Visitor Agreement.
Very counter intuitive of me... I normally don't believe in the use of additives.
I did order some for my 6 spd manual though where I truly need it (if it works) when cold shifting is a problem.
I just am finalizing my opinion on the use of another product that so far has not performed as marketed and now the company tells me I did not follow directions, which by the way, the instructions they now state I should have followed are not on the web site or bottle or box it shipped with. Just CYA as always.
Will see on the Lubeguard
I'm curious to hear others thoughts though.
The 1MZ-FE (since 1994)and 1AZ-FE use aluminum blocks.
All the "VZ" & "S" series engines had iron blocks.
I am getting ready to order a high end Alpine CD receiver and XM satellite radio tuner. I will let everyone know how the new XM satellite radio system works and sounds.
Currently only at 14,500 miles, just another 985,500 miles to go.
This is something to think about as the car ages. If you're dead serious about driving your car forever, I'd keep up on the oil and coolant changes, and don't try to stretch the intervals. Over time, you're going to build up sludge (I hate using that word nowadays, since it's such a touchy subject) and other debris that, if you extend your intervals too far, is only going to build up quicker. Maybe pushing your change intervals won't make a noticeable difference in the first 100,000 miles or so, but when you're talking about going 10 times that, I'm sure it's going to matter.
I use Amsoil 5w30 engine oil as it stands right now. I change the oil between 2,500 and 3,000 miles when most of my driving is city. At the maximum, I change my oil between 6,000 and 7,000 miles if all the driving is highway.
i lived up north and know i live in central florida [away from the coasts]
what a differance my accord has 250,000
i checked the valves last week and found zero wear needed no adjustment
oil flow at start up is instant
operating temp happen about two blocks down the road
98% highway miles
original a/c alt c/v joint[couple of boots]
changed the water pump with every belt change[4th belt] that would be the only major part change
I feel 250,000 for most of the north is like me doing a mil.
I just gave up my 1985 Camry, reasonable maintenance, but not perfect. Very few repairs... however, at 198,000, the transmission was about to go and so was a wheel bearing. And I'm not sure that the engine would have lasted too much longer. I'd hoped to make 200,000, but that car had a hard life, never garaged, rear-ended 3 times, (no damage), front-ended once (3/4" tear in bumper was all), major crash once (rear passenger door and quarter panel replaced), stolen once, broken into about 3 times.
Carried all kinds of loads, she was a liftback.
So, no where near your goal, but I can't complain a bit, great car, did everything I asked, never stranded me and pleasant to drive for 17 years.
Starting over with a Subaru Outback as of this past week. Should be interesting to see how it compares to the Camry.
a killer
keep an eye on the fans, sensor, an everything related to the cooling system
but that's going to be a problem further down the road
scheduale maintance is probably the only thing you'll be dealing with for a while
Recently sold my '83 toyota celica with 250K miles - got kind of bored with it, and bought a new celica. That car was my daily driver the day I sold it, and I clocked more than 20K miles per year in it, and I think if the next owner takes care of it, it could very easily go 1 million miles. Alas, I like the shiny new ones, or I could have kept it and tested it. That would only have meant the rest of my life driving a car older than current college graduates! but I never had to repair it, and just performed the maintenance per the schedule.
Of course, my old celica had an iron block...! :-)
I'm only at 16,000 miles on my Camry - 984,000 miles to go.
As far as other cars that could go the distance... you didn't say new or used, so: strange as this may sound, I would recommend the Ford Tempo, with either the 2.3L I-4 or the 3.0L V6. Both engines are excellent high-mileage pushrod powerplants - the 2.3L is known for running over 250k without problems - and the rest of the car isn't bad either, as long as it is cared for as well as your Camry. They are simple engines, easy to work on, so you can easily do your own maintenance. The only major weak spot on a Tempo is the ignition system, which is easily upgradeable. And the manual transmission is a must; if it's good enough for the Taurus SHO, it's good enough for me. :-)
Then again, that's the thing about Tempos; no one cares for them like they would a Benz or even a Camry. (For anyone who happens to own one and is interested in keeping it in tip-top shape, I found that TempoTopaz.com is an invaluable resource.)
Leo
http://www.preluber.com/index.htm
I don't know of many cars with 1,000,000 miles. There's the Rolls Royce Silver Ghost, the Volvo mentioned way back, and a Mercedes diesel that they keep at MB USA headquarters in North Jersey.
My next door neighbor had 247,000 on her '87 Maxima when the odometer broke a few years ago. She never got it fixed, but she figures she's over 300k now.
My old barber in Hackensack, NJ (at the Packard's building, if it's still there) has a '67 (I think) Dodge Dart that had over 750,000 on it last time I talked to him, which was maybe seven years ago now. He had put in one new transmission over the years, but no major repairs apart from that.
Dave
At 61,000 and still running like a dream!!!
Best price go here http://www.toyotapart.com/
The Toyota OEM pads are softer than aftermaket. This means less grinding and less noise, but shorter life.
Going with the lifetime pads can be risky because they tend to be hard and abrasive, that they squeal and wear down your rotors quicker.
You'll have to decide which trade-off you like better.
Don't forget, flush your brake fluid every 2 years.
Thinking along those lines, would you consider swapping your Camry for a Chevrolet S-10 pickup truck with a 2.2 liter OHV four cylinder and a five speed manual? Would this be a better tool in your quest for a million?
Original set of pads on front went 60,000 miles and Toyota ORM replacements still on front at 145,000, so on the second set. rear discs replaced at 100,000, second set still on.
Many aftermarket will squeal, etc. and just not worth the lower price. And from the wholesalers on the internet you can get OEM pads at AutoZone prices.
(yeah, were going to butt heads in this subject of OEM pads)
The best pads I used on my Camry was the TRD HP pads, carbon-metallic pads (made by Performance Friction), which lasted (before I traded the car in) over 60,000 miles with a nice chunk of life left.
I just added a 2003 Matrix to the garage to go along with the Camry. My fiancee will primarily drive the Matrix while I will continue to drive the Camry. So far the Camry is only at 16,500 flawless miles - long way to go to hit my goal. As aforementioned though, my job will be affording me much road travel here shortly.
In response to corsicachevy... I did consider purchasing a small pickup at one time in regards to my goal to take a vehicle 1,000,000 miles. I decided against it though as a sedan just seemed more comfortable for the long haul. When I considered the pickup, I was looking at the Tacoma as opposed to the Chevy. The statistics I had read indicated it was more reliable. Have you had good luck with an S-10? I do think they are nice looking trucks
The only reason I suggested the S-10 is because it is simple and durable, not because it would be a comfortable daily driver. The Tacoma is a much nicer truck, but the S-10 may be better suited for the loooooong haul.
I have enjoyed this thread - I have a few questions for the board:
I have a 99 Camry XLE - besides new tires, and oil changes every 3K - I have done ZERO maint on this vehivle. I now have 55K. Should I:
1. Get the anti freeze changed? I just checked it and it looks very clean.
2. Change the transmission fluid.
3. Any other essential items. Belts?
4. I posted on another board - I have one problem. The brake light comes on first thing when I use the car in the morning. Then it goes off but sometimes comes on when I go around a corner. I checked the brake fluid - its below the max line but above the min level. The brakes still work perfect. I hate to bring it to the dealer and get charged the usual BIG bucks!
Thanks for any help to these questions. I have enjoyed reading your postings.
Rick
Saw a story the other day about that Accord in the midwest someplace that went more than 650K miles, and that is just since the first odo broke at 300K+. If a humble Accord can do it, then CERTAINLY your camry can!
Many thanks for the info on the brake fluid - I tried it and sure enough - the light has gone out! I added about a 1/3 of a cup - and the light has gone out. I bought DOT 3....
My question is - based on ARMTDM's post - is this a sign that I need new brake pads? I have not noticed any problem with stopping distances and such.
