Turbochargers & Superchargers: Theory and Application
Is there a clear "better" way of boosting your car (in the pressure sense of the term)? Are the losses of "turbo-lag" sufficent enough to justify going supercharger over turbocharger? Does it depend entirely on the car?
Lastly, if you think superchargers are better than turbochargers, why do so many sports cars (i.e., the 911 Turbo) use turbos instead of superchargers?
Thanks for your opinions!
I believe there's no superior way. Both do its job, differently, with different characteristics of each.
- supercharges are more expensive but you get less lag time. s/c is supposed to be much stronger too.
- turbo's are cheaper but takes a bit longer to get you going. older turbo's are more expensive to fix and break down easily.
Centrifugal SC shows more of a peakier powerband. THey also require a geartrain to spin it faster to be effective.
Turbos are exhuast driven centrifugal compressors. With proper design, lag can be minimized.
Remember that neither system is a free lunch. You'll always get a more fuel efficient system with a naturally aspirated version. A SC that you can freewheel until needed is pretty much inert until you use it but while in use, much of the engine's power goes to the compressor instead of the wheels. You get more air through the system which yields more power in the end but the hp/gallon always goes down. The TC tries to be a free lunch by using the exhaust gases but it ends up being an exhaust restriction which hurts its efficiency. You get more power out of it but only at the expense of more fuel again.
The VW 1.8T & 2.0L on the otherhand, get identical gas mileage (24/30 city/highway).
The 1.8T gets the same mileage as the bigger 2.0L when you would expect it to get slightly better mileage in the same car if it were NA. They are not just turbo and non-turbo versions of each other either (1.8T is 5 valve/cyl for a start). The 1.8T isn't nearly as high-pressured as the Subaru 2.0 so it isn't as obvious.
The turbo charger looks like a perpetual motion machine (using the engine to speed up the engine) until you see that it uses more fuel in the process.
No comparison. Sure the SC is smooth but oh so boring. There is nothing like those twin turbos kicking in and putting you back in your seat. The SC just doesn't seem able to do that, too tame and constant
Turbos subject to cking if not idled down properly so it is more of a hassle to drive then a SC, especially if a daily driver, shopping multiple stopts etc. But, most peopel do not idle down for a minute either
For example the VW 1.8T has a very flat torque band, which (let's assume a 2001 1.8T in the Golf/GTI/Jetta/Beetle application) its torque peaks at 155 lb-ft at 1900 rpm. It stays in the near 155 lb-ft vicinity all the way to about 5000 rpms.
Let's take another small car example: the WRX. Below 3000 rpm, the turbo is not generating enough pressure for that "kick". After 3000 rpm, you'll feel a huge kick in performance. This is a case of a more serious turbo lag.
Twin turbo setups can have the same characteristics of either mentioned above.
Twin sequential, can have characteristics of both mentioned earlier.
For coking of the turbos, for most people, the idle down is not necessary. For customers of Volvo, VW, Saab, etc, where the vast majority will use it as regular transportation, the idle won't be critical (as long the oil is regularly changed).
If you're racing constantly from stoplight to stoplight, or keep the engine constantly revved closer to redline, then the issue of coking is more problematic (and oil quality), and hence you'll need to idle down for a few minutes, if not try to install a turbo timer.
So the real questions should be, which is better, turbo or supercharging for the following driving styles: light driving (point A to point
Right now we're trying to argue all aspects, but ultimately we won't get anywhere.
Next you can have 2 little turbo's or one big one...2 little ones always offer less lag for a set boost because of less rotational inertia then the 1 big turbine...so they spin up much quicker...also engine rpm dosent have to be as high to get them moving...As for fule economy they can be made the same as a super or even better...
Intake air is hotter on a turbo because the exaust gasses heat the exaust section of the turbine and it is pulled through the metel rod (metel conducts) which connects the exaust and intake turbines. This is why new ones may be made of ceramic to reduce exaust/intake heat exchange...
If this is true, wouldn't a SC be a better choice for increasing overall performance without sacrificing durability?
Centrifugal S/C has power characteristics similar to a turbo. In fact they are the same, except being belt driven.
Just based upon bad experience with Volvos and IMHO there is more scheduled maintanance on these cars then Amercvian or Japanese.
Overpriced purchase price, overpriced maintenance and overpriced parts.
gives better low end response of the sc and the better high end of a turbo without the turbo lag.
saw an mr2 with that setup.. it was damn fast
This was an early ('87) 9000 with no intercooler.
