'17 Chevy Volt Premiere
Secondly, manuals have numerous advantages like being able to push-start them in a pinch, starting off in second gear in snow, being able to react twice as quickly to gaps in traffic as you're in the right gear, and of course, the big one, the cost of a replacement clutch is 1/6th of the cost of an automatic. When you're buying a used car, that replacement transmission is not a matter of if, but when. And at ~4K for a replacement automatic in that Mazda, it's a big issue someday.
Of course you should go with the newer manual with a lot less miles and a dealer to back it up (the private party should be asking 9K, btw). It also gets at least 3-4mpg better in real-world driving.
As for the problem of driving and fatigue in traffic with a manual, it's 100% about driving habits. The skills that we learn when driving an automatic are not too surprisingly, incompatible and different than those which you use when driving a manual. You just need to un-learn the automatic habits that you picked up.
A typical driver in an automatic car, because the torque converter is always engaged, tries to maintain a constant distance between themselves and the car in front of them. Also, they tend to ride the brake a lot and have to press on the brake at stop lights. This is all due to the fact that the car will creep forward at a stop or roll on to its favorite coasting speed in that gear. If you don't reign in an automatic, it'll just keep going and going.
With a manual, you need to drive like a Big Rig driver does. That is, you pay attention to the gear that you are in and blithely ignore the gaps around you. You do not try to maintain distance or speed down to the last inch, or even the last ten feet. By stubbornly staying in gear as long as you can, and letting the engine wind up and down, you go from having to press the clutch every 5 seconds as you try to match traffic at all times to once every minute or two.
The last traffic jam that I was in, I counted. I shifted 4 times in 15 minutes. Most of the time I just left it in 2nd gear and as long as the car wasn't at a complete stop, I could get going again without shifting. Considering that the car had a 2nd gear range of ~2mph-40mph, shifting was optional as long as I left enough space in front of me to to always keep moving.
And it also works for higher speeds. Since there is no roll-on effect where the car wants to accelerate slowly (especially true when on a slight downhill grade with an automatic), you can modulate the car's speed quite effectively by just the throttle. I hardly touch the brakes, either, when driving a manual.
And, of course, it's different. Even the most bland econobox with a manual is still a bit manly and adventurous and all of that. :shades:
I have never had to replace an automatic transmission in any car I've owned. But that's unimportant too. There are advantages and disadvantages to both kinds of transmissions. It comes down to what you prefer.
For just a few thousand more you should be able to get into a brand-new entry-level 2013 with full factory warranty. Financing is very low right now.
In the long run, I think you'll be grateful you did.
Mazda dealers should be willing to deal.
Try
www.carwoo.com
and make Mazda dealers within 100 miles bid on your business.
Just bought a new 2013 Civic through Truecar (https://amexnetwork.truecar.com). Also tried Carwoo but their prices were much higher. Lowest offer on Carwoo was $17.8k but got it for $17k from Truecar.
And yes, Truecar is a good idea too. Try both!
It's closer to a $5K difference by the time you are done.
I also got a curveball from my insurance agent who said it'd be somewhat expensive for me to insure versus other makes and models I was looking at (mostly hondas). Anyway, I'm probably not going to go with a mazda 3 now. I'm trying to find something older that will be cheaper to insure, yet still reliable and easy on gas. I'm open to ideas/suggestions.
GM and Toyota used to have a joint venture plant in California. They made several cars there:
http://en.wikipedia.org/wiki/NUMMI
It's closed now, but the Toyota Matrix and Pontiac Vibe are the exact same car other than interior styling. They are essentially bulletproof, can carry a decent amount of stuff, and get good gas mileage.
I'd look at a 2009/2010 Vibe. This is the larger 2nd (current generation) model that looks exactly like what you find in a showroom new from Toyota (bigger and nicer inside). So why get the Vibe over the Matrix? There's a good 10-20% price difference due to "Pontiac" being out of business. Of course, the parts are 95%+ interchangeable. And GM actually had more interior trim options as well as Onstar available.
2010 Matrix (autotrader)
Highest Price:$22,700
Lowest Price:$7,700
Average Price:$15,478
2010 Vibe
Highest Price:$18,995
Lowest Price:$8,990
Average Price:$13,893
Right in your price range with a little haggling.
25/31 mpg highway.
