Jeep Liberty: Problems & Solutions
Yakima and Thule both make wind fairings that might work on your crossbars.
Can you move the rack forward or back (or swap the bars if they aren't symmetrical)? If so, experiment with different locations on your roof.
What I did was take two 1x4's, stain them, and attach them to my rails with U bolts. That did the trick for me and gave me a nice surface to put my canoes on - might interfere with a cargo box or whatever you're putting up there though. Good luck.
Steve
Dean
Bel Air, Maryland
Problems so far:
1. Squeeky windows on rolling up: Silicone will help rid you of the squeek.
2. Fan belt noise on start up: Replaced belt(warranty).
3. Wind noise coming from front passenger window at highway speed: Haven't pinpointed it yet. Suspect antenna or noise seepage thru window. Possible fix: Vent shades, don't laugh, wax antenna.
4. Annoying noise from rear. Lube the rear door latch and lower guide with white grease or petroleum jelly.
5. Clunk from rear when approaching a stop. I noticed this, asked dealer, could not duplicate. Still happens, but sporadically. Suspect transmission shifting back into 1st. Usually happens when I've accelerated quickly then stopped quickly. Plan on keeping an eye on it.
6. Rear seats fold flat enough for me.
7. NO wheel shudder. Alignment is fine.
8. Gas mileage roughly 17mpg with AC on all the time. Live in Texas.
9. Not really impressed with the 5-star service, but it will do.
10. Don't have horizontal roof rails so no roof noise and I suspect that is why jeep left them out.
11. Select-trac 4x4 works great.
12. Brakes could be a little better (ie, stops take a little longer than I like). Have to remember this thing weighs in over 4000lbs and its not the little hatchback I got rid of. I just leave a little more room to stop.
13. HAS PLENTY OF POWER. For those of you who want a sports car, go buy a sports car.
14. Did not care much for brushed aluminum parts of LTD, that's why I got the sport, however, all one color (black) was a little boring. Just installed a carbon fiber overlay on dash, around radio, climate controls, shifter, power window buttons, horizontal strip across dash. Looks very sharp. For those interested: Exoticwooddash.com. Different kits from $100-350. Comes in different wood tones also.
Thanks for reading. MARSPA
They also have stickers on each rail telling you which one goes on the front and which one goes on the rear (I already had these in the correct location).
It's a JEEP thing!
I don't get any kind of a "check engine" or any signals on the dash so I wonder if the dealership can do anything about it.
BTW, I love the truck. It is a very solid and tight SUV.
PS~Mine is at 1400 miles now, not sure when I first noticed this though. Otherwise things are great and I love it! When I take it in for my first oil change I'll mention something to the service dept. unless I have a major problem before then....if that's the case they will be seeing me ASAP :-)
I also have been having problems with my gear shifter. When I shift from park to drive or reverse it makes this crunching sound. Like plastic on plastic. I figured something was sticking so I took it to the dealership.
Unfortunately, they couldn't replicate either of these problems so they took the shifter apart and greased everything. The crunching went away for a while but I notice it again the other day. At this point I really like the liberty despite my problems but I am glad I decided on a lease instead of a purchase.
you might have tech check the rear shocks, as new ones took care of our problem. It sounds like a loose shock, but it is the shock itself making a noise when it reacts to a bump while driving. Probably not a problem that will leave you on the side of the road, but it is annoying. Try to determine where the noise is coming from, front or rear, etc. Good luck and I hope this helps.
RV Broker
clunks when you slow down at around 20 MPH. this happened mostly for me when the car was cold. once it warmed up thoroughly; (driving 10 miles or so) it did not happen as much if at all.
I reported this twice to my dealer and the technician test drove it with me & felt it too, but this was also after it warmed up. the second time, I was in for an oil change & reported it again. they connected the car's computer to their computer to check the tranny programming & performance. then gave me some BS about how the tranny "adjusts" to different drivers' habits etc...also showed me in a service manual about this phenomenon. whatever the case, since that visit, the tranny has been FINE (3 weeks now). I suspect connecting to the computer re-established (or corrected) some program error.
Problems I've had:
First time I used the back wiper it went halfway across the window and stopped.. The position it was in prevented me opening the back door and window. Problem resolved by service.. They replaced the whole wiper assembly.
One of the rear seat latches needed ajustment.. Seat wouldn't lock into place properly. Fixed by service..
