Repairing with tape
The power steering fluid line has been eaten through by contant rubbing against another line. Both are made out of metal. The hole is on the outside of an inverted U.
I've considered sticking a piece of rubber hose over the hole, but tape seems so much easier. I'm looking for some good heat-resistant tape to use, that will stand both the heat of the line, the fluid trying to leak out from below and the other line rubbing against it.
I'd be grateful for any tips on if tape is useful in this situation, and if I can expect any problems from it. Thanks!
if you have to try getting a pressurized line down the road a piece, rubber gasket material over the hole and covering it with hose clamps from before the issue to after it, all screwed tight, should get you a reasonable distance. probably won't work with power steering or a/c lines, but on tranny cooling lines and such, it beats walking.
hey wubberman- why not just drop the logo and enjoy talking to everyone here? you seem to have some pretty good ideas, just drop the pic, and stick around pal.
That repair lasted for a few days until I could get it into a garage. I always carry a roll in our cars now.
Dave