My other recommendation would be to consider a classic car. You can get some amazingly good deals on classic and soon to be classic cars. My top pick for something modern is a BMW E36. (92-99)
http://losangeles.craigslist.org/lac/cto/3659727450.html
Inexpensive, reliable, fun to drive, and if it does ever need repairs, you've got a $6K+ nest egg. And it's the real deal. A M3 Convertible in something other than white. It's only going to hold onto its value at this point. MPG? about 20 combined. But it also uses regular gas, which isn't so bad. That 5 mpg difference takes a LONG time to make back. Close to a decade just based upon the initial price difference.
Your soul will thank you every time you drive it.
I have a Pontiac Vibe. It is a very useful vehicle, also extremely utilitarian. If you want basic, no frills transportation, it's a great car. They are sometimes skimpy on safety features. I think ABS only became standard in 2008. So insurance is sometimes higher. We have had very few problems with ours. But I wouldn't want it to be my only car.
For the same reason, a used Honda is not always such a bargain. Recent used Hondas have such high resale value that you might as well go for a new one.
Seriously. A dealer with a 2 year old Accord or Civic will probably try to sell it at close to the price of a new one with discounts.
So my 2 cents is to still go for new and use the low financing that almost all makes are offering right now.
As someone here mentioned, you can usually get a brand-new 2013 Civic LX, which is a bit roomier and in some ways better than a Mazda3, for about $17k. Look at the math of what that would be over 5 years with the 1.9% offered by Honda with a low downpayment.
If you're anywhere near Nashville, Crest Honda there is selling 2013 LX Civics for 16,990
http://www.cresthonda.com/index.htm
The Sandman :sick: :shades:
2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
http://en.wikipedia.org/wiki/File:Matrix_Interior.jpg
Those metal strips are rails for tie-downs. A nice touch.
The 2008 and older ones are a bit like a Corolla wagon, which isn't bad, really. But the 2nd gen are noticeably better. If we're talking econoboxes, getting some cargo space out of it isn't a bad thing.
I don't know why so few companies make small wagons any more. It's a shame, since a wagon is much better overall than a sedan of the same model. And, yes, they do make a Civic and Accord wagon in Japan. We just don't get it over here.
Personally, over the past four or five years, I have found it not difficult to buy under the TC price. Essentially the prices available on TC are set by the dealer and they are designed to intice folks who do not enjoy negotiating. They are really not much different than the no-haggle prices some dealers employ. While such prices often represent a substantial discount off MSRP, they are rarely the best price possible.
The best prices are almost always attained via the traditional negotiation process. Negotiations are most effective when they are based on research and knowledge.
An effective method to price a vehicle is to obtain, from Edmunds or other on-line sources, the invoice price, the dealer holdback, and the incentives available to both the dealer and customer. Reduce the invoice by the holdback and incentives. Add freight and whatever you think is a fair profit. The result should be our initial negotiation position. The negotiation should start at that price, not at MSRP which how the dealer wants to negotiate.
Also this calculation will reveal the true value of the TC price.
The real problem area of many deals is the trade. I think it is very hard to get a real estimate of the value of the trade. My method is to take Edmunds, NADA, and KBB at the good condition level and average the values. I then add a bit if I believe, which we all do, my vehicle is better than average.
This calculation at least provides an idea of what I should expect for my vehicle. This process seems to work as I have always gotten close to my number. Of course, almost always, the initial offer from the dealer is a low ball number.
With that said, though, some people learn and can drive them OK, but still hate driving manuals, and others are not the most gifted, so it takes longer and/or they make more mistakes than most, so they don't appreciate driving them.
But I feel everyone should learn.
My preferences are: Japanese make, reasonably new (2005 and newer), 4 door sedan. Things high on my priority list are Toyota Corolla, Honda Civic, Mazda 3, Subaru Impreza.
Any suggestions? And any ideas what would be a good place to search for such cars? I feel craigslist seems to offer better deals than most websites, perhaps because the middle man is cut out so I can get it a little cheaper. Do you guys agree that craigslist is a good place to search for deals?
The IS250 is too soft and underpowered, IMO. The IS350 is basically a Infiniti G35/37 competitor. Great, but lacking that "sport sedan" balance that you typically get out of a European car. And the current generation also cost a hefty premium as well. Similar to say, a Cadillac CTS - the first gen models are dirt cheap now compared to the more modern design.
The first poster has a much wider range of criteria and a lower budget. That said, the IS300 would also be a good second choice for him as well.
http://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?&listingId=33653513- 0
This is a typical example. Avoid dealers like the plague in the 8+ year old range as the car usually will either be vastly overpriced or salvaged or have some other issue. And you want paperwork as well on it, of course. Yes, he's asking $2K more for it, but it is low miles and you can haggle.
