Midgets are simple and fun, but VERY small. So be sure you can even fit in one.
I wouldn't recommend the 1975 on up models. They are ugly and slow and do not appreciate like the older ones do.
Another good thing about them is that you can buy any part quickly and inexpensively (relatively speaking). This includes body, trim, mechanical, etc.
Sure, it's the last of the breed, the last of a dying breed that, by 1979, wasn't worth saving as a car (but would end up being worth saving as a brand name).
According to CAR, MG Rover's new owners are considering exporting it to the US. If only...
Good luck!
Hal
As for another car of this vintage: There have been some kind and not so kind words about Alfa Romeos in these posts, but not much said about the 1960's/early 1970's GTVs. They seem semi-exotic, at least around here, but I've always thought they were particularly attractive and the asking prices for them do not seem astronomical. There's a beautiful one featured on the Panasport website, under the 14" road wheel section.
Your only real concerns are:
1. If you get the later cars with Spica injection, this should be set up by an expert and not touched, only maintained (the injection pump needs maintenance from time to time but it's pretty simple).
2. Electrical issues, usually resulting from corroded fuses or grungey wiring (bad grounds). Not a big deal, because the car is pretty simple and doesn't have a lot of gadgetry.
Parts are plentiful and not too expensive. Repairs are generally straight-forward, but valve adjustments are complicated (shim system) and a few of the components (distributor, water pump, alternator) and a tight fit and a bit annoying to access.
When looking one over for purchase, look for rust and rust repairs along front and rear windshield trim, and for oil leaks at the back of the cylinder head.
The 2-3 upshift and downshift will grind a bit, that is what they all do sooner or later.
And Alfa bottom ends are very strong, so the oil smoke is just a sign of abnormal engine wear due to neglect.
If the car were otherwise cherry (why do I doubt this), it might be worth the $2,500, as a rebuilt or used engine might be had reasonably.
In top shape, that car should be worth about $6,500, stunning shape $7,500.
Anyway, a real fun car to drive; don't remember the Hand Crank abililty. Non-pressurized cooling system, great chrome radiator cap, wood frame of course, not real comfortable on trips over an hour or so (and I was a lot younger then!)...lousy heater and radio, as always in old Brit sports cars...
But I sold it for more than I paid and wish I still had it.
Dumpy or not, the TD was a lot more masculine than that girlie TC with those prissy wheels that looked way too big for the wheelwell and body.
Of course, if you want to stick-up for those prissy girlie wheels, go ahead.
And if you're talkin' Ugleee, that would be the TF with those fenders. "Interesting?" Ahhh - no. Just ugly.
'Course, this is just my opinion, humble or not.
The market prices rather prove the point. A brilliant TC will bring $5,000-7,000 over the price of a TD, about a 30% premium, as will a TF 1500.
I think the reason the TD was so successful is that it was the first MG offered with left hand drive, so of course it sold well in America.
Otherwise, styling aside, the TC, TD and TF have a lot in common and in some ways the TD and TF are improvements mechanically.
But in terms of value, no contest, the TC is pulling away rapidly in the collector car market.
I personally like the TF and A best of all!
Enjoy!
Best thing you can do for a TC is weld extra bracing into the steering box area and install stronger rear axles and get some of those fancy brake drums that grip better.
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
The problem with the engine is the head gasket and subsequent warping of the cylinder head.
If a TR7 is fastidiously maintained, and if you don't buy one of the earlier cars with the crummy Austin Marina 4-speed transmission assembled by blind men at the Speke plant (look for the ACG prefix in the serial number and if you see it run away)---but if you care for the later cars they can be reliable.
The rule with TR7s is that you never, ever, let the temp gauge rise toward the red. No matter if you are in the left lane of an LA freeway going 80 mph, if you let the car overheat you have lost the engine and probably, due to cost, the entire car.
-One who owned a Triumph when they were among the best looking sportscars ('66 TR-4A).
I had big hopes for the TR-7. I was hoping for the beauty of the TR-6 with reliability. Instead it was just the opposite. Ugly as H*** and even more unreliable.
That's when I knew that English cars were doomed beyond saving in America. Of course, I knew that Alfa was doomed too, for different reasons.
The most desireable TRs to me are the TR3As and the ('68 only)TR-250/5s which had the motor & suspension of the 6 combined w the Michelotti body work of the 4s(TR6 bodywork was by Karmann).
What people failed to grasp about the Fiat X1/9 is that they were built to a price...a LOW price, and the quality of materials put into the car were pretty low. They were also tough nuts to work on.
But really FUN cars...not fast but even today for $2,500 you could not find a better bargain in a sports car.
What you need to own one is patience, the ability to glue back on all the parts falling off, a good support network and realistic expectations.
It's definitely a "hobby car" and you need to be a clever fellow to work on it.
