Acura Integra GSR Customizing and Modifying
Check out this guy's site. He drives an E30 M3 (like we all should
Anyway, is suspension travel good? I know I have quite a bit with my setup and then I see my friends almost full race 93 Si with GAB revo's with 600+ spring rates and he hardly has any. It's easy to tell when the cars are jacked up. Curious to hear your thoughts on this subject.
Yes, suspension travel is good which is why we 've alwasy said not to lower more than 1.5-1.75". This is also why many cut the bumpstops by 1/3 or 1/2 when installing GC coilovers. To have more suspension travel and not ride on your bumpstops. More suspension travel is advantageous for auto-xers, but road racing/track cars can get away with less.
'06 Civic LX coupe
'11 BMW 335i coupe xDrive
'13 Honda Accord sedan (wife's car)
Is this because the R to L transitions are less dramatic in autox?
Did anybody see this? One more item from BSQ.
http://www.honda-tech.com/zerothread?id=140106
He is selling it for $30.
As most of you know his ITR sway bar mounting kit is a popular and reliable one.
Run the RE730s at about 31-32F/30-31R for the first 600-700 mi. or so. They 're a little slippery at first which is why you want to go with lower pressures. After the initial 6-700mi. run them at 33F/32R. I don't go much above that on the street. Even when auto-xing the most we go up on the RE730s is 37F/35R but that's totally different that street driving and not good for high speeds, so keep them in the low 30's.
Be extra careful in cold weather. This is an Ultra Performance tire and does not grip well when the pavement is cold or wet & cold. Don't take turns fast in under 40deg. temps. They 'll slide depending how high the pressures are. When the temps are warmer they grip much better and are excellent in the wet too. Get your self a decent analog tire gauge, nothing cheap or digital.
'06 Civic LX coupe
Anyway, I finished 4th out of 16 STS cars. Again, half of these cars I'd never seen before, many of which had out-of-state plates (I guess these young bucks are going to school down here). I was shooting for a top 3 finish and missed it by one, and I would have been third if it had not been for those two dreaded cones that fell over after I had passed them
My V700s just came in. I have to mount them and heat cycle them before this Sunday's event. I didn't go with the new Ecsta V700 because I haven't been reading very good things about them and most said they grip the same as the old V700s so I got the regular V700 that I had last year. The good thing about the new Ecsta V700 is that it comes in 225-45-15" but I want to hear from others if they rub or scrape with Kosei K1 wheels 45mm offset. The new EV700 is supposed to be lighter too but people were saying that they got worn out faster than the V700 and gripped the same, so I 'll stick with old one which they will continue to make.
'06 Civic LX coupe
Good luck to you for your event on Sunday. How are you supposed to heat cycle your new tires? I don't know if I've heard anyone describe that process before. I imagine that it's similar to how you condition a new set of brake pads -- drive on them a bit to make sure they get hot, but not too hot, and then let them cool down completely. Sound about right?
ANDY'S TOP TEN AUTOX DRIVING TIPS
[Just got back from a weekend of teaching Evolution schools and thought I'd share some stuff that I must have said a thousand times. Sure beats talking about rules!]
1) Position first, then speed. Positioning the car perfectly is more important than trying to attain the highest potential speed. For example, you will drop more time by correctly positioning the car nearer to slalom cones than you will by adding 1 or 2 MPH in speed. Same with sweepers (tight line). Same with 90-degree turns (use all of the track). Also, position is a prerequisite for speed. If you are not in the correct place, you will not be able go faster. Or at least not for very long!
2) Turn earlier...and less. To go faster, the arc you are running must be bigger. A bigger arc requires less steering. To make a bigger arc that is centered in the same place, the arc must start sooner (turn earlier).
3) Brake earlier...and less. Waiting until the last possible second approaching a turn and then dropping anchor at precisely the correct place so that the desired entry speed is reached exactly as you come to the turn-in point is quite difficult to execute consistently. Especially when you consider that you get no practice runs on the course, and the surface changes on every run, and you aren't likely to be in exactly the same position with the same approach speed on every run, etc. Better to start braking a little earlier to give some margin of error. And by braking less you can either add or subtract braking effort as you close in on the turn-in point. This will make you consistent and smooth.
