Honda Odyssey: Problems & Solutions:(1995-2004 Models)
19293959798126
  • thegreatozthegreatoz Member Posts: 39
    It is common knowledge that the speed for the best mpg is about 55 - 60 mph.
    That's common propaganda to get people to obey the 55 speed limit (which admittedly saves lives). It is not the most fuel-efficient speed for V-8's. 70 mph is the most fuel efficient speed for moderately aerodynamic vehicles with large engines which have been properly broken in.
    States with 65 as their speed limit have improved fuel efficiency for drivers of 6 and 8 cylinder cars. 4 cylinder cars should stay below 55.
    'Pay no attention to that man behind the curtain.' ;)
  • khoakhoa Member Posts: 64
    You get the best possible MPG driving at the lowest RPM and highest gear combination to get within the allowable speed limit. On the freeway, that translate to the overdrive gear (5th gear for the new Odys) and ease the throttle to get the lowest RPM without having the tranny switches back to 4th (haha, you might be cited for impeding traffic). This is what I learned from drivers ed many, many moons ago regarding how to conserve gas to get to the nearest gas station if I run out of gas.
    You want 30MPG, you better drive like my grandma behind ;) .
    The Odys do get better with age. My '99 @90k gets 24MPG loaded with a car-top carrier, 5 passengers, full of luggages, on 87 octane.
  • lastwraithlastwraith Member Posts: 350
    I'm gonna have to agree with the consensus that your mpg numbers are within the norm. I get 25-26 mpg on the highway at about 70mph with my Plym Voyager. Considering any minivan is essentially a giant brick, these are not bad numbers.
    I don't see how you can give an absolute speed based on engine type for maximum fuel efficiency considering how aerodynamics and gearing are totally different for each vehicle. I'm inclined to agree more with the person who said to keep your RPMs low in overdrive. If your engine is barely working to maintain a decent highway speed your efficiency is going to be near max. This is why I like Pontiac Bonnevilles and other larger GM cars with the 3.8L V6. You can get near 30mpg on the highway with those cars because they will cruise at 70 under 2000RPM. Engine size has very little to do with it.
  • hondaoddhondaodd Member Posts: 3
    My suspicion also but I've also seen times where oil dripping from that area was coming from higher up and following the path of least resistance! My problem is not being able to get under the beast at my house- however, it's up on a lift in the next couple hours so I guess we'll see. Hey- while we're playing around with it- what else should I be watching out for with that # of miles? (we're doing the timing belt/water pump too).
    As you can tell- I'm new to Honda's. I'm a converted (hopefully!) Volvo guy (on # 8 or 9 now- my last 7-series) that finally got sick of working on the dang things.! :sick:
  • marine2marine2 Member Posts: 1,155
    I have a 99 Ody with 79000 miles on it and have a Honda Care 7/100 extended warranty, I called Honda and was told that if I cancel it I would get a $330 refund.
    That is probably true. They are giving you a refund on the balance of your unused extended warranty. But you don't get a full refund just because you don't use your warranty. Honda would lose all kinds of money doing that.
    I've always been objective in these forums!
    My only point was/is, an isolated, oddball problem can become amplified in these forums to the point everyone fears the same thing will happen to them when it probably wouldn't in 200,000 miles of driving.
  • chris24alichris24ali Member Posts: 2
    Yesterday I drove for about 1/2 hour with the navigation functioning. After restarting the van I noticed that the Nav splash screen loaded but the ok button screen never shows up. Instead I hear 3 short beeps from the nav unit and an message saying that the navigation dvd door is open or the dvd is not loaded into the drive. I tried removing the dvd and reloading it into the drive, with no success. Has anyone seen this before? Is there a quick fix?
  • bj2bj2 Member Posts: 6
    I own a 00 Ody with 93K miles. Recently noted the check engine light on, went to the dealer and told it was code P0 420 otherwise known as "Catalytic Converter below threshold" Told the dealer would be happy to replace for $1,050.00.
    I can buy an OBD II compatible converter online for $150.00.
    Anyway anyone ever had a converter fail? There is a Honda TSB #03073 referencing this issue. Wonder if Honda has a design problem with the converter?
