60s-70s big Chevrolets vs. big Fords
I remember the Pontiac version of the Nomad was called Safari. I think Buick's hardtop wagon was called Caballero, or something along those lines. Chrysler started playing around with hardtop wagons too, around 1960. I think they lasted through 1964, after which they reverted back to the more traditional pillared design.
Another car that mesmerized me in 1960 was a 53 merc, two door hardtop Monterey, black/white top, on a used car lot. We popped the hood, and there was a Cadillac OHV V-8 in place of the Ford flathead.
Mercury interiors in those days were gorgeous. Had a "rolled and pleated" look.
If I recall correctly, the Mercury Colony Park Wagon was the most expensive car delivered at our local FoMoCo dealer until he got his first Lincoln Continental--a whopping $11k and some change!
Those were the days!
A friend of mine used to have an '82 Cutlass Supreme that had a loose ignition. He swore up and down it was a standard convenience feature. I had an '82 Supreme though, and mine didn't have that "convenience"!
Here's a shameless website plug, if you want to see a few pics of it, along with a few other cars I've had over the years...
http://briefcase.yahoo.com/andre_1969
Very cool!
That wedding day was kinda fun. Perfect day for it, too. It was either late September or early Oct of '94, somewhere around there. That was one of my co-workers. When I got married, it wasn't nearly exciting...a ride in the back seat of an '87 LeSabre down to the courthouse on a hot July day!
Enjoy,
Hal
Seriously, both cars were in an excellent state of tune when I bought them, or as the British say, "properly sorted", so I haven't had much trouble with them. Typical things you'd run across with any 20+ year old car, but nothing really wild or expensive. The JH is very un-British-like as it starts and runs everytime you get in it! The Fiat is great in that it just goes! No tinkering, no bother, just get in and drive. Supports the theory of buying as much car as you can on the front end....it'll be worth it later. Both are really unique little cars with a terrific history behind both of them....but that's another whole story!
Enjoy the 4th!
Hal
BTW, anyone can call me a Swede, since I'm Swedish.
As for Mopar engines, the small-block and big-block V-8's, as well as the old poly-head and hemi-head V-8's that came before them, were virtually indestructible, as was the Slant 6. From what I've heard though, the 360 wasn't as reliable as the other smallblocks, mainly because it had thinner water jackets and was more prone to overheating with age. And in 1989, they had a run of bad camshafts. If you got stuck with one of these gems, between 70-90,000 miles, the #8 cam lobe would disintegrate by that time. If you got lucky, then the engine would run until the car either got junked or wrecked, or abused.
With GM engines, I'd always heard that the Chevy smallblock was pretty weak structurally. Still, I had an '86 Monte Carlo with a 305, that had about 192,000 miles on it when it got wrecked. My granddad also had an '85 Silverado with a 305. He's passed on, but my mother still has the truck. I think it only has about 100-110K miles on it. It doesn't get driven a whole lot, but does get used to haul hay and other stuff, and to pull my Mom & stepdad's boat. I'm guessing that old age and overwork will take its toll on that truck before high mileage does.
One thing that's interesting too, is how well non-metallic paint holds up over the years, compared to metallics. My grandparents bought that Silverado the same year as their '85 LeSabre, which we still have. Both of 'em are still on their original paint jobs. The truck is a non-metallic red with a white roof, and white lower body. Still nice and shiny, after all these years. The Buick is a dark metallic gray. It looked good until it was about 10 years old, but then started to go. Today, the sides still look ok, but the hood and trunk are shot...hopelessly spider-webbed and cracked to oblivion. Sad thing too, is that the truck was always outside, while the Buick was parked in the garage, at least up until around 1990-91. Grandmom worked up through 1994, and there was a covered parking garage at work. So the Silverado actually got more sun-time than the LeSabre, but ended up holding up better.
Anyway, when the Chevy smallblock came out in 1955, it was very advanced and lightweight, actually weighing less than the inline-6 that was the base Chevy engine. The only problem is, that lightness was achieved by using lighter, flimsier components and a more fragile block. They'd last if you took care of them, but wouldn't hold up to abuse like the heavier, less "advanced" engines of the time.
