Visitor Agreement.
Scruple k
Actually in the past with my Accords I've done the same thing - but did use a private garage.
Haven't had the issue with the current cars as the antifreeze now has an insanely long life but in the older Accords old Prestone did fine.
Here's a link
http://shop.store.yahoo.com/truckstuffusa/portvtotfor9.html
http://www.mpt.org/motorweek/goss/21009.shtml
However, the question remains: can I take the Oddy to a nearby non-dealer shop for a coolant service as long as they use the same TYPE?
For other fluids, Honda only seems to recommend using their brand but allows for others as long as they meet certain specs. But genuine Honda coolant is the only king they allow? If I have to add some coolant on a trip, must I find a Honda dealership?
If you decide to use something else and the cooling system fails, you can be denied warranty coverage if they can show that use of non-Honda coolant caused the failure.
Mark
I was told, by the dealer that if my battery had failed before 3 years I would have gotten a 100% credit on the battery, so that looks to be another $37.66. My bill would then have been, without tax, about $22.
On your brakes: They are suppose to check your brakes at certain service intervals and show you, in percent, what you have left on your front and rear pads, on your service invoice. You should be able to look at this record and tell if you were about due for new brakes. So if you have gone say 22,500 miles, and you still have 45% then you have used 55% So your brakes should be good for 22,500/0.55 = 41,000 miles.
I see it looks like my front brakes, on my 2000 LE, are good for about 40,000 miles. I would say, from my past experance, that front brakes will last in the 30,000 to 45,000 miles range. I see, by using the same formula, that my rear brakes will be good for 150,000 miles. That sounds high. I have usually gotten about 90,000 miles on my rear brakes, in the past.
I would take it to another place and get a second opinion. Then you will know if your dealer is honest. What I like about extended auto warranties, is for most major repairs, I don't need to get a second opinion. I just tell them to do the job. Of course that does not help with brakes.
Don't buy anything at the dealer unless you have to.
The Odyssey weighs what, something over 4,000 pounds? I think a lot of RV's top out, like some SUVs, at ~3,500 pounds towing capacity.
I think you'll have to look at the tow vehicle's rating to pin it down closer than that.
btw, I don't know what you mean by "only a bar" - a simple tow bar as opposed to some anti-sway or dolly gizmo?
TOWING YOUR HONDA BEHIND A MOTORHOME
Your Odyssey's Owner's Manual advises against towing at more than 35 mph or for more than 50 miles. However, this recommendation exists primarily because Honda has not conducted formal towing tests at higher speeds and for greater distances.
We are not aware of any particular problems being caused by motorhome towing of Honda automobiles with either manual or automatic transmission, so long as proper pre-towing preparations are made and the vehicle is towed at legal highway speeds.
Automatic Transmission
When preparing to tow your Odyssey, make sure the transmission fluid level is full. Do not overfill.
If a Honda automobile with an automatic transmission is to be towed with the front or all four wheels on the ground, you must do the following every day immediately before towing:
Start the engine.
Press on the brake pedal. Shift the lever through all the positions (P,R,N,D,2,1).
Shift to D, then to N. Let the engine run for at least three minutes, then turn off the engine.
Release the parking brake.
Leave the ignition switch in ACCESSORY (I) so the steering wheel does not lock. Make sure the radio and any items plugged into the accessory power sockets are turned off so you do not run down the battery.
If you travel more than 8 hours in one day (including stopping time), you must stop and repeat the above procedures.
Notice
The steering system can be damaged if the steering wheel is locked. Leave the ignition switch in the ACCESSORY (I) position, and make sure the steering wheel turns freely before you begin towing.
Improper towing preparation will damage the transmission. Follow the above procedure exactly. If you cannot shift the transmission or start the engine, your vehicle must be transported on a flatbed truck or trailer.
SEVERE AUTOMATIC TRANSMISSION DAMAGE WILL OCCUR IF THE CAR IS SHIFTED FROM REVERSE TO NEUTRAL AND THEN TOWED WITH THE DRIVE WHEELS ON THE GROUND.
If you tow a Honda Odyssey with automatic transmission, the transmission fluid must be changed every two years or 30,000 miles, whichever comes first.
Note
Although experience has shown that the Honda transmission and powertrain are capable of being "motorhome towed," American Honda does not assume responsibility for any vehicle damage or liabilities incurred due to the towing device, towing vehicle, lighting hookup, or other towing equipment or towing procedures; any responsibility for these items is assumed by the owner/operator.
For more information about towing your vehicle, check your Owner's Manual or contact us.
I'm impressed by the Honda Board and willing helpfulness!
No matter how flat the road, the wheel is always pointed at one o'clock or two o'clock. It makes it tiring to drive - you always fight the wheel.
Anyone have the same issues/resolution. Could it simply be tires inflated wrong?
Note that I didn't have to fight the wheel to keep the van straight; the steering wheel was just off-center. If you're fighting the wheel, you may have the infamous pull problem. But an alignment should fix that too.