4) Lift early instead of braking later. Continuing with the philosophy of #3, when you need to reduce speed only a moderate amount, try an early lift of the throttle instead of a later push of the brake. This is less upsetting to the car, is easier to do and thus more consistent, and allows for more precise placement entering the maneuver (remember #1 above).
5) Easier to add speed in a turn than to get rid of it. If you are under the limit, a slight push of the right foot will get you more speed with no additional side effects. On the other hand, if you are too fast and the tires have begun slipping, you can only reduce throttle and wait until the tires turn enough of that excess energy into smoke and heat. Don't use your tires as brakes!
6) Use your right foot to modulate car position in constant radius turns, not the steering wheel. In a steady state turn, once you have established the correct steering input to maintain that arc, lifting the throttle slightly will let the car tuck in closer to the inside cones. Conversely, slightly increasing the throttle will push the car out a bit farther to avoid inside cones. It is much easier to make small corrections in position with slight variations in the tires' slip angle (that's what you are doing with the throttle) than with the steering wheel.
7) Unwind the wheel, then add power. If the car is using all of the tire's tractive capacity to corner, there is none left for additional acceleration. At corner exit, as you unwind the wheel, you make some available. If you do not unwind the wheel, the tire will start to slide and the car will push out (see #6 above).
8) Attack the back. For slaloms (also applicable to most offsets), getting close to the cones is critical for quick times (see #1). To get close, we must move the car less, which means bigger arcs. Bigger arcs come from less steering and require earlier turning (see #2). Now for the fun part... When you go by a slalom cone and start turning the steering wheel back the other way, when does the car start to actually change direction? Answer: When the wheel crosses the center point (Not when you first start turning back!) How long does that take? If you are smooth, it takes .25 - .5 seconds. Now, how long is a typical person's reaction time? Answer: about .5 seconds. Finally, how long does it take to go between slalom cones? Answer: Typically on the order of 1 second. Given all of that, your brain must make the decision to begin turning the steering wheel back the other way just *before* you go by the previous cone!! Since this is a mental issue, a good visualization technique to get used to this is to think about trying to run over the back side of each slalom cone with the inside rear tire of the car. To hit it with the rear tire (and not the front), the car must be arcing well before the cone and the arc must be shallow. Attack the back!
9) Hands follow the eyes, car follows the hands. 'Nuf said.
10) Scan ahead, don't stare. Keep the eyes moving. Looking ahead does not mean staring ahead. Your eyes must be constantly moving forward and back, and sometimes left and right. Glance forward, glance back. Your brain can only operate on the information you give it.
Bonus Tip: Don't forget the stuff in between the marked maneuvers! Too often we think of a course as series of discrete maneuvers. There is typically more to be gained or lost in the areas that are in between. Pay special attention the places where there are no cones.
The fact that you have to modulate and position your car with your foot (on the gas or letting off), I 've known for a while plus most of the tips he talks about here. Some I found out by myselft and some I learned by watching other National level drivers and some by talking to them.
Yes, that 's exactly how to heat cycle R tires. You run on them for 4-5 miles at moderate speeds and do not go overboard with cornering or anything. Then let them cool off for 48hrs. Most people rotate them and then drive a few more miles. I probably won't be doing that because I 'm going to try not to heat up the tires more than the rear, and they way you do that is by not taking fast turns. You 're actually supposed to take them off the car after you 're done so there 's no load on them, and let them sit. Some say up to a week, and tirerack says 24-48hrs. I usually let them sit at least 48hrs so I 'm safe.
I don't know if I 'll have time for this Sunday. I 'll try and take off from work tomorrow so I can be ready for Sunday
'06 Civic LX coupe
1) What the weight distribution of a 95 gsr sedan
2) What are your opinions of 300lbs/in and 270 lbs/in in front and back respectably
3) If you don't like those numbers, what would you prefer
I'm excited about getting this setup and I want it to be perfect. Right now, my only suspension mods are 20-21 mm rear swaybar with new endlinks and urethane bushings, and a 24 mm front swaybar with new endlinks and urethane bushings. The car is pretty neutral as it is, and I want to keep it that way. Thanks for all the help.
1. the weight distribution between for a GSR sedan is very similar to the coupe. I don't remember the exact percentages front to rear, but it doesn't vary by more the 5% or so. Sure, the sedan has about a 2" longer wheel base, but is only about 100 lbs. heavier. Sure, the sedan has two extra door in back, but the coupes have some big [non-permissible content removed] massive doors up front (compared to the sedans front doors). Plus the glass on the coupe's hatchback weighs a lot. So, if you're worried about weight distribution, don't! -- you're just splitting hairs...
