I would expect my 91 camry with 189k miles to rattle (and it actually rattles very little) but not a 2 week old 2007 outback. Just venting as who wants to spend 20k+ on new wheels to have them rattle so soon. BTW the car has only been on paved roads and driven very easily.
Anyone have any ideas on why this unit might suddenly behave this way?
I'm going to go ahead and follow the dismantling the radio thread, and see if its a wiring issue.
Yeah, most definitely take it back to the dealer and make 'em fix it to your satisfaction
The rattle would drive me crazy as well. Heck, my '96 OBW has 214K miles on it now and the only rattle (aside from the suspension when hitting decent bumps) is the in-dash cup holder... and even that drives me up the wall. That one is intermittent though (thankfully) so I have not yet resorted to ripping it out and leaving it upon the highway somewhere. :mad:
Talk about a statistical outlier!
-juice
The average MPG is linked to each trip odometer, so resetting the odo will reset average mpg. Some people never rest trip B with the idea that they will accumulate the long-term average mpg but it doesn't have that long a memory...
So it does not seem to be that rare.
I've got 83k on my 2000 outback and it may have just a minor rattle here annd there. I remember riding in my dad's 87 chevy astro van with no interior on the roof or sides--that truck would rattle, vibrate and squeak constantly--it took him 3 transmissions, but he did get 340,000 miles out of it before it was all said and done.
As the adage goes an ounce of prevention....
--K9Leader
I will test first, though, by sealing the edges of the sunroof with duck/duct tape and dowsing the car. If no leak, then I know it is the sunroof.
It's always something!
--K9Leader
It is better to follow your procedure so fuel lines get pressurized too.
Krzys
Lately, when driving the engine doesn't sound right. There is a heaviness, kind of draggingness when I drive, I guess one can see it runs a bit rough. It's like a grinding. On my way to the dealer 2 weeks ago, I stalled at a stop light. They did the 60,000 mile check and found everything to be okay. On my way home, I stalled out again. This week, the "Check Engine" light came on. Among other things, the manual said, a loose fuel cap could cause the light to come on. In fact, the cap was loose. I tightened it, but the light still keeps coming on. And, the engine still does not feel right to me.
Any ideas?
Thanks--JP
I would go to somewhere like autozone and ask them to scan the computer for free and see what codes are given and/or go to a different dealer that will take your problem seriously.
Do you have any remaining powertrain warranty?
So I went ahead and dismantled the console to remove the radio. I was hoping that the unit had some sort of face plate and not be one piece. But it looks like it is one piece and that if any wiring was at fault, it would have to be inside.
http://njjuliano.smugmug.com/photos/96542962-L.jpg
It'll have to wait till tomorrow, since it is a bit darker now.
It looks like just a few more screws and the whole cage should come out. If you have any advice, or words of wisdom on what to look out for, please dont hesitate to chime in.
Has anyone actually changed this particular unit in their car? Anything comparable that you can suggest that can utilize the 11 speakers that the Mc was using?
TIA!! JB :confuse:
-juice
The other thought is to change it now and do the next change at 90k. Then you remove any crud and fine metal particles from break-in.
Jim
The coolant in the overflow reservoir is getting kind of an amber look to it. It seems like the level has been going down as well just a little--although that may have to do with the cooler weather lately.
Temp gauge is ok and never got close to overheating. I've been looking at the coolant for an oily film on top, but don't see anything.
I was thinking it could be the coolant conditioner changing the color to a light amber color. Has anybody else experienced this?
Eric
-juice
Eric
Jim
I did notice that the rattle did start as the weather changed from hot to autumn 50-60's degrees.
So if you do happen onto the cure please post.
Try the sponges and see if the sound goes away. If it does, at least you know where the issue is.
Karl
Did not know if others had the same sensitivity to rattles as I. I think my son (16) thinks I'm nuts. He says I on a mission.
Karl
Mark
2003 Legacy Wagon Spec.Edt.
The reality is quality of everything seems to decline with each passing year. Im in IT and every new batch of computers I order the components seem a little flimsier, more plasticy/fragile, etc.
Overall I am pleased with the Outback 07 ride. There are some things which are annoying (the clutch footrest is cheap plastic and creaks--cmon Subaru either put in a rubber one or get rid of it all together) and the doors could have been hung a bit better (makes a cracking noise when opening) but Im just being a perfectionist.
But the ride is smooth, I like the layout and the 4 cylinder has plenty of pep to it. out of 10 stars I would give it a 8.5.
I would give the dealer a rare 10 for quickly fixing the problem and being very polite/professional especially in following up post-repair.
I own a 1999 legacy brighton wagon with only 65k mi that has begun to make some dreaded engine knocking noise (4-cyl 2.2L phase 2 engine). It's a pinging/knocking noise that gets worse at higher rpms, but sometimes it just happens.
I've had the car for one year and still owe about $7k on it. Taken it to a dealer (ran some diagnostics and suggested "replace the engine" or accept a $300 trade-in), a local repair shop (over their head) and finally our local independant subie AAA all-star repair shop.
The indy subie dealer looked under the hood and walked me through his sage diagnosis- likely a failing bearing and to replace the short block...upwards of $4500 worth of work.
Should I-
a) invest $4500 in the car and hopefully have it for another 150k+ miles? everything else on the car is in great shape.
b) try to sell for for around $5k as-is?
I really wasn't planning on having this car forever so option a seems less appealing right now...
thanks.
of ownership, I have noticed that there is a hesitation. You
really notice it when you are stopped on a hill waiting for
the traffic signal,I let off the brake and give it gas not flooring it and there is a hesitation like it wants to stall. It will even do it on a flat surface when stopped and
again give it gas,same thing but not all the time. The service manager drove the vehicle, while I was present and
said it's fine, the famous I couldn't duplicate the problem.
They wouldn't even take it in to check the diagnostics. My husband sat in the passanger seat and I drove and he noticed the problem when we were on a hill. I'm frustrated and hope that the car doesn't stall while I'm on the highway. Anyone experiencing similar issues? Thank you so much.
The Subaru Crew Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
