Visitor Agreement.
Kerry
Hubbie :mad:
transmission shifting hard and in the same order.
The transmission problem only happened once.
Have you found out what the problem was?
If so, what was the remedy? Thanks.
thinking this is a sencor problem, just don't know were it is located. I have a 1998 venture van. HELP!!!!
thanks,annie14 :sick:
p.s. water pump appears to be working.
I bought a used one on 12/29/06 and according to reviews I read on the 2003 Venture LS, its suppose to have a standard Power sliding door on the passenger side,height adjustable drivers seat and an overhead storage bin. Mind does not and was wondering if the review was in error or if someone slapped an LS badge on a base model?
I have a question for you... Does your starter sometimes stick when you start the van? Does your heater work right? Mine won't get warm until the van is in motion. Does your radio work alright? Mine will get louder when I drive fast up on the highway. I think my van has a major electrical problem somewhere in the front end. I ram starting to regret buying this van. I purchased mine in August of 2006.
And yes, the heater could be better, I think it's a matter of being underpowered considering all the space it has to heat up.
Now you can put any of the middle seats in the rear, put just two seats on one side, one behind the other, so there is a long flat 7-foot stretch down the other side, or remove one of the seats from the middle and put just one seat in the rear on one side, etc. There is almost unlimited interchangability, as far as spacing of the seats, ONCE YOU REMOVE THOSE STUDS with a dremel tool cut-off tool for instance. Take notice that some combinations will preclude using the shoulder harness, but if you move a second-row seat to the same side in the rear, you are ok, and the middle seat has a regular seat-belt which can be used if kept on the side where the clip belongs.
REMOVING the studs does not mean the seats won't fit where they were originally, and have all the original functions, just that you can put any seat anywhere. By cutting off one side of the stud, close to the seat frame, the stud can be punched all the way out of the hole (hammer and nail-set) and you will never miss it again.