I'm looking for some feedback on Wood Trim installation in Honda Odyssey. I've posted same in Accessories forum but it seems to be least happening forum. I've Odyssey 03 Silver model. I want to know if I can get wood trim interior on this. I'd like to know what is good source to buy wood trim (of good quality).
Help Appreciated.
MJ
it is sooooo slick, the holder folds over itself and you put into it's own bag, the holder holds extras like remote and 5 dvd's should get an award, will hold up to 10" PLAYER i got a 7" from walmart for cheap and it's great size works weell and i can take it into the hotel with us. i'll use it instead of the big$$$$ unit that nissan charges
HIGHLY RECOMMEND THIS TO ANYONE WHO WANTS TO USE A PORTABLE--IT'S THE BEST UNIT AVAILABLE. works with both between seats or behind one seat. no i don't get commission for you buying one, just a satisfied customer
Michael
Does the 36 month policy have anything about mileage in it?
Services to Be Performed over the First 36,000 miles, for Severe Service, per the owner’s manual, and my actual cost for the services including tax. Note I get my oil changes for free, but I have included a generous $35 for that charge:
A = Oil Change. Cost $35
A+B = Inspect front and rear brakes, Rotate tires, Inspect tie rod ends, steering gearbox and boots, Inspect suspension components, Inspect driveshaft boots. Cost $103
A+B+C= Check parking brake adjustment, Lubricate all hinges, locks and latches, with multipurpose, Inspect brake hoses and lines (including ABS), Check all fluid levels, condition of fluids, and check for leaks, Inspect cooling system hoses and connections, Inspect exhaust system, Inspect fuel lines and connections, Check all lights, Inspect the underbody. Cost $185
A+B+C +D = Replace air cleaner element, Inspect and adjust drive belts, Replace transmission fluid, Replace air conditioning filter. Cost $350
Services to Be Performed over 36,000 miles with costs:
3,750 miles A = $35
7,500 miles A, B = $103
11,250 miles A = $35
15,000 miles A, B, C = $185
18,750 miles A = $35
22,500 miles A, B = $103
26,250 miles A = $35
30,000 miles A, B, C, D = $350
33,750 miles A = $35
37,500 miles A, B = $103
Total cost = $ 1019
Cost of your service contract is $895, so you save $124. You will have to have all that service done by one dealer, even if you are on vacation and away from home at the time. You do not get interest on the $895, but you are protected against inflation. If you like the dealers service a lot and are sure you will not move away and you will be there for all of the services, over the time period, it could be worth it. It is not a big savings however.
fwiw, I keep track of my expenses. I spent $464.46 on dealer service during my first 36,000 miles of ownership on my Quest.
I've spend $3257 since Dec. '98/83,000 miles on maintenance items, including things that your dealer wouldn't cover, like 5 tires, a rim, canoe rack, factory manual, windshield chips, stripped stud, 4 new hubcaps, etc. (The maintenance category is a big catch-all on my spreadsheet).
A rough estimate from looking at our Maintenance Guide pegs the cost through $36,000 miles at ~$533, so Bill's dealer seems to be doing a bit more than recommended or charging more than we think he should. And his last $103 service is beyond the 36,000 interval :-)
Doesn't look like so hot a deal to me, but usual disclaimers about my math.
Yes, I question also, weather it is a good deal. I would pass on the deal, myself. I would want at least a 1/3 to 1/2 saving, before I would take it.
Also I do not trust dealers who make up stuff, like $1,800, to sell me something.
Just arrived at the 3 year/36,000 mile point and I performed the 3 year maintenance. Total cost for genuine Honda vital fluids (coolant,ATF,brake) and a pollen filter = $80.
I can live with reliability like this!!
Thanks again
Michael
I saw a nice wood trim package on a Honda LeGreat (same as our Odyssey) when I was in Japan last year. I stopped by the dealership and got the car and accessories catalog which shows it as an option. Too bad we cannot get some of that stuff here in the USA.
Steve
Could it be my RCA cables? Or is there something wrong with the RES system?
Thanks for your update. I'm still looking for good deal on wood trim.
MJ
BTW, am purchasing from Honda of Nanuet--distant suburb of NYC. I highly recommend them as professional and pleasant to deal with so far. I got an EX with leather and DVD at 3.5% over Edmund's invoice + destination. I feel like I got a good deal. If it's not, please don't tell me
Thanks! to all of you for all the great info on these boards that helped in my negotiating.
checklist link
JD
So... Has anybody bought touch-up paint for their Ody? Should I get it at the dealer or an H&A type of store?
BTW - does anybody know of "instructions" or "How To" for simple scratch repair?
Suggestions appreciated! Enjoy!
2004 Honda Accord EX-L Graphite Pearl
2007 Honda Civic EX - Atomic Blue
2013 Honda Civic LX - Crimson Pearl