    It is not a drivability issue and do not live in an area with emission testing so.....but would like to replace it for a reasonable amount.
    Hope someone out there has some insightful insight.
    I wouldn't be so quick to just replace the converter, it could easily be something related like an O2 sensor. As for having a converter fail near 93K, are you asking just new model Ody owners? I have certainly had them fail at those mileages before on other cars, whether it be from a bad 02 sensor causing the converter to burn out, or the converter just basically coming apart from age and/or road salt eating away at it. A friend of mine had a plugged converter that had to be replaced and that was at only about 73K. But none of these vehicles were Odys obviously.
    Anyway, I would have the O2 sensors checked with an oscilloscope if possible to make sure they are behaving themselves. Then if all the related components are good, you can feel safer in dropping that $150 on a converter.
    good luck
    i'd have to agree - it's possible it's something else.
    this dealer/parts site has '00 convertors for $670 or so:
    http://www.hondaautomotiveparts.com/
    there are presumably some re-usable covers and bolts and gaskets although they seem to be relatively inexpensive. i imagine an independant shop would be willing to mount the stuff for a flat fee - if bj2 is not a DIYer.
    there are some other sites on the web with discounted parts. i don't know if a non OEM cat. is a safe bet or not.
    Nevermind, I found the problem, my club steering lock was on the floor
    and it must have went far enough under the driver's seat to open the
    navigation door. I didn't realize there was a door that had to be
    closed. Once I closed the door on the dvd drive the nav worked fine. :blush:
  • longhornmikelonghornmike Member Posts: 1
    I have a 1999 Odyssey EX and when I reach a speed of around 70 mph the steering wheel starts shaking like crazy. I had the front end aligned and had new tires installed and also a front brake job as the rotors were very scared but the problem still exists. The dealer told me that I also have a broken motor mount that needs to be replaced. Could the engine be shaking at high speeds due to the broken motor mount cause the steering wheel to shake? Has anyone experienced this same issue and if so what did you do the fix it?
  • needavan1needavan1 Member Posts: 2
    I purchased a used 04 ODY at 15000 miles. After putting about 2000 miles on it, it started stalling at stoplights and when driving at 5-10mph. Also, while driving at higher speeds at times it feels as if the engine is starving and the car has no power and eventually the car starts slowing down very rapidly. On pushing gas paddle multiple times, some times it picks up with a big jolt like abrupt gear shift.
    This problem mostly starts after the fuel tank reaches little less than half tank. The problem becomes more frequent with less fuel remaining in the tank.
    Took it to dealer twice. During the first visit, they could not reproduce the problem and returned the it. The second time, the car stalled while idling under mechanic's watch. Replaced the Air-thermo valve. The problem resurfaced the next day.
    Frustrated as it's been just over a month after buying this car and all these problems! Any ideas or has anyone experienced something similar?
    In general, does it idle poorly or stall when taking your foot off the gas completely?
    If so - I guess I would ask the dealership if they performed the idle learn procedure following an interruption of the supply from the battery. for example, the H&A sponsor at the top of the page includes the procedure as part of the CD changer install at step number 18 in the document:
    http://www.handa-accessories.com/odyssey/03odycd.pdf
    Perhaps you have a fuel pump problem or clogged fuel filter issue or contaminants in the gas tank (did someone put something in the tank?)
    I guess I would take it to a different dealership for diagnosis.
  • cuongcuong Member Posts: 45
    Hmmm. I got the same error code on my 98 Accord EX couple years ago around 80,000 miles. Two of my friends Honda got the same problem. We now got after market audio. Look like Honda's audio system need to replace before get to 100,000 miles?
  • stickguystickguy Member Posts: 53,870
    our temp display seems to be stuck on 77 (it is about 93 outside right now). ANyone know of a way to reset, or anything to check? I don't even know where the sensor/probe it to check it for damage.
    checked your engine and transmission oil?
    I had similar problem with my Accord while driving on freeway. Luckily, I got off the freeway. After I filled up the oil to normal level, the problem solved. Hope this is your case.
    Appreciate your input and lastwraith's.
    So sounds like this could be a primary catalytic converter failure.
