Visitor Agreement.
I found this information at: http://auto.consumerguide.com/auto/new/reviews/full/index.cfm/id/- 38135
News Pilot will be freshened for 2006. The changes won't be major, but Honda says they will include the mileage-boosting cylinder-deactivation feature already offered on the Odyssey minivan, which uses the same basic V6. In addition, all '06 Pilots are likely to add no-cost curtain side airbags and perhaps the antiskid system now restricted to top-line versions. This would be in line with Honda's new policy of making such features standard for most all Honda/Acura models by 2007.
A fully redesigned Pilot is apparently on tap for 2008, with a new 3.8-liter V6 likely. Other components and even some body/chassis structure could come from Honda's new 2006 Ridgeline pickup.
I hope this helps!
My buddies 3/4 truck just hauled our ATVs and an off road golf cart back today and we never knew they were behind the truck. Unfortunately, I think I found my new vehicle in the pick up world.
October'ish is when I believe Honda usually comes out with the next model year of a pre-existing model. At least, that's what happened with the '04 and '05 Pilots.
Otherwise you should leave it on all the time.
The other circumstance that is what some drivers define as "having fun." E.g. they want to do doughnuts or spins in an empty, snow-covered parking lot. Similarly, some drivers of sports cars or sport sedans will want to hang the tail out "for fun." VSA will work against those activities.
Having my moonroof button down there would definitely be a big issue for me. I would have to relocate that thing.
Really? It would be THAT big of a deal that you would go to all that trouble?
I'll agree, it could be up higher on the dash but I know I got quickly used to mine and didn't fumble after the first few times.
While this may not be a big issue for most of the people most of the time it is very clear that open diffs do not allow for nearly the level of traction as locking ones do. For example, if one front and one rear wheel has no traction you don't move
I had asked the dealers about the Pilot but they did not know what I was asking and normally just made up some babble that had no meaning. So, it was the internet to the rescue again. So far I have discovered the following about the 05 Pilot VTM-4 system:
-100% FWD at speed
-Up to 55% moved to rear axle as needed
-Rear diff is a set of two electromagnetic clutch packs (think Jeep) that create a true locking diff. This alone moves the Pilot above the Highlander, Murano, and other car based SUVs.
Questions I still have:
-Does the Pilot move power to the rear wheels when moving from a stop? Honda says nothing about this but I have seen references to it in some reviews
-Is the FRONT diff locking? I am guessing not but I can't seem to find anything specific on this.
*The new Jeep GC can be had with an AWD system that can move 100% of power to a single wheel should all others loose traction! Very impressive.
See:
http://www.hondanews.com/CatID2078?mid=2002051647918&mime=asc
VTM-4 has three modes:
- Normal cruising, the vehicle is 100% FWD until slippage is detected, upon which torque is routed to the rear. The vehicle can alter how much torque is split between the two rear wheels.
- Under certain acceleration curves, some torque is routed to the rear to help with the "launch."
- If you are in 1st, 2nd, or reverse gear, AND you hit the VTM-4 lock button, torque will be routed to the rear, split 50/50 between the rear wheels. The amount of torque will vary depending on the speed, totally being removed from the rears at 18mph. This "lock mode" is designed for extricating yourself from a sticky situation.
As far as the front wheel goes, I know that more recent years of the Acura MDX use brake-based traction management on the front axle. The VSA system will pulse-brake an individual front wheel to gain traction. Supposedly this means that the vehicle can, on paper, get by with only any one wheel with traction. I do not know if the Pilot has this capability yet. Previous MDX's had a totally open front differential so it was theoretically possible to get stuck when only one front wheel had traction.
The Pilot's AWD system, with the acceleration and manual lock modes, is thus more advanced than other more basic AWD systems. It is not as extreme as systems that have front/rear lockers, true center differentials, permanent rear torque distribution, and/or deliver more torque to individual wheels. However, after several years of MDX and Pilot experiences, most owners are quite happy with their AWD systems. There are some who wish they had a bit more traction. In some cases those can be handled with winter tires. Some look at other vehicles.