A bit over your budget, but not terribly so considering that you get over a basic Toyota.
http://www.314allstar.com/used-cars-st-louis/2007-mazda-mazda6-i-grand-touring-4- dr-car-36035a
Good luck & keep us posted on what you do. And if you get it, welcome to the club. Zoom zoom!
I have a 2010 3s that I have owned for 3 years/36k miles. It was an early build of the new body style (smily face). Despite being the first 6 months of the new body style it was build EXTREMELY well. The build quality and reliability of my '10 3 has blown my '03 Volkswagen Golf and '06 Volkswagen Jetta out of the water.
Tight as a drum even after 6k miles on horrendous Atlanta in town roads. One warranty repair that was well under $200 and no other issues to report. Coming from a Volkswagen owner this does not mean much, but I have to say my 2010 3 has been absolutely fantastic!
My 3 still drives like new, except for normal wear on the leather seats anyone who rides in my car still thinks it is new. Mazda builds some fantastic cars to say the least. Have had a truly good experience with my 2010 3s.
One con. Be wary of door dings!
Now I have taken the car back to the dealership four times for the heater. When both sides were set for 80 deg, the right blew out tepid air and the left frigid air. The service agent felt both sides, agreed that something was wrong and set an appointment to repair. When I took it in, they couldn't replicate the issue and told me they couldn't fix it if they couldn't replicate the issue.
The second time, both vents blew only frigid air until the dail was turned to 88 or 89 deg. At that time the air changed from frigid to heat blast. There was no in between. Once again, I took it in, they witnessed the problem and set an appointment for repair. Again then could not replicate the problem, so they could not fix it. I had them check the records which documented that they had witnessed the problem and they agreed that they had indeed.
The service manager then began to explain to me that the new Nissan Altima has a heat sensor that checks the outside and the cabin air temperature and will not kick on the heat or air if the need is not indicated by their sensor.
At that point, I threatened to call the owner who is on TV regularly saying "If it has our name on it, you have our word on it."
Immediately, they provided a loaner and kept my car. The next day, they called to say that they have now ordered parts.
I have driven a Toyota Camry since 1973, each of them had almost 200,000 miles when traded. I have never had a defect or even a repair beyond basic maintenance. I am beside myself with buyers remorse!
* must take regular unleaded fuel (no premium),
* have an MPG higher than 17/23,
* i would prefer if it can have a hitch installed
I currently have a 2005 Subaru outback Limited XT that I am trying to sell. It is a great car, but I am really trying to save money on gas and this cars "always on" turbo doesn't help. I also don't make a ton of money, so whatever I sell the car for is what I have for a new one...I could potentially try a payment plan and use the sale money to get started and use the time to search for other income, but that doesn't seem so smart :P
Subcompact, compact, midsized? Need to carry large items on a regular basis?
If you go with a somewhat smaller wagon or sedan than the Outback you will get better mpg. Another possibility is the Subaru Impreza, though the older models don't get very good mpg compared to today's.
to buy some trailer laying around. And you don't look like some dufus at Menards. Oh I forgot...women love a guy in a pickup eyeyyh
i have great credit score.
i never lease a car before, so i saw the car dealer has speical offer. after my lease, i can pay in the rest of the full price and buy that car, is that really worth it?
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Under $26K street price after discounts
Do well in new small overlap crash test
Keyless passive entry and push button start
Backup camera
Rear seat HVAC vents
Bluetooth stereo streaming
Remote start
Well controlled road and engine noise
Best possible initial quality and lack of interior rattling and squeaking noises
2 cars that seem to best match this are the 2013 Nissan Altima SV and the 2013 Accord EX
Advantages of the Accord.
Small overlap crash test results are better (Good vs Acceptable)
Prefer the looks of Accord inside and out vs Altima (but not by much).
Side view camera is nice.
CVT performance is more responsive
8 way power drivers seat on Accord EX vs 6-way Altima SV
Manufacturer's extended warranties are priced about $350 less for top end 8 years zero deductible option (Lower cost extended warranties imply better expected long term reliability).
Maybe less depreciation (resale value dollar amount will surely be higher, but real depreciation cost depends on initial purchase price).
Advantages of Altima
Pricing is better especially since I can buy an SV without an unwanted bundled moonroof that comes with Accord EX (Accord LX and Sport are missing required features in my list). Lack of moonroof maximizes headroom and eliminates a source of rattles and future repairs).
