Well put. I'm tired of hearing how BMW horses are superior to "other" horses, blah blah blah. There's much more to acceleration than just horsepower, such as programming and gearing, as you mentioned. With the 330i, BMW spent their money on these aspects. And with its $8000 premium over the G35, you'd hope that they spent their money on something.
In any case, I expect the RL and M35 to be class leaders in terms of 0-60, with the 530i, E320, and GS300 about a 3/4's of a second back. That gap will surely close when these three up their V6 engine output.
jrock65 - It isn't BMW's fault the Infiniti can't get a 340hp car to outrun a 290hp car. If you're going to boast about hp the 0-60 times need to back it up. BMW doesn't even brag about hp and yet in most cases they're either as fast or faster than their competitors, right now. Gearing and what not are just excuses for Infiniti not being able to make the hp advantage mean anything in the real world. When BMW or MB do make a point about hp they blow the other cars off the map, usually sucking out their windshields.
M
What are you talking about w/ "bragging" and "backing things up" and "BMW's fault"?
The current M45 and 545i Auto both run 0 to 60 in about 5.7 secs.
The G35 Auto runs in the low 6 second range, with the 330i maybe a tenth of a second or two behind it.
I'm sorry, I'm just not impressed at all by BMW's supposed technological superiority at squeezing the most out of their horses. It's a different model for achieving performance based on each company's cost/benefit analysis. Infiniti uses higher output engines with less efficient gearing, and BMW usese relatively lower output engines with more efficient gearing. In the end, more or less the same straight-line performance.
Ditto for the Q45 vs the LS430. This has been well documented.
"Infiniti uses higher output engines with less efficient gearing, and BMW usese relatively lower output engines with more efficient gearing. In the end, more or less the same straight-line performance."
In the end that means BMW has a more efficient drivetrain. There is no way around it. What is the point of boasting about more hp only to wind up with more or less the same performance? There is no point is having a killer engine and then hindering it with poor gearing and/or an inefficient transmission. Makes no sense. Audi has had similar problem too with certain models.
M
I don't see you your point here. Infiniti doesn't need to make excuses. The G35 competes very well with the 330i in terms of "real world" power. Maybe Infiniti is overstating hp, BMW understating hp, or both, but it doesn't matter.
Now, if Infiniti is charging more for the G35 than the 330i for its 35 hp advantage, then I could see the point, but we all know that that's not even close to being the case.
Yep, it was all marketing. Obviously, it didn't help the M's cause.
"In the end that means BMW has a more efficient drivetrain."
I don't disagree with you. But my point is that it doesn't matter, as long as real world performance is similar.
The same could be said for the 5. The Audi actually had a much better interior with better fit and finish than the new 5 series, despite dating back into 1998. Also, the active steering thing is just a plain bad idea. There was more than a few times where I was driving the car, and I would either steer too much or not enough into a corner because the ratio kept changing on me. I rarely parallel park, and when I do, I really dont mind my car's 2.5 or whatever turns lock to lock. Its not that hard. Maybe if the AS was used only up to 5mph or something it might be more useful for people who have to parallel park every day, but otherwise its totally useless, and could be considered almost dangerous if you're not paying attention to how far the computer decides to turn the front wheels at 26mph, or 37mph.
The G35 is bigger than the 330i, but not too much heavier. I believe the difference is about 100lbs, despite the size difference.
Did I say somewhere I'm buying a BMW 5? How did you get onto air conditioning from power & performance?
All I'm saying is look at the acceleration difference between a 330i and G35. Despite the horsepower difference between the 2, the 330i is only a few tenths of a second slower. And again, the weight difference between the 2 is negligible.
You're right the M35 could be a fast car(faster car than the 530i), but looking at Nissan's track record, I doubt it it will be considerably faster. Look at the Q45 vs. LS430. The Q45 has a supposed 50bhp advantage yet is about the same in acceleration. Personally I think their engines are overrated in terms of power. Even magazines have said Nissan seems to overrate power.
And you keep missing another point I have made, by the time the M35 comes out, the 3.0L I6 in the 530i will probably be replaced by a bigger Inline 6.
Enjoy!
However, I havn't been able to find 2005 prices on the web as of yet and will be going into the dealer blind. Anyone have an idea how I can prices for Volvos and Acuras?
Also Volvo has a discount when you buy with overseas delivery.Is it possible to negotiate my best deal and then tell them I want overseas delivery and reap an additional discount?
Kiffeee
All you have to do is go to the home page and then click on the "New Car" button. Follow this through to your particular model and trim level... and you'll get all the information that you need.
However, I wish you the best of luck on getting an Acura for $500 over wholesale. Acura is a high-line import that is in limited production. Most new Acuras sell for sticker price or very close to it.
