The AV looks 'mean' on the road so those little DC van people should just move out of the way.
Enjoy!
I have had my avy longer than you and have had no problems......none ...nil.......
No leaks.....none dry as a bone.......
no seals coming loose none....
good luck with yours....
there is a TSB about a floor seam not sealed properly....and a hole in rear fenderwells....or something like that....so it may not be a midgate leak...
The Avalanche is a truck. It is more prone to roll over than, say, a Toyota Corolla. I don't beleive it's more likely to roll over than any other truck. You can check out results of tests at www.nhtsa.dot.gov (http://www.nhtsa.gov/NCAP/Cars/2248.html for the AV) or http://www.highwaysafety.org/.
Had fun back then....
Heck back then you did not like avy txtank1...hehehehe
txyank1 "Chevrolet Avalanche" Oct 4, 2001 9:04am
I notice you like it now...great!
Which do you like better? wbh or cladded?
As for the Z66 label and np Z66 package. Sounds like a plain ol' scrrewup.