My foglights are also strange.. Intermittent problems getting them to go on.. (Will have looked at next O/C)
Other than that, no problems.. I've taken it through a couple state parks and the national forest down fire roads, etc. Handles well.. No rattles or anything.
I have a sport. patriot blue.. 6 cylinder automatic. power moonroof, infinity sound controls on steering, crusie, tilt, the nice aluminum rims, foglights, power windows locks, security and keyless entry.
got them to $24,250. I also made them pay my registration and fees $220, they gave me $330 towards my sale tax (MA sux!) because they had an online registry and get a discount or something, also got them down on their interest rate. I still think its a sham that they aint offering any real good rates for the liberty, but I'm happy with the vehicle so far
I think that we got a really good deal!
27G
Sunroof
ABS
Front Heated Seats
After figuring out what the dealer finagled with the numbers (trade in value and Liberty cost) he sold the Jeep for approximatly $25,900! There were only two on the lot and the first was sold. We got the 2nd one.
First impressions are good! I like it better than my 96 JGC. V6 is smooth. I'm waiting for her to try it in Snow!
Robert
The shop forman at my dealership knew exactly
what it was. The driveshaft needed to be greased.
Apparently theres a half inch of play at the end of the drive shaft. The driveshaft was hanging up
occasionaly. Just greasing the end of the shaft
solved the problem.
Thx
I have never owned a black vehicle so I can't say for sure why anyone would call it a mistake though the arguments I hear usually have to do with black looking worse with dust and dirt buildup than other colors and that it makes the car feel hotter in summer.
Perhaps those with hands-on experience will share their experience.
tidester
SUVs
I like black cars, when they're clean. They're very classy looking.
Bob
Jonathan
-gypsy-
Enjoy your stone white Liberty!
tidester
SUVs
--gypsy--
The only “problem” I can see so for is that the Overdrive Off button only seems to work when the lights are turned off. Do the rest of you Liberty owners have the same behavior? I shouldn’t be turning the Overdrive at night all that much, but if I am pulling a trailer, I may want to turn off the overdrive for hills. It doesn’t make sense to me that the overdrive will only work with the lights off.
Any ideas?
-mad
Now, all of the dealers were willing to order for me. But of course at first they're going to want to sell you one off the lot. I think you have to be stern and know what you want. If you tell them that you're ready to buy now, this is what I want, can you get it? I hope this helped. By the way what kind of Liberty w/options do you want and what state are you in?
Oh yeah about the price, just tell them you're not paying sticker when you find the one you want. They'll ask what do you want to pay, then give them a price below what you don't mind paying so you can come up to your price. Be strong. :-)
Matt
Also, I've never used them, but could you try locating your exact vehicle (or close to it) by using one of the many internet vehicle searches (like carpoint.com, autotrader.com or vehix.com)?
Best of luck. I ended up ordering one, now I'm only hoping the jeep plant does not strike
I told all the dealers I visited that I priced the Liberty Sports on the internet and had a good idea of a fair price. The comments I received were that the markups on Libertys are not that much, I'll never get one for the price I want to pay, and that the internet underestimates the dealer's actual costs.
I visited one more dealer this afternoon and made some headway, but I still haven't signed on the dotted line. The nice thing is that I still have my G.C. Laredo, which I love, so I don't have to settle.
Steve
They seemed to find an extra $600 when we did this
-Scott
Where I live we have 10 months of winter and 3 months of road construction. The only roads that get de-icer is the freeway and only within a few miles of a city and the temperature is above 20. I'm thinking....that's probably where u drive your Liberty all the time in NY. An hour or so of driving in the winter here can build up enough ice in the front wheel wells so that you can't turn the wheels very much. That's why the Cherokee's doors opened before the wheel well moulding and thus made it harder to get in and out of.
Other than this service visit, the Liberty has been exceptional. Just returned from a driving trip to Colorado (I live in Indiana). On the highway it zoomed, effortlessly climbed to 11,000 feet in the Rockies, and handled some minor off-roading with ease. I have had a Wrangler, a Cherokee, and two Grand Cherokees. This is the best Jeep I have owned. What a blast to drive.
Also, I have a dull rattle too, that only pops up on city streets. Good to know it may be a universal problem and easy to fix.
My Liberty has 7000 miles on it and I love it!
I thought about that too :-( not the problem. I'm thinking it's a wire or something.....to give you a better idea it's sounds similar to the turn signal, but not as loud.
