Visitor Agreement.
http://www.safercar.gov/RollRatings.cfm
In the dynamic test, the vehicle is put through some maneuvers to see if it will tip its swheels. The test is done at specific speeds and is a pass/fail, based on whether the vehicle tips or not. It isn't done at progressively higher speeds to see if one vehicle is more likely to tip sooner than the other.
In the static test, the height of the center of gravity is measured versus the width of the vehicle's track. From this, the percentage probability of rollover is computed.
The Pilot benefits from having a very wide track, which does help stability and, on paper, helps reduce rollovers. I believe the Outback suffers because it has even higher ground clearance than the Pilot and is significantly narrower.
The problem with the NHTSA test is that with just a pass/fail test with a moving vehicle, it doesn't factor in enough of vehicle dynamics. E.g. in the pass/fail maneuver, one vehicle could well have been precariously close to tipping but just made it, while the other vehicle was rock-solid and could have been going 20 mph faster without a tip.
Nevertheless, the Pilot and its MDX brother both do very well in these tests.
Pablo
Come to find out, I had put a "zapper" in the garage to deter bugs/spiders/mice and it was causing my backup sensors to go crazy. I told the service writer what I had discovered so he could let others know just in case someone else came in with the same problem.
Mark
Black Ice, and general slick conditions are a far bigger problem, once the temp gets down to 5 below and lower. Drivers think they are smarter than physics. They can't hold the corners that"appear" to be dry pavement, but are actually ice you can't see. I see them lose it just going straight on the interstate also (driving too fast).
The Pilot EX-L with stability control will help. When I get mine, I plan to swap out the tires for some good Nokians. We do a fair amount of driving up north, and those tires give a lot of extra security. I like the Nokians since I don't have to change them spring and fall, I just leave them on all year.
know you are starting out on a really slippery road you can always lock the Pilot's
AWD with the push button (locked until 18MPH??).
Glad you like the BMW - we're quite happy with the space and cost of ownership
of the Pilot.
I'm reminded of something my uncle (a long time car dealer) once said about
BMW's "whenever you see a BMW with the hood up - there's one thing you know:
It's going to be EXPENSIVE".
I have experienced no problems with the Pilot in Northern Minnesota. We live in Duluth, a hill city near lake Superior, and when the storms arrive the Pilot has driven through the snow with out any problems. That is considering activities that are off the main roads. In short, NO SWEAT.
Cheers
You're correct. Because I always lease, BMW is an option for me. BMWs out of warranty can be financially "dangerous".
Regarding the Pilot, the problem is they only allow full for wheel drive at low speeds. This can be a very dangerous and expensive compromise.
Think of it this way, if locking the Pilot into 4 wheel drive wasn't an advantage in poor conditions, that switch wouldn't be on your dashboard. (Unless you think the switch is a sales gimmick.) Then understand they made a safety compromise by only allowing you to lock it up to about 20 mph versus being in 4 wheel drive at highway speeds. Finally, even with the Pilot locked in 4 wheel drive, the X3 is far superior in poor conditions.
Drive a bit slower and leave some space between cars, and just about any car/truck/SUV will get you to where your going.
The northern States have lots of snow removal trucks, so the roads are kept pretty clean even during the bigger storms.
Of course I own a subaru and a Chevy Tahoe (4x4), but its more for the back roads and farm roads that I have the AWD/4x4.
--jay
If you think about it, though, I'm not putting the Subie down for its AWD capabilities. There are just those occasions where the added weight of the Pilot is helpful. Ruts or snowbanks that would push our Subie around have little to no affect on the far heavier Pilot.
any improvement with warmer weather? it becomes a factor at 2.35 per gallon.
I wish I could get a definitive answer on this, since I'm one of those on the fence waiting for the '06 with VCM Vs just getting an '05.
CR did say that the Chrysler 300 (with their version of VCM) did not get the milage improvement Chrysler advertises.
