Honda Odyssey: Problems & Solutions:(1995-2004 Models)
I first checked if any screws were loose, found all good, I then studied the mechanicals of the door operation, again I could not find fault.
Third I began to adjust the screw rubber grommets in the back, again nothing. Then I removed the three front rubber spacer/grommets from the door. Aha big difference rattles almost dissapeared. From this I found the door is able to twist and vibrate normal without being annoying, I noticed the primary latch is the one making all the ruckus, so I tried one more thing, I placed all the stationary rubber spacer/grommets back in the door then I added small cut pieces of 1/2 inch rubber weathersripping to the head of the spacer grommets, this forces the door to push out against the latch, making the latch fit tight, not giving any play.
This I believe to be the solutions: Honda must redesign the front rubber grommets/spacers to fit snuggly againt the body, make them adjustable, or redesgn the door latches to latch tight or have an inability to vibrate freely when closed.
Which brings me to another thing. I would never tow anything with this or any other mini-van. They are built on car platforms with the same transmission that the car had, though they now handle a 1,000 lb heavier vehicle. You are just asking to chew up your transmission. I have a hitch on ours, but only to put a bike rack on. Even that has me nervous.
I have examined the door seal, found one very slight indentation on the inner door seal, but at this time, don’t believe it by itself is responsible for the noise. Another area that looks suspicious is on the front part of the mirror housing is a horizontal area about ½ “height where no seal exist. Perhaps some wind is entering here so I placed a temporary weather seal there to block any wind but during a Saturday drive, it had no effect. The noise is still there when the door is opened or when the window is rolled down when driving.
I am now beginning to believe it may be a partially closed driver side’s vent. While it makes no difference when opening or closing this vent by its manually operated roll switch, this is the next suspect. I went by the local Honda dealer Saturday and spoke with the service representative and will bring it in sometime this week. I’m keeping my fingers crossed that this can be fixed quickly.
Has anyone ever heard of a similar noise and how it was resolved?
We've a 2005 EX RES/NAV and just realized you can't play the XM-radio and the CD changer at the same time (one in front with other in rear). This is documented in the manual but I'm hopeful there is some sort of workaround or 'hack'. Anyone know???
Thanks!!
He then examined our Odyssey for an hour, discovered that the driver side black vertical piece is loose at the bottom, “may” be missing an attaching clip, and “may” be the source for the noise. Also, placing wide masking tape over the entire vertical plastic trim eliminated the noise when he test drove the vehicle. In the end, he didn’t want to remove the strip until he has a full kit of new holding clips on hand if he has to replace one so he ordered one which may come in this Friday or next Wednesday. We’ll keep our fingers crossed that it isn’t something else.
While the source of the noise is still unknown, it has certainly deflated my confidence in the quality of the Honda Odyssey. Yes, it may be an isolated case but it has already cost me several hours of time and at least 2 trips to the dealer (20 miles round trip). This is my first new car ever and after spending a premium to get the Odyssey, I didn’t expect to be putting miles on it traveling to the dealer to fix something that, at this point, seems to be poor workmanship. I give an update after our second visit.
My question now is “Where is the famous Honda quality on this vehicle”.
the brakes. It does not happen every time, 80% or 90% time we can hear the
squeak noise. When happens, it is occurred the first few seconds while applying
on brakes. Sometimes we hear the noise while release (step off) the brakes too.
The van has been dealership twice for the same problem. We are told the brakes
are working fine; both front and rear pads have more than 60% left, other brake
parts work well too. They basically told us they do not know the problem.
Anybody on the forum had the similar problem? Should I try another
Honda dealership to fix the problem? Thank you very much for any information.
Apparently this is a serious engineering defect. In order to keep comfortable inside temperature, the air conditioner would have to work excessively at all time in order to cool down constant hot air in the vent pipe. It also explains why so many drivers of the new Odyssey are complaining that they got much lower fuel efficiency than the manufacture claims in the window stickers, namely 19 miles per gallon. It is likely that people reporting good fuel efficiency were driving in the cold season or with the AC turned off or without automatic climate control. More complaints are expected when the hot summer comes. Honda should issue a recall and fix the problem.
To check if you got the same problem; try drive the car for at least 45 minutes without AC, stop the car, and turn fan speed to high. If you got hot air (hotter than outside temperature), then you got a defect.
The goal for this posting is to invite all 2005 Odyssey owners to test drive the way I indicated and report the problem, so that Honda will issue a recall and fix the problem.
Air coming through your vents basically has to pass through an oven (your engine) to get there. No matter how well insulated the passage, after 45 minutes of driving the air in there is going to wick some of the heat from the surrounding ventilation passage. The only way to get truly outside temperature air is to open the windows.
This is not to disagree that there may be a defect, just to clarify that just because the air coming out of your vents may be a bit warmer than the outside air....doesn't mean that everyone has a faulty vehicle.
However, a cursory search or two online has revealed no other evidence of this "engineering fault". Do you have any links to share?