2. 300F/270R sounds like a decent set up... BUT it all depends on what your aspirations are... e.g., street only, auto-x, track, etc. We'll be more helpful if you could remind us again what your plans are.
3. those sway bars will serve you well. Having a bigger than stock sway bar upfront will mean a bit more understeer, and could basically minimize or reduce the effects of the larger rear sway bar you've got. Some of this can be remedied with stiffer springs in the rear, but again it all depends on what you want to do with the car
thanks again, and I promise, this will be my last suspension question.
So if it were me and the car was a daily driver, I 'd go with 300-350F and 250-300R respectively. If you feel the rear slipping or coming around you can always dial down the Konis and make them softer in the back. Trust me, if you like the way the car feels now, you 'll be ecstatic with your new setup and the car will feel really tight.
It's a great feeling changing lanes fast on the highway and having the car stay totally flat. My first experience with that was with my brother's Type-R when I drove it (stole it) to the airport to pick him up back in '98. I don't think I stopped grinning and smiling all the way there. I had never experienced such handling before and such lightning fast lane changes. That when I knew what I was missing.. He wasn't too happy to see me in his car though. I parked in the unloading zone about 100ft away looking at him and he was sitting there with his luggage looking at me. A minute went by and he didn't walk over. I then started signaling him to walk over an yelled out his name. He was so surprised. He walks over and says: "it thought it was someone else's R, I was thinking what jerk would drive a Type-R through the pot hole infested NYC to get to JFK.." Needless to say he wasn't too happy. He was so pissed he drove like a maniac back home and I couldn't believe the roadholding and agility of the ITR when he was weaving through traffic. I drove it nicely because I didn't want to get into an accident but he was auto-xing at the time and knew the car well. Plus it only had like 2k mi. on it so it was new and tight.. I don't know what made me tell you this story.. I guess I 'm trying to put my self in your shoes and I remembered the 1st time I drove a car with a nice suspension and then I remember when I upgraded mine. One of the best feelings in the world..
'06 Civic LX coupe
Argh, I hate that. Before, I could have waited until next year, but now I can't wait to get the new setup. Alright, everybody have a great day:D
BTW, you can ask more questions if you want, but we 'll have to start charging you consulting fees now
Hey make sure you have $150-200 for installation too!
'06 Civic LX coupe
Thanks for waiving the question fee ;o) It's much appreciated.
Note: Register on honda-tech.com and learn oodles of information about different parts, set-ups, etc.
There is a BIG difference between a "warm air" intake and a cold. About 8-10whp worth. For maximum gains you want the filter or intake point to be away from the engine bay, way down there where it can suck in 100+ degrees cooler air. Remember, for every 10 degrees difference, your power goes up (or down) 1hp! Save up and get the "real" thing. Nothing really beats an AEM CAI, and if you 're afraid of H20, get the bypass valve.
'06 Civic LX coupe
P.S. I live in TX, and we get alot of rain. Do I NEED to be afraid of H20? I mean, does the valve affect performance to where I wouldn't get it as a precaution?
Anyway, any carbon fiber hood you get will help as long as it is ligter than stock which should be. Different rotors shouldn't be a problem with weight either, if anything they 're slightly ligher (x-drilled).
You need to be afraid of taking in H20 if you get floods where you live. If your car is stock height, and not dropped, I wouldn't worry about. Just stay away from big puddles that are more than 3" deep or drive very slowly over them..
'06 Civic LX coupe
Seriously though, yes the best thing to do when going through a puddle is to get your foot completely off the gas, because you don't know how big that puddle really is.
'06 Civic LX coupe
15s, 16s, or 17s? The smaller the wheel: less wheel weight, less tire weight, cheaper tires, more tire selection, and cheaper wheels. If you have no desire to take your car to a HPDE (High Performance Driving Event) or local autocross and you want to spend money on wheels rather than other areas, eliminate the 15s. If you have any inkling towards performance and care what you spend on wheels and tires, eliminate 17s. This is the best I can say until I know how much $$$ you have and what you want it to do.
