Best Regards,
Shipo
-mike
I'll write back and report my findings when I get it diagnosed, hopefully sometime this week.
Got the brakes inspected today at the dealership. They said they were "fine". So, I guess I have been imagining a different pedal feel and lower brake fluid.
They did say I needed a new battery though. Cold cranking amps way down below normal. Has been a slight struggle to start on cold mornings. A 7 year GM battery for $170. No thanks... I'll go to Sears.
Yeah, first thing I think of when I hear "Energizer" is that pink rabbit with the sunglasses. I may be interested in a new-tech battery.. as long as the price isn't to high. I'll pay a little bit more to not have to worry about a new battery for awhile, but not to much. I'll probably go with the Sears Gold as I plan on keeping my car for only another 2 or 3 years.
Be that as it may,Napa's car battery was rated higher than Sears Gold.
I used to only buy Sears/Interstate after market. (as each used to last 10 years)
I think if you check Napa it might even be cheaper . (than either, being as how you only plan to keep it 2/3 years)
-mike
Motorsports and Modifications Host
Neighbors who work on cars have done it with a slight pressure from a C-clamp and using large plier like tools to twist to screw the caliper piston in. The parking brake set up is what complicates the piston on these rears.
Search Advance Auto for brake parts and tools or Autozone to see what the tool is like. One is a cube with various knobs on the sides for different brands of rear pistons...
-mike
Boy, is this a coincidence that I read this post. I just ran into this on my sons 05’ Mazda 6 this past Sunday. If you buy or have bought the pads at Advance or AutoZone they can provide a free loaner set of tools to do this (screw the piston back into the bore). You’ll have to leave a deposit until you return the kit but that’s more than fair, right. According to Advance (where my son bought his pads, the single tool to do this costs about $15 to purchase.
My advice is to use the tool, either way, to do this job. As far as I’m concerned it isn’t worth the risk of tearing the boot with pliers/channel locks if/when they slip, when you can do it right with no fear of slipping off the piston and tearing the boot but that’s your call.
If you want to go over to “Stories from the Sales Frontlines”, post 26171, you’ll see what I just said with a little more info.
Hopefully I didn’t post this too late.
Also, after "resetting" the caliper and installing new pads. Do not forget to "set" the parking brake mechinism using the approprate procedure for your vehicle. If you just start to drive and use the footbrake, you may be in for a nasty surprise later.
As far as I’m concerned, there is no reason to force something. I never subscribed to the mentality that “all you need is a bigger hammer”. :surprise: When you first put a C-clamp to the piston and it doesn’t move with the pressure that you normally use to back seat a piston this ought to tell you something. There is always a tool to do the job right. After all, this is the part of the car that stops you. 0-60 means nothing when you have to stop.
Good advice. Since I had never worked on a caliper before that required the piston to be screwed back in, I just figured that since the emergency brake was part of this contraption, it would be best to apply the emergency brake a few times just to be sure everything worked. Like I said, this is what stops ya.
Epilogue: Once he completed his pass, he pulled over to the right shoulder of the roadway, slowed to a crawl, and then pulled over into the grass where he dismounted his bike and laid it down on its side.
Best Regards,
Shipo
So I take it you changed both pads and ROTORS when due?
That said, my reason for changing rotors at every brake pad change are as much for convenience as they are for safety. Simply put, I can buy the exact pads and rotors that I want and shelve them until they are needed. When the time comes, zip, zam, zowie, I've got the brakes on all four wheels changed in a little over two hours, WITHOUT the need to visit a machine shop to have the rotor turned.
Best Regards,
Shipo
Here is a photo of "high quality" POWERSLOT rotors after 2 Vermont winters.
The replacment "Bendix" rotors have lasted 4 years since then but are starting to show some rust too.
-mike
My rotors used to look like that after as little as one year here in the Boston area, however, during the summer of 2006 I put a set of "Zinc-dichromate plated" cross-drilled Power Stop rotors by "autospeciality" on my daily driver, and now almost two full winters later (and over 40,000 miles), there is virtually no rust on those rotors.
Best Regards,
Shipo
Right now we're looking at doing another ED trip late this summer, this time for Mrs. Shipo. She's looking at a 328xi Sport Wagon and we're thinking of going round trip from Munich to Madrid (via Paris on one leg and Barcelona/Lyon/Zurich on the other). Were it that we stay on the main route and resist the temptation to check out the local sights (something that we absolutely will be doing), the trip is nearly 2,600 miles. I'm figuring that we'll rack up well over 3,000 miles in two weeks on this trip.
Best Regards,
Shipo
Best Regards,
Shipo
Believe it or not, the savings that you can get in ED sourced cars is really significant. erickpl, "BMW European Delivery" #1, 5 Sep 2002 8:42 am
Best Regards,
Shipo
-mike
Best Regards,
Shipo
shipo, "BMW European Delivery" #1436, 14 Mar 2008 8:14 am
Best Regards,
Shipo
So I had a chance to re inspect the brake pads and rotors. The pads still have massive material and the rotors are within specs and not warped.
about 6 months ago we started a project of redoing the brake lines from the anti lock unit to all the wheels. Well other things took up our time and in that time I have lost the paper that I had wrote the locations of the 4 lines off the brake unit.
I need to find how the lines go from front of brake unit block to the firewall.
not sure if its drivers front, pass front, drivers rear, pass rear... I am hoping that someone can help me short of me haivng to go to a bone yard and crawl around in the mud looking under another caddy.
I happen to have a few free days with easter here, and thought it would be a good time to finish what I started. Can anyone help with the line locations PLEASE?
Dave
Not only the cold is bitter in NH! :sick:
I replaced pads on the front of my LeSabre and did not resurface. In fact the company info, maybe on Bendix's site, said the coating on the old rotor is good for breaking in the new pads. At least better than a resurfaced rotor.
I'll be buying US made Bendix rotors for the rears in a few days or weeks to replace those. One has warped slightly and I've never had good experience with resurfacing a warped rotor even back in the old days of disc brakes.
10k miles since inspection is almost a whole years worth of driving according to the 12k a year stats. And 20k since they were worked on is quite a lot.
I never resurface rotors mostly cause it costs almost as much to take em off and have em resurfaced as it does to just buy new rotors!
-mike
I averaged 35-40k miles on front brakes on both my 95 and 96 Suburbans. The 10k inspection was 8 months earlier.
