Chevrolet Avalanche Accessories & Modifications
Does anyone know of a good place to get factory wheels chrome dipped or to buy factory chromed wheels?
Bear
I was just looking through ebay and found someone
selling for Avalanche wheels. If any one is interested
Item # 593456400
The biding is currently at $455.
I thought someone may be interested...
Joe
Rob
Brad
try this!
Right: 15718561
Left: 15718562
gmpartsdirect.com price: $162.46 each plus shipping
GM list: $270.77
GM wholesale: $203.08
info from gmpartsdirect.com (Flow Chevrolet, a dealer)
Anybody have the part # for the roof rack, tent etc.?
1. The color coded running boards (pewter) for the left hand is part number 15768547. For the right hand is part number 15768546.
2. The black running boards for the left hand is part number 15718561. The right hand is part number 15718562.
3. The roof rack is part number 12497773.
4. The tent extension is part number 12497828.
5. The hood protector is part number 12497830.
spike1966@hotmail.com
Dennis
An e-mail from them had the part number for an appearance package - hood protector, splash guards and ventvisors. I don't know how the pricing would compare to buying each item separately like I did; there should be some discount.
Accessories for Chevrolet
Avalanche
Appearance Package 12497862
The Appearance Package includes running boards and roof rack. Running boards
give drivers and passengers a step for convenient entry and exit. The non-slip
step pad secures footing. The GM Accessories roof rack is easily adjustable by
pulling the handles and positioning the desired crossrail span.
Canoe/Load-Stop Carrier 12497222
Keep the cargo on the roof of your Chevy Avalanche secured with a load-stop
carrier. This product attaches to the GM Accessories roof rack utility bars and
secures everything from ladders to canoes. A permanent roof rack and GM
Accessories utility bars are required.
Hard Cargo Carrier 12497843 Black 92x28x15
12497845 Black 55x38x15
12497844 Graphite 92x28x15
12497846 Graphite 55x28x15
This lockable carrier is the ideal place to store and protect your cargo.
Constructed from ABS plastic. Smooth-finish carriers can be painted to match
vehicle color. Short hard-cargo carrier dimensions are 55" L x 38" W x 15" H,
and long hard-cargo carrier dimensions are 92" L x 27" W x 15" H. A roof rack
and/or GM Accessories utility bars are required.
Kayak/ Windsurf Carrier 12495613
Load up your kayak or windsurfer on the roof of your Chevy Avalanche. This
carrier is designed to safely secure your kayak or windsurfer for the long haul.
A permanent roof rack and GM Accessories utility bars are required.
Protection Package 12497861
The Protection Package contains a molded hood protector, molded splash guards
and vent visors. The molded hood protector will repel road debris and insects
from your vehicle. The sleek, low-profile protector, provided in an acrylic,
will be an attractive addition to your GM vehicle. Crafted to work in tandem
with your vehicle, this protector will not create side-view mirror vibrations
nor will it affect the windshield spray pattern.
* Molded splash guards help protect your Avalanche from gravel, salt, dirt and
other road matter.
* Vent visors allow you to leave your windows open to let the fresh air in, but
help keep rain, sleet and snow out. They also reduce sunlight glare and keep
your interior cooler. These appealing vent visors complement the distinctive
contours and styling of your GM vehicle. They will not interfere with side-view
mirrors.
Roof-Mounted Ski Carrier 12495610
Attached to the permanent roof rack, each carrier can tote up to six pairs of
skis or four snowboards. You have the freedom to mix and match to create a
combination that will suit your needs.
Vehicle Cover 12497707
Made of material that is strong, yet manageable, this GM Accessories car cover
will hold your vehicle under wraps. The cover is easy to handle and effectively
keeps dirt and dust out, while allowing water evaporation, which helps cut down
on moisture buildup. This cover is black custom fit with the avalanche logo.
Bicycle Carrier Package 12497223
Wheel mounted bicycle carrier
Bicycle Carrier Package 12495021
Fork mounted bicycle carrier. Bicycle must have quick release front wheel hub.
Roof Luggage Carrier 12497770
Splashguards 12497727
Front molded splash guards with bowtie logo
Splashguards 12497728
Rear molded splashguards with bowtie logo
Cargo Liner Package 12497838
This liner is off black in color and is used with 2nd row seats folded down
Liner Package 12496041
Front floor console trash or cd storage
Skid Shield Package 12496034
This is for the ½ ton Avalanche and includes the oil pan shield, transfer case
shield and mounting hardware
Skid Shield Package 12496035
This is for the ¾ ton Avalanche and includes the oil pan shield, transfer case
Step Package 12497719
Tubular chrome
Step Package 12497831
Tubular gray
Running Board package 12497718
Includes both left and right boards with mounting hardware. Gray in color.
Running board 15718561
Left hand with BVE option
Running board 15718562
Right hand with BVE option
Utility Roof Rack Bars 12497224
This is needed when adding any roof bicycle, canoe, and kayak accessories
Roof carrier package 12497773
This is needed when adding the hard shell roof carriers
Roof Luggage Carrier Cover Package 12497160
Tailamp Cover Package 12497975
Slotted tailamp covers, smoke in color
Hood Air Deflector 12497075
Smoke in color
Ventvisor Package 12497163
Window deflector that goes over the windows to keep out rain.