Remote starter for Altima SV is standard factory installed vs dealer installed at several hundred dollars for the Accord.
Spit fold down rear seat much more convenient than Accord's one piece folding rear seat
Maybe a bit quieter
Maybe front seats a bit more comfortable
Maybe slightly better fuel economy
Automatic backup camera lens washer and blow dryer is nice to clear camera lens when obscured by dirt or raindrops.
Headlights turn on with wipers
Fill tires with air without need of a tire pressure gauge
Nissan more experienced with mass production of CVT
2013 Altima was released many months earlier than the Accord, so more inline fixes have been done and dealers will discount more since it is no longer so new.
Both cars are first year models of new designs and both have had some 1st year issues that are still being worked on (stereo systems that freeze and need the car to be restarted to reset, CVT tuning issues etc). Maybe I should wait for 2014s for either one?
I haven't checked on scheduled maintenance and insurance costs yet, so I don't know if one has an advantage over the other there.
Anyone here have any opinions on these two specific car models against each other?
One big issue for me is resale value, which you touched on. I don't know how long you plan to keep this but the Accord will likely not lose as much particularly in the 1-3 year window. Nissan puts a lot of these on the rental lots which is partly responsible for big drops in the first few years. Assuming the Accord continues their historical trend, they usually hold value very well even over the long-term.
I spent a weekend with a 2014 Accord Sport CVT a few months back (my bro-in-law runs the body shop for a big Honda/Acura dealer and he brought it home for me). I’m still not a CVT fan and I don’t think I ever will be, but I must admit that the Honda CVT is light years ahead of Nissan and any other I’ve ever experienced!
I’m just excited that the Accord is a great car again. I’ve owned a few Accords and still have several 2005-2007 models in my family. I despised the 2008 model and it never grew on me. The 2013 feels, sounds and drives like a Honda. Enough said.
In addition to the Accord, you should at least take a drive in the 2014 Mazda6 i Touring! It is a stunning beauty, inside and out. Ward’s Automotive just named it to their 10 Best Interiors of the Year and the reviews all seem to range from fantastic to amazing!
It’s performance specs are virtually identical to the Accord’s and it has an exceptional 6-speed automatic transmission. The interior looks as upscale and attractive as the outside.
A couple of months ago, I had to take our CX-9 to the dealer to have a headlight assembly replaced under warranty. They offered me a loaner and I asked if I take one of these babies....and they did. It was immensely comfortable, as quiet as my 2012 CX-9 GT (which cost almost $40k) and I was amazed by how responsive the new Skyactiv 2.5L and 6-AT felt. I never felt the need for more power, and I have a heavy foot.
I was especially impressed by the quality of the interior materials and how well it was assembled. It was rock solid, even over moderate bumps or potholes or bad pavement.
The Mazda6 i Touring w/ Touring Tech Package would get you all the features you mentioned above. It would include Push Button Start, Advanced Keyless Entry System, Bluetooth audio and phone connectivity, Rear seat A/C vents and it was a very quiet and smooth ride, even with the gorgeous 19” wheels! It also does NOT have a moonroof, which seems to be a plus in your book. The Remote Start feature is a dealer-installed Mazda Accessory feature.
In addition to all that stuff, it also has a lot of other very nice features-
Bose 11-speaker Premium Surround Sound audio system
SIRIUSXM & Pandora capable
Navigation System
Voice Command for Audio & NAV systems
Dual-zone auto climate control (w/ rear vents)
Auto-dimming Rearview mirror w/ Homelink
Driver’s side auto-dimming mirror
Heated side mirrors w/ integrated turn signals
Trip Computer
And it also has some impressive and useful safety features-
-Blind Spot Monitoring System (Accord EX also has, I think)
-Rear Cross Traffic Alert (for backing out of blind parking spots)
-Rain-sensing automatic wipers
-Smart City Brake Support (SCBS)- under 24mph, it monitors for vehicles or obstacles in front of you, the brakes automatic tighten to provide the shortest stop possible, if no driver action is taken, it will automatically brake and cut engine power to avert or minimize a collision
-E911 automatic emergency notification- in cash of collision or airbag deployment, it will automatically call 911.
There are several other nice touches that also give it a very upscale feel. The steering-wheel, shift handle and parking brake handle are all leather covered, both front visors have auxiliary extensions, front and rear map lights and the center armrest slides to adjust. The power driver’s seat is also very comfortable and has manual lumbar adjustment.