    The dealer did do the initial diagnostic's, I did not confirm that they point-tested the front and rear oxygen sensors, certainly a much easier fix than the converter, but plan on asking details.
    From my research looks like all cat converters sold are OBD II compatible.
    Honestly, performance does not seem to be compromised at this time, so tempted to let it ride.
    Yes a DI Yer.
    Thanks to all for input .
  • fibber2fibber2 Member Posts: 3,786
    I believe that P0420 is a reading based on the rear O2 sensor. The front sensor sets the mixture that should result in proper balance to insure complete combustion, and the rear one confirms that it took place. It is just an indicator, and not an active part of the feedback system, so no, as you reported, it should not adversely afffect drivability. There is a diagnostic code for slow to respond or defective rear sensor, so it might really be a cat problem. Still, reading out the rear sensor directly might be wise before springing for a new cat.
    I would be tempted to go aftermarket with that much of a price delta. Curious, what did they charge to read the code and give you an estimate?
    Steve
  • ssolssol Member Posts: 2
    I purchased a 2005 Odyssey EX in February, and I am getting an average of 14 mpg, with mainly short trip driving. As soon as I let off the gas, the car slows significantly as if there is some resistance. My transmission shifts erratically, even downshifting when I am travelling 60 mph on a highway. Occasionally, there will be a sulfur smell (from the exhaust?) which can be smelled inside the van even when the AC is on and recirculating the air. Lately, the transmission hesitates when shifting between first and second gear (I would say "slips"). And when I punch the gas to accelerate quickly, it takes 3-5 seconds to kick into another gear, increasing my rpms by 2500-3000 in a sudden jump when it does shift to accelerate. Also, there is a metallic scraping sound on the right front side of the car when braking or turning to the right, but this is intermittent. When the scraping sound occurs, there is a shimmy while breaking and the car tends to veer to the right.
    I have taken the van in to be evaluated, but I was told (after the dealership had my car for 7 days), that there was no "code" coming up, and that if there were a problem, the engine light should have lit. I asked them to check the brakes for uneven or excessive wear, but there is no indication on the work order that this was done. I asked them about the possibility of the computer chip which records all the diagnostic codes being defective. How would they assure themselves that this wasn't the case? I received no answer to this.
    I was told on the phone before I brought my van in, that Honda's don't break in until between 3500-5000 miles, so I shouldn't worry about the gas mileage. When I took my van in at 3450 miles, I was told that it wouldn't be broken in until between 7500-10000 miles. When I asked if Honda drove each of its models 7500 miles before they were tested by the EPA, I was told that they weren't sure of how that worked.
    I took my van home, and continue to get lousy gas mileage. The problems I have described are becoming more frequent, so hopefully it will break down soon. That way the dealership shouldn't have any problem duplicating my complaints. If I'm being overly picky about gas mileage (and there isn't some underlying problem), then eventually my mpg should improve and they can tell me "I told you so." My money is on the eventual breakdown of the van.
    Are there any diagnosticians out there who can come up with possible scenarios based on the symptoms of my van's problem(s)? I fear that service departments of dealerships have become staffed by technicians who can only act (or think) if they are flashed some code on a diagnostic screen.
    I love everything else about this van, but the gas cost is eating my lunch!
    Break in period or not, sounds like your mileage is poor. Sulfur smell is generally due to a messed up O2 sensor(s) causing the car to run rich, which will also quickly destroy the catalytic converter. But this is not usually something that would happen on a new van. It doesn't hurt to have it checked though.
    Sulphur smell, hesitation, and/or bad mileage are classic symptoms of bad O2 sensor and/or bad or plugged catalytic converter. Not sure what would cause your tranny troubles but hopefully that helps some. I suppose a plugged cat could confuse the hell out of the tranny if the exhaust is backed up to the point the engine is rendered powerless. Certainly sounds like an emissions systems issue.
    good luck
  • cindy4cindy4 Member Posts: 19
    The "growth curve" associated with the application of a weather sealant between a windshield and a vehicle frame to prevent wind noise and on vehicles manufactured was identified 60+ years ago. Actually, curve is an incorrect term to use in this application as a simple “do, don’t do” procedure is more appropriate (“Do we apply sufficient sealant to the entire perimeter of the windshield…or do we not”)
    Based on the Honda technician’s statement and posts in this forum, Honda has known about this problem for some time but are either unwilling, or unable, to correct it back at the manufacturing plant.
