Visitor Agreement.
I have a 97 Outback. The plastic covers on the headlamps have, over the years, become crazed and faded. Has anyone had any experience getting rid of this fading? I understand it is from the heat of the headlamps over time. I also understand that you can buy a solution at Pep Boys, etc...that will rejuvinate the plastic.
Check out the ultimate Subaru website. There are several threads there on this topic. 400 grit wet sandpaper will clean them up, but they often yellow again. There are coatings that can be sprayed on them to delay this. You can buy new ones for about $125 a side from several online suppliers.
There are a lot more folks there who have owned multiple Subarus and done a lot of work on them.
I can't remember how to deactivate the valet...
it wouldn't be wise for me to reveal either, but the info is available in your manual
-Dave
Also, I am a little hesitant to spend $125 x 2 for a 1997 car. I could see spending $50 x 2. So lets see..........
Maybe the combination of the 400 grit wet sand paper and the solution that the dealer talked about would work.
I have owned the car since new and intend on keeping it for at least another 5 years.
Good luck w/ the cleaning and let us know how it turns out! Is your alternator still behaving?
Don't remember who you buy the lights from, ulitmatesubaru.net is where I got the information. I just polished mine.
Will you please elaborate slightly?
I took them apart and literally washed the internals with a detergent. What I could not reach I just let soak, and shook water inside. Got most of it out, not all.
Didn't keep the car much longer so I can't say what the long-term effects were, but it looked good enough that I sold the car.
-juice
There's probably less harm to be done by changing sooner than later. When in doubt, give your car a fresh supply of oil.
Also, some folks like to make their first oil change early. The thinking goes that because the engine is still breaking in, the oil becomes contaimated sooner.
In my case, I changed at 1000 and then 3000 before going to the regular intervals.
Ken
Sly
Still, that's nice they offer the service.
-juice
Forget what the dealer is telling you -- the owner's manual gives all the details and you can educate yourself on the whole thing rather than listen to the dealer.
In my experience, the dealers try to get you in for much more service than necessary. Personally, I stick to the book.
Craig
Wow, less mileage than I have: '02 OBW w/28k...
As you have probably seen from a scroll thru these boards, head gaskets are indeed a weak spot on the 2.5L engine. My drivers side began leaking and was replaced in '03 at 15k miles.
Many owners of '00-'02's received a letter last year advising them to visit their dealer for a coolant sealer additive that is supposed to alleviate the problem of scrubbing that occurs between the block/gasket/head. I am a bit surprised that they needed to replace both (90%+ seem to leak at the #4 cyl - drivers side rear), but maybe starting off fresh with new gaskets is for the best.
So no, you are not alone, but SOA seems to be taking care of customer issues reasonably well.
Steve
I suspect most of us change the oil sooner than needed - cheap insurance! My friends with BMWs comment on the onboard algorithm that tracks engine usage to compute when oil should be changed. They often go 10,000 or 12,000 miles before the light comes on.
Stanton
On the way home (200 miles) the engine check light came up.
I got Subaru to do the recall affecting the diagnostic code,
but nothing changed. Diagnostic says: cat is the problem.
Why would a cat be a problem so early?
Is this normal? I also have an old 98 Outback with well over 100000 miles
and no hint of any cat problems anywhere.
I am not just about to spend $1K on a new cat and labor.
Anyone knows what is going on?
Anyone knows if this could be one or both oxygen sensors?
Anyone knows if e.g. JC Whitney's catalytic converter cleaners are of any use?
Also, the oil level in the car was on the high mark
could that be the origin of the problem?
Would the cat recover if the oil is maintained on the proper level?
I certainly would welcome someone "shining some light". Thanks.
This summer when I clean it next, I will try out the brake fluid since I have a bottle hanging out. If it doesn't work, I know I have a 10-yr-old bottle of Brasso laying around here somewhere from USMA.
The post you are looking for tells of a car that needed a new catalytic converter, and the Subaru owner got the mechanic to admit that the head gasket leak could have contributed to the early demise of the cat.
Craig
I just dropped the car off at Subaru and am waiting for the prognosis. They charged $1700 for the repair and that was with support from Subaru..Oh well..I see what happens.
Due to the wide range of driving conditions and habits, it's probably impossible to measure what the impact of an early vs. on-schedule first oil change would have over the life of a car. Hence the multitude of opinions from people on what the best way to break in an engine is.
