Mazda Millenia S Turbo Annoying Whine
                    I would be interested in other owner experience with 2000 Mellinia S (< 10K miles). At about 60 MPH (2200 RPM) the turbo emits an annoying whine that can be heard over the radio. My service manager tells me that this is normal.  I beleive that noise of this sort is abnormal and indicates a defective unit. Have other Millenia owners had similar experiences? TFS
It's supercharged. Big difference.
ummm try a different dealer. same story, multiple sources, probably true...
YES---okay, then forget the radio as a cause
NO--only with the radio on----then you need a suppressor on your alternator.
If YES, you may indeed have a bad bearing in the s/c, or it could be belt noise, or a bad bearing in an idler pulley if your s/c runs off one.
