Minivans - Domestic or Foreign
1444547495073
    cpsdarrencpsdarren Member Posts: 265
    It seems you suggested it, not me.
    thegraduatethegraduate Member Posts: 9,731
    Firm doesn't always mean comfortable, but my extremely firm Honda Accord seats are the most comfortable seats I've ever sat in, much better than the soft, flat seats from the Suburban I used to ride in a good bit (Leather, 1999 Suburban). Much more enveloping and comfy in my car, despite the fact that my seats are harder.
    Firm isn't always bad, it just requires more attention to seat design than does a "fluffy" seat.
    hansiennahansienna Member Posts: 2,312
    Agree. My Volkswagen Bus and Beetle would not qualify as a German luxury car but each had firm seats that were comfortable for a long trip for the very reason you stated. ;)
    dc_driverdc_driver Member Posts: 712
    "Chrysler middle seats are firmer that's true. Uncomfortable? not a bit. If you think your under floor space that Honda gives you is enough and don't even use that, you chose the right van. That sure isn't my case. I use all the space I can get in my van. But I also use it for a lot more than seating people. It's also a working van."
    Okay, "uncomfortable" was a little strong. Less comfortable than the competition is a better way of saying it. That fact that you use your van as a work van definitely helps me to understand why you like Stow N Go so much. I would have picked the DCX vans over the Toyota and Honda as well if there was a constant need to take the second row seats out...
    Hey, I just went to your carspace site and noticed your birthday is June 18... That is my birthday as well :)
    Small world..
    No disagreement. Firm can be comfortable or not comfortable. Depends on the seat, depends on the support, depends on the person. So, each person has to decide if something is firm like a German luxury car, firm like a rock or something in between. The point is, German luxury car isn't the only possibility and some people may not find that German luxury car to be comfortable, anyway.
    Not sure what the big deal is. If seat comfort is a big issue and you find your seats comfortable, be happy with your choice. If someone else doesn't agree or finds another seat more comfortable, so what? No harm in telling people the differences. They're gonna check them out in person at some point, anyway.
    dennisctcdennisctc Member Posts: 1,168
    A friend of mine that works for GM told me something very interesting. He worked in seating a few years ago and GM was trying to improve their seats. When a GM engineer needs seats for a new vehicle, many times they almost design the seat from scratch for their specific vehicle. VW for example uses a basic frame/base for EVERY seat design for VW/Audi/Seat etc....then build on top of that base maybe adding motors or lumbar etc..but it's not a total redesign. That's why you get comfortable seats in a Jetta/Golf, even at $15k.
    scoti1scoti1 Member Posts: 676
    sc00bs,
    It doesn't sound good - no service records, was a lease vehicle. The 1998 Toyota models were ones prone to sludge, even when owners could prove reasonable oil changes. Lease vehicles tend to suffer more abuse and less frequent oil changes, so the possibility that this vehicle has or will sludge is much greater.
    There is a Toyota sludge warranty, but it is for only 8 years and unlimitedm miles, so yours is up sometime this year, and to get the warranty repair, you have to prove reasonable maintenance. Cost to repair a sludged engine is in the $3000 - $4000 range at best.
    If you have your heart sold on this vehicle, you need to see if the seller (I am assuming this is at a dealership) will offer a warranty against sludge OR have a mechanic you trust pull the valve cover to see if it is clean (the only way to check for sludge with certainty) -- this may cost $100 or so. If you try to use this as a negotiating tool, I would try to get the price significantly below the asking in order to cover a potential high $$$ engine repair.
    My advice would be to not buy a used Toyota of this vintage unless the seller can produce a full maintenance history.
    Scoti
    When all seats are the same, there will be a lot of uncomfortable passengers. I'm thankful mattress manufacturers aren't so shortsighted that they think one-type-fits-all is a good idea.
    sc00bssc00bs Member Posts: 87
    Scoti,
    Thanks so much for your reply. I think im going to take your words of wisdom. I was on that ether high, needed someone to knock some sense into me :)
    What years are good for toyota siennas ???
    Well its back to the hunt :)
    marine2marine2 Member Posts: 1,155
    Small world..
    Didn't realize I put that down anywhere. Yes, we are getting close to adding another one on. Happy Birthday to you in case I don't get on around then.
    The sludge policy was from 1997 - 2001, but Toyota did not make any engine mods to alleviate the problem until mid-year 2002. So to better avoid the problem, you can stick with a 2003 and newer model and make sure you can get maintenance records (and continue to maintain it well under your ownership).
    IF the owner can prove it was properly maintained and can provide you these records you may still want to consider the earier models. Not every vehicle got sludge.
    kbeckskbecks Member Posts: 4
    I'm wondering what folks here would consider the best value make/model for a used minivan in the 10 to 15k price range, with priority given to reliability and safety.
    My guess is the Dodge/Chryslers, or Toyota/Honda, although a used Japanese will be much more worn in that price range.
    Your thoughts?
    I'd like any used minivan I consider to have traction control, but I don't know which vans are equipped with it, and most used salespeople don't know either.
    (My 01 Acura TL has traction control and it makes me feel so much more confident / safe in winter driving.)
    I know that Hondas have traction control going back to 2001.
    On Toyota, Dodge and Chrysler (the other candidates, I don't know). Chrysler T&C currently has traction control on a couple higher trim levels.
    Can anyone shed more light on what years and trim levels I may need to go for?
    allison5allison5 Member Posts: 130
    I actually just wrote in another forum regarding this and then saw this forum. I have a GMC Yukon and I also have a bad back from degenerative disks. The yukon was okay in the beginning with large, comfy seats and now almost 3 years later, my back is having more problems after. I have driven it 36,000 miles. Now I am in the process of deciding what minivan to get, ( I am getting rid of SUV for various reasons). I think I am going to go back to Odyessy (I had a 2000) years back and the comfy part was so so in that. What do people think of the Odyessy as far as being comfortable? I have tried most other vans.
    masterpaul1masterpaul1 Member Posts: 421
    I can't speak for the other makes, but we bought a used 01 DGC EX that has traction control and with a lot of standard features. We bought it back in Sep. 2003 for $15,995 before taxes and stuff. It only had 36K. We now have over 75K and it's been very reliable. I think you can get one between 10K and 12K now. If you want side curtain air bags for all three rows, you might want to look at a 2002 and up. Ours only has the driver and passenger side airbags. :shades:
    jchan2jchan2 Member Posts: 4,956
    The best value would probably be a clean, ex-rental DCX minivan with Stow N Go as it will not be expensive, it will have a fold flat 3rd row, and there are plenty to choose from.
    I would also look into the Ford Freestar/Mercury Monterey,as they are cheap, have that fold flat 3rd row, and some trims have AdvanceTrac (albeit probably none of the ex-fleet models) but others would probably tell you to look elsewhere.
    A well used Honda Odyssey (mine with 90,000 miles is KBB valued at around $11,000) could be a good buy as it will last you far beyond 200K miles. (being a Honda, afterall)
    Agree with jchan2. For the money the DCX vans will be much newer and have much lower miles vs the Honda and Toyota vans. Your other option is to checkout the Kia Sedona. For 15K you may actually be able to find an 05 that has a solid warranty left.
    Good luck!
    97xpresso97xpresso Member Posts: 249
    A 2005 Kia would have a "solid" warranty only if purchased new. Second owners only get a 5/60,000 which starts at the original sale date. Still a respectable warranty, if you can get them to honor it. They have poor fuel economy and reliability issues. The 2006's have been highly praised by the media. The 2006 crash results are impressive. Time will tell if it's the real deal.
    I know GM had it on their Minivans starting 1998? maybe 1999.
    Yeah, I realized the 10/100 powertrain warranty would not apply but if he bought an 05 for 15K (should be plenty of them out there), he would still get the balance of the 5/60..
