Dodge Ram: Problems & Solutions
The continued inordinate problems with the fuel system indicate the root cause hasn't been addressed or you are having a parts/assembly quality issue. What type of fuel are you using? Have you ever dropped to fuel tank, inspected and/or flushed it? Have you check for pinched fuel lines? Was the inlet screen on the fuel pump replaced along with the pump itself? What brand of replacement parts have been used. Lastly, who is doing the work for you?
Constant U-joint problems can be attributed to how the vehicle is driven. Poor quality parts or not being lubricated properly can cause premature failure, especially if the vehicle is driven through standing water.
We sort of need more information in order to offer a more helpful opinion.
As far as a replacement, if I where going to go diesel the selection for me would definitely be Dodge. Neither the PowerStroke or the Duramax are equal in any way to the Cummins, IMO.
Best regards,
Dusty
Any way,.....I am a mechanic of sorts......more of a fabracator....I know the limits as far as driving goes.....I also drive comercial vehicles.....I drill wells for a living....
The Local Dodge dealer ship is the one who does all the warranty work....Injector pump turbo etc... I do the U joints. for a reason. On the third set of Joints I took it for warranty and they tried to tell me they were fine that all I needed was a complete 400$ brake job. I asked if that didnt fix the vibration would they give me my monney back? of course not...needless to say I put the joints in and the vibration was fixed and I drove on those brakes till 92000 miles....
I dont know what causes the u joint failure. they have grease fittings and I grease them every 2500 miles when I change the oil....when they go the needle bearings seem to just turn to a greasy paste. No rust or anything....
I sure love the way it handles though. Thank you for your support.
bunkee
Best regards,
\Dusty
The lift pump was replaced fairly early on (i had a Cummins part installed which was supposed to be better than what came with the Dodge's) and I had front bearings replaced at 80k miles. Swapped the pads at the same time even though they were still pretty good. I'm still on the second set of pads. Beyond tires only lasting about 35k miles, It's been a great truck.
I also have an '03 and had a bad u-joint at 70k miles. The dealer replaced it under the factory powertrain warranty and he thought it was a fluke. He says they have several dozen high-mileage '03's they service and that's the first u-joint. In fact, that's the first repair and this rig pulls 15,000# constantly.
I'm not sure I would trust your dealer at this point, when you have repetitive repairs it either means things aren't being fixed right or they're using low-quality parts. Once the warranty is up, get it fixed right. Or do it before the warranty is up and eat the cost. I recently had a problem with my Silverado where two dealers couldn't get the rear doors from rattling/squeaking. I ponied up the cash and had a well-known body shop look at it and they had it adjusted and fixed in no time.
I just happen to have a very good Dodge dealer nearby, but generally I don't find dealerships to be all that great. The GM/Chevy dealers here are pretty bad, as is the Toyota shop. Last Ford I had was a lemon so I avoid them until they build something I can't live without. Good luck!
Bunkee
but the Dodge dealer didn't even hint to that. They seem to have no fix. Anyone have any ideas? I'm at a loss, but know it's getting worse. Any help would be appreciated.
I do not have a RAM manual, but I believe they use the same design as Dakota based on my foggy memory.
Bests,
Dusty
Once while working on a race car, and hearing a similar grinding, grating noise, I found that the pilot shaft bearing had failed completely. I'm wondering if the way my truck transmission sounds if I even have a pilot shaft bearing in the craftshaft.
It sounds as if the transmission shaft is extremely loose, especially at low speeds. When the truck is warmed up to normal operating temperature, that's when the sound is the loudest. Thanks for all your comments. I'm really frustrated. This truck only has 6000 mi.
Kevin
The PCM controls the engagement and disengagement of overdrive through the operation of the Overdrive Solenoid. This solenoid switches the overdrive hydraulic circuits in the transmission that determine overdrive engagement or disengagement.
Best regards,
Dusty
Kevin
Go to a local AutoZone to have any codes read (free), which should point you in the right direction to find the problem.
kcram - Pickups Host
sounded like some sort of relay switch going on & off; this clicking noise is very consistant(20-30second apart). Is that clicking normal? Any help would be greatly
appreciated....Simon
The signal in question is simply a toggle. Since it already works against chassis ground I'm sure this signal line is safe to ground out.
Good luck,
Dusty
I have the a/c or defrost on. So, it must have something to do with a relay switch or something when those things are on
The vibration starts when I'm accelerating and also cruising on the highway with engine rpm between 1500 to 2000. It's a low level vibration that cannot be dublicated with simply reving the motor. everything seems tight and nothing seems to have fallen off including tire weights for balancing. The dealership has told me that it is just the nature of the truck.
Any Ideas?
When it gets cold here in Chicago,my brakes have what I would call an excessive amount of travel at the beginning of the application,I get about 3-4 inches of travel where nothing happens.It can get scary when this happens,my Dodge dealer is guessing at what causes this,I replaced the master cyl and it went away for a while (week),now they think it might be the vacuum booster,also a big money item to change,bad boosters usually give you a hard peddle,right,.. Truck is a 98 2wd V6 with 54,000 on it. Its been doing this for at least 3 years, and at least 3 sets of brakes,,,,,anyone else have a problem like this? :confuse:
:O) Happy again with my flaming red baby!
http://www.alldata.com/TSB/17/021777F0.html this should give you a list of service bulletins wasn't sure if you had the 4x4 or just the Plain Jane.
idea on how to test the relay?
