Visitor Agreement.
-- Don
Any Chevy truck owner that would like to know what I found out, please feel free to e-mail me. I've already forwarded the information to Dr. Phillips (tep) and quadrunner500.
Joe
Don't worry, PitaMan will fix it!!!
I know the GM 5.3 has excellent fuel efficiency for its displacement and performance figures, but could the problem possibly be that GM has leaned this engine out too much, and now it has the knocking tendencies? To my knowledge, the GM engines didn't have this problem until they introduced their Vortec engines.
I'm no engineer or mechanic (though I've been doing my own basic maintenance and service for over 20 years) but that clatter is reminiscent of an overlean condition. In an older carbureted engine that possibility could be readily ruled out with 5 minutes and a screwdriver. I'm not sure how to diagnose it in an engine that probably has more computing power than the mainframes of my childhood!
Just for grins, I tried a tankful of 93 octane to see if it would affect the "clatter"--no discernable difference to my ear.
tep
As for the obnoxious ones, I have a place reserved for them at their local Psychiatric Center. LOL!
Ray T.
After all, you called PitAman "testy" a while back!! We know how sensitive he can be. LMAO!!!!
I don't think 5W30 breaks down any faster than 10W30. My engine runs the same temp summer / winter - which is right around 208 degrees. If your engine runs warmer in the summer - just because you are stuck in traffic I would say there is something wrong with your cooling system. (If you are towing a heavy load I would expect a higher temp) I think I will stick with the owners manual -
I really don't think it makes that much difference - my 5.3 L has almost 30K - I have used one quart of oil in the last 10,000 miles. The way I understand it both oils are 30 weight when they are at operating temp - so the only difference is at start up.
I spend hours every week in Houston traffic - two summers ago the temp was 111 degrees - I was sitting on I-45 - stuck in traffic - A/C on max. My temp gauge never went above 208.
I think Ford even calls for 10w20 oil - but I am sure most owners know better and use 20w50 in the summer. Also a good idea to add 2-3 cans of STP or a quart of 90 weight gear oil if outside temp gets above 80 degrees. (LOL)
-- Don
I will admit to putting a can of this [non-permissible content removed] into my 69 Chevy Chevelle SS 396 back when I was a 17 year old punk - thought it would help my 1/4 mile time. Did nothing - I could never get better than 99 MPH in the 1/4. I really wanted to hit that 100 mph mark. I wore out a few clutches and several sets 60 series rear tires - man those were the days.
STP, wow there's a product not talked about for last 20 years, yup I used it once and never again. Did absolutely nothing for performance on my 69 AMX. I had better luck with Marvel Mystery Oil, now how many remember and still use this product ??
Ray T.
Along the lines of the motor honey. Sure quited-up them noisy lifters, but was only good for trading in a car (never could restart them). LOL
-Eric
Ray T.
Joe
-- Don
As for the GM V8 engine noises, It seems that GM knows they have an issue and are borderline on helping individuals with particularly noisy engines..I would not put anything extra in that engine so that if any long term problem occurred and the customer had been persistent in keeping after the GM dealer/mfg there would be no claim of "customer abuse"...If that engine died at maybe 80k because of the piston problem, I'd hate to hear them say "you're fault dude, you added junk to the oil....
Good luck with the warranty engine replacements, I look forward to seeing GM fix this one.
Rando
xyz71...I still own that AMX that I bought used off a dealers lot in 71, and it has the rare Big Bad Blue paint option & Go Pak w/390 V8 4spd. Yes it is a two seater, 68,69 & 70 AMX's were all 2 seaters. In 71 American Motors offered the AMX package on the Javelins thru 74. The Javelin was the sister car to the AMX the difference being longer wheel base and a rear bench seat.
Ryan......Menards blows?? I thought you left on your own for a better job.
Oh yea back to the topic....still got that morning wakeup "lifter tap" when cold on start-up for 10-15 seconds, has gotten no better no worse.
Ray T.
However, the idea of pouring a quart and a half of STP along with 20-50 into the crank case of a new motor spec'd for 5W-30 just really, really hurts my head.
Now that I've noticed, I can't find it anywhere, either. I'd really like to get a can or two to go with the rest my collection of automotive antiques; like 4-bbl, '57 Ford intake manifolds.
-- Don
Can't you get the same result in an old oil burning engine by using 20w50.
I did know a guy that "winterized" his car by changing the oil and adding 2 cans of STP. The temp got down to -20 overnight and the next morning his car would not even turnover.
It comes in plastic bottles now (and most places have a store brand too!)....I use 10w40 in that Nissan and swap 1/2 qt oil for 1/2 qt of goo...I mean STP...I don't think any more would be such a great idea.
If anyone had any real hangups about using it they could probably swap out 2 qts 10w40 for 2 qts 20w50 just to heavy up the mix I reckon.