    I agree with your assessment of the Kia, I personally would rather drive an older Honda or Toyota, but some people like to own newer.
    The 06's do look much improved (drove one when we shopped recently), but I agree with you that I need more time before I buy Kia/Hyundai...
    "A well used Honda Odyssey (mine with 90,000 miles is KBB valued at around $11,000) could be a good buy as it will last you far beyond 200K miles. (being a Honda, afterall)"
    I would say that the average vehicle will get about 150k miles. I would not say that just because its a Honda it will get 200k, there are just too many factors that play into the longevity of a car especially when you buy one with higher mileage or one that is used. I would say 150k and anything you get after that would be bonus.
    In my area the price of Toyotas have been dropping. For 15 or under some examples at local dealerships are :
    02 CE with 55k is 12k.
    00 XLE with 69k is 11k.
    00 LE 75k is 9500.
    Honda Oddyssey
    2000 LX 65k miles asking price 11,950.
    2003 LX 68k miles asking price 14,900.
    Dodge Grand Caravans
    There are TONS of off rentals right now, one listed is an SE for 12,999 with 29k on it and its certified (so the warranty is 8 year/80k powertrain, 3 month 2,000 maxium care, 24 hour roadside assistance). There are several with under 20k for 14ish. SXT's with under 20k are listing at the top of your range at 14,995. If you really wanted to go cheap, they have a gazillion of 2000-2001's with around 50-60k on them for about $8,000.
    Kia's can be picked up right and left, loaded for around 10k, even under if you are patient and look around.
    "We drove the Sedona and actually considered it but the price really wasn't so great."
    I have to agree. I was extremely disappointed when the new model came out and the pricing was higher than Kia's normal pricing. I think that was the biggest mistake that they made (Hyundai also). They could have sold TONS MORE if they would have kept their target market the same.
    In fact we still have many sitting on our lots around here untouched. I have seen ONE actually owned and driving on the road here. When I went into the Kia dealership they kept pushing the van even saying they could take a TON off the price just to get them out on the road.
    People are not going to spend as much as a Toyota knowing the resale value is going to be horrible. I would love to wait one year and then pick up a used one for way way less.
    aaron_taaron_t Member Posts: 301
    I've see advertisements as well as people on here buying new 2006 T&C base model for under $15k. No traction control and short wheel base, but lots of godo equipemtn and a brand new vehicle. 2005 DGC SXT & T&C Touring should also be in under $15k and come with lots of additional features including TC. If i had a choice between a $20k mile 1yr old DCX van vs. a 100k mile 4-6yr old import, I'd buy the DCX. While I don't agree with many Honda/Toyota resale values, they are real and I would only consider buying them new. As mentioned above, there are too many factors involved in reliability of any 100k mile vehicle. Lots of people buy them, but I wouldn't.
    hondakidhondakid Member Posts: 17
    I am in the process of buying the Quest ... Right now, in the Toronto Area, the 3.5 S is going for $6,000 CDN under MSRP ($32,000 - $6,000 = 26,000 before taxes and freight / pdi).
    What kind of deals have you been able to get?
    What was your buying experience like?
    Where did you buy from?
    How do you like the Quest?
    This "June Offer" clearly states the $6,000 rebate is off of MSRP .... I am sure I can get them to do around invoice and then have them take the 6K off.
    Any suggestions, ideas, opinions, etc will be GREATLY appreciated ..
    Thank You,
    HondaKid
    Ok, I test drove an 05 Dodge Grand Caravan SXT. I also drove an 05 Dodge Grand Caravan SE. I also was able to test drive a brand new Caravan SXT.
    Scary. First of all it was 91 Degrees out. The vans were sitting in the sun, so they were a bit hotter. The SXT had a HORRIBLE shutter when I turned on the AC. It almost killed the engine it was so draining. It also was NOT pushing out what I would call cold air, at all. I drove the van for almost 45 minutes and even with front and rear AC the van still felt warm.
    With the AC running the van had absolutely NO power. I had to push the pedal all the way to the floor to get it to even want to move. Ridiculous.