I think that they're just such great cars that people keep on fixing them.
I don't honestly speak from personal experience however, so feel free to tell me the true story of the TR...but they sure weren't Chevy's when it came to reliabity.
As I remember the X1/9's reputation, they were supposed be be excellent handlers, but about 1/3 too small and 1/2 underpowered for American use.
We Alfa owners used to feel that it was easier to have work done on an Alfa than the X1/9.
TR6--they weren't too bad for reliability, and quite good by British standards. They had those pesky Stromberg vacuum depression carburetors, which gave more power than the SUs but weren't anywhere nearly as easy to service and adjust. Also they liked to tear out the rear axle anchoring bolts (or welds, I forget exactly) and that was a big job. I also recall that the distributors were not very long-lived, and of course, the usual electrical hassles, mostly caused by crummy connectors, corroding fuse boxes, etc. Nothing that some upgrading couldn't solve once and for all.
It's a car you can "make right" which is more than one can say for some 60s cars.
You can actually get some money for a TR8 these days.
The biggest failing of the TR-7 was that it was bor-ring. A sportscar can have no greater sin.
There was also the small matter of chronic overheating leading to chronic head gasket failure.
And replacement parts that were as bad as the defective parts they replaced.
And they were ugly, not endearing ugly but ersatz Ferrari ugly.
British sportscar unreliability with the British sportscar charm carefully removed.
"Over what?" asked Harry.
First, useless trivia. The Herald wasn't converted to swing axles, they were designed that way from the outset. Just think, a small sedan with 4 wheel independent suspension and disc barkes standard in the early '60's. The TR7 used the 5-speed gearbox and stronger rear axle of the TR8 from 79 on. All the TR7 convertibles were 5-speeds. Most of the convertibles were built in the Solihull factory and had far better build quality than the Speke built coupes. Far better quality is a relative term, as in dismal is far better than utterly attrocious. The 1957 TR3 was the first production sports car with standard front disc brakes. Yes Jag had discs on the D-type and the XK-SS but those weren't exactly production cars. The TR7 slant 4 was designed by and built by Triumph for Saab. I think they went in the 93s and the 99s. Saab started producing the engine themselves and changed it over the years. Saabs are FWD but the engine is longitudinal in front of the wheels. Hence the water pump being mounted on the side of the engine to keep it shorter. The slant 4 was used by Triumph in the 1850 saloon. They put two of them together to make a V8 for the Stag.
What other 4-cylinder sports car built in late 70's early '80s was "exciting". The rubber bumper MGB? The VW powered 914? Nothing was very exciting because the smog laws took away all the power. The TR8 only made like what, 135 HP from a 215 cu in engine? The "exciting" TR7 would have been the Sprint with the 4-valve head. Prototypes were built but it never went into production. The same engine was used successfully in British Formula 2 racing. lots of potential.
FYI, More TR7s were sold than any other TR model, over 112,000, and most of those were coupes! One of the reasons they have no value is that there are so many of them around. I can't tell you how many I've been offered, many for free!
How to make a TR7 reliable. Pull the head, not easy believe me, and have it serviced by someone who knows what they are doing. Replace the head bolts and studs with ARP parts. The head bolts and studs were too soft and they would stretch easily, result, blown head gasket. Keep the cooling system clean with good coolant and have the radiator serviced every 2 years or so and your cooling problems are gone. 90% of electrical problems are corroded connectors or bad grounds. The late 80 California TR7s and all the 81s had Bosch L-Jetronic fuel injection. No air pumps, EGR valves or smoggified Strombergs, wery reliable. The 5-speed is nice and strong. Upgrade the front brakes. There are several kits to do this, some of them pretty inexpensive.
OR
Toss the Triumph lump and put in a Toyota twin-cam, a Mazda rotary, a GM V6 or a Rover (BOP 215ci) aluminum V8.
Cheers
Thanks carphoto, for the informative and interesting post! All too true!
By the way, the Saab 99 was an equally lousy car because of that engine, and in fact Saab was plagued with head gasket issues well into the early 90s. Saabnet itself suggests a failure rate of about 8%, which is very high--about one in ten owners were doomed.
Of course, other factors are numbers produced and body types. The 4-doors survive at the lowest rate, the convertibles at the highest rate.
BTW, not to be kicking a marque while it's down, but is it my imagination or did Triumphs (all of them) seem to disintegrate from the inside out? I've looked at several, as well as an equal number of similar aged MGs, Fiats, etc. (car shopping with my sons) and the Triumphs always seemed to be the most ragged interiors, flaking wood, dashes erupting with yellow foam. Was their quality that much lower than the others?
Ah, fall weather and all my cars are running fine!
Hal
Not that anyone should expect more than $25 or so for a good driver example of these great old sports cars that for me personify the term "British Sports Car".