I also just went out and replaced the air filter - WOW!!! $16.50 at napa. I remember the days when you could get a LEE air filter for 3 bucks. I also found a stack of leaves and other debris under the air filter.
Thanks for the help on the brakes.
Rick
Used to be most cars were carbureted, and in fact, if you still have a carburetor in your car today, you can STILL get air filters for $4-5! But most of the filters for fuel injected cars cost a wee bit more...
my father has a 1994 toyota camry xle v6. he's looking for a front down pipe (it looks like a "Y" and it connects to the exhaust manifold.) does anybody know where he may be able to find this part? any ideas on where to look online?
thanks. any help would be greatly appreciated.
I would like to make my 2000 LE last as long as possible. While critics maintain that this car is plain in design, I feel its design is perfect. I intend on doing some work on the car and once finished it will be quite an investment. Therefore I would like to gather as much info on how to maintain this car's drivetrain for as long as possible. If anyone would like to share data, please respond. Thanks
For those who might be curious as to what I plan to do to the Camry.
-Fine tune lighting on dash and headlights.
-Larger wheels and lower profile tires
-TRD body kit package (w/ struts and springs)
-Replace some of the cheaper interior bits
-Get more HP and performance out of the 4-banger (need advice for this one, usually the v6 is the candidate for upgrades, but I feel if VW, Nissan, and the 2002 Camry can, then this one can also)
Once completed I feel this car will make a statement. See cardomain.com for photos of other 1997-2001 that have been worked on. Thanks
Furthermore, buying a statement car would not be cheaper, unless I shopped used, at which point it becomes a gamble as more and more ex-rentals and abused leases end up in that market. I can get TRD body kits, which would help by adding beefier stabilizer bars, sportier strut/springs, alloys, and effects for $4000. Definately cheaper than buying a new or used car (unless Hooptie is the statement I'm trying to make).
As for your statement regarding 4 bangers ("a 4 banger will always be a 4 banger"). 4 bangers range from 115 hp (see Civic) to close to 200 hp (see altima, jetta, passat, Mazda 6, Miata, WRX, etc.). While I am not looking to turn this Camry into a hotrod, I would like to know if there are modifications that I can do that would make for a more efficient, slightly more powerful, and durable engine.
Thanks for your reply though.
I would stick to maintenance to assure longevity.
Using the severe schedule with quality fluids and you will be fine.
A Jacobs Electronics ignition system, http://www.jacobselectronics.com will increase the low end pickup and overall powerband of the motor (and best of all....NO CUTTING OF WIRES for install), and maintain fuel efficiently.
Headlights: don't get those fake HID bulbs. From my personal experience, they look cool....but visibility turns horrendous when the weather gets wet. Get the some aftermarket fog lights, like the Toyota projector fogs. If you still want the "look" get Sylvania Silverstars.
Dash lighting: the best is replacing the stock ones with red 194 bulbs. They look cool, and also easier on the eyes and easier to read at night.
Wheels, stick the TRD package, while you can't really brag too much about the 16" rims, they are however high quality BBS RX rims, one of the best out there.
MAINTENANCE SCHEDULE
Every 3,750 Miles:
Oil and Oil Filter Change
Every 30,000 Miles:
Radiator Coolant Flush/Change
Air Filter Change
BG MOA Oil Additive
BG 44K Fuel Induction Additive
Every 60,000 Miles:
Transmission Fluid Flush/Change
Spark Plugs Change/Tune-Up
Brake Fluid Flush/Change
Power Steering Fluid Flush/Change
Battery Check/Change
Every 90,000 Miles:
Timing Belt Change
Every 1 Year:
Exterior Wax/Detail
Interior Leather/Wood Cleaning and Conditioning/Detail and Carpet Shampoo
Wiper Blade Inserts Change
BG 44K is a blessing in a can. Nothing is better than BG 44K.
I also use a shop that has the special BG machines for flushing/sucking the radiator/tranny etc. before fluid refill.
Opinions?
