He's right about the thermostat pipe which goes under the (driver's side)cams and has a torx bolt holding under the dipstick which is difficult to get to as is most everything on this engine..
You do have to remove the wiper [non-permissible content removed]'y. for upper plenim removal.
I would suggest trying to solve your problem any other way possible before disassembly of the above items unless you're a patient doublejointed mechanically inclined genius.
I've done hundreds of oddball engine situations but this one takes the cake.
If you have a leak, try using a stopleak product, if you have a bad thermostat and coolant flows ok, put another thermostat in a radiator hose.
I spent the last three weeks taking a head off and putting it back together.
The machine work is exceptional but the engineering makes it almost impossible to repair the engine in the car. Cadillac was experimenting with the Opel/Catera in Germany to develope the now CTS which is a great car after learning all the issues with the Catera which was overdesigned with intentions of being a superb automobile.
Dave
Book says 2.2 hours labor but that of course if after you've done it a few times.
This is the Catera forum. You need to be in with the Escalades
So you may wish to cut and paste your question and put it over there.
Visiting Host
Also, last week a problem with the shifter started. It would not let me move out of park. I took the cover off the shifter and now every time i shift out of park i have to press this lever to release it.
Does anyone have any idea what would cause either of these issues?
Did the engine run rough for awhile and then clear up? If so, then could be a blown head gasket causing a rough run for a bit until the coolant is burned up, the code would then indicate a clyinder miss...excessive fuel could also do the same, like a leaking injector, however that's not likely. Check the coolant level, is the problem consistant?
Ben
Chances are your ok with all that excess stopleak out.
Please help!!
Cissie :shades:
As far as shutting down the alarm, you have to insert the key in the driver side door and turn it and the alarm should turn off.
My car used to stall all the time unless I pressed on the gas because of the bad MAF. The dealer wanted to charge $700 for parts + $400 for labor. Try cleaning this first and see if it helps.
Any ideas Thanks in advance
I am having problems starting, when the tempersure is hot my car would not start back after being park I took it to gm they said the starter I fix but the same problem please help ,
I had the same problem, checked all, no one mechanic had idea of the problem, very strange (the mechanics).
Finally, with a good logic, I guided the "research" and discoved the guilty one: the Neutral Safety Switch (NSS). Study what's the function of this switch!!!
The solution was very easy: disconect the NSS and make a direct connection to the starter ($25.00 to my electro-mechanic). ATENTION! disconnecting this switch will permit you start your Cadi not only in Parking and Neutral - this may be dangerous if you have kids or forget shift to P or N !!!!
If you want to buy new NSS, this is a good decision too. It may cost starting at $45.00. Good Luck.
MD
If not, then possible electrical problem from setting. WD-40 removes moisture which might be causing circuits to malfunction. The computer connections ( 3 of them near front left near battery) have twist on caps which could be sending incomplete signals.
Only a guess! If not really overheating, driving for awhile might eliminate the problem on its' own. Dave
