with P&I heads, 110K miles but well maintained every 3000 with
synthetic oil. Loud rattle from the front of the engine. Two Ford
dealerships are suggesting front timing chain(s?), however both suggest
engine swap. It seems both shops have limited experience doing the
chain repair. Said this problem is pretty rare.
Has anyone else seen this problem with this engine? Any suggestions?
The repair is $1700 and the swap is $5700. No guarantee on the repair.
Its my daughter's truck and in this shape I'm afraid she owes more
than it might be worth.
Thanks in advance. - JimC
Second issue is the starter grind I've seen on this forum. Mine does the starter grind when its cold, for about a second after the engine is running. I haven't confronted the dealer with this one yet, but I see its on this forum.
Any body else have the rough idle thing going on?
jriscign
Uhhh, I think you're low by a few thousand for conventionals (5-7k) and half an order of magnitude for synthetics... (15k).
See http://neptune.spacebears.com/cars/stories/interval.html
Under "Past Results" you'll see Mobile1 and Amsoil going 14-18,000 miles.
Two Ford dealerships are suggesting front timing chain(s?), however both suggest
engine swap.
This may be because your oil habits indicate you might just buy an engine instead of changing the spark plugs. (Nothing personal)
It seems both shops have limited experience doing the chain repair.
I think I'm thinking of the wrong part here - A timing chain is a $20 part that synchronizes the crankshaft and the valves. Replacing it is/was part of standard 100k service because if it fails you do generally need a new engine. Still, that need is not a kinda-maybe sort of thing - You know your engine is toast when you munch a valve. Any mechanic with limited experience here is a "run, don't walk" situation.
Something doesn't feel quite right here... Give me a call at 404.391.2153?
-Greg
I drove around for 3 months with a camcorder to document the issue. I basically pointed the camcorder on the instrument cluster whenever conditions were ripe for a stall (cold engine, stopped at the first few stoplights on my commute). The NHTSA was really happy to get a copy of my tape. I made the tape after I contacted an attorney and started the buyback process, but in your case it might help prove your case to the dealer.
The Expe drive like a different vehicle. Try it, it should be under warranty. Or if out of warr go to your favorite good mech. and have him replace the seals and bearings with heavy duty. What irritated me was Ford knew about the problem and still put the vechicles on the market without saying anything. Only when customers asked did Ford acknowledge the problem.
my suv used and you know when you have something new you want it to look good :shades: . So I washed the truck inside and out and i also wash the engine off thats when she got :sick: thats when it all started . water got down in the spark plugs and it ran just like your truck.It went back & forth 4 time to the dealer befor someone found the problem.Now my truck is runing grate :P
A couple of months ago it coded "missfire cyl.3" Replaced plug wires, reset codes and everythings been good since. What's up?
http://www.tennsoft.com/ExpeditionTranyFix.htm
Hope it helps!
Rob :shades:
