Volkswagen TDI Models
in Volkswagen
Does anyone have any advice on buying a Volkswagen Station Wagon diesel?
The Jetta TDI Wagon is made in Germany as is all of the Jetta Wagon versions, this seems to be important to some but I have seen no evidence that shows better assembly quality for the Germany vs. Mexico vs. Brazil debate.
The first TDI Jetta Wagons arrived in my area in November of 2001. They are sure scarce at the dealers, the rarest of all current VW's, Eurovans are even easier to obtain.
However, I LOVE my 1.8T Tiptronic sedan. It has 7200 miles since bought new (at 119 miles) on 11/3/01.
The GTI will cost a little more, handle better and of course be quicker, but the TDI folks sure rave about their cars.
1) Definitely use the fuel additive below freezing.
2) Keep the RPM's low (don't rev it up).
3) There is some kind of 'check' light for the glow plug that I have to make sure lights before starting.
4) The fuel filter has a water separator on it that needs to be serviced regularly.
5) Use Mobil 1 / equal synthetic in it.
6) Not too sure about chips, but I understand you can increase MPG / HP by having one installed, although the warranty may be affected. (anyone know specifics about this?).
That's all I can think about right now. Any comments appreciated. Motorweek gave the diesels a good recommendation. What's the best mileage on a TDI motor w/o a rebuild (anyone know)?
Can't wait for the car to arrive.
I have also had quite few defects that have needed to be repaired. 10 In total ranging from a lose door hinge, rear brake rotor, alarm system, power window failure as some of the examples.
I love the car, but I am disappointed in the overall build quality and the maintenance costs.
Has any body else had any of the same concerns and problems? PS I live in Canada, so that is why I have shown the miles vs kilometers and the Canadian dollar conversions
Other than the timing belt issue, the fact is that you would have had approximately the same cost of maintenance with a gas model.
What are the "hidden costs"?
There is just no excuse for the 10 defects you have experienced, I would be very disappointed if I had that experience also. I have a TDI 2001 and I have had to have one window regulator replaced and the glass in heated mirror replaced.
I remember seeing oil change pricing of $69.95 USD at my dealer. The first oil change is at 5k, then 10k and every 10k afterward (20k, 30k, 40k and so on).
I guess dealers use a 5w-40 Castrol Syntec that is VW approved for TDI use? Otherwise I understand there is a Shell Deisel oil at WalMart that also meets the requirements, does this sound right?
It seems like a great engine to me, and I'm looking forward to many happy miles with it. It joins my 1.8T Jetta in the garage (his & hers).
Mark
I highly recommend using diesel specific synthetic oil in the TDI. Recomended oils are: Mobil Delvac 1, 5w40 (full synthetic, a reformulated version of Mobil 1 which is intended for diesel engines)
Chevron Delo 400, 5w40 (full synthetic version)
Shell Rotella T (full synthetic version, not to be confused with Rotella SB synthetic blend or regular Rotella T non-synthetic)
Amsoil Series 3000, 5w30 (full synthetic, CH-4 rated)
Amsoil High Performance, 10w40 (full synthetic, CH-4 rated)
Amsoil semi-synthetic 15w40 (CH-4 rated and high quality, but almost as expensive as the full synthetic, and higher viscosity at low temperatures)
Redline, synthetic version (make sure you get the type meant for diesel engines, with the CG-4 or CH-4 rating).
Oil in diesel engines needs to be able to suspend the soot that diesel motor creates and I am not going to trust a non-diesel specific oil.
Thanks again
So the bottom line is that chipping your car will not affect reliability, will give you increased performance without decreasing mileage, is the most cost effective way to increase performance on the TDI, and does involve a very small amount of risk should you happen to have a blown engine, turbo, injection pump or etc and VW uses the chip as a scapegoat.
Thanks, again, I appreciate the info.
The Upsolute chip is very popular in the TDI so it has a history. Other than a small increase in soot and sizable increase in power, it requires no difference in maintenance, and there really are NO horror stories. Wait, there is one thing, if you have a manual transmission and you chip the car you will likely experience some clutch slippage. The increase in torque and HP does shorten the life of the clutch. A clutch upgrade is available http://www.dieselgeek.com/clutches_index.htm .
Some people do not experience clutch slippage, it really depends on how hard you drive your car.
I do not have my TDI chipped, but do have plans to do so some time in the future.
Thankfully, my Passat has a monster clutch (that can handle the v6) and I've never had any slippage.
There is a new box out from http://www.jannettyracing.com for TDI that is $450 (a little high$) that claims 30HP and 45lb-ft torque, it is new in the US so I don't have much to say about it, but it can be easily removed before going to dealer.
Thanks again.
Anyone else notice this - the VW manual seems to be geared toward the gas engine. It states 5w-40 / 5w-30 for oil. Is this the same for the TDI? In any event, this car will take synthetic oil.
Lastly, I'm will not decide on a chip until the warranty runs out (see prior 'chipping' discussion). VW is definitely looking for this on the TDI's and voiding warranties.
Synthetic "Diesel" oil is available in 5W40 multi-weight, namely Mobil Delvac1. The Shell Rotella synthetic I heard is excellant also.
Oils which are suitable for the full recommended oil change interval in all climates include, but aren't limited to:
Other sources are the dealer, www.vwparts.com, Amazon.com has some of them, local book stores can order them, and etc.. The Bentley is the best that you will find.
The new TDIs don't drive like the old Rabbit Diesels, they have power (which a Rabbit Diesel owner said after riding mine).
They're full of it if they say it's for diesel only.
The correct oil for the TDI is 5W-40 or 5W-30 full synthetic CH-4 or CG-4 rated oil. If you put anything less in your car you are not meeting VW requirements for the TDI engine.
Older TDI such as natescapes B4 originally used non synthetic oil, VW later issued a TSB calling for synthetic and it is required in all current models.
For a list of locations you can buy BD, go here - http://www.biodiesel.org/retailfuelingsites.htm
These kits are NOT for the TDI though, Only the Pre-1992 diesels.
I love my car...It has 260,000 miles on it.. still going strong. But I have had the pleasure of driving a TDI.. One word.. WOW!!!
More power... better mileage.. less smoke..less noise... Doesn't get any better.
Thanks for your help.
Also, any comments on the cold-weather option; is it needed?
I live on the seacoast in Mass; but travel to Maine regularly - so get cold weather there. Not so much this year; but usually -10 to -15F happens often.
Check out the site below for a list of places that carry it:
Love my TDI more than my 1.8T as a city car AND on the highway. When the 1.8T lease is up, I'm getting a 2nd TDI!
Go Diesel!
I am considering buying a new VW jetta TDI. We have been using homemade biodiesel for a year now, but only on cars from the 80s. It has been working great! I was wondering if anyone out there is running a NEW car on biodiesel. If so, what difficulties and advantages have you found? Does VW remove the warranty if they find out that someone has been using an alternative fuel in the car?
skilikeagirl
