I think juice is right that you're feeling the electronic throttle control. Is your car new? It may just need some time to adapt to you driving style.
The whine is probably coming from the transmission. Some turbo Subarus have more aggressively cut gears to help handle the torque. The downside (depending on your preferences) is that it increases noise.
Ken
Gus
I guess you could spray a soapy solution at the seams, then maybe blow air from the inside, and look for bubbles. I've used that to find leaks in tires. It might be hard to build up enough pressure inside, though.
-juice
Front seatbelts have noticible slack and no return when 'tugged' on. Since I'm a safety freak, it's driving me nuts! I don't expect whiplash, but they could at least fit! Dealer said 'this may be covered' under the classic warranty (paid $1100), but I shouldn't expect it to be.
Next issue - driver's side door is either off alignment or there's a seal issue - I hear the wind more than when the windows are down. Dealer "it may be covered."
Almost last issue - retractable cover in the back - the spring has sprung. I used it 4 times. Is there a cheap place on the web to buy a new one? New one (w/o labor) is $130 at dealer.
Last question (I promise). The engine knocks like an overeager salesman in the mornings. I let it warm up (like a good owner), but it's annoying. It gets regular gas (what the manual said to give it). It takes about 10 minutes to be 'normal'.
Other than this, I'm overall happy with it. It was cheap enough and has handled well in nasty rain. It's in beautiful shape outside and my 10 year old son's friends think it's cooler than a minivan.
TIA.
Wind noise - There was a tech service bulletin about poor fitting gussets (the black triange near the mirror) that might apply to your car. Also, get some vinyl/rubber lube (Meguires, etc. - the good stuff - skip the Armorall) and go over all of the rubber until it is clean and black. Clean off any transfered gunk on the glass where the rubber seals. This will help a bunch. Last resort, one of our members, Craig, wrote up a procedure for adjusting the door glass angle that would put more pressure against the seals. But try the easy fixes first.
Rear cargo shade - try calling local junk yards. Try taking it apart (?). Try one of the on-line Subaru dealers. They typically sell for 20-25% less than your local dealer.
Engine knock - It probably isn't octane related ping/knock as you might expect. Subaru engines are prone to something called 'piston slap'. Again, there is a tech service bulletin out on this. It happens when short skirted pistons vibrate in the bore until everything comes up to temperature equilibrium (about 10 minutes or so when really cold). In the summer, I barely notice this. When it is near zero' F, the sound can be hard to stomach. Yet in most cases, it is considered normal. If it goes away, you fit right into the model. If it does not, the pistons might have to be changed out for oversized ones. A few members with severe cases have suceeded in getting this done.
Did we cover everything??? Sorry, no more questions. You used up your quota for this month
Steve
so your saying that the ETC will adapt? I am not saying I try to get the best 0-60 rating at every stop light.. The car just feels like it is hesitating when I do a hard shift into second and give it all the gas it wants. disengaging the engine out of first is fine.. so you think throttle is just not allowing full go right away? by the way normal easy shifts are fine.
I guess I can just keep practicing.. which isn't a problem:)
the whine isn't a bad thing.. I mean you can only really hear it through 2nd gear with the windows down.. and honestly it kind of sounds good..
Liberty Subaru has the cover for roughly $100 including shipping and handling. I was able to use my Subaru bucks to pay for it. There should be no labor charge, because all you do is throw out the old, and clip in the new.
Mark
No issue with the seat belts, but I'd guess its covered since its a safety issue.
Wind noise, I hear its a fairly simple adjustment.
Engine knock. like another said, its piston slap. I had pistons replaced which made it go away for 20K miles but its coming back now. Its not a problem other than noise.
Retractable cover. I have mine in my garage for the past 5 years collecting dust. Brand spankin` new.
--jay
I checked the belt closer tonight - it twists and catches, which slackens it. I'll look into the Meguires, but I really think the door's out of alignment, it happened a lot on my Saturn. I may go check ebay for the cover. It still works, but won't retract.
I'm enjoying the wagon more than I thought I would, though - I hauled mums, hay, pumpkins, craft supplies and groceries on Saturday - did it all in 1 trip and still had room in the back seat for more stuff!
TSB are not recalls, as they typically don't deal with safety issues, and are not required by the NHTSB (da government..). They are really designed to help the dealer get to the root cause and fix a problem quickly, or provide info to tell the customer that it is a 'non-problem'. Subaru pays the dealer for this work done during the warranty period. If it is after the warranty, the dealer typically must get prior approval before doing the work, otherwise they will not get reimbursed (and you know who pays when they don't collect from the factory!!!).
My advise in this situation is to go in armed with data, but be nice! Remember that you are basically asking for a favor. You need the dealer to go to bat for you against the district manager, and you will get nowhere if you piss them off.
Steve
Has anyone had this problem fixed correctly?
mgmbigdog
If it is a leak, and you're under the 3/36 make them pull the windshield to reseal it. Goop around the edges doesn't usually work for long. Took me 4 trips to the dealer before they finally got it by pulling and resealing. All they did the first 3 times was move the leak around.
BTW - it wasn't really the dealer's fault - they were sending it to a glass place and the folks there were afraid of breaking the windshield.
One last piece of advice - if they do pull the column trim to work on the windshield, give it a light tug /feel when you get the car back. In my case the trim was so loose it rattled. Why? Because the clips, at least on the Foresters are designed to be removed exactly once.
HTH
Larry
Explain the "rattle" a bit more - is it a noise? A physical movement of the engine? Does it happen at any time or only when stationary/moving? More details are better...