According to KBB, it is also the current Resale Value champ. Consumer Reports got 32mpg overall, compared to 31mpg for the Altima and 30mpg for the Accord. IIHS rates it as a ‘Top Safety Pick’ slightly ahead of the Altima, if you dig into the numbers. The Mazda6, Accord and Altima are all within a fraction of an inch of each other in every dimension, but the Mazda6 back seat has a longer cushion to make it more comfy.
A Touring w/ the $2k Tech Pkg is currently selling around $25,800 according to TrueCar.com.
I just bought a CPO 2010 Acura TSX V6 a few weeks ago, but I still may end up with a Mazda6 before the year is out. Within the next few months, Mazda is adding a 2.2L turbodiesel to the lineup and, if it’s as good as the reports of pre-production models say it is, I may not be able to resist....and I got such a steal on the TSX that I could easily trade it in without losing any money! Then we’d have a CX-9 and Mazda6....time will tell...
One advantage of fleet sales is that I will probably be able to rent a 2013 Altima somewhere and drive it for a full day or weekend rather than being limited to a 10 minute test drive of an Accord with salesman riding along.
2014 Mazda6 is not really an option because you cannot get all the features I wanted (for instance, proximity sensor passive keyless entry) unless you get the maxed out top of the line model with leather and the crappy 5 inch TomTom navigation for around $31K.
Mazda6 is also the newest released car, so it may have unknown quality issues since there are not many owner reports from people who have driven them more than a few weeks and a few hundred miles. Also, probably difficult to get good pricing since it was just released and inventories are probably very low.
I'm looking for a car that has every feature I listed with a sales price under $26K after discounting.
I plan to keep the car for around 7-8 years and might buy a factory extended service contract with zero deductible for about long. Toyota, Honda and Nissan are the only car manufacturers I've seen that even offer 8 year zero deductible warranties that cover everything except a small list of exclusions.
I considered the 2013 Dodge Charger SXT V6 8 speed automatic for a day since that vehicle also had the features I wanted within the price rage (after big discounts plus rebates). It looked like a viable option until I looked at Chrysler's pricing for extended coverage and even at these prices, it had $150 deductible per visit. I think it was more than double the cost of the prices I found for even a zero deductible 7 year 100K mile service plan on the Accord and Altima. If there are massive discounts available on the service plans somewhere, I might look at the Charger SXT again. The fact that the Chrysler service plans are so expensive compared to the Japanese brands says alot about how much they predict will need to be spent on repairs during those years.
Chrysler does offer a option of a "Lifetime" unlimited mileage service plan for even more money. I guess they are expecting many people to not get full value out of it because they will sell the car or it will get totaled and the warranty will be lost at that point.
After 7 or 8 years, I'm not sure resale value of an Altima SV vs an Accord EX of the same mileage and condition will be that much different.
Even if the resale value of the Accord is higher after 7 years, that does not make it cost less to own overall unless the difference in resale value is greater than the extra money spent up front on the higher initial purchase price.
I have not driven either yet, so if I hate the way one drives or can't get comfortable in the seats or armrests etc or find some kind of deal-killing shortcoming during the test drive, then I will get the other car. If I like both, it will be mostly about the total cost of ownership over 7 or 8 years.
So, now I will shop the Mazda also and start monitoring Mazda forums to see what kinds of common problems owners have been having, if any. I like the looks of it anyway.
I'll check on extended warranty costs for the Mazda also. Even if I don't choose to purchase an extended service plan, I will use the service contract pricing to gauge how confident they are about repair costs it will need during the coverage period.
The cheaper the factory backed service contract is with zero deductible, the more likely I will be to buy the car. Less cost and less hassle
of repeated visits to the dealer for repairs covered by warranty or not.
The one thing I don't like about the Mazda 6 with that package is 19 inch wheels. I don't even want 18 inch wheel, much less 19.
It looks good and people buy them for looks without thinking about the consequences.
Much higher tire replacement costs.
Shorter tread life, so you are replacing the tires more often.
More road noise.
Bumpier, rougher ride.
Massive turning radius like a big truck.
Reduced fuel economy.
Increased risk of wheel theft (higher insurance?).
If it is noisy enough to comment on, it probably isn't the car for me.
The "base" model Mazda 6 Sport has smaller wheels and may not be so noisy on the road, but it cannot be optioned up to even the level of an Altima SV.
