Thanks for all the advice and help!
Can't thank you enough for your help Alcan.
Dont forget that while braking, the ENTIRE WEIGHT OF THE CAR is forced into the edge of the pads. The edge of the pads put this huge force against a metal "tang" that sticks out. (all that force into space about the size of a pencil-eraser!)
That metal "tang" gets burrs in it over time. If these burrs are not filed smooth when replacing pads, the new pads will not behave/last as well as they should. This is the same area that you should apply hi-temp brake-grease when installing new pads.
Personally, I perform PM (Preventive Maintenance)on my brakes every 2 years. I pull them apart, clean everything up, file off any burrs, re-grease and assemble. The brake-fluid has to be changed every 2 years also.... but I am sure you already knew that.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1- 6/25/f2/0900823d801625f2.jsp
I did some research on the web. Some articles link the noise to bad pads. But I still can't understand why. If I have bad pads, shouldn't the noise kick in when the brake is engaged instead of when the brake is released.
I claim no expert in auto repair. So maybe some of you can explain in more details. Thanks.
It's said that Honda's brake pads last a long time. So, do you think 73k miles is normal for mixed local & freeway driving in metro area?
Give your car a small break, put brakes on it all around.
Take it in and get the brakes inspected! the noise you hear is no doubt from your wear indicators!
73,000 miles is a LONG time for front pads to last! If you keep driving it you will need new rotors too!
Highly unlikely you will need rear brakes. These last 150,000 miles sometimes.
This isn't something to guess about.
when i am stopping the car pulls to the right/left and the wheel falls. i had 4 new tires put on under warranty because of tire cupping. since then, i have been experiencing an intermitten hard pedal. can anyone help me with these problems? can't recreate these problems for the dealer to do anything or gm...
Since you are still under warantee, the best you can do is complain to the dealer often and MAKE SURE that they document every time you complained. Make it THEIR problem.
unfortunately - I suspect what you are experinecing may not be unusual for that vehicle. There is a reason that Daewoo did not sell cars in the USA for very long. My wife rented a Daewoo once in Colorado and she said it had a tough time keeping up with traffic at the 75MPH speedlimit.
Lets review some Facts:
In the "olden days", if one got 60,000 miles from their automobile - they were VERY lucky indeed. Most cars were ready for the scrapyard by then. (A Mercedies-Benz was the exception) Today, An automible is expected to be usable for at least 150,000 miles. (Almost double from the the "olden days") My daughter had her last car for about 260,000 miles!!
In the "olden days" there were DRUM brakes on all 4 wheels. (Some had Disk in front) The DRUM brake design is MUCH more heavy-duty (That is why big trucks still use DRUM brakes) Also, the brake systems were OVER designed and often more capable than they needed to be.
When fuel-efficnecy became an important factor (1970's), the designers made the cars lighter and altered the braking systems to handle the bare-minimum they needed to. (taking into account the lighter vehicle)
Then came SAFETY! Braking systems started to incorperate dual-redundant hydrolic systems. ABS started to be designed in to the systems. My car has ESP which is the next progression above ABS. ESP has the ability to apply the brakes on any of the 4 wheels indipendantly in response to the input from a myrad of sensors.(read- MORE COMPLICATED!)
Given all the above mixed in.... we now have more COMPLICATED braking systems that are working closer to their maximum abilities and are expected to last TWICE as long.
It is not very difficult to see why there are more problems with the braking systems on modern automobiles.
One of the biggest issues is that Brake fluid is hydroscopic (attracts water into itself) If the fluid is not changed, then your hydrolic system will corrode from the insisde-out. Given the tight clearances within hydrolic-systems, it does not take more than a pinpoint of rust to cause a failure.
To reduce the chance of failure due to water-contamination, BRAKE FLUID MUST BE CHANGED EVERY 2-3 YEARS!!
Overall, cars are much better than 20 years ago. Much, much better than 30 years ago.
Fuel injection systems and their electronics are very good. Exhaust systems, with unleaded gas, last 5 times the life under leaded gas. Plugs will last to 100,000 miles. Oil to 7,500 to 10,000 per some manufactors recommendations (I just can't bring myself to strech it this far!) Antifreeze to 100,000 miles (Same comment!)There are no 'points and condensor'. Basically, there is no 'turnup' as in olden days until 50, 75, or 100,000 miles. Many, many cars, with reasonable maintenance will reach 150,000 miles, and more.
But, I think the braking system is one area where there are problems. I think the manufactors are purposefully under-designing braking systems, mainly in an effort to give their dealer network one area where they can make big money on 'maintenance' type repairs.
Rotors are designed too small and thin. Pads the same. Rotors do not have any extra metal allowing 'turning' them, which means they are to be completely replaced. And these repair services are greatly overpriced.
This underdesigning was not done a few years ago. You seldom saw warped rotors 20 years ago. Pads would last 40,000 miles minimum on most cars. Now there are many models where you have severe warping and pad replacement at 20,000 miles.
The concept of disc brakes has not changed. The design has been weaken by the manufactors.
The only U.S. manufacturer who used silicone fluid as OE was Harley Davidson, and that was for paint damage concerns. HD has now switched to conventional glycol fluid.
I do see thats theres a lot more negatives then positives for silicone brake fluid. I read that some classic car owners switch over to it though. Probably not a good thing to do.
With glycol-based brake fluid, it will keep in suspension a certain amount of water which acts as a "buffer". Only after it has absorbed too much water does it need to be replaced. (2-3 years...NOT milage dependant!!)
The Silicone brake fluid, being impervious to water, will let all moisture fall to the LOWEST POINT of the brake system and collect there as droplets. This is usually where the walls of your brake-cylinders exist....thus Silicone fluid has been shown to cause more-frequent brake-cylinder failures.
How does the moisture get in there? Same way it gets in your gas tank and oil sump! As the weather changes (temp. and humidity) condensation occours in the system.
I like the idea of using "test strips" diped into the master-cylinder to determine the ion concentration in the fluid. I wonder where one could procure these "test strips"?
The bottom line is the same.... CHANGE YOUR BRAKE FLUID REGULARLY. This will replenish the additives that get "used up" by the copper and iron ions.
-If the brakes get hot, water near the brakes could boil. Once it boils into steam, it is very compressible. Which means you have soggy or no brakes.
-Water accumulating on metal parts, especially in the piston bores or master cylinder bore, will rust the metal causing pits. Pits will cause leaks when the seals move across them.
Thanks for any assistance, my mechanic doesn't seem to know what it is.
I'll have someone check out the rotors. Thanks for the feedback.