Try checking out the aforementioned site for how people are getting smoother launches. I think most people have found that mashing the throttle actually gives less than optimal response.
Ken
I suspect you are in FWD mode, and just due to some internal bias it appears like it's just the right side.
Ask you co-workers, neighbors, etc to recommend a mechanic. You don't have to bring it to a Subaru dealer. Not at all. There are many good shops out there that can work on Subarus.
Good luck....
If you're referring to the heater control backlight, I have an old e-mail saved at home that walks you through the fix. I can email it to you if you'd like. Let me know.
Cheers!
Paul
Cheers!
Paul
The only time you would really want to use it is if you have different size tires, though I think you need to keep the same size on the front.
baffeled
My guess ld be that the water is faling onto the release cable from some point further along and then running along the cable before dropping off.
The most likely culprit is that the drains from the air inlet area immediately in front of the windscreen have become clogged. To check them, use a fine bored plastic coated witre, or better still a semi rigid plastic hose to poke up from the base of the drains under the car. To check where the water drains, pour some water down the windscreen with the car parked on a flat dry surface.
Wth the Outback, I found the areas in the front wings (I think fenders to you) immediately in front of the front doors filled up with mud if I had been driving on dusty roads.
I fabricated a piece of 4mm (say 3/16") drip irrigation hose (fairly rigid black plastic but bends to curves easily) into a hose fittng, sealing the gap with silicon. This allowed me to deliver a fine high-pressure spray against mud inside the drain, reversing the normal water flow. This simple tool is very effective.
The other possibility is the drain from the air conditioner unit or possibly some problem with the drains from the sunroof, if fitted. These run down the inside of the A pillars, I think and might conceivably have been pulled away from thir connection into the fromt of the sun roof. However if the sun roof was closed their should be only minimal water coming this way.
Cheers
Graham
It's better if we have the conversations right here on the Forums for that reason - a lot of times folks can find the answers to their questions without having to ask them over and over if someone will be generous enough to share a solution right here.
I am sorry to insinuate that there could be dishonesty at your shop since you've been such a long-standing customer, but it seems very odd that this would have started immediately after having the car there. I'm suspicious, that's all.
-Wes-
I rotated my tires this weekend and inspected the pads in the process (2000 Legacy). You can easily see the lining on the outer pads. The caliper has a horizontal slot that allows you to see how much lining is on the inner pad. It's not necessary to remove the caliper at all.
And yes juice, I waxed the wheels inside and out!
Jim
Wes - It's an e-mail text... I'll just copy & paste, but thanks for the offer.
Cheers!
Paul
Hope it helps.
Cheers!
Paul
Subject: Re: HVAC bulb
Actually, the operation is incredibly simple. Pop out the cupholders and
remove the two LARGE phillips screws (don't touch those teeny ones) that
hold the cupholder assy in. Pull out the cupholder. Pull out the ashtray
all the way (push down on the spring loaded "lid" and it comes all the way
out) and look in the now vacant hole for two phillips screws fairly close to
the rear edge (vehicle's rear) of the "roof" of the vacant hole. They're
impossible to access with a normal screwdriver - I used a bicycle multi tool
but you can also use a phillips bit and a pair of pliers to complete the
half turn it takes to loosen them enough to remove by hand.
Now pull out on the top edge of the trim piece that surrounds the radio
until it resists further leaning. All you need is for the top edge to come
out about 3 inches - DON'T try pulling this out all the way, meaning don't
try pulling up on it to pull it's bottom edge out of the slot. Leave the
bottom edge pinned between the front edge of the center console and the
center of the dash. I pulled this trim piece out when putting a stereo in
my nearly identical '97 last week and it was a pain to put back.
Now point both center vents all the way down, providing a ledge at their
bottom edges to grip the trim piece with several fingers and pull back and
down at a 45 degree angle, wiggling it side to side to help free it. It
takes a surprising amount of force, but then two plastic clips at the
vertical centerline of the vents on each edge will pop out of the dash
opening. They're not fragile at all, but just don't break the trim piece
that defines the bottom of the vents - spread the load with several fingers.
Once it's free, there's a wiring harness to the emergency flasher switch to
disconnect - I think the catch is on the top surface of the white connector.
Now you've got 4 phillips screws holding the HVAC unit in place. Remove
them, then lift it like the hood of a car and see two small silver phillips
screws. Remove these (key here is don't drop these into the dash) and you
can now wiggle the part they held onto the back of the HVAC unit away about
a half inch. These screws hold the cable mechanism that moves the water
valve. Now put the HVAC unit back down (again like a car hood) so it's
close to its normal position and you'll see you've opened up a half inch gap
into which you look. At the bottom you'll see a white 'wire tape' that's
the wiring connector and the thing that limits you from pulling the gap
wider. On the rearward face of the slot you've opened up, you'll see the
back of a circuit board and on it are 3 green plastic discs about a quarter
inch in diameter. These are the light bulbs. Use a small standard blade
screwdriver to hook a crevice on the edge and rotate the uppermost one
counter clockwise about 1/16th of a turn. That's all it takes to remove
them as they're kind of a 'push and turn' install. Once you've pulled this
easy one, it will help you get the harder two that are down deep in the slot
you've created. Note that the one by the fan switch is longer - the other
two are identical. Once they were loosened, I used a pair of needlenose
pliers to reach down and gently remove them from their holes. Kind of like
that old game of "Operation".
This whole thing should take you no more than 20 minutes. Now slap the new
ones in, remembering the long one goes by the fan switch and button it back
up. The bulbs again take just the slightest rotation to lock them back in
place. A penlight helps you see the holes they go in have notches in and
position them with the needlenose.