Your owner's manual specifically says NOT to top off your gas tank! yopu can damage your emission system by doing this!
"Last four takes about four minutes"
Yeah, I think I got stuck in line last week behind you!
Tourings have PAX tires which may slightly help mileage - supposedly they have less rolling resistance than conventional tires.
And you are, of course, right - driving style has a tremendous effect on mileage. It would have been more helpful if kidtopia had provided some specific mileage figures rather than broad generalities.
I would insist the Honda dealer check it out. I have an '05 EXL and the fuel system acts very normally. The one time I let the light come on it took about 18 gallons. For a 20.5 gallon tank, that's about right.
While you can only lock the rear clutch packs to the drive line at low speeds the Pilot's computer systems will automatically route power F/R and L/R (rear) at all speeds when there is a loss of wheel grip. So, it is AWD at all speeds.
The manual locking feature is there strictly to allow you to lock up the rear wheels if you are starting from a stop in heavy mud, snow, or up a steep inclie while towing. Under normal driving in poor conditions the computer systems do the locking and power distribution for you.
-D
I guess this may be a good thing but for me, a waste of time.
What is of utmost importance to some people is a waste of time for others.
For those interested in the gas debate and SUVs, check out this thread:
isellhondas, "SUV Sales Slump" #4, 18 Apr 2005 5:30 pm
No offense intended, but you must have a lot of spare time. I guess I'm one of the "it is what it is" types. I checked milage a few months after purchase so that I would probably recognize a substantial change in milage indicating a problem. Other than that, there are way too many variables involved with accurately measuring fuel consumption by the "miles/fill" method.
I, on the other hand have no real reason for doing it besides to check general trends of how often I buy gas and how much I spend, which really makes no difference at all because ya gotta get the gas anyway. Oh, I do check often to see how many miles I drive per month so as to extrapolate when I might "have" to buy a new car. ;-) I figure that at about 100,000 miles, I better start looking. I do it in about 5 years. My wife doesn't do it for her car. When I buy gas for her, I don't do it. I actually could get by with having a little book to note servicing, repairs oil changes etc...
By the way Niblick45, no offense taken.
I purchased my 05 Honda Pilot EXL a week ago. This is my first Honda. I have driven the Ford Explorer and BMW sedan prior to this.
The car handles quite well. I like the roominess interior except for the third row seat.
There are some details that I thought Honda overlooked such as audio function buttons and others on the steering wheel are not lit, so using these function at night is a challenge. The channel changing only step forward and not reverse. The glove box is also not lit. The power door lock not activated when vehicle is in motion.
Question regarding fuel. I thought regular unleaded fuel is ok , but the owner manual say to use fuel with 91 octane or higher.
Well, with only 500 miles on the odometer I hope that these are all the short coming I will find with the Pilot.
If it's any consolation, the 2005 MDX doeesn't have lighted steering wheel buttons and only "up" direction on channel selection. Our 2004 TL has an excellent lighted multifunction steering wheel that integrates well with the navigation system. I would have thought that the 2005 MDX and Pilot would have incorporated these advancements.
I did think the Pilot was fine with regular gas, but perhaps with the bump in horsepower for 2005, they went to premium. The MDX engine and exhaust system are tuned differently and requires premium. For what it's worth, I could hardly tell a difference in acceleration between a 240 hp Pilot, 255 hp Pilot or 265hpo MDX. The increased noise in the Pilot under hard acceleration is noticable, but it's not like the Pilot screams like my former S2000.
Again, congrats on your new Pilot. As a two Acura family, I am a big fan. And I have never owned any vehicle that was built to the quality level of my HONDA S2000. So, in spite of wanting the extra goodies that came with the MDX, I have no less respect for or confidence in the build quality of the Pilot.
I assume that Honda will issue a TSB or send out a sticker for the owner's manual to fix the error. What does the fuel flap say - use unleaded only or regular unleaded?
