings?
Seems no matter which way you cut it, the Tundra still comes out on top.
And remember a good safety cage is very important. Think about a person driving the Silverado 10mph more and how much more of a pancake that cabin would turn into!