    My confidence in the high quality, one of Honda’s mantras, of the Odyssey has been brought down to earth.
  • daedae Member Posts: 143
    If an average person drives 12000 miles a year. Then driving 65miles vs 55miles he would save 34 hours of his time (the difference is greater if the average speed is lower and you also going 10 miles over limit)
    For say 100million people driving or beeing driven, that would save 340 thousand people-years. That means that raising speed limit 10mph is equivalent to adding one third of a million of productive workers into economy for free! Or 11,000 times 35 year long lifes spent commuting.
    So, if driving 65 vs 55 saves less then 11,000 lives per year cut short (And I do not believe that one bit, as I did drive on roads with no speed limit, and they are doing just fine thank you) then it is not worth it. We waste more lifes sitting stuck in traffic.
    And this oil economy thing is also bogus. Just think how much more productive this country can be if we do not waste 340,000 people sitting on the road driving slowly.
    That's a nice thought but in metropolitan areas, where the population density is highest, there would be basically no benefit to raising the speed limit. No one gets to travel at anywhere near 55 here in NYC or the Long Island area so it's a moot point. In many of the southern states where there is less traffic the limits are 65 or 70mph anyway.
    I'm not sure what any of this has to do with an oil economy. People are not wasting time in their cars driving 55. They are wasting time poking along at 7.5mph during rush hour on overclogged freeways and local roads. You can raise the limits to infinity billion to the seventh power and still never affect the major traffic flows in any way. Except maybe to annoy them by reminding them that if there were no traffic they could go as fast as they wanted to.
    Partially because 20% of highway capacity and untold amount of road maintenance dollars are spend on the thoroughly misguided attempt to force us to carpool and to build insanely expensive carpool-to-carpool interchange lines etc.
    If every car could spend 20% of time less on the road (when the road is unclogged), and the highways were 20% wider, there would be almost 50% less cars per lane, and many roads would not become clogged at all. It does take very few extra cars to grind a road to a crawl.
    Socialism in action.
    I live in the San Francisco Bay area and commute to work at 80mph every day (just like almost every other car), and have not had a single traffic ticket or accident in 12 years. I calculated that I do save 20 hours a year vs driving at a speed limit.
    More then 2 full working days a year is wasted for each worker here who drives 65.
    Minimal productivity of my engineers is about a thousand dollars a day. So just my little group is loosing $40K a year in lost productivity for the speed limit.
  • odbuyerodbuyer Member Posts: 5
    Our week-old '05 does the same thing. Yesterday when the temp was over 90, it read 76 degrees. At one point it read 88 (which was probably correct) and this morning it was back to 75 (which may also have been correct). I'll have to keep an eye on it to see if it's consistent or not.
    I know the owners manual tells you where the temperature sensor is. I don't remember exactly what it said, but it's somewhere under one of the bumpers, I think.
    PO420 is listed as "Catalytic system Efficiency below Threshold. (Bank no. 1)"
    Like I stated earlier there is a TSB on this issue referencing PO420, so wonder what Honda is seeing on this problem.
    The dealer charged $63.91 for reading the code. Do not know if they checked each sensor.
    There is a big price differential and honestly if I replace will likely go after-market and DIY. I will have the sensors checked before I spring for the converter.
    It was reading different temps today. Over the weekend I will drive it, and see if it moves like it should.
    And, the sensor is behind the front bumper, in front of the radiator. I haven't gone to look for it though.
    I'm glad you get to do 80 to work, but here that is simply not an option. Since most people work a 9-5 shift, they are basically all on the limited road space at the same time. We have 3 lane highways here, maybe 4 in some spots. There is simply not enough road to handle the traffic. You can start out going 80, but people jump on from different exits and eventually you are slowed to a crawl. Some people commute for more than 90 miles each way from CT into NYC, there is simply no way raising the speed limit would matter here at all for commuters.