As the engines got bigger, which usually meant thinner cylinder walls, water jackets, etc, they became more fragile. Evidently though, there must be ways around this fragility, as racers routinely build these things up to get much more hp than General Motors ever imagined. Then again, I'm sure they're not using stock, run-of-the-mill GM parts!
By the time the '70's came around, the Chevy V-8's were known for having crankshafts prone to early failure.
Still, the only problems my family has encountered with a Chevy smallblock was my Grandparents' 1972 Impala, which had a 350 2bbl. Granddad gave it a valve job around the 60-70,000 mile mark.
In those days, I never used the keys and let the car sit outside in front of the house. Those days are gone, unfortunately.
One thing might affect this attitude too-the old Ford flathead V8s were notorious for needing rings and valves around the 40,000 mile mark. Some of the early ones were notorious for failure as well. But what the heck-they only had 3 main bearings. Many people adopted an "anti-V8" attitude, and would only buy sixes. Then too there were sixes like the Mopar flathead, that were known to go past the 100,000 mile mark [taxies for example] and lasted way longer than the Ford V8s.
I think you're right about the Mopar V8s durability. My old 72 Dodge Van with 318 torqueflite had 191,000 miles on the original engine and trans, and now it has over 220,000, and it still runs strong-the guy says its reliable as hell. Of course, I changed the oil and filter every 2-3000 miles for all the 20 years I had it. My current Dodge Van has 100,000, and runs like new-doesn't burn a drop of oil. I expect to get at least another 50 thou without even a valve job.
I think may be the use of unleaded fuel, and better lubricants has increased the longevity of all engines today. But heck "most V8s are shot at 100,000"-no way-I've known of many that go the 150-200,000 mile mark-with regular maintenance, that is. And that includes small-block Chevies. If anything, I think the low-stressed, slower turning and simpler V8s would last longer, [all else-maintenance,etc being egual] than a highly stressed, faster turning 4 or V6.
The GTO 400 used chrome top rings and the premium Morraine 400 bearings. The only real weakness was the timing chain, which started to stretch around 100k.
Let's see, my parents' '66 Impala 283 started to burn oil around 100k but I'm not sure how well maintained it was. The Powerglide starting slipping shortly after so they sold it to some guys who claimed to have driven it to Mexico City and back in that condition.
I bought a '68 Cougar 390 with an indicated 80k on it that I assumed was 180k but may have been 280k--apparently the 390 goes a long time. I drove it for about 5K with minimal oil consumption and then one day it suddenly started smoking so much I could have gone into mosquito abatement.
Except for some front end bushing "squeaks", car rides like new. Changed the load leveler shocks at 110,000.
302 motor seems to pull better uphill than my 94 ThunderBird 4.6. Same rear end ratios (3:27).
Older V8s were pretty crudely built. I remember seeing a video of a 50s assembly line with some guy smacking pistons into a block with a big wooden mallet! I don't remember which car it was though.
Also, remember those old V-8's didn't have to strain very hard, in comparison to today's cars.
There should be no reason today, except for a "manufacturing mistake" or unusual internal failure, that with proper oil changes, any car should go 100K or more.
Book 'em Dano!
Enjoy the reruns in the A/C!
-Japanese engines typically had timing belts; if they snap, some of the engines would self-destruct.
-In aluminum engines, if overheated, the heads will warp, causing permanent seizure
Both are preventable. Usually, '80s Japanese sedans died due to rust more than because of mechanical failure.
Reliability? American V8s were pretty good, and could withstand abuse. I don't know about mileages of 200K being "common". I rarely ever saw that without at least head work and rings and bearings. The bottom ends were strong though. An American V8 would run on 7 cylinders, puking oil through the rings and valve guides, 5 lbs of oil pressure. These are probably the 200K unopened engines you might have seen, the crippled survivors.
Nowadays, a 200K unopened engine is quite believable, due to so many gains in metallurgy, oils, fuels, etc.