I agree that when car has been driven for 45 minutes, the air in the air duct can get a little warm, but I don't think it can hit 110. This is certainly a problem to me. Here is what I will look for:
1. check if someone didn't accidental turn on either REAR or FRONT heat. I don't know if you have an auto climate control system or not. If you do, operating it can be a little tricky.
2. you may have a faulty heat switch or air exchange unit. It let the hot air from the heat core into the passenger compartment although you never turn on the heat.
Of cause, this problem can be contributed by other faulty parts. Without inspecting it in person it is difficult to make any conclusion, but I think these are the right directions you need to head to.
I have a 05 Ody EXL-N+R , and I don't have this problem.
So I've called Honda Care and customer relations, who opened a case, with no guarantees of course. But I wondered if you have advice for getting work done on "routine maintenance" items like brakes. (You must have a super nice dealership to work with.)
Thanks in advance.
The hot air occurred when automatic climate control and AC are turned off, i.e., in fresh air mode.
Could a faulty heat switch or air exchange unit cause hot air even when NO heat is asked for? I know my dealer checked the air exchange unit, it works properly. What do you mean by "other parts"? Your comments may help my dealer.
There are a couple things you can do if you haven't done.
1. What happen if you use the recycle mode? Do you still get the hot air?
If you do, it means this problem has nothing to do with the air intake leakage.
2. Have you tried to adjust the temperature setting all the way down? (lower than the outside temperature) Normally if the temperature setting is higher than the cabin temperature, the auto climate control will automatically engage the heat switch without your knowledge. I remember you did say the fan was on. This means the auto climate control was not completely off.
3. You never mentioned about the air temperature from the rear vents. Was it normal?
I was forced to file a complaint, because my Honda dealer ignored my case and sent me home. They want me to live with it.
I tested my wife's EX-L last night in the driveway right after she got home. The van idled in the driveway for 15 minutes (after it was up to operating temp) while I did some minor yard work. Ambient air temp (according to the thermometer by the kitchen window) was a bit over 80.
No hot air from the vents. It looks as though this "major engineering defect" doesn't affect us. Thank goodness.
I brought my car to the dealer again today, and it happened another Odyssey came in for the same problem. His vent blew 100 degree of hot air, mine 110, while outside temperature was around 75. When the engine lid was opened, it was extremely hot. Dealer still need to figure out what is the cause or causes and the remedy. It appears that people are now beginning to notice this problem.
Dealer kept on persuading me just use the AC and live with it. But this is like a stupid guy turns on his heater to 110 degree in his room and in the same time turn on his air conditioner to cool it down to desirable temperature, while in fact he can achieve this by using the fan to draw cool air from outside.
We need more people to pressure Honda take this issue seriously.
The ONE time I actually need the NAV to get somewhere, it froze.
Arrow quit moving on the screen and no directions given.
I tried everything I could think of...turned off the car, started NAV again...
Anyone seen this?
1. The switch couldn't fully shut. It is located in the back of engine compartment. There is a steel wire attached to the switch on one end, connected to an electronic motor behind firewall. This motor gets the command from the auto climate control system to open/close the switch. Anyway, it should be very easy to exam.
2. A problem with the flap door that opens to expose the heater core to the passenger compartment. If it could not be fully closed, you would get the hot air. To trouble shoot, the dealer has to dis-assemble the dash board. It can be very time consuming. Maybe this is why they have done so.
Remember, any of these problems can be either a machanical or electrical problem. I don't think this dealer has the expert to figure out your problem. Can you try another dealer?
btw, this happens to my other cars too, the "fresh" air that comes through the vent are usually a little more warm and damp than the outside air.
It sounds this hot air problem affect different cars in different degrees. Some get very hot air (110 degree like mine), some get 100. Perhaps the temperature depends on how much hot air leaks through the switch or flap door, which both are supposed to close when not heat is selected.
Another thing I discover is that while the dealer was testing my Odyssey and another customer's side by side, my car's outside temperature read 75, while the other had 84. That means the thermostats are not precise. I am not sure this is related to the hot air problem.
Second, you told me that you had lower the temperature setting to the lowest. If so, it would be below 60F I believe. There is no reason for the heat to turn on at this temperature if everything is in perfect working order.
I still think this is a defect, not a design issue.
Cindythomas-has the dealer installed the clips? did that correct the whistling?
thanks for any info!
Now where is it. The service manual references it but I don't know exactly where it is.
I think I found it once. Maybe under the left panel by the hatch (where the acc outlet is.)
It is not out in the open, you have to find it and get it there (like under the hatch back).
good luck
The 2 switches that signal the motor to run work as prescribed (same as right side). The motor has about 1 ohm continuity (same as right side). The contacts are all clean. Fuse 13 was pulled and the doors cycled thru their operation.
The only thing that happens different now is that the slide motor stays on longer waiting for the closer motor to complete the latch.
The only thing left is the controller. OR is it?
any help out there?
