It's worse when the weather is warm and when it gets bad, the brake pedal gets hard to press.
Could this be the master cylinder?
We have had our 2000 Jeep grand cherokee for 2 years. In Oct 05 we replaced all rotors with after market NAPA slotted and cross drilled rotors. Got new ceramic brake pads. Caliphers were not replaced (told they were ok) but they did do something to them - refinished? Not sure there. Here's the problem. It seems off and on (and we only notice it when we go down a muddy road - gravel after it rained type of thing, or 4x4ing) but we get a burnt brake smell coming from the front wheels. Could the mud be causing problems or is that just when the smell is the worst so we notice it? Not sure there.
What do you guys think is the problem? I know these trucks are bad for their brakes but after spending $1200 on all new top of the line (non jeep parts lol) you'd think i'd be free and clear.
Any sugggestions would be appreciated.
tHanks
mandy
R
I would have the condition of the pads checked to see how their wearing.
Sometimes when it squeals, I can release and reapply the brakes and it won't squeal on the next brake application. Other times they will squeal several times in a row.
Anti-squeel pads are basically thin peel-n-stick thingies that apply to the backside of your brakepads. They alter the resonant frequency of the brake components.
Could something else be causing the brake booster to operate outside of normal limits, thereby causing the noise? To me, and I'm sensitive to this type of thing, it feels like I must use a little more pedal pressure than normal to stop the car.
We're on our third (counting the original) brake booster, and the noise/feel is exactly the same as before. While Ford may have suspect suppliers, I find it hard to believe that "that's just they way they are" (as stated by the dealer).
Bad vacuum connection to the booster? Bad connection to the master cylinder? Bad master cylinder itself?
Run rough, slow down, etc.
If so, this indicates a vacuum leak in the booster. And the leak may be what you are hearing.
Father in laws Pontiac van blew a booster - push the brake and idle dropped significantly. Braking took heavy push to stop the car. Of course, I think this booster had basically failed completely. Yours might be just starting to leak.
Low fluid means the brakes have worn, the pads/shoes have moved out, and more fluid is displaced from the master cylinder out thru the system, or...
a leak.
If there is a leak and fluid gets on pads or shoes, they may 'grab'.
I would look for a leak first.
No, first I would top off the brake fluid.
This is only occurring while braking from, say, 60 mph to a stop. Not getting this 'effect' when braking up to 40 mph. It's like the brakes work fine braking from 60 down to 20 mph, then the pedal suddenly depresses without any further braking! Fortunetly, that last inch before the pedal bottoms out against the floorboard stops the car.
I did have the brake power booster replaced around 2 years ago, this feels eerily similar...
Anyone got any thoughts or experience on this???
thanks!
A weak or expanding brake hose however decreases the pressur in the line, much like air would do, thereby giving you a weak pedal.
But...as long as your problem got fixed, that's really all that matters....maybe just replacing the line did the trick regardless of the initial cause.
I suppose they could have pinched it while the brake cylinder was off and managed to trap some air in the line.
Best Regards,
Shipo
Best Regards,
Shipo
Perhaps one of the brake lines had sprung a leak?
Regardless, they're working great now!
Of course, this is all just idle speculation---but the explanation just didn't make sense to me personally.
Supposedly, it's the rubber bellows inside the booster making the noise. But, since we're on our third replacement so far, I'm beginning to wonder. What else could be causing this noise? If it is coming from the booster, is there anything else that could be causing the booster to make that noise?
It's worse when the weather is warm and when the problem really gets bad, the brake pedal gets hard to press, as if there is a lot of resistance.
This car does not have anti-lock brakes.
Where should I start troubleshooting this issue?
GP
:confuse:
It sounds to me as if the adjustmet of the "pushrod" between the brake-pedal and the master-cylinder may be too short.
Another possibility is that you may have a brake shoe/pad that is retracting a bit too much when not in use. This would make for longer-than-normal brakepedal travel.
If you have rear drum brakes, I would suggest that your automacic-adjusters be checked to be doing their job. (of keeping the 'slack' out of the brake system)
One word of caution, if an adjustment is available it has to be done right. To tight and it won't allow for pad retraction on the disc brakes when they heat up.
New master cylinder, bled the lines and all is well. Hope that helps.
Within the past week, I have noticed that when I apply the brake and get to the point of almost being at a complete stop, I get a little bit of squeeking just for a second. Now, my rotors and pads were replaced about 12K miles ago, so I have a hard time believing I have worn my pads down to the warning indicators. Is a little squeeking like this normal?
Specific to your situation, as many different aftermarket pads use different friction compounds and different backing materials (if any at all), it seems to be a safe bet that your mechanic A) didn't use OEM pads, and
If you can live with the noise, then you're good to go for the duration of your pad life, however, if the noise becomes unbearable, then your only real option is to have the brakes done again.
I hope this helps.
Best Regards,
Shipo
The reason people use slotted/drilled rotors is to improve COOLING of the rotors. (or to just look cool)
Under SEVERE braking, the Slotted/drilled rotors can help disapate gasses that build up underneath the pads. I doubt that you will EVER use your brakes to this degree. (How often do you race on the track?)
I am surprized that your rotors were not marked "right/left" (or had an arrow on them somwhere)
In any case, the slots should "fan out" as you move forward. This helps the brake dust to work its way to the outside of the rotors (self cleaning)
That point is actually debatable. True there is slightly less surface area on a drilled and/or slotted rotor, however, due to the fact that the gasses are able to escape easier/earlier (as opposed to remaining trapped between the pad and the rotor, effectively preventing full pad pressure from being brought to bear), there is a school of thought that suggests that MORE of the pad comes in contact with the surface of the relieved rotor than with a standard undrilled/unslotted rotor.
Is that the true science of the matter? At this point I'm not qualified to make that statement. That having been said, the drilled rotors I'm using on one of our MiniVans (which came from the factory with nominally undersized brakes) seem to have more of a bite when warm than did any of the five previous sets of rotors. FWIW, I didn't make the move to drilled rotors to gain more braking, I did it because the relatively thin and small eleven inch rotors that were designed for the van have proven to be incapable of stopping a two ton vehicle without warping, usually in the first 10,000 miles of use.
Best Regards,
Shipo
(As can water splashed on a hot rotor)
BTW: I can relate to Western PA.... I visit there every summer. (town of West Newton) I have driven all over the country and western PA seems to be some of the most hilly of all. It seems that EVERY road was pourpusly built over the peak of a hill and there is a railroad crossing at the bottom 8-) I usually just use the lower gears to reduce the need to brake in western PA.
