All the other cars in this movie are from today. There is even a BMW motorcycle.
-juice
To those who have had the Element for a while, does it have staying power as a daily driver? Does it hold up in the 80 MPH highway game? Is it comfortable enough for the 3 hour weekend getaway? Can one leave behind the leather wood and turbos and find peace in the simple car life?? OK, that might be too far...looking for input from similar heads on the board ...thanks in advance.
It was an Element EX 4WD (w/rear sunroof), Satin Silver Metallic. First you see the front view, then the side. Ben Affleck climbs out the back door, as you said, then just closes it. The front door never even moves. Then it drives away.
I noticed lots of product placement in that movie (sunglasses, phone, lotto, even spring water), but this one was odd. Why would Honda pay to show a car used in a way customers can't use it?
Any how, flick gets a B+, maybe. I doubt I'll remember it in a week, but it was worth it for the entertainment value.
-juice
Someone may sue if they watch the movie, run out to buy an Element, then get home and realize the doors don't work as "advertised."
Oh well, the publicity can't be bad for the Element.
If you've watched In The Bedroom, great flick by the way, a Forester is featured in that film. It actually gets a lot of attention, they talk about it in a scene at a restaurant, comparing it to a Jeep (presumably Cherokee?). In the next scene they drive off in it, it's Acadia Green Metallic just like mine. :-)
-juice
If a turbo has excess efficiency, it'll just use its blow-off valve less than it would at sea level. So a turbo could make the same power even at altitude, while any normally aspirated engine will basically be wheezing.
I'm sure you could climb Tahoe fine, just don't plan on passing unless you have one of the two vehicles mentioned above.
-juice
I am now a little torn between the two cars. I realize that their uses are not the same but there are quite a few similarities.
Here is the problem. The scion is one price like saturn and is around 15k. The element you have to try and get them to bring the price down and anyway, its around 19-20.
Could someone please give me some good reasons why the element is worth another 4-5 thousand dollars.
Thanks, I appreciate any help. Would like to buy one of the two soon.
The deal killer for me on the Element was the hassle for passenger entry/exit and the uncomfortably low rear seats. On the other hand if you regularly haul a lot of stuff from Home Depot, or transport pets, the Element may be a better choice.
The Element is more substantial, has more cargo capacity, a bigger engine, and at the prices you're talking probably AWD.
What are your needs? xB looks quirky, but actually it's much more conventional. Element is what I'd call a special-purpose vehicle, question is does it meet your purposes?
-juice
-juice
If I get one I'd go with AWD and the 5 speed - I liked the way it was geared when I test drove one and it is nice having 4th gear to downshift to when it gets really steep.
Scion doesn't have AWD and it has less ground clearance. If I had a Scion I'd have to resort to chains and a shovel - that's not something I find fun at 4am...
IIHS tests the cheapest model avaible, in this case a DX. They will re-test another model if the manufacturer provides one, but Honda typically does not. The CR-V and Element may score better with the optional side air bags, but I guess we'll never know, because IIHS won't pay to re-test them, and neither will Honda.
-juice
AND, did I just read correctly (in an 2003 issue of Consumer Reports, which rated the Forester as the #1 small SUV) that the payload for the Element is only 675 pounds? Is this a mistake? I mean that's barely three full-sized guys--admittedly, perhaps a bit out of shape--but without gear!! Where do the obligatory black lab dogs go?
So Subaru doesn't have to provide a 2nd vehicle.
Ford did provide a 2nd vehicle, and the one with side air bags did far better (surprise).
-juice
I for one can't stand the sound of the Subaru flat 4 cylinder. So no Sube for me. Everyone has hot buttons.
Stated payload is low, but we calculated GVWR minus curb weight and it seems to be capable of handling more, FWIW.
-juice
The sound is very characteristic, I guess you love it or hate it. I like that it sounds unique, I can recognize one the way you can recognize a small block V8. They have character.
I don't think Element's powertrain stands out, its extroverted styling does instead.
-juice
Maybe it would sound better if Subaru put the boxer engine in the rear; then it might sound like one of those old VW squarebacks, with the sound always doppling away (unless you're in reverse, I guess).
Seriously though, the boxer noise does not bother me at all. In fact, find that most 4s have some sort of a distinctive whine--perhaps a good reason to add on a premium audio system.
Actually, I liked the Element overall more than I expected. The handling was crisp and the acceleration better than either the Forester X or the CRV (I tested the manual). I thought I'd hate the placement of the Element's stick shift, but in fact I ended up liking it a lot. Forester, like the CRV, has a more conventional placement.
Unfortunately, the visibility out of the Element I thought was poor, and the height of the door panels drove me nuts. I like hanging my elbow out the open window--not possible on an Element unless I want to dislocate my shoulder every time I drive. But, at the 20K mark, I suspect I'll have a specific gripe with any model.
-Mudge
I like the shifter where Honda put it. It didn't make a difference driving it and it sort of reminds me of the car my husband drove when I first met him (happy memories).
I did like the equipment on the Forester. Just didn't and/or need it enough to justify purchasing one. I didn't buy an Element either as I found the 4WD auto a wee bit sluggish for my driving style.
I had that height-of-the-door problem in an MR2 I test drove, of all cars. Same issue - too high to rest my elbow there. It also hurt visibility to some extent.
Civic Si's shifter looks funky, but I haven't tried it. Everyone that tries it likes it, though. Like the old Alfas.
Subaru does package in a lot of extras. That's good if you like that stuff.
I'll be in Detroit on Tuesday to check out the new Honda pickup. Anything else Honda will show there?
-juice
I expected it to make the 40K mark, but I'm surprised by the YTD totals.
In the next few years, the hype will die down, the competition will increase, and sales will start to falter. But I'm guessing they'll average out to the high 40s/year for the Element's complete run.
My dealer (I just got rid of a 2003 Civic) new I was interested in an Element and twice made me very excellent offers...if I would take a 2003 instead of a 2004.
-juice
Honda has been pushing the Element in several venues. They've had more Element concepts (like the Studio E) than any other vehicle. They also used it for the Bibendum green car challenge.
Of course, all that press may be bolstering sales as well.
Unfortunately, I may not be the best one to answer your questions since I commute one mile to work - by foot. The Element gets plenty of attention on weekends though, and the wife exercises it a lot during the week. If you do take the step down from the Pilot, you will certainly miss some of the creature comforts. We got rid of a MINI Cooper for our Element (a sad day, but necesasry with a new baby). I'll admit, I miss the heated leather seats, auto climate control, audio controls on the wheel, the handling, etc., etc. After a while, though, I seem to miss them less and less. The Element is really a great car for what it is - as you say jaunty and quirky. We love ours. Though it is admittedly a bit under-powered, it is also surprisingly quick and nimble. In the highway game, you can get by just fine, though acceleration won't be as good as you're used to.
Perhaps someone else can chime in on long commutes ...
I never replied since I'm not a similar head. I didn't come from Euro sedans but rather from economy cars.
"To those who have had the Element for a while, does it have staying power as a daily driver?"
I think it's great.
"Does it hold up in the 80 MPH highway game?"
I don't usually drive that fast, but my latest 2.5 hour trip at 70-75 was better than I expected. I really expected lots of wind noise in a box, but it was surprisingly quiet.
"Is it comfortable enough for the 3 hour weekend getaway?"
I say yes.
"Can one leave behind the leather wood and turbos and find peace in the simple car life??"
Only you know how obsessed you are with turbos and and leather wood.
The CRV could be a better buy for those who have older kids or who don't often travel with muddy large dogs. It does offer some nice options.
