Chevrolet Avalanche Problems & Solutions
Hey All,
My AV arrived tonight and I will be picking it up sometime tomorrow. The first think I noticed is that it is missing the deep tint on the rear windows. I am thinking of pushing the dealer towards this being a defect that they need to address. Anyone else try this yet? Thoughts?
Cheers,
Bear
Cheers,
Bear
Let me know how this works out for you.
Cheers,
Bear
What are you seeing on the initial oil as far as pressure? Mine is running at 60psi at an idle and 70 to 75 at load. Seems a bit high to me, but I have never heard of high pressure causing a problem.
Cheers,
Bear
PS Temp is about 200 without any load and 85 OS temps. How does this compare?
PS I see straight up on the voltmeter and averaged 16.5 on my first tank of 87 octane.
I saw the 2500 has a transmission oil temp gauge in the lower left corner of inst. cluster. Has anyone checked if this can be an add on to the 1500? I'll be pulling a boat after break in and would love to know. Sounds like a good call to Chevy tomorrow.
Roger
I see these are rated 44 psi while the sticker on the door indicates 30 psi recommended. I put 35 lbs cold in them. Any advice would be welcome.
Roger
Also, service dept suggested if pulling over 4000 lbs in terrain other than flat country, tow in third so transmission doesn't shift so much. I inquired about tow/haul mode and they said to use it but go ahead and use third in hilly areas. FYI.
Roger
From the owners manual:
The Certification/Tire label, which is on the rear edge of the driver's door, shows the correct inflation pressures for your tires when they're cold. "Cold" means the vehicle has been sitting for at least three hours or driven no more than 1 mile.
Over inflation can cause unusual wear, bad handling, rough ride, or needless damage from road hazards.
If you need more info on this, check out:
http://www.delphi.com/gmsuv
there are a few people there that have posted pics of what the different clusters look like and what it cost to buy and have the mileage set.
Campo57
Campo57
Roger
$ 198.18 Escalade Part # 15073350
$ 160.01 Denali Part # 16252295
$ 160.32 2500 Part # 15758079
now all you have to do is give them the part number. (the above prices are without shipping charges)
Campo57
Bear
Bear
Roger
Anyone else have this experience?
I'll keep you guys posted!
G
The failed/defective tires in question are: Goodyear Wrangler AT/S P265/70R17 - 113S
All tires had the same lot number (found on the back sidewall) DOT MK16 BYDR 1901
The correct number is: DOT MKT6 BYDR 1901
Rich
I have scheduled to leave my AV at the dealership next Tuesday after work, so they will experience the white smoke when they start it up in the morning. I reminded the service rep about the mechanical switch or relay noise too. I will keep you updated.
Ropd
The 4.10s will make your RPMs higher at highway speeds, it will allow for more torque when towing up hills and the lower gear ratio will alow for a more controlled drive of tough terrain. The 4.10 will also be good if you decide to put bigger tires on your AV. I use to have a jeep with a 4.56:1 ratio and a 4:1 transfer case. With the stock tranny, I was at roughly 90:1 ratio. I'm not a rocket scientist but I think the engine revolves 90 times for every one complete turn of the wheel. Your gas mileage will suffer a bit. I hope this helps..
Black AV Z-71
G
Thanks for the input. My boat and trailer weigh in at around 6,000 lbs. so I'm not so concerned with that end. My old Suburban had a 3.73 axle with the 454 engine and had no problem. My main concern is the mileage. I don't tow the boat that often but the truck is used every day to and from work. I'm just trying to decide if the fuel savings would justify re-doing the gears.
One...after washing the vehicle I constantly have water drips from the mirrors. Even after having it sit for 5-6 hours, the drips still came down. If you drive the vehicle after washing...the drips make an awful streak down the sides of the doors. Has anyone come across a way of getting rid of the excess water after washing? I know its petty...but I have the indigo blue and it shows everything.
Two...I know that after I own the vehicle longer than a week this will change...but I keep looking for my temperature and compass in that useless compartment above the rearview mirror...for some reason that black hole is where my eyes wander to...I have the sunroof so the upper console may be different for non-sunroof owners. I would appreciate any and all comments!
I also thought that black hole was the temp and compass until I put my finger in it and said oh, that's what that is. Before that I was pushing on the homelink buttons trying to get the temp to come up. Duh.
I also have installed the mud flapps and running boards which seem to keep some road dirt and dust off the sides now.
Dennis
I had the streaks on my Indigo, handwash with very little water worked, covering per txyank may be best.
One thing everyone there seem to make use of is "Leaf Blowers" for drying. Most of these guys have Black or other dark colored vehicles that water spots "wreak havoc" with. The other tip with water spots is "vinegar" to remove the mineral deposits.
Hope this helps
Brad in SoCal
Bear
spike1966@hotmail.com
Are any of you experiencing a slight rough idle after vehicle warmed up? I have tried mine both with and without AC on, still idles just a touch rough. I am going to get it in next week to have dealer check it out as soon as I get my other car back from shop.
One other thing, very early on in the AV posts, people were talking of a "Clunk" when turning to left with their Rados. I have experienced this twice in my AV, both at a dead stop, turning left at a stop sign/light. Anyone else?
I was told from sales department, get your AV lined up and tires balanced by service BEFORE 7500 miles. Up to that limit, service will take care of it, after, it is your baby. FYI
Roger
Rich
Bear
I am afraid for the dealer to remove or replace the panel as it might not ever fit the same. I will wait and see if it becomes a bulletin or just leave it as is.
