Visitor Agreement.
My Acura 1987 DOHC had short rockers which allowed for easy valve adjustment.
My 1995 Nissan Maxima V6 DOHC has hydraulic valve adjusters.
i ask this because after not reading here for quite some time, i decided to catch up on the Chevy topics. obviously you have caused your usual "rucuss" as there seem to be a lot of posts missing.
PLEEZ, if you can, quit with the emotional replies and HOGWASH. it's old and annoying. i have grandchildren with better dialogue than you.
this topic and others like it are for chevy/gmc owners that would like to know facts that concern their vehicles.
Well the story is (From Corporate Saturn) that what we are all hearing is normal valvetrain noise due to the fact the engine has an aluminum block and head and instead of having a timing belt, it has a steel timing chain and the noise I am hearing is all that noise coming through the engine from the chain and the solid lifters. I think they mean tappets, I looked at a cut out of the engine while I was at the dealer and it shows what looks to be a large lifter about the same size as the valve spring (in diameter) that is on top of the valve and the cam lobes riding on top of that lifter or tappet. Those are tappets right?? Well anyway, they want me to drive it for a little while longer and keep them posted if the noise gets any better or worse. Maybe changing to synthetic oil might help get the oil up there quicker to quiet the noise faster. I duno...we'll see.
Bob
Hope the new Rado doesn't have any problems.
Thanks..........Ray T.
Be careful here. I would suggest the GMPP major gaurd to anyone who has a truck. I purchased it for my 1997 GMC Sierra and it paid for itself in spades. It is prettymuch a hassle free repair on the major gaurd. The Basic gaurd only covers the drivetrain. I have yet to get a full component list of what is covered but I am sure it does not cover a/c and such.
I had called the GM CAC to document the engine knock. They in turn offered me the Basic gaurd 5/100.
FYI
Walter
It's funny though, I also got the questionaire, sent it back and have heard nothing from GM. I told them that if engine knock is nothing to worry about then back up their words with an extended warranty to 100,000 miles unlimited years, maybe that pissed them off who knows? I also don't think the knock will effect the life of the engine but I have never had a new engine make this kind of clatter on start up even if it only lasts for 30 seconds or so. It's not normal!
I will e-mail my fax give me all the particulars...thanks
Ray T.
My knock seems to last alot longer than 2 minutes. I have yet to time it, but by general counting it lasts 3 minutes. Both of my analysis I have sent off were done by Blackstone Labs.
I posted the second results in the maint board
gator36 "Oil Analyst Sites." Feb 7, 2002 12:25pm
Post 53. The justification is off. But the numbers are in this order. Last, Average, first, Industry average.
So far they state the Copper is from the factory fill oil but we will see on my next sample.
The high's as I see it are the copper being more than three times the Universal average
and the Tin being just slightly above normal. The high readings at the bottom are for detergents
added to the oil.
I am sending another sample in on Monday. I think with the samples I am covering my rear.
kip
-- Don
http://www.autonews.com/article.cms?articleId=38302
Are you Dodge boys feeling left out? No prob; you have a web forum all your own to discuss your numerous problems. Here 'tis:
http://www.allpar.com/cgi-bin/ub/ultimatebb.cgi?ubb=forum&f=6
Awww...Ford diesel owners suddenly get very quiet about their coolant loss problems? Let's not leave them out--they also have their own support group:
http://www.interstat.net/ford/
Now, if you Dodge and Toyota boys and girls will now quietly leave along with your 'perfect' trucks that NEVER break, maybe this forum can get back to helping people with their Chevy and GMC trucks!
Ray T.
So could the both of you try e-mailing me the particulars of your extended warranty GM gave you related to the "knock" issue. Or fax me the info at home 845-462-6297
Ryan
Thanks again.......
Ray T.
Ryan & Martin, you'll be happy to know I mentioned your correspondance related to an extended warranty after 3/36 runs out and the rep said that is what GM has been doing in most of these cases.
To Be Continued..............
Ray T.
it is signed also
engine block, cyl heads, intake&exhaust manifolds, all internal engine components, valve covers, eng. oil pan, timing gear cover, eng. oil pump/oil pump housing, eng. seals and eng. gaskets.
It states to keep letter with the truck and that the service Mgr should contact Chev Cust. Assistance for confirmation and authorization of a claim.
I later contacted the BBB and got a 6 yr/100k value guard zero ded. warranty.
ryan-
so you did get a scanner after all...hehe
Ray T.
Ray T.
kip