    Next was the SE. It actually performed better than the SXT, but was still struggling to cool off the entire van. It had only front AC, but it did BETTER than the SXT. The seats in the SXT and SE were cheap.
    The smaller van, well it was interesting. It actually had some pep (maybe because it had the V6 and wasn't carrying the longer wheelbase with it?? The AC still struggled, I thought, but was able to cool the van down.
    The front was invisible to me. When trying to park it and such I could not tell were my front end was. That was a bit different to me, I have been driving cars with visable front ends.
    I had a hard time finding the controls and operating the radio (I saw that mentioned above). The readout on the 05's was almost impossible to make out. As a newbie in a vehicle it would take a while to get used to those controls. The model I drove did not hava audio controls on the steering wheel, which really was stupid.
    The speakers STUNK!!! I don't know why Dodge even wasted their time with those.
    Other than that they were nice to drive. I was HIGHLY concerned with the AC issue in the SXT. My friends bought an 04 in which the alternator was dead within the first 5,000 miles. The doors, oh the doors in the SXT were power and they upon first approach got stuck. We had to manual pull them to get them to open, but they worked after that.
    By the way, they are advertising used SXT Grands with around 15k on them for 14k. Brand new 06 Carvans (not the SXT's, short wheelbase) for 11k.
    rwallisrwallis Member Posts: 3
    Any comments about the Uplander?
    daddioof4daddioof4 Member Posts: 50
    Back in March before I bought my Mazda MPV, I was receiving quotes on Nissan Quest 3.5S, with DVD players and some additional upgrades for $21,300 USD (approximately $24921 CDN). I would holdout a little longer because I think when they bring out the 2007 models with the redesigned dashboards, you will be able to pickup a 2006 for under $20k usd ($23.4K CDN). But once you see the 2007, you may not want the 2006 dashboard. But, beauty is in the eye of the beholder. My neighbor likes the dash. I think it is ugly! Right now I have seen Hyundai Entourages advertised for $20.8k USD. Good luck in whatever you buy!
    theflushtheflush Member Posts: 100
    Ugliest van I've ever seen.
    mrblonde49mrblonde49 Member Posts: 626
    I can't fathom why anyone would buy a GM van with all the other choices out there
    It sounds like something was wrong with at used Grand SXT. My 06 T&C Touring (almost the same) had been trouble-free in 19k miles. The A/C is very cold and cools down the cabin quickly when I leave work @ 4:00pm, the heat of the day. The rear AC helps a lot, IMO. I notice that power is down a little with the compressor running, but no shuddering. There have been a couple TSB's regarding the A/C for the 3.8L and a friend of mine with one has had problems with her 2005, but it's been fixed by the dealer under warranty and no problems yet this summer.
    As for the radio, the Grand SXT has the better speakers (maybe the SWB SXt as well). It isn't the best OEM system, but far from the worst I've had.
    I have 12k miles on my 2005 GC SXT.....the AC works great. One trick I use if it's parked outside in a hot parking lot - I keep the sunroof cracked and on the way to the van I use the keyfob to open the power doors and hatch. The hot air is purged from the minivan instantly!!
    Last time I was at dealer for oil change they performed a TBS adding a shield to the condensor, to protect it from damage.
    We have a 01 DGC EX with over 76K. We've had no problems with our AC. Just about a month ago, I took a meat thermometer to see what temperature the AC was. It was around 62-64 degrees on a day where the outside temp. was above 90 degrees. We open all the doors and roll down the front windows to let the hot air out before turning on the AC. Sometimes it might take five minutes or so for the AC to get to it's coldest temp. depending on outside temp. and the last time the AC was used. :D
    ClairesClaires Member Posts: 1,222
    There's a newly-created discussion for the Fairlane in our Future Vehicles Forum too. Enjoy!
    Ford Fairlane Concept
    Looks exactly like a Scion xB on steroids :):D
    sebr0d1esebr0d1e Member Posts: 17
    And once again, Ford just doesn't get it..just like they didn't get it when they decided to come out with one sliding door instead of 2 on the debut of the windstar.