    I would think CA urban areas would not be much better off, but I guess certain parts are lucky even at rush hour.
  • macakavamacakava Member Posts: 775
    Since there is no minivan with a V8, the 70mph theory does not apply here, i.e. a no-brainer.
    If there is credibility in the under 55mph for 4cylinder cars and 70 mpg for V8, then it stands to reason by interpolation/extrapolation that for V6, it would be between 55 and 70, and 55 - 60 lies in that range.
    Actually there is more to it that. It depends on many factors such the engine discplacements within each class of 4, 6 or 8 cylinder engines; OHC vs OHV, etc
    Just using some logic from my engineering background..
    Sounds like a fuel delivery/starvation or fule contamination problem.
    Did they check fuel pump pressure?
    "This problem mostly starts after the fuel tank reaches little less than half tank. The problem becomes more frequent with less fuel remaining in the tank."
    Did this problem occur after a tank fill-up in case it is bad gas with water? The half tank point sounds like water or something in the tank. I would consider having the tank flushed/emptied and refilled with new gas... from a different gas station. Install a new gas filter in the process.
  • autowriteautowrite Member Posts: 226
    I am living in Guelph, Ontario, Canada
    I have had very few problems with the 2002 Odyssey. As of June 2005 I have 125,000 kms (76.300 miles). Replace, on warranty, rear seat fabric in 2002,due to flaw. Change on warranty, rollers on doors, in 2003; suggest they just oil them. Replaced windshield twice, on warranty, in 2002, due to top rubber moulding loose.
    The transmission recall added just the 2nd gear oiler. The front brake pads were replaced at 95,000 kms (59,600 miles) and read pads and rotors replaced at 115,000 kms (71,500 miles). I am currently on my 2nd set of Semmary tires and will mostly likely replace these at 140,000 kms (the 1st ones replaced at 72,000 but could have gone longer {worried about snow traction)). Replace at 94,800 kms, on warranty when engine light came on, 'by-pass solenoid and two-way valve; evap bypass control solenoid valve.Replace, not on warrenty RW/OD/PI/S2 B/P Sol. Replaced gas cap as engine light came on. I feel that these emission items go sometimes and you must replace them when they age. My 1992 Taurus had a lot more problems (I traded in the Taurus at 283,000 kms, for the Odyssey). I find the van rides great, but you must keep you tire pressures at 36 pst, cold. I check mine once a month before the day warms up. I have been down to New Brunswick, Virginia, Arkansas 3 times, Michigan 4 times and Montreal 12 times. Other then this I am driving the van in city/rual driving about 600 kms per week.
    Another thing I do maintenance By-The-Book at the Honda dealer; no skipping. :)
    I hear you. It is quite bad here in many spots - the trick for me is to avoid that. A lot of folks do get stuck.
    But still - it does not take a lot of cars to slow everybody down, and if some cars passed by faster in the morning, jam will start later (they are off the road by then) and end earlier.
    And money saved on carpool lanes can be used to build better intersections while opening up a lot of underused highway capacity.
    I think that is the main problem here, our roads were not built for the kind of traffic we have.....heck, many of them were built not even for cars at all. The old infrastructure is having a hard time keeping up, and for various reasons (corrupt govt, overstressed treasuries, slow work crews) roads are either not being expanded or are being worked on forever.
    Personally, I would be all for raising the speed limit. I generally ignore them on major highways and stay in the 70mph range anyway. It was refreshing to travel to places where that WAS actually the limit. It's just unfortunate that the traffic here would not be able to take much advantage.
  • jbejbe Member Posts: 1
    Anybody had a problem with the clear finish on the wheels flaking off. Have a 2000 Odyssey, 50k. Honda dealer said they have never seen it, must be powder coat flaking off. Looks like a clear lacquer coat, peels off like paint.
  • just4fun2just4fun2 Member Posts: 461
    If you think that most people can drive their Honda Ody at 80+ mph you are nuts. Things happen faster, the faster you drive. In a "perfect world" you might be able to drive at those speeds , but this isn't a perfect world.
    Dial that cell phone, put on your make-up or have a flat tire and see how well you "think" you can handle that Ody!
    Be kind and let people merge when they need to get over a lane will make traffic flow better. My 2 cents.