I used mobil one during most of that period and always warmed and cooled the car for a few minutes.
On the downside, I beat on the car and ran higher than factory boost.
So...I can't complain
Pros:
Consistently good torque at all rev range
No lag
Relatively simple
Cons:
Sucks usable engine power causing poor fuel economy.
Turbo charger:
Pros:
Highest power capability per unit displacement
higher torque curve over usable engine speed
improved fuel consumption compared to non-turbo of same power
better emission
Cons:
Needs enpensive heat resistant ceramic material
needs intercooler for optimum performance
low torque at idle and near-idle speed
turbo lag
Guys are getting astounding amounts of hp out of turbos, but lots of fiddling with computer/fuel curves, etc... - $$$
SC - simpler, but much less power.
Again, this is with reference to the Miata. Lots of pertinent info on the above mentioned site. Check it out. I would love to turbo my Miata, but it's still lots of fun stock - Zoom Zoom !
THe Audi TT, has them on both sides.
The Turbo Diesels have the intercooler in the same location as the GTI, Jetta, & New Beetle
Is there any difference in the designs that would require higher octane in a SC and not a turbo, or vice versa?
(I'm not saying I'm going to be doing that or anything... of course not...)
carlisimo - of course, there is the standard strain of added pressure (see above) on an engine when forcing induction. In that respect, both are the same. It is my understanding, on the other hand, that a turbo results in much higher operating temperatures in and around the engine, so I would think that could negatively affect an engine that wasn't designed for it.
Last Summer I was taking a trip in New Jersey. I was also in the market for a new car. I was vying for a new Solara coupe, or maybe a Lexus ES.
Well, the dealership was toyota-lexus, so the salesman had to go across the parking lot of the toyotas to get to the lexus-s. Anyway, I stopped him in the middle and asked him what that pretty black car was. (Yes, I like the way the '04 'rollas look better than the '05s. I think they look like lexus's.)
"That's a Toyota Corolla. It is a little smaller than what I expect you would want."
Then he tried to get me to buy the '05 XRS. >.< I got a fully loaded LE Corolla, and I've installed the navi. system, tinted the windows. My dilemna now is the engine. I'll tell you, I have absolutely NO experience with turbo's or SCs or whatever. I just want to turn my Corolla into a little luxury cruiser, and the engine is the last step. Any help you could give would be great Thanks By the way.... what's the plural form of lexus?
does the same apply to turbochargers ? don't know...but I heard that the lower octane do make the turbo cars turn out less horsepower....
I hope that didnt sound to mean, its just that i am frustrated with not being able to get a straight answer and find the info i want.
I appreciate any advice
The REAL question though when we are talking about cars like Elantra, Lancer, Corolla, etc is the question of cost of modifying vs. cost to just upgrade to a faster car. In other words, maybe if you want a faster car you should just go buy a faster car. If you put a turbo on a 3-4 year old inexpensive car, you are never EVER going to sell it for the money you have in it. You may finding selling it AT ALL to be very difficult. So you are going to lose money on this type of modification on this type of car I think.
Supercharging is my preferred way to get more power since I like the driving characteristics of S/C vs. Turbo, at least in the "bolt-on" world. You can run a low boost, maybe 6 lbs with a S/C and get power right down low on the rev band. With a turbo, generally not much going on until 2500 rpm and then you get a big rush.
So I guess what I'm saying is that for that "class" of car, as you call it, I'd reallly hesitate to invest in a turbo or s/c---I think I'd upgrade first. You can buy a brand new or slightly used EVO and get a car that you couldn't really build up from a Civic or Lancer without great expense and effort.
I dont mean to get too far off the topic of this Forum, but would you guys or anyone else have any suggestions of how i could increase the power (of any of the cars i mentioned in my first forum entry) and for a relatively inexpensive cost.
Once again thanks guys for helping me get some of my thoughts straightend out.
Have you done much research with chips, either substitutes or re-flash? I am finding some pretty extravagant claims (40 RW HP from a chip?!!!) and also some testing that suggests some of these things work pretty well and some don't and some do but are kind of risky because they raise boost on turbos.
Any comments on that? I think the chips relate to this discussion as some do affecdt turbo output.
P.S. Toyota actually uses a bolt-on supercharger, not a turbo as I had erroneously mentioned.
