wco81 "Lexus RX 330" Jun 19, 2003 4:44pm
And here's an old link with some dealers selling aftermarket warranties, Bbhavsar - try a Discussion Search here for more recent stuff.
billg7 Feb 8, 2001 7:27pm
Once I park the Ody, the destination is right there so there's no need for NAV after that.
I mean who parks miles away from their destination and walk to their destination?
PDAs in cars can be dangerous.
Besides, they just don't make the car look cool because they are not part of the car. A built-in NAV is part of the car and so it makes the car look sophisticated and cool.
Jim d.
I don't know if the Honda dealer will install one.
I have a 2003 EXL-RES and can't recall reading this anywhere
drive too fast on highways on a new van (less than 60m/hour). Is this true? And Why? Thank you
in advance for your reply.
Even then, there were plenty who disagreed, instead adhering to the drive-it-from-the-start-the-way-you-will-later school of thought. Their theory was that if you baby a new car then you'll create a dog; if you want responsive power then teach it to do so from the get-go (a technical term). These theorists were obviously all men with undiminished testosterone levels. ;-)
With the new materials, engineering and lubricants, the breaking-in period has become less important. The only (still debated) remaining recommendation seems to be to avoid long periods of driving at the same speed for the first thousand miles or so. Apparently, the theory is that you don't want to wear the engine and drive train in a set pattern initially. I'm not sure even that applies.
And, in any case, as you have passed the magic 1000 mile mark, I think you can rest easy and enjoy your vacation. If it will make you feel any better though, you can move the cruise control setting up and down a few mph every hour or so.... ;-)
I have the Ody w/NAV.
http://www.mototuneusa.com/break_in_secrets.htm
Still waiting an answer in regards that outside temp? Maybe this is one of those HIDDEN options?
I was wondering however, since you have put a lot of miles, 158,000, on your Odyssey, could you please tell us what has failed over that period of time, other then normal maintenance items. It would be interesting to know as those items would also be more likely to fail on our Odysseys as the miles go by.
I couldn't believe it so I did the same for the next tank of gas and I got about 27mpg.
Presently I'm getting about 23mpg for the drive to work and running errands(30%city+70%hwy).
I think MPG has a lot to do with your driving. Cruise as much as possible, keep the RPM low (don't press accel pedal too hard) and, if possible, let it shift to the top gear sooner. (cross 48MPH and it shifts to 5th gear and stays there till you go below 40MPH)
BTW, I'm usually pretty good with measuring mpg - I top off and divide trip counter by gallons filled. Also, I only use 93 Octane grade gas (preferably Shell) in my van.
Now, I do have my share of the complaints with the minivan (roadnoise/windnoise/stiff ride) but MPG ain't one of them.
Similar experiences anybody?
The LX had those Firestone tires which have more noise then the Michelin tires on the EX. You get a lot more noise on concrete then asphalt. The cross bars on the roof rack add significantly to the noise, I think.
On my EX I have never been able to find a concrete road, where I live, and I do not have the cross bars. I and my passengers have never noticed excessive noise.
The ride in a new car can be bothersome at first as you are not use to it and it is different from the car you were driving. After a while however you get use to it, the ride seems fine to you, and it is not a problem. The ride in the Odyssey is faster but small oscillations. In the Ford minivan, Windstar, it is slower and larger oscillations. The Ford is considered to have a very good ride, but I prefer the Odyssey ride which is listed by Consumer Reports as one step below it, at good, and have ridden in both cars. I think the difference is a matter of preference and what you are use t.
But they are tread rated for 80,000 (?) miles so the tire compound is probably a lot different than your Firestones were. I doubt that they are defective though.
You may want to ask the dealer about a swap while they are still "new."
Oh, and check out this recent post:
andrewtran71 "Honda Odyssey vs Toyota Sienna" Jun 30, 2003 9:00am
Need help on who to call, price, pitfalls, things to ask for etc. Any and all experience is appreciated.
The drivers seat has no place to rest your left arm. It needs a left armrest. Has anyone put one in or have a suggestion besides a pillow.
www.classicsofttrim.com and www.katzkin.com
They are the 2 most common aftermarket sources for dealers I believe. They both have locations nationwide you can contact directly.
Good Luck
Robr, thanks for the link, I too will look into that.
I am going to ask the leather installers if they put a drivers seat armrest in for me.
I even considered making one that would fit in the hole on the door rest.
As for the leather install it appears there is little competition to the two companies noted earlier.
Scuple k
I have taken my Odyssey through maybe 20 car washes, and maybe 10 of those times with the antenna on, and it always comes out with no problems. On my other car I had a problem as it would bend it, so I would keep a very small wrench, in the glove compartment, I bought just for that purpose, to remove the antenna.
As far as the high water pressure bending the seal. I have not had that happen. Perhaps with those "Touch Less" car washes, which use only high water pressure to wash you car, and no rotating cloth, do you have that problem. I have found no problem with the rotating cloth, as to causing scratches, as opposed to the rotating hard brushes of years ago.
I just got my owners manual out of the car and it says under Appearance Care> Exterior Care> Washing> NOTICE:
"The radio antenna on your vehicle does not need to be removed when you use a "drive through" car wash. However, if you remove the antenna, make sure to re install it and tighten it securely using an appropriate tool."
I appreciate your posting. I think I read somewhere in the manual (between drives)
One car wash I went to suggested to me that they do this, and reinstall it when your car exits the wash. That's a wash though with people at the front end, and back end pre-washing portions of the car, and toweling it off. They used a system of sweeping cloth brushes on the top, and rotating cloth brushes on the sides.
Looking at the antenna, it wasn't clear that it came off easily.
I'm glad to hear you haven't had a problem with the seals for the windshield, but your statement about those "touchless" washes with the high-pressure water does have me concerned.
It's been a long time since I've owned a new vehicle...First time through with a rotating brush...
There must be a term for a new car owner that's appropos here.
Thanks again.
Is Honda coolant that much different from others? Has anyone had any bad experience by not sticking to Honda coolant?
There's a footnote there reminding you to look at the water pump while the belt is getting replaced. Naturally there's no estimate that I can find off-hand for what we think that should cost, but the labor wouldn't be much more.
