Visitor Agreement.
With a really long duration cam you have exhaust gases leaking back into the intake manifold and diluting the air/fuel mixture at low engine speeds--that's what gives the engine the rough idle and poor low-speed throttle response. That must be why '70s smog cams had long duration--poor man's EGR.
I had a chance to dust off a few more brain cells and what I was getting at is this...
IIRC you use a manifold vacuum gauge to set timing by rotating the distributor until you maximize manifold vacuum--the engine is in an optimum state of happiness.
But I'm wondering whether this state of bliss engine-wise is still the goal. You've got variables like valve timing and compression ratio, even axle ratio and vehicle weight, predicated on gas of a higher octane than what's available now.
You've also got a combustion chamber design that dates back to 1957 or so and is relatively inefficient at handling high combustion pressures compared to a more modern design.
Throw in a crude, relatively inflexible 2-bbl. carb that's jetted lean and can't dump a load of raw fuel to cool down the combustion chamber. Plus carbon deposits that have increased the effective compression ratio and created hot spots.
So I'm just wondering if you're not forced to set the timing on sylvester's car by ear these days.
Not all engines respond to bumped timing though, interestingly enough.
For better or worse, a big inefficient American v-8 sounds like a good first car to learn on - relatively simple and forgiving of mistakes.
Per the manual, the dwell angle on both the 289 & 390 is 26-31*. All 390 2 barrels came with one of 3 "dual advance" distributors (the manual did show me how to find the part number and manufacture date - I'm trying to figure out if the distributor could be original, I'm hoping the points are not)
I'm starting to see why the old mechanical timing is still preferred for low rpm weekend cars - it is not exactly rocket science once you understand it.
I'm trying to plan my restorations now, as the girl I'm dating is dropping hints on marriage, which means instead of spending money on resealing the frame, fixing the minor flaws in the 8 year old paint job, etc., I'll have to buy dumb things like furniture, carpeting, etc.
"Pinging" is actually all your engine's internal parts rattling around--in some severe cases, even the walls of the cylinder bores are flexing under the strain of premature combustion presssures.
And never, ever tune modern engines that way.
It's really not "tuning by ear". That is a misnomer. It is tuning by ear AND road test, over and over again.
But there's just no way around doing it this way, at least in my experience. Setting it to factory specs will just hole a piston.
I'd at least check into a water/alcohol injection system. The latest ones (well, circa mid 1980s) offer some flexibility the first ones didn't have.
Then set your timing by ear making sure you set it with the gas you intend to use everyday.
I did this in my 67' Galaxie with a 390 and set the timing to run on regular gas.
Is Pertronix an electronic ignition system?
Of course, I did pull off the heads just to see what was there, cleaned all the carbon off the pistons, and had new valve seals installed. Now I know it's all clean inside and out.
Anyway, surprised it's never pinged with compression like that.
As soon as I finish building my shed, the car's ignition is next. I'm anxious to start tooling on this issue.
Thanks to everyone for their help. I think I'll try the dwell timing, and do the seat of your pants/tune by ear method and see if the results are satisfactory.
We just used a dwell meter to set the points at, I think 30 degrees.
Loosened the distributor and set the timing by ear. The old timers laughed at timing lights!
I was taught that we wanted just a slight ping under load, barely noticible. That meant you had it right. I remember a bit of trial and error.
One time, I did borrow a timing light and set if to factory specs. All I got was a sluggish car!
My '65 Riviera was the same way. It really ran so much better with the timing set by ear.
How I miss those two cars!
I've always set my cars by ear. We still have Granddad's old timing light somewhere, but it's broken.
With my 55, and the 327 I had in there, I changed the weights and springs in the distributor, and then set it by ear, and it flew! That was the fuelly cam with the valves set at .030. What a sound.
That reminds me of the trouble I had with that little Solex carburetor, and the little nozzle in the top always clogging up, causing a crapout on low speed acceleration. After having the dam thing apart over and over, and trying to clean that little tube with 90 degree turns with Berryman's, I finallytook it down to the VW parts, and the guy opened a drawer right there at the counter filled with new ones-for 50 cents. I wonder how many people fiddled with that problem, not knowing they could press in a new nozzle on top for 50 cents and solve the problem.
Looking back, when I trashed my 69 Catalina, the reason it ran so badly was probably due to the timing being way off. Oh yeah, the brakes had to be pumped to get the car to stop, and the heater core went out as well - no heat or defrost in winter.
Was there really any major differences in the ignition systems of GM and Ford?
As far as I know, a stock OEM type coil will easily cope with the engine's secondary ignition demands past 5000 rpm.
With a low-revving street engine, more isn't necessarily better, just more expensive. The stock set-up isn't merely adequate, it's as much or more than you'll ever need. Just make sure it's in good shape and of good quality.
You certainly wouldn't have trouble finding your car in the supermarket or mall parking lot if you bought an old wagon instead of a minivan!!
http://adcache.collectorcartraderonline.com/10/2/0/33912020.htm
If I were considering such a thing I think I'd go for a '68-'72 Olds Vista Cruiser. At least they have a bit of "cool" factor.
If I were looking for a big, old station wagon, I'd definitely consider brands other than Chevy (Pontiac/Buick/Olds, Ford/Mercury, Mopars), since, as with other cars, they're cheaper and likely even more rare. Of course, with any old wagon, finding unique body, interior and trim peices is likely not going to be easy.
http://adcache.collectorcartraderonline.com/10/9/4/30962894.htm
http://adcache.collectorcartraderonline.com/10/3/6/32204236.htm
http://adcache.collectorcartraderonline.com/10/1/8/3996918.htm
Check out http://stationwagon.com/ for more wagon stuff.
I figure if you were to get a big wagon you may as well go all-out and I am a sucker for those fuselage Chryslers from '69 to about 73. A friend has a '71 New Yorker hardtop and I love it. That wagon you found is ridiculously overpriced though. He has had that car for sale all year.
Here's a question I don't know the answer to: when was the last year Chevrolet made a "Sedan Delivery" and what chassis was it based on?
Prior to that I think possibly mid sixties Chevelle 64/65. I know there was the 2 door wagon I think there were sedan deliveries also.
I'm 99% sure I've seen at least one '60 sedan delivery. In fact it was just recently--the only question is whether it was a '59 or a '60 and I'm pretty sure it was the latter.
As far as I know the El Camino chassis was just the passenger car chassis.
http://adcache.collectorcartraderonline.com/10/0/2/31868502.htm