Some cool, cheap, and lightweight wheels to check out:
http://www.g-speed.com/enkei/
Rota Slipstreams, Subzeros, and Circuit 8s (www.groupbuycenter.com)
Kosei K1 Racing (Tirerack.com)
Konig Helium (www.groupbuycenter.com, 11.34 lb, 15", $385 shipped)
Don't ever buy anything Arospeed. I hate to make the generalization but it is true. Their intake is not nearly as good as the AEM.
17s with stock suspension would be ironic because you want to get 17s for looks but it wouldn't really look good.
If it were my car, I would do the following:
ITR 22mm rear sway
AEM CAI
Falken Azenis (205/50/15) on stock wheels or on one of the wheels above
Solo short shifter with some cheap ball knob
Good set of pedals (less space between brake and gas)
AXXIS Ultimate (not Metal Master) brake pads, very versatile (just front)
*keep front pads for street*
Valvoline Syn Brake Fluid
Goodridge Stainless Steel lines
Acura OEM Front Underspoiler (I love these things)
Remove badges (Acura, and "VTEC") and possibly rear spoiler
Good SA helmet
SCCA Solo II membership
several HPDE and track events
Once I could outdrive my car, I would go Ground Control (400F/500R, yes I have driven a GS-R with these rates and it is VERY nice) with Koni Yellows. I would also invest in at least one racing seat. Down the line, harnesses and a 4-pt rollbar would be nice as well as a smaller diameter aftermarket steering wheel.
Remember, when you are racing a car you are doing it to have fun and improve the nut behind the wheel--you don't have to necessarily be competitive or spend big bucks on a car to have fun and give yourself a good platform to learn on.
You may not need most of the things detailed above, but before you ask what we suggest please tell us what you want to spend and what you want to do with the car.
Integraguy: listen to Chem; he gave you some important questions you should answer first, before heading down the road of making any modifications. If it's important to you to have a nice looking, uniquely modded car, with little or no intention of performance driving, then so be it. A C/F hood, bigger wheels and tires, and other stuff should make you happy. But please realize that if you have aspirations to auto-x, attend HPDEs, etc., then some of what you do cosmetically will hinder or interfere with your ability to "go fast." Also, little things (like the C/F hood) would bump you from a stock or street class in auto-x to a "prepared" class where you would have a woeful time trying to compete. Think about it, ask a lot of questions, talk to as many knowledgable folks as you can, think about it some more, and then figure out what direction you want to head. Have fun and good luck.
http://www.kingmotorsports.com/
click the mugen link
Casey, I am "kent, clark" on H-T but don't post often (my brother uses it more often than me). I just search stuff when I have a question or IM the pros on the site. I read practically every thread in the ITR and Comp forums. The Civic forum used to entertain me but not so much anymore. Sometimes there is something cool in the Integra, Tech, or Hybrid forums but not most of the time. If I am really bored, I check out some of the other forums. Some of the good people on the board are Neo, VTEConly (haha, sound familiar guys?), Teken, Mike K, HXguy, HXman, Matthewk, Houston, Crack Monkey, Cobra, Yoshi, Driven, and the S and M Racing guys. A VERY good source of information.
'06 Civic LX coupe
Harry: the new 15x7 "loaner" set of wheels I just got access to have a 42 offset. Do you think I'll need spacers to avoid any "rub" problem? Thanks!
It had not had its timing belt changed yet, so we did that immediately after we purchased it, at a local auto repair facility.They also changed the water pump and adjusted the valves. After picking it up, the engine seemed to vibrate much more than before. ( It actually hurt my ears). I took the car back to the garage that changed the timing belt, stating something had to be wrong, such as the timing or a loose vacume hose.
They checked it over again, gapped the plugs, but indicated that the timing was correct. We go to pick it back up tomorrow, so I am not sure if they have fixed it or not. They state that although there is still a vibration, it is not as bad.
I am not a mechanic, so I have no ideas what could have happened after having the timing belt changed that would result in the increase in vibration.
Does anyone have any suggestions as to what could have caused this. Is there anything special on these engines that they might have missed?
It might be worth next time to take it to the dealer or Acura/Honda independent shop since they work on these cars all the time. You might pay an extra $50-75 but most of the time it's worth it plus the dealer gives you a 1yr/12k mi. warranty on any the work they do. Good luck
'06 Civic LX coupe
'06 Civic LX coupe
