my suzuki vitara 1992 has a miss fireing problem! i have tryed sevral things up to this day wich are change
Ht leads , spark plugs , dizy cap , cleand out fule tank not sure what else to check/change
tha car missfires for about 20 mins the it seams to clear its self and runs fine ...
but the if you stop the car and try star again the hole cycle starts again ???
any idears ?
cheers
Danny
At minimum, you should get a replacement part from a wrecker or the system wreckers have access to. You could also determine who is the best auto electric mechanic near you and have them look at it.
No need to buy a new one from a dealer. From the forums, this is the first case of this I've heard about, so (a) this may not be the real fix, and (b) a used module should be fine.
the12volt(dot) com website has participants who could help diagnose this. And there is suzuki-forums(dot) com where you could also ask about this.
Did you ever figure out what was wrong???!?
Are you having any electrical problems with the cabin lights or the head lights. We bought the car new and seems that we have changed light bulbs numerous times for the cabin and also for the head lights. Very frustrating.
Both cars without any modifications (Tires, shock-absorbers...-original).
I'm very absent to find thst the fuel consumtion of the G.V is significantly higher :9 KM/liter compared to 12.5 KM/l , for the same speed (average-100 KM/h)
1. What are the main reasons for this difference ?(The G.V's wight is only 100KG higher.)
2. Are there any knowen (not theoretical) "Minor" motor changes (i.e - computer parameters)that can reduce this consumption ? Roughly speaking: Estimated improvment? How much profational should be the Mechanicare to do this changes? What will be the "cost" for this canges ?(i.e- less power ...).
I have an 08 GV and the ticking noise you are hearing is unfortunately inherit with this vehicle. The ticking does go away after warm up, however you sometimes hear it when in Park and idling but once in drive it is no longer audible. Hope this helps.
Suzuki USA Customer service will be receiving my complaint! Plus I only have 28k miles on this vehicle!!! :confuse:
About my 03 Vitara 4Door SUV, so far 47k milage. Starting from Oct 2010, weird thing happened.
(1) It's good to drive normally for ~20 minutes (I seldom drive it over 20 minutes), even on stop-and-go local. But if stop the car, then after ~5 minutes, I can't start the car again :sick: , I can clearly hear the engine is bumping and shaking, with the clicking, and all lights on, it simply can not start. But after leave the hot car idle for 15~20 minutes, I can start the car again and drive ok.
(2) And worse. For couple times, if I drive the car on trafficed local, stop-n-start, again and again, after ~20 minutes, I can hear the engine start clicking noise, some shaking, and kind of back-force, then the car engine just shut-down, and no way to start it with similar pattern. Similarly, after leave the hot car idle for 15~20 minutes, it came back alive again.
Any suggestion, and any great idea so I can check it by myself before bring it to the shop? Thanks a lot!
I looked under the dash on the drivers side and did not see anything the resembles the OBDII connector.
Also is anyone else having issues with the ESP? My ESP light came on about 4 months ago. :confuse:
I'm in positiion of disassembling the SOLONOID.
I findout that there are 2 screws in the bacck of the SOLO.,
BUT i'M AFFRAID that this screws are for seperating the SOLO.[b] front-case [/b] from
the starter.
If this is the situation:
1/ does it mean that unscrewing this 2 screws
will leave the SOLO. back-case attached to the STARTER ?
2. If so, isn't it reasky to unscrew this screws (may cause inner Solon. parts to dismantale)?
What about disassemling the STARTER?(iF THE SOLO. is attached to it,isn't this step more usefull??)
By the way: with what type of key can I open the 2 SOLO. screws ??
If it's necessary to disassemble the Starter, pls' let me know
I have a 2002 Suzuki Vitara and I can have the heat on full, and all I get is luke warm air. Its been this way forever. Have been noticing the temperature going up. And now It almost goes into the red at stoplights. Recently changed the thermometer, water pump and today the rad. Well, It did not make one bit of difference. Am waiting for appt. to check rad pressure, or something to tell me if it is the head gaskets.
Anyone have similar problems?
Thanx for your time
http://www.amsoil.com/mygarage/vehiclelookup.aspx?i=1&zo=525794