    Now here they (johnny) come (lately) again with a car to 'replace their minivan.' Yet, the thing has regular (not sliding) doors. Sorry, but sliders make the minivan...without them, you have something else, but not a minivan.
    You can get convenience, comfort, power, 5+ seating, etc, in pretty much any other type of vehicle, but only one has the sliders. Call it a people mover all you want, call it a replacement for your minivan too, but don't expect it to do the #s in sales that minivans do, bcuz there's enuff competition for this new type of vehicle..plus, ford isn't known for making big vehicles that are good on gas, so to me this is just another Freestyled-attempt to defray attention from their moronic and eroding leadership decisions of the past 6+ yrs..
    The Fairlane is going to have to be either really cheap or really innovative to be a success.
    sebring95sebring95 Member Posts: 3,241
    Ford has publicly stated they "have no intention of competing on the minivan front". They don't feel there's any money in it (probably not when you build garbage....). This was per an article in Automotive News about a year ago.
    bobw3bobw3 Member Posts: 2,989
    I think the the Ford Fairlane, Freestyle, and other crossovers are for people that don't need the 3 row capability every day, but when they do need it they want something spacious in the 3rd row. For those that are driving around 5+ people everyday, than the wide boxy minivans make sense, but these crossovers are great for those of us that don't need that much capacity. Think of the Fairlane, Edge, Freestyle as modern versions of the old station wagon.
    I consider my Freestyle as a Ford 500 station wagon, no matter what Ford wants to call it. Not too tall, not to short, and I'd rather have regular car doors and not sliding doors, which are either too difficult to close unless automatic, slow to open/close, and present more problems down the road than regular doors. The Freestyle's 2nd row seats flip forward, and it's easy to access the 3rd row when I need to. I just prefer the driving characteristics of a car.
    Motor Week did a comparison of the Freestyle vs the Odyssey. Most people would say that of course the Freestyle isn't even close, but then it did pretty well in the article. Better and driving and handling but lost mostly for space, so if you don't need the space, then cars like the Freestyle, Fairlane, Edge and other crossovers are a good alternative to the full sized minivan.
    http://www.autoweek.com/apps/pbcs.dll/article?AID=/20050502/FREE/505020705&Searc- hID=73248434937503
    "What it all comes down to is this: We look at which vehicle fulfills its purpose better, not necessarily which is the fastest or nimblest or sportiest. Sure, all those things matter, and even contribute to making a vehicle safer (the ultimate family-friendly feature). To this end the Ford does have one big leg up on the Honda, especially with its available all-wheel drive. But in the end, the win goes to the Odyssey, by a hair—and that’s nothing to be embarrassed about."
    Sigh.. dumb GM. You know I drove an older Oldsmobile Minivan and out of all the minivans it not only had the most room it also was the most comfortable and drove the smoothest. It is just too bad that GM can't pull its head out of rump to get a van with a good crash test rating and some better reliability (although I did read an article recently that some of GM's problems are stemming from the DexCool especially in the 3.4L engines in the past).
    I did notice in the new GM van (pontiac) that it has the rail system just like the Dodge GC.
    mtdavis0mtdavis0 Member Posts: 10
    There does not seem to be many forums to discuss the Entourage. "Performance" or "Prices Paid" discussions like I have used before for other vehicles.
    Has the van come out? It is limited to certain areas of the country ? Is it too early or are folks & the industry just not too excited about it?
    Thank You
    mrmcgoomrmcgoo Member Posts: 2
    I'm also interested in the Hyundai Entourage, but I suspect people are just discovering it. I was very close to buying one this week, but I decided to wait a month or two to see if rebates or incentives get better. Right now it seems my local dealers in NJ are not really offering anything special on pricing.
    I would definitely wait a few more months. Also, have you checked out the 06 Kia Sedona? It is essentially the same minivan as the Entourage and you get them cheaper.