Tent Package 12496559
Gray in color with avalanche logo
Here is some info on the brush guard shown on page 32 of the sales liturature:
[copied from http://forums.pickuptruck.com/Forum11/HTML/006663.html]
I called GM and they have the part number but the grill guard is not available for sale yet.
Grill Brush Guard 12497622
Grill guard for the avalanche as pictured in the brochure. (Not yet available for sale)
In some cases many of the avalanche accessories may not be available for sale, but I like supplying the part numbers in hope GM will soon put these accessories for sale.
for links to pictures of my AV with these options added.
Dennis
Enjoy!
Trenz Co. has a couple Billet grills out. Someone posted a link to a lowering kit on the pickuptrucks.com site and also a link to performance truck.com site that offers some. I am really waiting to a FIPPK from K&N.
Brad in SoCal
No good pics.
I want the Brush guard! Sources?
Look at the bottom of post 18: if you want the GM brush guard, gmpartsdirect says it is not available yet, but we do have the GM part number for it. I guess you could ask the local dealer to look it up and get you an availability date.
Also, is the doodad above my head the microphone for the auto-volume or On* phone? There's another mic on the headliner console. Which is which? I'd like to wire the existing auto-volume mic into the CD-70 (when I get a mounting kit) instead of mounting yet another one.
Here are some things I learned when replacing the stereo:
1) Don't pull the mic grille off the headliner to see what color the mic wires are. Find another way. It took me 30 minutes to get the grille back on.
2) The stock stereo has two plugs into the back, plus the antenna lead. The smaller of the two plugs seems to include the mic input as well as a few others. For a retail stereo to work, your remote turn-on (auto antenna) lead must be connected to the red wire on this second wiring harness. There may be a stock 4-channel amp in the Av, but I don't know where it might be.
Now I just have to figure out a way to get a power lead from the battery, through the firewall, to the sub amp under the back seat. The firewall looks pretty tightly sealed to me.
Anyway, I hope this is helpful.
How did you remove door panels? My front ones would not come off they were stuck near the just above and to the left of the door handle.
Did you mount a sub Woofer and where? Does your amp interfere with the folding of the seats?
I am considering contactin Gm about just buying the BOSE system they are using in the Caddy version. Any comments there?
Jpendlum is working on putting together a kit for this setup. He has done this with other GM accessories. I'll keep you posted as to progress and price.
Brad in SoCal
Good LUCK and love the Avalanche!
I didn't replace the speakers in the front or rear doors, so didn't try to remove the door panels. The stock speakers actually sound OK once you get rid of the stock head unit. I may replace them at some point, but probably not for a while.
There were three dark-colored wires coming from the back of the headliner mic. They are connected through the smaller wiring harness mentioned in my earlier post, but I didn't play with it any further. I'm pretty sure the mic is for the auto-volume function. Cruise along at a constant speed, then roll down the windows. The volume increases.
I had a sub box built a while back for my Grand Cherokee. The box has 2 JL Audio 10" drivers inside, and I placed it right on the outside of the midgate. I haven't run the power wire to the amp yet, so I don't know if any sound will actually get through, but we'll see. I put the Phoenix Gold ZX600ti 600w sub amp under the rear driver-side seat. Fits perfectly, and does not interfere with the folding of the seats. I used one of the seat floor bolts as a grounding point. Again, I haven't found a way to get power to the amp, so I don't know if it's going to work very well.
Jason
2) I'd like the fog lights to come on with the headlights every time. It's annoying to have to turn them on all the time. No, they're not necessary for normal driving, but they add a bit of light right in front of the hood. Plus, I think the truck looks better with all 4 lit up.
Any ideas? #1 especially? Thanks.
was looking for a Radio with a in dash CD changer built in ? Does any one know of one avalible? Or just put in the Escalade EXT one.
I contacted OnStar and they said changing the head unit voids their warranty. All I asked them was how to wire it up with a different head unit. They were not much help.
I am replacing the stock speakers in my AVY. Components front and rear doors. I will use double sided tape to hold the crossover inside the door.
I have looked everywhere on the net and cannot find any stereo site that has any info on the AVY. I was trying to find the speaker harness since the wires are short in the door and I may want to re-install the stock ones IF I EVER SELL my AVY.
Anyone do any stereo mods yet?? Info desired here!
I am using Blaupunkt PCCI 650 in all 4 doors. Panels remove typical of a Suburban or Silverado.
The stock rear speakers screwed in and the front mid range clip in. The front tweeters have a seperate wire which you should not use if planning to use the existing stock head unit.
If a speaker upgrade makes a nice improvement, I would consider it. I am sensing the stereo also needs a serious boost in power to take full advantage of a speaker upgrade. Any advice on speaker upgrade, additional amplifier or complete replacement would be appreciated as it would make my AV "perfect".
My wife drive a Jeep Grand Cherokee Limited(MSRP < $38K). It has an Infinity stereo with an Infinity amp all stock. It blows away the Chevy stereo set up. The steering wheel controls are also real convenient! I'd like to ultimately add steering wheel control to the AV.
I have seen some posts about a full dual exhaust system (Flowmaster muffler was used I believe). If anyone has a photo of such a system, I would give it a try at my local muffler shop. The routing of the driver side of the dual looks like it may be tricky with the spare tire hanging down.
I have seen some posts about a full dual exhaust system (Flowmaster muffler was used I beleive). If anyone has a photo of such a system, I would give it a try at my local muffler shop. The routing of the driver side of the dual looks like it may be tricky with the spare tire hanging down.