The best thing to do is do what makes you feel comfortable. Definetly stick to the manufacturer's minimum, but if you want to change more often, there's probably little harm to be done if at all.
Ken
As for valet mode, use the fob to unlock the car with the door open to remove it from valet mode. Rob M.
Those ANC winters are brutal...lots of salt and cynders to keep a car whitish looking. I could see the headlamps taking a beating up there!
Krzys
Sly
Of course, on my van, I show 1xxx on the odometer, and this is second time it has rolled over...
But, to get back on point, the tranny should not have gone out unless it was subjected to some sort of severe neglect or abuse. I wonder if the scouring/cleaning treatment outlined above (was it last week?) could help it, or if this is a matter of replacing just a couple defunct parts in the tranny versus a complete replacement.
My neighbor rebuilds transmissions for a living and he says the best way to get a car cheap is for it to have a bad tranny because people usually are just not willing to mess with having them fixed.
I just took mine to the dealer to have the tranny looked at. I told them that at cold temps, it shifts HORRIBLE. It delays shifting and seems to pause between gears. Shifts are really harsh and it really pisses me off. I've had 4 Subaru's and none of them have done this in the past. My most recent one was a 2000 Outback Ltd.
They looked it over and nobody bothered to tell me that this is "normal". They just said they couldn't find anything wrong. I guess I'll just live with it until the temps get warmer.
About the brakes issue... I've had wierd instances where the brakes felt mushy, but I can't pinpoint how/why they occur.
I have also experienced the "non-starting" you're talking about... just a week ago.
The tranny does upset me though... they should tell people about that, because a new car should NEVER shift that badly, I don't care if it's trying to warm up the tranny fluid. Nonsense...
Jun
Thanks.....would it be worth purchasing an extended warranty in case this issue cannot be fixed?
I am not surprised the dealer was clueless. Seems like dealers don't have any enthusiasts that know all the little quirks/details like people on this board. We've heard about some pretty lame information and mis-information coming from dealers.
Craig
Craig
2) Why does my car idle at about 500rpm, then move up to 1000rpm all by itself, then drop down again? Shouldn't the rpm stay constant at idle?
Chuck
DaveM
1) The gauge position is fairly arbitrary and can vary by manufacturer. One can't really compare the position of one make to another. Most gauges are non-linear too -- the needle will stay in it's "normal" position for quite some time before it starts to show an overheating situation.
2) Your engine also drives all the accessories in your car -- alternator, pumps, fans and compressors. When there's an increased load on any one of these items, the engine responds by increasing it's RPMs. Similarly, if you are accelerating hard, the car is smart enough to temporarily divert power away from accessories like the A/C compressor to make sure you get maximum power.
Ken
http://www.cartalk.com/content/columns/Archive/2005/January/01
Was your dealer ever able to diagnose your car problem. Please post an update about your car. I continue to have problems starting mine on very cold mornings and would like to know how things are going with yours. Thanks.
Jun
If the tech replaces the converter but not the contaminated 02 sensors, the new converter will fail also.
You might wnat ot try an independant repair shop that does good brake work. Do an oil change and tire rotation and they might look at the brakes for free.
--jay
Even though I have owned 3 previous Subarus, I have never owned them long enough to have these kinds of problems occur.
But, I keep saying "This Subaru I will keep till the wheels fall off". So, knowing what to expect around 70,000 miles will help alot- just in case I do keep my 05 Legacy 2.5i that long.
-Jim
seems that the jump in my tach reading at idle is maybe related to the temp gauge reading a little hot. I was on my way home from hockey practice last night, and not half a mile into the trip, the tach jumped to 1000 while sitting at a light. I listened carefully, and definitely
heard the whirr of the fan which had kicked on. Why the fan is on that early in a ride is beyond me, but perhaps that adds some info
to the temp gauge reading hot? I plan to call the dealer today and see if they will address this Saturday when the car goes in for non-
mechanical "we owe" items.
A nagging question: I went to teh dealer Monday to drop something off, and while there asked if they could give me a printout of what they did on the 30k service so I could use it to start my file of service records. After 10-15 minutes of waiting, someone finally told me that they were having some trouble with the computer, and is
there any reason that I couldn't just get teh record this Saturday when I come back in. I agreed, but after a few days to think about
it, I am wondering if they really did not do much of anything but told me they did a full 30k service, and now they are in a bind because I am asking for a record that they do not have or do not want to show me. Thoughts?
Chuck