Toyota Camry Solara
Chrysler Sebring coupe
Nissan Altima
Honda Accord coupe
2005 Subaru Legacy sedan
2005 Pontiac G6
Acura TSX
The Legacy for this year does a lot of things right, and a lot of things wrong. They've certainly done a lot to move the car up from being like a 3rd-tier player.. but it still is just not on the level as the big guys from Japan, and it has Subaru's REALLY annoying practice of THIS ENGINE ONLY option packages. For example, the 2.5L Turbo 4 is considered the performance engine, and yet Subuaru's advanced LSD is only available with the 3.0L flat six, which is only available with an automatic. What? What genius thought that one up?
The G6 I havent heard much about, but I was entirely underwhelmed by the "new" Grand Prix, so my guess is it will probably be the old Grand Am minus body cladding and some more curvey lines. Yawn.
The TSX is a rather interesting choice, as it doesnt really fit with the above mentioned cars. The TSX will lose stop light races to most of the V6s, but its in a handling class way above any Solara. If you're really interested in the TSX, I suppose the Altima SE-R could qualify as competition, but then I would also look at cars such as the G35, IS300, and maybe a 325i.
I' am in a dilemma--Need a good reliable econobox. Got a 10 yr old Windstar to get rid of but also paying on an '03 Dodge Durango. Obvious $$ is tight. Looking for something closer to
< $15k
Issue to debate--What should I get?---4 dr base Chevy Aveo or Saturn ION 1.
They are real close in pricing.
Anyone have any idea how this situation affects the selling price of such a "new" car? Thanks.
paul j.
Good luck!
2005 Mercedes C230 Kompressor
2004 BMW 325i
2004 Lexus ES330 "special edition sport design"
2005 Jaguar S Type 3.0
Any opinions, advice, information on these choices would be greatly appreciated. It seems there are pros and cons to all....so hard to know what to get!
If bad weather handling is an issue, the '05 Infiniti G35x offers AWD, combined with 277hp and 270lb.ft. of torque, something Germany cant beat, not unless you get an E500 4matic or A6 2.7T Sline, for only about $45K+ for the Audi, and $60K+ for the Mercedes.
The reason the Infiniti is not on the list is she doesn't like the look of the car...and the Acura...a combination of not liking the news lines of the car..and the problems she's had with her current Acura.
And yes, the driving experience between the Mercedes and Bmw is totally different from that of the Jag and Lexus...that's where they each have something comes in. The latter two are much more luxurious inside...and the Jag has a more distinctive....not like every other car on the road look to it. The first two have more handling and responsiveness on their plus list rather than interior luxury.
I imagine we'll be out testing them all again today! Thanks for your input!
Top 10 Cars With the Best Residual Value for 2004
http://www.edmunds.com/reviews/list/top10/102467/article.html
Top 10 Cars With the Worst Residual Value for 2004
http://www.edmunds.com/reviews/list/top10/102471/article.html
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
I wonder if you are talking about the Phaeton? You can join a discussion on any VW model by using the Browse by Vehicle search feature on the left side of the page.
Good luck!
If you have done this, or someone you know has, and would be willing to speak with the reporter, please e-mail pkrebs@edmunds.com by 5 pm PT today. Thanks!
Review your vehicle
2004 Pontiac Grand Prix GT2
2004 Chevrolet Malibu LS
2004 Nissan Altima 3.5 SE
2004 Toyota Camry LE V6
I have only driven the GT2. I plan on test driving the others very soon.
Kristen
I am trying to see what would be the best bet in buying a sedan. My cieling is $14500, can't go past that. Basically I am a first-time buyer and I want to make the smartest decision possible. Do I go for the reliability of Honda/Toyota or the value of Hyundai/Kia? Any feedback would be appreciated.
Now, here are my deal options (all auto tranny):
1) '05 Toyota Corolla CE out the door - $13,5k -like the deal because reliable car plus 3 yr bumper/5 year powertrain warranty
2) '04 Honda Civic VP out the door - $14,4k - reliable and great mpg but only 3yr bumper warranty, no powertrain
3)'04 Kia Spectra - $10,5k out the door - cheap price, great warranty but I've heard it makes too much noise and warranty service is suspect. Plus really bad depreciation rate. Still good value though
4) '04 Hyundai Elantra $11k out the door - again cheap price but bad depreciation rate, not as reliable as Honda or Toyota?
...thoughts?
We once had a 1983 Celebrity, replaced it with a 90 Taurus kept for ten years and now have a 2000 Taurus. Have been very happy with it. You may be able to get a leftover 2004 model with huge rebates and keep your cost well under $20K.
Ford is also introducing the 2005 model year Five Hundred and I would bet this will have comfy supporting base cushion seats as well. The 500 is more "state of the art", but will be somewhat pricier as well, especially until supplies increase and dealers are willing to deal.
You may also want to check out the Ford Taurus and Chevy Impala.