FYI for others: Laurheis had a Pacifica that gave her nothing but grief. Luckily she got her money back and is now a Pilot owner.
After driving the Pacifica a great deal and almost buying one, I can say that I am glad I chose the Pilot. Quality issues still abound on the Pacifica, even though looks-wise it is nice the quality just is not there compared to the Honda.
But when we finally got to drive a Pilot then she made up her mind immediately. We went to test drive a Pilot just to compare and we purchased it immediately. After one test drive she was convinced that the Pilot was a much better choice than the Pac.
That was further confirmed when we went on vacation and drove a rental Pac for a week. Again I liked the style and the ride, but functionally the Pac is not as easy to use for 6 people as the Pilot. And with 6 people in the Pac there is room for almost NOTHING behind the 3rd row.
If you husband wants more style have him buy a new Honda Ridgeline! I told my wife I would give her my Pilot and get a new Ridgline...there is just that pesky thing of paying for it.
-D
The good news is that you should be able to get the MDX at invoice as they are being redesigned for '06.
I have owned both the MDX and now the Pilot. To me the extras in the MDX were not worth it and the difference in monthly payments was not 20 or 30 bucks but 100+. To me the two vehicles are very similar. In the Pilot EX-L there are still the heated seats, mirrors, and similar interior. I noticed the extra space in the Pilot and it has been a big plus. The ride of the Pilot is a little softer vs. the MDX with touring. Regular fuel vs. premium fuel also is easier on the wallet. We have had zero problems with our 2004 Pilot.
Good luck........
Three 18inch wide child/booster seats = total width of Pilot back seat with no extra room between them.
I'd consider the Sienna 8 passanger, but if the seat comfort is poor then maybe something else?
-jay
NV - from about sea level, over Donner Pass
(7.8k ft?) and back down to about 5.2k ft. Two
people and a 100lb dog.
The lady of the house has a bit of a heavy foot
and she had no complaints. She did have trouble
keeping the speed down, and had to rely on the
cruise control.
I suspect a bunch more luggage will make a
difference, as would a heavier passenger, but I
wouldn't describe the car as under-powered.
--S
I would think your Honda dealer would let you drive a demo Odyssey home for a day and see how you like it. For the room you need, it's gonna be tought to beat that minivan versatility.
I'm looking at a Pilot/Odyssey as well. Wife thinks it's a no-brainer to go with the SUV because it's cool. I say, more value with the van and I can always put TVs in it and the kids will think I'm the greatest thing since sliced bread!!
Each is a fine vehicle but the Odyssey is both more practical and the better value unless you absolutely must have AWD.
According to my two teens, the Odyssey is also "way cooler."
Does the navigation in the 05 Pilot double also as a rearview camera when backing up?
Thanks in advance for your response?
In fact, if we had bought the cars in reverse order (Odyssey first) there is no way I could have justified the extra cost for the Pilot navigation system.
"Minivan stigma?" I understand it as my wife refused another (after driving one for 8 years) and now drives a Pilot.
However, after I brought home an Odyssey Touring the other night (for me) she said, "Gee, I may just use that to get groceries - that power hatch is really nice."
My teens think the Odyssey is "way cooler" than the Pilot.
Ultimately you have to drive what you like, even if it's hard to justify some of the trade-offs.
I have to have a vehicle for towing, so the minivan thing is out for me because the Murano doesn't tow also. Look for the practical, most used aspects of these vehicles you're going to have to live with. Of course, if you can live with some shortcomings in the SUV and the image does really matter (I'm not poking fun here), go with the Pilot.
Remember, this is my take on the situation. My wife loves her Murano and thinks I'm over anaylizing and picky. She's the one driving it all the time and thinks it's the greatest. Like Steve said, drive what makes you happy. That Pilot could put a smile on your face at the end of a hard day where the Odyssey might make you even more mad.