I say again though for the GM new V8 issue stay with mfg recommended oil wt just because it looks like it is a design problem at the moment...only do the STP thing on older engines and use short changes intervals (3k/3 mo)...don't screw up a possible GM engine extended warranty on those engines...
Also use the lowest octane gas you can find that does not knock...it creates less carbon residue in the cylinders and gives better gas mileage to boot.
I personally believe in thicker oil/better metal protection over the thinner oil/better mileage idea but I don't get any paychecks from GM either.
I also keep vehicles for a long time, don't believe in leasing them....just depends on what is important to you.
see y'all in the morning
Rando
A couple of the people I sent this to asked me to put it here in the forum, so here goes:
I spoke to my friend, Steve Gehrlein, on his radio show Saturday morning.
I specifically asked him about the guy who said his engine got noisier when he went from hydrocarbon oil to synthetic oil. Steve's opinion is different from what others seem to be getting from GM so far; that it is caused by the piston skirts. Steve believes the rings are too loose on the pistons, and not the piston skirts making the noise, as GM seems to be saying.
I tend to lean toward Steve's opinion due to his experience in building and racing Chevy small blocks, and the fact that he owns one of the 5.3 engines. If he is right, this would better explain how you can have a noisy engine, yet not have lots of metal in the oil. I'm one of the people who always equated noise with something bad, usually metal-on-metal contact, so I couldn't understand GM saying the noise is no big deal.
He explained that because the rings are too loose, the synthetic oil makes a little more noise because it is designed to flow better, while still coating parts and avoiding a dry start. He says this causes more of the synthetic to flow out of the piston's rings at night while the truck sits for several hours. He said he would recommend going to a 15W40 or 20W50 synthetic for anyone not living in a very cold climate. He said he went to a 20W50 synthetic on his engine and it stopped the noise.
Tom Roper also provided some information he found that seems to be consistent with what Steve told me. Here's the link and a thanks to Tom for providing the information:
http://www.c5registry.com./2k2z06/page5.htm
By the way, I heard the noise first-hand yesterday. When Chevy upped the incentives to $1500 on a 2002 and $3000 on a 2001, I considered trading my 2000 S-10 for a Silverado with a 5.3. One of the trucks I drove also had a 6.0 engine. The noise, while not as loud as a diesel, sounded just like many of you have described. After hearing it, I decided for now to keep my quite 4.3 V-6.
Joe
I don't know how I feel about this ring too loose thing as that to me would indicate a bad wear problem with the rings banging up and down in the groove of the piston....
I don't know I think everybody is guessing at this moment...thankfully my knock has not reappeared in the last few hundred miles.
Bob
I agree.
As far as your discussion of additives goes I offer this advice...I use STP (Stops Terrible Pounding) in the summer and Marvel Mystery Oil ( Mechanic In a Can) in the winter. Also!! only put STP in a HOT motor and run that motor for at least 10 mins. to mix the STP well with the oil.
If, on the other hand, your engine knocks during normal driving and under load, then you DO have a problem.
Also, a few people have stopped the start-up knock after some injector cleaner and hard running (trailering with high rpms). This seems to point to a carbon build-up theory.
What I am wondering is if Toyota has done anything along these lines? Has anyone brought their Tundra in and gotten an explanation on the knock?
On another forum someone mentioned these issues could be fuel related, not a motor/manufacturer issue...
Still not sure.
-Eric
This morning i changed it and there was no knock.
hmmm
1. The knock on first COLD start-up in the morning. This happens when the temperature dips really low. I hear three knocks and then it goes away and it never comes back during the day. I only hear it with the door open and sometimes with the hood and the door open. I have not heard it with the door closed and I am inside the truck.
2. The second sound is the clatter that comes from the DOHC valvetrain and injectors. I think this is caused by the lack of oil in the valvetrain after the car sits over night. The truck sounds boomy/clattery and then it goes away.
Toyota has not issued any TSBs about this. Most of those who took their Tundras to the dealer got the usual "It is normal" answer.
I think those who really want their dealers to do something about it must be armed with more than the noise. They need to get an oil analysis done at blackstone labs. If the result shows a higher than normal rate of metal in the oil, then they have EVIDENCE of wear and can force the dealer to do something about it.
Once I get more mileage on my Tundra (currently at 1500) I will do an oil analysis and report back to you guys with the results.
"secondly, well, I won't mention that one"
good luck on this one now!
Why the attitude? When an engine sits overnight oil will seep back to the oil pan. What is so radical about this? When do you check the oil level on your engine? You let the car sit for a while, right? Why do you do that? Because you wait for the oil to make it back to the pan in order to take an accurate measure with the dip stick.
The same principle applies here. The car sits over night and the oil drains back to the pan, leaving the DOHC valvetrain with little to no oil. When you start the car in the morning, it will be noisy/clattery until the oil runs through the engine.
-- Don