    535353535353 Member Posts: 10
    I've got an '05 Uplander and would recommend it. I'm not going to argue it's in the same class as the Honda or Toyota, but it's a solid car & in my opinion a very good value (i.e., deeply discounted).
    Addressing some previous negative posts -
    (1) Why would anyone consider the Uplander w/ the other options that are out there? The simple answer, unfortunately for GM, is price (not MSRP necessarily, but price after discounts, negotiation, etc).
    (2) "It's ugly." Granted, it's not as "beautiful" as your typical minivan, but I like the "SUV-like" front end and larger wheels. Also, the interior is nicely done (features the "next" generation GM interiors... similar to the new Tahoe, Yukon, etc... much nicer than what we've seen from GM in a long time).
    (3) Sc00bs mentioned poor crash test results and dexcool / 3.4L problems... I think he's out in left field here (maybe thinking about an older Venture?). The Uplander has excellent crash test results and a 3.5L (or 3.9L) engine that, while not state of the art, is very proven & reliable.
    Till recently, the Entourage discussion was in the Future Vehicles Forum and it's pretty active. It's been moved here:
    Hyundai Entourage (2007+)
    (1) Why would anyone consider the Uplander w/ the other options that are out there? The simple answer, unfortunately for GM, is price (not MSRP necessarily, but price after discounts, negotiation, etc). "
    You can get a DCX van with stow and go for just as much of a discount
    You can get a DCX van with stow and go for just as much of a discount (as the Uplander)
    That's a good point. I guess I was primarily thinking about the Honda and Toyota (in terms of being more expensive @ point of sale). The DCX, as well as the Ford, Kia, etc can all probably be had for close to what you'll pay for the GM van.
    If the S&G is a critical feature for you, the DCX is the clear choice. For me, it wasn't... I liked the seats in the Uplander a little better & simply folding them over or pulling them out (albeit they are pretty heavy) seemed to provide more than sufficient cargo carrying options.
    In general, when looking at everything, I simply preferred the Uplander over the other options in that price range (DCX, Ford, Kia, Mazda, etc) for various reasons. All had their pros & cons... but I liked the GM drivetrain & interior a little better, so that's what I went with.
    The discounts / deals on the GM vans don't seem to be that great right now, but given their slow sales I'd expect that to change pretty soon to clear out the 06's.
    badgerfanbadgerfan Member Posts: 1,565
    I've been doing a bit of preliminary poking around and have decided that a short wheel base Caravan SXT with 3.3L V-6 fits our needs quite nicely. I was pleasantly surprised that DC has an option with a split removable rear bench seat in which the two halves are quite light weight. Thus the negatives associated with not having Stow and Go available on the short wheel base models is somewhat overcome by having the seats so light weight compared to our 1996 Caravan.
    Biggest dissapointment I have is that ABS is optional on the short wheel base versions, and I could find only one such short wheel base minivan equipped with ABS in an internet inventory search of all the 10-15 Dodge or Chrysler dealers in my area. And that one is gray, which is not a preferred color for us. Bummer! DC should make ABS standard on at least the upper end short wheel base models (IE Caravan SXT). Don't understand why the dealers are not ordering more of them with ABS. ABS is standard on all versions of the long wheel base models, however.
    The deals are just amazingly good. I can get a comparably equipped short wheel base Caravan similar to our 1996 Caravan for about $4K less than we paid for our 1996 as a leftover new minivan in March 1997! About $6k off MSRP
    We might just hold off a few months, or even up to a year and keep checking the available stock and work a deal when I see what we want at one of the local dealers. Otherwise, could go with the long wheel base version, but it will be my wife's call as I am not sure whe wants to drive a longer minivan than she has now.
    staceypmillerstaceypmiller Member Posts: 4
    I am searching for an AWD minivan and can't seem to find much. Toyota makes one, but who else? I currently have an SUV and really miss the convience of my van - don't want to go the SUV route again. However, I REALLY need AWD or I will never be able to get up my driveway in the winter. Any help???