    That is exacty what people said when cars started to drive faster then 30mph.
    Nothing wrong will happen at 80+ mph in a modern vehicle if you keep your distance and your eyes open. Nothing. Every single car on my road to work every single day goes 75+. Watch total lack of chaos.
    There are plenty of highways in the world with no limitation. People survive just fine. No rise in accidents, no nothing.
    "Speed kills" is a blatant lie and misuse of statistics. For example, if they say that 80% of cars involved in a collision were exceeding speed limit, that really means that it is safer to drive fast - as 95% of the cars on the road are exceeding speed limit around here. So you get a lower percentage of them involved in an accident. The fact is - those statistics are unrelated.
    You are right on about good driving habits and common courtesy. That is the real issue.
  • sunclesuncle Member Posts: 1
    We bought odyssey in 2000. Had regular maintenance until now and no problems with sliding doors. But yesterday new problem pops up with sliding doors which are not opening with remote control (or) front panel switches.
    We are able to open doors manually by using force which the dealer says shouldn't be the case. Is it the case?
    Please pos/reply if you had any problems related with sliding doors not opening as designed.
    Sounds like a blown fuse(s) to me. Especially if BOTH doors do not operate under power. It is very unlikely that both door motors would go at the same time.
    Did you or the dealer checked the fuses?
    I know the feeling!
    It was a refreshing thing to switch from my previous "Fix Or Repair Daily" Windstar to a trouble free Ody which I have never taken back to the dealer for repairs or PM(since I do these myself).
    Continue to enjoy your Ody! It handles like a great handling sport car.
    Your logic is flawed! You are talking like this is a perfect world and people are all perfect. The fact is that people do make mistakes and the faster the car hits something in an accident the chances for surviving go down.
    I have driven a vehicle at speeds exceeding 120 mph, never had a speeding ticket or an accident while driving at those speeds, does not mean it is safer to drive at 120 mph than 55 mph?
    Sorry, not buying that.
  • azkid2azkid2 Member Posts: 47
    Laws of physics will determine the amount of energy in an accident. Kinetic energy equals one half times mass times velocity squared. Squaring the velocity means if you double your speed, the kinetic energy increases by a factor of 4. You can't fool mother nature.
  • ehickeyehickey Member Posts: 2
    I have a 2001 Honda Odyssey with 127,000 Km (70,000+mi) and both front struts are leaking.
    I have never had a vehicle up until now that has had one strut leaking let alone both at the same time.
    Anyone else experienced this?
  • aspesisteveaspesisteve Member Posts: 833
    my '02 warranty expires this month.
    anyone know if the warranty should cover the wireless headphones that come with the RES (dvd player)?
    the headphones are pretty cheap and don't hold the batteries very well.
  • naobunninaobunni Member Posts: 7
    ok driving around - the suddenly the "d" (Drive) indicator light begins to flash on and off - nothing in the manual - checked transmission fluid
    can anyone assist?
    :confuse:
  • odybuyerodybuyer Member Posts: 4
    If you have a 4 year- old like I do who loves to play with switches, you might want to check for the automatic override on these doors. My son switched it the other day, and I though something had gone wrong. Just an override.
  • dulnevdulnev Member Posts: 652
    ... to stop the insane discussion about speed???
  • imidazol97imidazol97 Member Posts: 27,731
    In every discussion at the top is a line that says "Your host is XXXX." When you click on that it gives the host's info page which includes the email address in case the host hasn't browsed through the discussion and caught the drift in topic.
    naobunni, I bet the manual does address this indicator. I don't have my ODY manual handy to reference but probably somewhere near the description of the shift lever position indicator diagram there is probably wording indicating when it flashes something could be wrong with the transmission, and to bring it to the attention of your honda authorized service center immediately.
  • freewill365freewill365 Member Posts: 3
    Hi folks,
    Just got an '05 Ody Touring (with 90 days free XM).
    I want to plug my iPod into the AUX port. But the dealer says I cannot use the AUX if XM is enabled.
    Anyone know if this is true or not? If it is, is there any way to have BOTH XM and my iPod working?
    Many thanks.
    freewill
